Video and ISP Development
This page focuses on the product video pipeline and ISP interfaces. For a regular C/C++ application environment and deployment, follow the quick start in recamera_pro_toolchain. The rockit, IQ, and sensor configuration details referenced here are advanced topics from the full source package.
Core Concept: The rockit MPI Pipeline​
Rockchip video processing uses the rockit (MPI, Media Process Interface) model of modules, channels, and bindings. Avoid operating V4L2 directly. Module abbreviations:
ModuleFull NamePurpose
VIVideo InputCaptures frames from the sensor through the ISP
VPSSVideo Process Sub SystemMulti-channel scaling, cropping, and format conversion
VENCVideo EncoderH.264 / H.265 / JPEG / MJPEG encoding
VDECVideo DecoderDecoding
VOVideo OutputSends frames to a display
RGNRegionOSD overlays and watermarks
AI / AOAudio In / OutCapture / playback
AENC / ADECAudio Encoder / DecoderAudio encoding / decoding
AVSAround View SystemMulti-camera surround-view stitching
IVSIntelligent Video SurveillanceIntelligent analysis, such as motion detection
TDETwo Dimensional Engine2D acceleration
MBMedia BufferMedia buffer pool management
SYSSystemInitialization, binding, and memory management
The corresponding headers are in output/out/media_out/include/. They follow the rk_mpi_<module>.h naming convention (for example, rk_mpi_vi.h, rk_mpi_venc.h, and rk_mpi_sys.h). Other headers include rk_debug.h, rk_defines.h, and rk_errno.h.
Typical pipeline:
sensor → VI(dev0/pipe0/chn0) → VPSS(grp0) → VENC(chn0) → RTSP/File
↘ RGN overlay
↘ IVS intelligent analysis
Connect modules with RK_MPI_SYS_Bind(). Data then flows automatically, so you do not need to move frames yourself.
Existing Sample Index​
Each .c file is a complete, independently buildable program. The filename describes the pipeline:
FileDemonstration
simple_vi_get_frame.cCaptures VI frames; the smallest VI example
simple_vi_get_frame_rkaiq.cCaptures frames and manually initializes rkaiq
simple_vi_bind_venc.cVI to VENC, encoding to a file
simple_vi_bind_venc_jpeg.cJPEG snapshot capture
simple_vi_bind_venc_rtsp.cVI to VENC to RTSP streaming; the most common starting point
simple_vi_bind_venc_rtsp_lowdelay.cLow-latency RTSP
simple_vi_bind_venc_rtsp_eptz.cElectronic PTZ
simple_vi_bind_venc_svc_rtsp.cSVC scalable encoding
simple_vi_bind_venc_osd.cOSD overlay
simple_vi_bind_vpss_bind_venc.cAdds VPSS for multiple streams
simple_vi_bind_vpss_bind_vo.cAdds display output
simple_vi_bind_ivs.cConnects intelligent analysis
simple_vi_bind_avs_bind_venc.cSurround-view stitching
simple_vi_gdc_vo.cDistortion correction
simple_vdec_bind_vo.c / simple_vdec_bind_vo_rtsp_lowdelay.cDecode and display / low-latency restreaming
simple_ai_bind_aenc.c / simple_adec_bind_ao.c / simple_ao_send_frame.cAudio capture and encoding / decoding and playback / direct frame playback
simple_multi_ahd_vpss_test.cMulti-channel AHD
rv1126b/simple_irfpa_vi_bind_venc_rtsp.cRV1126B only: infrared focal-plane array and streaming
The simple_test/ directory also includes rk_2_1920x1080.json / .xml as a dual-camera 1080p AVS calibration example.
media/samples/example/ — Full Examples​
SubdirectoryFile
vi/sample_vi.c, sample_multi_vi.c, sample_vi_eis.c (electronic image stabilization)
venc/sample_vi_vpss_osd_venc.c、sample_multi_vi_avs_osd_venc.c
vo/sample_vi_vo.c
audio/sample_ai.c、sample_ai_aenc.c
avs/sample_avs.c、sample_multi_vi_avs.c
demo/sample_demo_vi_venc.c、sample_demo_dual_camera.c、sample_demo_dual_camera_wrap.c、sample_demo_multi_cam.c、sample_demo_multi_camera_eptz.c、sample_demo_eis.c、sample_demo_aiisp.c、sample_demo_dual_aiisp.c、sample_demo_vi_avs_venc.c
test/Stress tests:sample_venc_stresstest.c、sample_vpss_stresstest.c、sample_isp_stresstest.c、sample_mulit_isp_stresstest.c、sample_multi_cam_stresstest.c、sample_rgn_stresstest.c、sample_ai_aenc_adec_ao_stresstest.c、sample_avs_stresstest.c、sample_vdec_vo_stresstest.c、sample_vdec_vpss_vo_stresstest.c、sample_demo_*_stresstest.c
For stability testing, run the corresponding stress test under test/.
