Create Dynamic IoT Dashboards with ThingsBoard and reComputer R1000
Introduction
The ThingsBoard Community Edition, an open-source platform, offers powerful features for creating interactive dashboards that stand out among other open-source IoT solutions. With a variety of graphical tools, ThingsBoard allows users to easily visualize and monitor data collected from IoT devices, making it ideal for managing and analyzing real-time data. Whether for industrial automation, smart city projects, or environmental monitoring, ThingsBoard provides a versatile and user-friendly way to track and respond to IoT data insights.
Prerequisites
Hardware
| reComputer R1000 |
Software
If you're new to ThingsBoard, please ensure it’s installed correctly. Refer to this wiki for guidance.
Login to ThingsBoard
Use the following credentials to log in:
Username: [email protected]
Password: tenant
Step 1: Provision a Device
- Navigate to the
Devicespage under theEntitiessection.
- Click the
+icon in the top right corner of the table and selectAdd new devicefrom the drop-down menu.
- Enter the device name. Give Client Id, Password, Username. Click
Add.
- As you add more devices, they will appear at the top of the table. The table automatically sorts devices by creation time, with the newest ones listed first.
Step 2: Connect the Device
- Click on your device and then click the
Check connectivitybutton in theDevice detailswindow.
- In the opened window, select the messaging protocol and your operating system.
- Install the necessary client tools and copy the provided command.
- Execute the copied command. Once the
temperaturereadings are published successfully, the device state will change from "Inactive" toActive. You will also see the published temperature readings.
- Close the connectivity window.
Step 3: Configure the MQTT Node in Node-RED
- If you collect data using different protocols like Modbus, BACnet, or OPC UA, you can use Node-RED.
- Open Node-RED and add an
MQTT Outnode. - In the MQTT Out broker setup, configure the
client name, password, broker username, and the IP address of the reComputer. - Use the topic
v1/devices/me/telemetryto send telemetry data.
- If you want to learn more about the MQTT In node, you can explore it further.
You do not need to install the Mosquitto broker on the reComputer.
Step 4: Create a Dashboard
Create an Empty Dashboard
- Navigate to the
Dashboardspage from the main menu on the left side of the screen. - Click the
+sign in the upper right corner of the screen and selectCreate new dashboardfrom the drop-down menu.
- In the dialog box, enter a title for the dashboard (the description is optional). Click
Add.
- After creating the dashboard, it will open automatically, and you can start adding widgets.
- To save the dashboard, click the
Savebutton in the upper right corner.
- Your first dashboard is now created. As you add more dashboards, they will appear at the top of the list, sorted by the creation timestamp.
Add a Chart Widget
- Enter edit mode and click the
Add new widgetbutton at the top of the screen.
- Find the
Chartswidget bundle and click on it.
- Select the
Time series chartwidget.
- In the
Devicefield, specify the device you created earlier as the data source. - In the
Seriessection, enter the data keyTemperatureto monitor the temperature values of a device. - Click
Add.
- Resize the widget and apply the changes.
You can explore additional dashboard widgets here.
