First Task: Detect and Record
In the quick start you confirmed AI detection works in the live preview. This tutorial turns that detection into something the device does on its own: when a target appears, reCamera Pro records it automatically — and you play the clip back from the Web UI.
The workflow:
- Prepare: pick a model and a target
- Set the recording format
- Configure the AI inference trigger
- Apply the rule and trigger a recording
- Find and play back the recording
1. Prepare: pick a model and a target
- Make sure AI inference is running: AI Inference → Inference Configuration → Inference Enable on, a detection model selected as the Running Model, status Running. If you have not done this yet, follow step 4 of the quick start.
- Decide what should trigger the recording. The simplest first task: record when a person walks into view. The available categories come from the running model's output (e.g. Person, Vehicle, Hardhat, Mask, Safety Vest, Machinery).
The detection parameters themselves (categories, confidence/IOU thresholds, inference frequency) are configured on the AI Inference configuration page — this tutorial only references them.
2. Set the recording format
Open Recording Settings in the left navigation bar. At the top of the page, select the recording file format:
| Parameter | Description |
| Recording Format | Format for saved files: MP4 (video), JPG (images), or RAW (original image data) |
For this tutorial, choose MP4. Note: when MP4 is selected, each recording has a fixed duration of 1 minute.
All recording options on this page — trigger methods, schedules, storage quotas — are documented in detail on the event recording configuration page.
3. Configure the AI inference trigger
In the trigger method list, choose AI Inference Trigger and click Configure:
| Configuration item | What to set for this tutorial |
| Inference Task | Select the running AI inference task |
| Confidence Range | Keep the default range for your first recording |
| Category Filter | Select Person (or the category you want to detect) |
| Trigger Area | Leave empty — with no region drawn, the whole frame triggers |
Optionally, use Schedule Management to limit when the rule is active (e.g. night hours only). For a first test, leave the schedule covering the current time.
4. Apply the rule and trigger a recording
- Click Apply next to AI Inference Trigger. The status at the top of the page shows the active trigger method, e.g. Current: AI Inference Trigger.
- Walk into the camera's view (or hold up your chosen target).
- The system detects the target and automatically starts recording. With MP4 format, the clip is 1 minute long.
5. Find and play back the recording
Still in Recording Settings:
- Open File Preview — recorded files are listed in directories by date.
- Open the file for today: the Web UI plays it inline, so you can review the event without downloading anything.
- Check Storage Management to see disk usage and where files are saved. You can set a storage quota and enable overwriting old files so the latest recordings are always kept.
Storage behavior in depth (quotas, full-disk policy, download): see Find recordings and storage.
Result
You now have a standalone AI recording rule: no computer involved, the device detects and records on its own. Typical next steps:
- Narrow the trigger to a zone (entrance, hazardous area) with Trigger Area.
- Switch or combine trigger sources — scheduled, GPIO, serial, HTTPS, loop, or sound events — on the event recording configuration page.
- Send detection results out to your own system via MQTT or HTTP/UART.
- Before mounting the device permanently, run the pre-deployment checklist.
