Record and Playback with reSpeaker XVF3800 44mm and XIAO ESP32-S3 Plus
This example captures five seconds of stereo audio from the XVF3800 over I2S into the XIAO's PSRAM, then plays the same buffer back through the I2S transmit path. It is the quickest way to prove the full audio round trip works without a PC, and a good starting point for voice-record applications.
reSpeaker XVF3800 44mm with XIAO ESP32-S3 Plus
Prerequisites​
  • The array must be running the I2S firmware. See Update Firmware.
  • Arduino IDE with the ESP32 board package and the Arduino Audio Tools library. See Software Preparation.
  • Board selected as XIAO_ESP32S3_Plus, Port number need to be selected.
  • PSRAM enabled: Tools > PSRAM > OPI PSRAM. The recording buffer does not fit in internal RAM.
note
Five seconds at 48 kHz, stereo, 32-bit needs 1,920,000 bytes (48,000 × 2 channels × 4 bytes × 5 s). Without PSRAM the sketch stops with PSRAM allocation failed!.
The sketch runs the XIAO as I2S slave (config.is_master = false) because the XVF3800 generates BCLK, LRCLK, and MCLK.
How It Works​
  1. At boot the sketch reports total and free PSRAM, then allocates RECORD_BYTES (five seconds) with heap_caps_malloc(..., MALLOC_CAP_SPIRAM).
  2. Record: I2S is restarted in RX_MODE and bytes are pulled into the buffer in 8 KB chunks until the buffer is full or a one-second read timeout fires.
  3. The byte count is trimmed to a whole number of stereo frames so playback stays aligned.
  4. Playback: I2S is restarted in TX_MODE and the buffer is written out in 8 KB chunks, followed by flush() and a short delay so the last frames drain before the stream is stopped.
  5. The loop repeats, recording again after a one-second pause.
Arduino Sketch​
#include "AudioTools.h"
#include "esp_heap_caps.h"
// Audio configuration
constexpr uint32_t SAMPLE_RATE = 48000;
constexpr uint16_t CHANNELS = 2;
constexpr uint16_t BITS_PER_SAMPLE = 32;
// Recording configuration
constexpr uint32_t RECORD_SECONDS = 5;
constexpr size_t FRAME_BYTES =
CHANNELS * (BITS_PER_SAMPLE / 8);
constexpr size_t BYTES_PER_SECOND =
SAMPLE_RATE * FRAME_BYTES;
constexpr size_t RECORD_BYTES =
BYTES_PER_SECOND * RECORD_SECONDS;
// Process audio in smaller blocks
constexpr size_t CHUNK_BYTES = 8192;
AudioInfo info(SAMPLE_RATE, CHANNELS, BITS_PER_SAMPLE);
I2SStream out;
I2SConfig config;
// PSRAM recording buffer
uint8_t *audioBuffer = nullptr;
size_t bytes_read = 0;
size_t bytes_write = 0;
// Start I2S
bool startI2S() {
if (!out.begin(config)) {
Serial.println("I2S initialization failed!");
return false;
return true;
// Arduino Setup
while (!Serial);
AudioLogger::instance().begin(
Serial,
AudioLogger::Info
Serial.println("\nI2S Record / Playback Test");
// Check PSRAM availability
size_t psramTotal =
heap_caps_get_total_size(MALLOC_CAP_SPIRAM);
size_t psramFree =
heap_caps_get_free_size(MALLOC_CAP_SPIRAM);
Serial.printf(
"PSRAM total: %lu bytes\n",
(unsigned long)psramTotal
Serial.printf(
"PSRAM free: %lu bytes\n",
(unsigned long)psramFree
Serial.printf(
"Recording buffer required: %lu bytes\n",
(unsigned long)RECORD_BYTES
// Allocate audio buffer in PSRAM
audioBuffer = (uint8_t *)heap_caps_malloc(
RECORD_BYTES,
MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT
if (audioBuffer == nullptr) {
Serial.println("PSRAM allocation failed!");
Serial.println(
"Enable Tools -> PSRAM -> OPI PSRAM"
while (true) {
Serial.println("PSRAM buffer allocated successfully");
// Configure I2S
config = out.defaultConfig(TX_MODE);
config.copyFrom(info);
// XIAO ESP32-S3 Plus pins
config.pin_bck = 8; // D9 - GPIO8
config.pin_ws = 7; // D8 - GPIO7
config.pin_data = 44; // D7 - GPIO44 - TX
config.pin_data_rx = 43; // D6 - GPIO43 - RX
// XVF3800 is I2S master
config.is_master = false;
if (!startI2S()) {
while (true) delay(1000);
Serial.println("I2S initialized successfully");
// Arduino Loop
// STEP 1: RECORD AUDIO
Serial.println("\n========== RECORDING ==========");
out.end();
config.rx_tx_mode = RX_MODE;
if (!startI2S()) {
return;
bytes_read = 0;
uint32_t lastReadTime = millis();
Serial.println("Recording started...");
while (bytes_read < RECORD_BYTES) {
size_t remaining = RECORD_BYTES - bytes_read;
size_t request =
(remaining > CHUNK_BYTES)
? CHUNK_BYTES
: remaining;
size_t received = out.readBytes(
audioBuffer + bytes_read,
request
if (received == 0) {
if (millis() - lastReadTime > 1000) {
Serial.println("RX timeout!");
break;
delay(1);
continue;
bytes_read += received;
// Stop receiving
out.end();
// Keep complete stereo frames only
bytes_read -= bytes_read % FRAME_BYTES;
Serial.println("Recording finished");
Serial.printf(
"Captured bytes: %lu / %lu\n",
(unsigned long)bytes_read,
Serial.print("Recorded duration: ");
Serial.print(
(float)bytes_read / BYTES_PER_SECOND,
2
Serial.println(" seconds");
if (bytes_read == 0) {
Serial.println("No audio captured!");
return;
// STEP 2: PLAYBACK AUDIO
Serial.println("\n========== PLAYBACK ==========");
config.rx_tx_mode = TX_MODE;
if (!startI2S()) {
return;
bytes_write = 0;
Serial.println("Playback started...");
while (bytes_write < bytes_read) {
size_t remaining = bytes_read - bytes_write;
size_t request =
? CHUNK_BYTES
: remaining;
size_t written = out.write(
audioBuffer + bytes_write,
request
if (written == 0) {
Serial.println("TX write failed!");
break;
bytes_write += written;
// Allow queued audio to finish playing
out.flush();
delay(150);
// Stop transmitting
out.end();
Serial.println("Playback finished");
Serial.printf(
"Transmitted bytes: %lu / %lu\n",
(unsigned long)bytes_write,
Serial.println("\n========== TEST COMPLETE ==========");
// Wait before next recording
Expected Output​
PSRAM total: 8388608 bytes
PSRAM free: 8386804 bytes
Recording buffer required: 1920000 bytes
Recording finished
Captured bytes: 1920000 / 1920000
Recorded duration: 5.00 seconds
Playback started...
Playback finished
Transmitted bytes: 1920000 / 1920000
The PSRAM totals depend on the module. What matters is Recording buffer required being smaller than PSRAM free, a full 1920000 / 1920000 capture, and a matching transmit count.
Connect a speaker or headphones to the array to hear the recording during the playback phase.
Troubleshooting​
PSRAM allocation failed!​
Tools > PSRAM > OPI PSRAM is not enabled, or the board selected is not XIAO_ESP32S3_Plus. Re-select the board, enable PSRAM, and re-upload.
