Model Compatibility and Output Formats
This page summarizes what runs on the reCamera Pro NPU (Rockchip RV1126B, 3 TOPS, mixed INT8/INT16) and what the inference pipeline outputs. Use it as a quick check before you invest time converting or training a model.
Supported model format​
ItemValue
On-device model formatRKNN (.rknn), compiled for RV1126B
Required target platformtarget_platform='rv1126b' when building with RKNN-Toolkit2
Conversion toolkitRKNN-Toolkit2 2.3.2, host-side (x86_64 Linux or WSL 2, Python 3.6–3.12)
Runtime alignmentKeep the Toolkit version aligned with the RKNN Runtime shipped in the reCamera Pro firmware
PrecisionFP16 (non-quantized baseline) and INT8 (quantized with a calibration dataset)
Source formatsONNX (via RKNN-Toolkit2 or SenseCraft conversion); Ultralytics YOLO checkpoints (.pt) can export directly to RKNN
  • Do not use rknn-toolkit-lite2 for conversion — it is a device-side runtime library, not a converter.
  • A model built for a different Rockchip SoC (e.g., RK3566/RK3588) will not run on RV1126B.
Conversion walkthroughs: RKNN-Toolkit2 Conversion (host, scriptable) and SenseCraft ONNX-to-RKNN (browser-based, no code).
Built-in and tested model families​
The firmware ships with built-in detection models, and the Web UI Model Management list exposes these attributes per model:
FieldTypical values
FrameworkRKNN
AlgorithmYOLO, nanodet
TypeDetection
Tested/bundled use cases include person detection, hard-hat detection, construction-safety detection and vehicle detection.
Input contract requirements​
Your ONNX model must have a known, static input contract before conversion. RKNN applies (input − mean) / std once — if normalization is already inside the ONNX graph, use identity values (mean=[0,0,0], std=[1,1,1]).
ItemRequirement
Input shapeStatic, batch-1 preferred (e.g., [1, 3, 640, 640])
LayoutNCHW or NHWC, matching the exported graph
Channel orderRGB vs BGR must match training — a swap severely reduces accuracy
Resize policyStretch, crop or letterbox must be identical at runtime
Unsupported operatorsRe-export the ONNX model or use a semantically equivalent supported op
Inspect the contract with Netron or model-inspect before converting. Details and troubleshooting: RKNN-Toolkit2 Conversion.
Custom classes and post-processing​
Uploaded models are configured in the Web UI (Upload and Configure an RKNN Model, Configure Detection):
  • Detection Categories — set output class names manually or bulk-import a category list from a TXT file; inference results then display your own labels
  • Post-processing parameters — IOU (NMS threshold), Confidence (detection threshold), max_obj (max objects per frame)
Inference output formats​
Real-time inference output (Web UI monitoring, logs) uses these fields:
FieldDescription
timestampInference result timestamp
task_typeCurrent task type
class_idDetected class ID
class_nameDetected class name
scoreDetection confidence
bboxBounding box coordinates
detection_countNumber of objects detected in the current frame
Results can be pushed to external systems over three channels, with configurable output template and task type:
ChannelGuide
HTTPSend Detection Results over HTTP/UART
UARTSend Detection Results over HTTP/UART
MQTTSend Detection Results over MQTT
Recordings can also be triggered directly by inference results (categories, confidence range, trigger areas): Configure Event Recording.
Native (C/C++) inference​
For custom applications outside the Web UI, models are loaded through the RKNN Runtime C API. Cross-compilation setup and a minimal application: SDK Setup, Native Development. An AI-agent-assisted workflow with a C++ template: Develop with AI Coding Agents.
Sound models​
Sound event detection uses a separate pipeline: models are visualized, trained and switched in the Sound Lab (Web UI), and selected sound categories can trigger recording. See Train a Sound Model and Sound-Triggered Capture.
