Validate Model Performance
After uploading or converting a custom model, verify it runs correctly on reCamera Pro before deploying it in production.
Step 1: Start inference
- In the Web UI, go to AI Inference → Inference Configuration.
- Enable inference.
- Select your model as the Running Model.
- Set the inference frequency.
- Click Save Configuration.
Step 2: Check real-time monitoring
Go to Real-time Inference Monitoring to observe:
| Metric | What to check |
| Inference Status | Running or stopped |
| FPS | Frames per second — higher is better |
| Detection Results | Class names, confidence scores, bounding boxes |
| Detection Count | Number of objects per frame |
Step 3: Validate detection accuracy
- Point the camera at test subjects matching your detection categories.
- Observe whether detections appear with correct class names and reasonable confidence scores.
- Check for false positives (objects detected that are not present) and false negatives (objects present but not detected).
Adjusting post-processing parameters
If detection quality is poor, revisit Model Configuration:
| Parameter | Effect |
| IOU threshold | Lower → fewer duplicate boxes; higher → more overlapping boxes kept |
| Confidence threshold | Lower → more detections (including false positives); higher → fewer but more reliable detections |
| max_obj | Maximum objects reported per frame |
Step 4: Check resource usage
Monitor device resource usage during inference via SSH:
# CPU and memory
top -bn1 | head -5
# NPU usage (if available)
# TODO(verify): confirm the command to check RKNN NPU utilization on reCamera Pro
Common issues
| Symptom | Possible cause | Fix |
| Model fails to load | Incompatible operator or quantization format | Re-convert with RKNN-Toolkit2; check Model Compatibility |
| Very low FPS | Model too large or complex | Use a lighter model or reduce input resolution |
| No detections | Wrong category configuration or threshold too high | Verify detection categories match model output; lower confidence threshold |
| Garbled class names | Category list mismatch | Re-import correct category TXT in Model Configuration |
Related pages
- Choose a Model Deployment Path
- Upload and Configure an RKNN Model
- Configure Detection
- Model Compatibility