Application-Level Examples under project/app/​
DirectoryContents
testdemo/low_delay_net_displayLow-latency network display
testdemo/yoloworld_demoYOLO-World detection demo (includes 3rdparty, resources, and RkLunch.sh)
aov_sample/Low-power always-on vision:sample_aov_aiisp_iva_venc.c、sample_aoa_capture.c、sample_aov_audio.c、resume_suspend_test.sh
cvr/In-vehicle recording
ao_record_demo/Audio recording demo; its Makefile is a useful template for linking rockit
uvc_app_tiny/UVC camera mode
recamera_ipc/The complete product implementation; see Product Service Architecture
Build and Run Samples​
Samples are built with media (make -C ./samples is called by the all target in media/Makefile):
./build.sh media
ls output/out/media_out/ # should contain the sample binaries
For RV1126B, the build automatically adds -DRV1126B and uses chip-specific source files under simple_test/rv1103_rv1106_rv1103b_rv1126b/ and simple_test/rv1126b/.
Copy a sample to the device and run it:
scp output/out/media_out/bin/simple_vi_bind_venc_rtsp root@<device-ip>:/userdata/
ssh root@<device-ip>
# /userdata/simple_vi_bind_venc_rtsp --help
Resource conflict warning: On product firmware, rkipc (recamera_ipc) is already running and owns VI/VENC/ISP resources and the RTSP service on port 5554. A sample may fail because the device nodes are already in use. Stop the application before debugging:
# sh /oem/usr/bin/RkLunch-stop.sh
# Or use /etc/init.d/S21appinit stop
Do not kill system services indiscriminately to access device nodes. Restart them after debugging. In production, coordinate access through shared configuration or an explicit service-stop procedure.
RTSP Streaming Architecture (Important)​
Streaming on reCamera Pro uses two stages:
recamera_ipc(rkipc) internal RTSP service listening on 127.0.0.1:5554
↓ rtsp://127.0.0.1:5554/live/0 (main) /live/1 (sub)
go2rtc converts the stream
↓ WebRTC :8555 / RTSP :554 (optional) / HLS, etc.
External clients
Configuration is in project/cfg/BoardConfig_Recamera2/overlay/overlay-buildroot-go2rtc/oem/usr/etc/go2rtc/go2rtc.yaml. Whether port 554 is exposed externally is controlled by the enable settings in the [video.0.rtsp], [video.0.onvif], and [video.1.rtsp] sections of /userdata/config/rkipc.ini. See Device Access and Debugging.
The default configuration file for recamera_ipc is project/app/recamera_ipc/src/rv1126b_ipc/rkipc-3840x2160.ini. It contains resolution, bitrate, frame rate, and RTSP/ONVIF settings.
For a custom streaming application, there are two options:
  1. Use rockit and librtsp: Start your own RTSP service as in simple_vi_bind_venc_rtsp.c (link with -lrtsp) and choose a port other than 5554.
  2. Use GStreamer: The device has GStreamer 1.22 (the plugin list still needs verification on hardware) and can capture with v4l2src. The following probe command is recorded as working:
# gst-launch-1.0 -v v4l2src device=/dev/video13 num-buffers=30 \
# ! 'video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1' \
# ! videoconvert ! fakesink
Device node numbers (such as /dev/video13) depend on the firmware and may change between versions. Confirm them on the device with v4l2-ctl --list-devices.
ISP and rkaiq​
Source Locations​
  • Engine source:media/isp/camera_engine_rkaiq/
  • IQ File:media/isp/camera_engine_rkaiq/rkaiq/iqfiles/isp35/(this board configuration uses isp35)
  • FEC calibration:media/isp/camera_engine_rkaiq/IspFec/fec_calib/
  • Headers (after building): output/out/media_out/include/rkaiq/, with subdirectories such as uAPI, uAPI2, algos, common, xcore, iq_parser, iq_parser_v2, and smartIr
  • Libraries: -lrkaiq (also link -lstdc++ -lm)
Newer code consistently uses uAPI2 (rk_aiq_user_api2_*.h); only builds with the RV1126_RV1109 macro use the older uAPI.
IQ Files in the Board Configuration​
The board configuration specifies:
export RK_CAMERA_SENSOR_IQFILES="ainr/sc450ai_default_default.json ainr/sc450ai ainr/sc850sl ainr/sc850sl_default_default.json"
export RK_CAMERA_SENSOR_CAC_BIN=""
export RK_AIISP_MODEL=NONE
This packages AINR (AI noise reduction) IQ files for the SC450AI and SC850SL sensors in the image. The AI-ISP model is disabled (RK_AIISP_MODEL=NONE).
