Camera, Audio, and Inference Development
This page covers the building blocks of a native reCamera Pro application: camera capture with GStreamer, audio capture and playback with ALSA, RKNN inference, and RTSP video output. All facts here are drawn from working on-device projects — most examples come from the Visual Wake and Offline Speech Recognition application.
For environment setup and deployment, see SDK and Minimal Application.
Reference Pipeline
A complete on-device AI application chains the stages below. This is the actual pipeline of the Visual Wake project:
GStreamer camera
-> SCRFD face detection (RKNN)
-> IoU tracking + PFLD 98-point landmarks (RKNN)
-> OpenCV solvePnP head-pose estimation
-> EMA smoothing, hysteresis, and continuous-look timer
-> visual-wake event
-> bilingual streaming Zipformer STT (RKNN)
The key point for your own application: camera frames flow through GStreamer, each frame (or a downscaled copy) is fed to one or more RKNN models, and application logic consumes the model outputs. Audio capture starts only when the application logic requests it — the app does not record continuously.
Camera Capture
- Camera device:
/dev/video13, read by GStreamer (v4l2src) - Default capture format:
1920x1080at up to 30 fps; actual processing rate depends on inference time - Firmware GStreamer elements used by working projects:
appsrc,videoconvert,jpegenc,rtpjpegpay
Capture frames in your application through a GStreamer pipeline, then perform the exact preprocessing your model requires.
Do not feed NV12 camera bytes directly to an RGB or BGR model. The pipeline or application must perform the NV12-to-RGB/BGR conversion and normalization required by the model; mismatched color order or normalization produces wrong colors and wrong inference results.
Audio Capture and Playback
Microphone Input
The firmware provides a dedicated PCM audio device for applications:
- Device name:
ai_asr— 16 kHz, S16_LE, four channels; channel 0 is typically selected - Using
ai_asravoids competing with the vendor process that ownshw:0,0
Record a test clip directly on the device to verify the audio input path:
arecord -D ai_asr -f S16_LE -r 16000 -c 4 -d 5 /tmp/test.wav
Speaker Output
The onboard speaker is driven through the standard Linux ALSA interface. Play a WAV file with:
aplay test.wav
aplay is an ALSA PCM player: it can only play PCM/WAV data and cannot decode MP3. Convert first if needed:
ffmpeg -i test.mp3 test.wav
Volume control and device listing (aplay -l, amixer) are described in Play Audio and Control Volume.
RKNN Inference
- Use the RKNN Runtime C API for native C/C++ applications;
rknn-toolkit-lite2is not used for this workflow - Toolkit and runtime version: RKNN-Toolkit2 2.3.2 / RKNN Runtime 2.3.2, target
rv1126b - Link against a board-compatible RKNN Runtime and use the runtime already installed on the device — your application should not replace it
- A successful model conversion does not guarantee correct inference: compare RKNN numerical output against the source ONNX model, and keep preprocessing explicit
Model conversion from ONNX (including FP16 and INT8 quantization with calibration images) is covered in Develop with AI Coding Agents and the model deployment section of this wiki.
RTSP Video Output
Applications can publish an annotated video stream over RTSP for remote monitoring. The Visual Wake project runs an RTSP server with these defaults:
| Item | Default |
| Port | 8554 |
| Mount path | /visual-wake |
| Output resolution | 960x540 |
| Declared frame rate | 15 fps (actual rate depends on inference throughput) |
Play the stream from a host computer using TCP transport:
ffplay -rtsp_transport tcp rtsp://192.168.42.1:8554/visual-wake
The stock firmware also provides its own RTSP stream for the WebUI-configured pipeline — see the RTSP documentation in the Build Your Own App section.
Monitoring and Debugging Aids
Working applications expose status through multiple channels; adopt whichever fits your project:
- Terminal events — print actionable events (for example
VISUAL_WAKE track=1,STT_RESULT ...) to stdout - Debug logging — startup, per-frame pose, audio level, RTSP, and inference-performance logs behind a
--debugflag - Web dashboard — an HTTP/WebSocket service (default port
8080, health endpoint/health) with no cloud dependency - Terminal dashboard — an interactive in-terminal view (minimum 80×18 characters)
Quick Troubleshooting
| Issue | Likely cause | Resolution |
| No camera frames | Wrong video device | Verify /dev/video13 exists and is not held by another process |
| Wrong colors or bad detections | NV12-to-RGB/BGR or normalization mismatch | Recheck the model contract; make preprocessing explicit |
| Audio capture fails | ai_asr unavailable or format differs | Run the arecord test command above on the device |
| RTSP cannot be played | Network, port, or GStreamer plugin issue | Use TCP playback and verify the required firmware GStreamer elements |
For device-wide issues, see Troubleshooting.
Technical Support and Product Discussion
Thank you for choosing our products! We are here to provide you with various support to ensure your experience with our products is as smooth as possible. We offer multiple communication channels to meet different preferences and needs.
