Upload and Configure an RKNN Model
If you already have a .rknn model file (see Choose a Model Deployment Path), upload it to reCamera Pro and configure it via the Web UI.
Upload a model​
  1. In the Web UI, go to AI Inference → Model Management.
  2. Click Upload Model.
  3. Drag and drop or select your .rknn file.
After uploading, the model appears in the Model Management list.
Model fields​
FieldDescription
Model FileFilename on the device
Model NameDisplay name
FrameworkRuntime framework (RKNN)
AlgorithmAlgorithm type, e.g. YOLO, nanodet
TypeTask type, e.g. Detection
VersionModel version
SizeFile size
OperationsConfigure or delete
Configure the model​
Each model has a Configure page for setting basic information, detection categories, and post-processing parameters.
Configuration ItemDescription
FrameworkRuntime framework, e.g. RKNN
TypeTask type, e.g. Object Detection
AlgorithmAlgorithm, e.g. YOLOv5
AuthorAuthor information
DescriptionModel description
Detection CategoriesNames of the model's output categories
Post-processing ConfigurationIOU, Confidence, max_obj
Detection categories​
Categories can be added manually or imported in bulk from a TXT file. After configuring categories, inference results are displayed and output using your category names.
Post-processing parameters​
ParameterDescription
IOUIntersection over Union threshold for bounding box non-maximum suppression
ConfidenceObject detection confidence threshold
max_objMaximum number of objects output per frame
Click Save to apply.
Run the model​
  1. Go to AI Inference → Inference Configuration.
  2. Enable inference, select your uploaded model as the Running Model, and set the inference frequency.
  3. Click Save Configuration.