On the device, the packaged files are located at /oem/usr/share/iqfiles/, and /etc/iqfiles is a symlink to this directory (created by __PACKAGE_OEM() / __PACKAGE_ROOTFS() in build.sh).
Replace or Tune IQ Files​
  • During debugging, replace the file on the device directly: /oem/usr/share/iqfiles/<sensor>/<Module>.json(remount /oem if it is read-only), then restart rkipc to apply the change.
  • For a release, put the tuned JSON file back in media/isp/camera_engine_rkaiq/rkaiq/iqfiles/isp35/ainr/ and list it in RK_CAMERA_SENSOR_IQFILES, then rebuild media and the firmware.
For tuning tools and procedures, see docs/zh/isp/Rockchip_Tuning_Guide_ISP35_CN.pdf、Rockchip_Color_Optimization_Guide_ISP39_ISP33_ISP35_CN.pdf、Rockchip_Development_Guide_IRFPA_CN.pdf(infrared), andRockchip_Development_Guide_FEC_CN.pdf(distortion calibration).
Sensors and Kernel Drivers​
The kernel fragment rv1126b-recamera2.config builds many sensor drivers as modules:
SC450AI SC850SL SC200AI SC3336 SC401AI SC4336 SC530AI SC635HAI SC00AI series
GC2053 GC8613 GST412C IMX415 IMX464 IMX586 IMX708 OS04A10 PS5458
TECHPOINT(AHD Decoding)
It also enables CONFIG_VIDEO_ROCKCHIP_FEC=y (distortion correction hardware) and CONFIG_OF_OVERLAY=y (runtime DTBO overlays); CONFIG_VIDEO_RK_IRCUT is disabled.
Camera-related device trees:
FilePurpose
rv1126b-recamera2-v1.dtsTop-level entry point,model = "Rockchip RV1126B RECAMERA PRO Board"
rv1126b-recamera2-cam-csi0.dtsi / -cam-csi1.dtsiCSI0 / CSI1 camera paths
rv1126b-recamera2-ext-cam-csi1.dtsExpansion board camera (compiled as .dtbo)
rv1126b-recamera2-baseboard-0.dts / -baseboard-1.dtsBaseboard variants
rv1126b-recamera2-extboard-0.dts / -extboard-1.dtsExpansion-board variants
rv1126b-recamera2-disp.dtsiDisplay
RK_KERNEL_RC_DTO=y enables DTBO (Runtime Device Tree Overlay). The build outputs rv1126b-recamera2-ext-*.dtbo are copied by build.sh to /oem/usr/share/. At boot, board identification (S00board-id) reads the ADC and writes /run/board_id.env; the system uses this information to select an overlay dynamically. This mechanism allows one firmware image to support multiple reCamera Pro hardware configurations. See System Customization (DTS / Kernel / Buildroot / Overlay).
RGA and Format Conversion​
media/rga/ provides 2D acceleration for scaling, NV12↔RGB conversion, rotation, and blending. Link with -lrga.
A common use case: VENC requires NV12, while the NPU model requires RGB. Converting with RGA is much faster and uses less CPU than videoconvert.
Do not pass raw NV12 bytes directly to an RGB/BGR model. Convert the pixel format and normalize the data explicitly.
DocumentPath
Rockit Runtime Developer Guidedocs/zh/media/Rockchip_Developer_Guide_Linux_Rockit_Runtime_CN.pdf
MPI C API Guidedocs/zh/media/Rockchip_Developer_Guide_MPI_C_CN.pdf
VI Driver Guidedocs/zh/isp/Rockchip_Driver_Guide_VI_CN.pdf
Camera Driver Guidedocs/zh/isp/Rockchip_Developer_Guide_Camera_Driver_CN.pdf
ISP35 Development and Tuningdocs/zh/isp/Rockchip_Development_Guide_ISP35_CN.pdf、Rockchip_Tuning_Guide_ISP35_CN.pdf
EIS Electronic image stabilizationdocs/zh/media/Rockchip_Developer_Guide_EIS_CN.pdf、Rockchip_RV1126B_Development_Guide_DIS_CN.pdf
AOV Low-Power Modedocs/zh/media/Rockchip_Developer_Guide_Linux_AOV_CN.pdf
DVR In-Vehicle Recordingdocs/zh/media/Rockchip_Developer_Guide_Linux_DVR_CN.pdf
VENC Troubleshootingdocs/zh/media/Rockchip_Trouble_Shooting_Linux_VENC_CN.pdf
AVS Calibrationdocs/zh/media/Rockchip_Developer_Guide_AVS_Calib_Product_CN.pdf
Fast Bootdocs/zh/ipc/Rockchip_Developer_Guide_Linux_RKAI_CN.pdf(Thunder Boot)
