UDP Face Analysis with reCamera
Introduction​
This demo demonstrates how to build a real-time face analysis system using reCamera. The system performs:
  • Face Detection: Using YOLO face detection model
  • Attribute Analysis: Age, Gender, and Race estimation using FairFace model
  • Emotion Recognition: 7-class emotion detection
  • UDP Streaming: Send JPEG frames with detection metadata to PC via UDP
The C++ application runs on reCamera and pushes video frames along with detection results (bounding boxes, attributes) through UDP. A Python receiver script running on your PC displays the annotated video stream in real-time.
Key Features:
  • Real-time face detection with confidence threshold control
  • Multi-attribute analysis per face (gender, age, race, emotion)
  • Efficient UDP streaming with JPEG compression
  • Skip-frame inference to reduce CPU/TPU load
  • Detailed performance statistics
Demo Setup​
To set up this demo, you need to:
  1. Cross-compile the C++ program on your PC
  2. Run the compiled executable on ReCamera
  3. Run the Python receiver script on your PC
1. Compile the C++ Program​
note
Before building this solution, make sure you have set up the ReCamera-OS environment according to the main project documentation.
Set the following environment variables for the ReCamera-OS build environment before running cmake:
export PATH='current compile chain path'/host-tools/gcc/riscv64-linux-musl-x86_64/bin:$PATH
First, ensure you have the required models:
  • yolo_face.cvimodel - YOLO face detection model
  • age_gender_race.cvimodel - FairFace model for age/gender/race
  • emotion.cvimodel - Emotion recognition model
You can download these three model files from the sscma-example-sg200x v1.0.1 release, or train your own models and then quantize/convert them to .cvimodel format.
Navigate to the solution directory and compile:
git clone https://github.com/RobotXTeam/sscma-example-sg200x.git
cd sscma-example-sg200x/solutions/sesg-project/face_udp
export SG200X_SDK_PATH='current clone path'/sg2002_recamera_emmc
rm -rf build && mkdir build && cd build
cmake -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-std=c++17" ..
make -j$(nproc)
The compiled executable will be at: build/face_udp
note
The repository includes pre-compiled models in the solution folder:
  • yolo-face_mixfp16.cvimodel
  • age_gender_race_bf16.cvimodel
  • emotion_bf16.cvimodel
2. Configure ReCamera​
warning
Before running the C++ program, you must stop the default Node-RED services as they occupy the camera resources. Run the following commands via SSH:
sudo mv /etc/init.d/S03node-red /etc/init.d/disable/
sudo mv /etc/init.d/S91sscma-node /etc/init.d/disable/
sudo mv /etc/init.d/S93sscma-supervisor /etc/init.d/disable/
3. Run the Executable on ReCamera​
Upload the compiled executable and models to /home/recamera/ on ReCamera, then run:
chmod +x face_udp
./face_udp <yolo_face.cvimodel> <age_gender_race.cvimodel> <emotion.cvimodel> [single|multi] [threshold] [skip] [udp_ip] [udp_port] [log_every_n_infer]
Parameters​
ParameterDescriptionDefault
yolo_face.cvimodelYOLO face detection model (required)-
age_gender_race.cvimodelFairFace model (required)-
emotion.cvimodelEmotion model (required)-
single|multiYOLO head typemulti
thresholdDetection threshold0.5 (multi) / 0.7 (single)
skipInference every N frames3 (multi) / 1 (single)
udp_ipPC IP address for UDP-
udp_portUDP port number-
log_every_n_inferPrint log every N inferences20
Example Commands​
Basic usage (no UDP streaming):
./face_udp yolo-face_mixfp16.cvimodel age_gender_race_bf16.cvimodel emotion_bf16.cvimodel
With UDP streaming:
./face_udp yolo-face_mixfp16.cvimodel age_gender_race_bf16.cvimodel emotion_bfpf16.cvimodel multi 0.5 3 192.168.31.100 5001
note
Remember to replace 192.168.31.100 with your PC's actual IP address on the same network as ReCamera.
4. Run the Python Receiver on PC​
On your PC, ensure Python with required libraries is installed:
pip install opencv-python numpy
Navigate to the solution directory and run:
python3 udp_receiver.py
Expected Output​
On ReCamera Terminal​
The program will display real-time performance statistics every 2 seconds:
========== Performance Stats (Last 2 Seconds) ==========
Video FPS: 30.2 | UDP FPS: 9.8
Frames: 300 | Inferences: 100
Average YOLO Timing:
Preprocess: 0.9 ms
Inference: 35.5 ms
Postprocess: 32.3 ms
Total: 68.7 ms
Average Attribute/Emotion Overhead:
mmap: 1.2 ms
AGR: 45.3 ms/frame | 45.3 ms/face
EMO: 12.1 ms/frame | 12.1 ms/face
UDP Send:
avg_send: 2.1 ms | throughput: 850.5 kbps
On Python Receiver Window​
The PC will display a window showing:
  • Live video stream with JPEG frames
  • Face bounding boxes (green rectangles)
  • Attribute labels in the top-left corner:
    • Gender (Male/Female)
    • Age range
    • Race classification
    • Emotion (angry/disgust/fear/happy/sad/surprise/neutral)
Troubleshooting​
Camera Access Error​
If you see "No camera" error:
  • Ensure Node-RED services are stopped (see Step 2 above)
  • Check camera connection
UDP Connection Failed​
If PC doesn't receive data:
  • Verify PC and ReCamera are on the same network
  • Check firewall settings on PC
  • Confirm UDP port 5001 is not blocked
  • Test with ping between devices
Model Load Error​
If model fails to load:
  • Verify model files are uploaded to /home/recamera/
  • Check file permissions with ls -la
  • Ensure sufficient storage space
