How to reflash the bootloader with factory firmware
You can simply connect the board to a PC via USB Type-C and reflash the bootloader with factory firmware by using ESP RF Test Tool.
Step 1. Hold on the BOOT BUTTON and connect XIAO ESP32C3 to the PC to enter bootloader mode
Step 2. After it is connected, release the BOOT BUTTON
Step 3. Visit this page and download ESP RF Test Tool and Test Guide
- Step 4. Extract the .zip, navigate to
ESP_RF_Test_EN\ESP_RF_Test_EN\EspRFTestTool_v2.8_Manualand open EspRFTestTool_v2.8_Manual.exe
- Step 5. Select ESP32C3 as the ChipType, your COM port, 115200 as the BaudRate and click open
You will see the following output
- Step 6. Select Flash and click Select Bin
Step 7. Download the factory firmware of XIAO ESP32C3 and select it.
Step 8. Finally click Load Bin
You will see the following output when flashing is successful
