reSpeaker 2-Mics Pi HAT V2.0 FAQ
This page contains verified answers for the reSpeaker 2-Mics Pi HAT V2.0. Each answer states the product variant and firmware mode it applies to, together with the date it was last verified against current official sources.
Before you begin​
  • Confirm the exact product variant and the firmware mode (USB or I2S) the device is running.
  • Check the current firmware version before applying version-specific steps.
  • Answers on this page were last verified on 2026-09-01; re-check the linked official sources if you are reading this later.
Hardware Issues​
What is the codec I2C address on ReSpeaker 2-Mics Pi HAT V2.0?​
Applies to: ReSpeaker 2-Mics Pi HAT V2.0 only; V1.x uses different codec hardware
Last verified: 2026-09-01
ReSpeaker 2-Mics Pi HAT V2.0 uses a TLV320AIC3104 codec at the 7-bit I2C address 0x18. The official V2.0 device-tree overlay declares tlv320aic3104@18 with reg = <0x18>, and the public V2.0 schematic identifies the same codec.
Prerequisites:
  • Confirm the board is V2.0 with the official hardware-revision guide
  • Use the revision-specific V2.0 driver and device-tree overlay
  1. Follow the official V2.0 Raspberry Pi guide to install respeaker-2mic-v2_0-overlay.dtbo.
  2. Check that the V2.0 overlay declares the codec at 7-bit address 0x18.
  3. Reboot and use arecord -l or aplay -l to confirm that the tlv320aic3x-hifi sound device binds successfully.
Success criteria:
  • The V2.0 overlay loads and the TLV320AIC3104-backed sound card appears in the ALSA device list
Notes:
  • Do not copy this address to ReSpeaker 2-Mics Pi HAT V1.x, which uses different codec hardware.
  • The address alone is not a complete or supported ESP32-S3 wiring and codec-initialization guide.
References:
