UDP Streaming reSpeaker XVF3800 44mm with XIAO ESP32-S3 Plus
Overview
This project streams real-time audio from the reSpeaker XVF3800 44mm array over Wi-Fi. The XIAO ESP32-S3 Plus captures the processed stereo output over I2S, splits it into numbered UDP packets, and sends them to a Python receiver on your PC, which reassembles the stream and saves it as a WAV file.
Functionality Overview
- Connects the XIAO to a Wi-Fi network in station mode.
- Captures 48 kHz, stereo, 32-bit audio from the XVF3800 over I2S.
- Sends five seconds of audio to the PC as UDP packets, each with an 8-byte header (
AUD0magic + sequence number). - The Python receiver reassembles the stream, detects missing or duplicate packets, inserts silence for gaps, and writes
respeaker_recording.wav.
This example expects the I2S firmware on the XVF3800, at 48 kHz. If the board is still running the USB image it will not produce I2S clocks. See Update Firmware.
Before You Start
- Put the board on the same network as your PC.
- Set your Wi-Fi credentials and your PC's IPv4 address in the sketch.
- Find the PC address with
ipconfig(Windows) orip addr(Linux/macOS). - Allow inbound UDP port
12345through the firewall, or the packets will be dropped silently.
Arduino Code
Update these values before uploading:
// WiFi credentials
const char* ssid = "Your-SSID";
const char* password = "Your-PASSWORD";
// Your PC's IP address and the UDP port the Python script listens on
IPAddress pcIP(192, 168, 1, 100);
const uint16_t udpPort = 12345;
Full Code (streams 5 seconds of audio)
#include <WiFi.h>
#include <WiFiUdp.h>
#include "AudioTools.h"
// WIFI CONFIGURATION
// Your Windows PC IP address
WiFiUDP udp;
// I2S CONFIGURATION
#define SAMPLE_RATE 48000
#define CHANNELS 2
#define BITS_PER_SAMPLE 32
#define I2S_BCK_PIN 8
#define I2S_WS_PIN 7
#define I2S_TX_PIN 44
#define I2S_RX_PIN 43
AudioInfo info(
SAMPLE_RATE,
CHANNELS,
BITS_PER_SAMPLE
I2SStream i2s;
I2SConfig i2sConfig;
// RECORDING CONFIGURATION
#define RECORD_SECONDS 5
#define BUFFER_SIZE 1024
#define FRAME_BYTES 8
#define BYTES_PER_SECOND \
(SAMPLE_RATE * CHANNELS * (BITS_PER_SAMPLE / 8))
#define TOTAL_BYTES \
(BYTES_PER_SECOND * RECORD_SECONDS)
// UDP PACKET CONFIGURATION
// Header: 4-byte magic + 4-byte sequence
#define HEADER_SIZE 8
#define PACKET_MAGIC "AUD0"
uint8_t audioBuffer[BUFFER_SIZE];
uint8_t packetBuffer[HEADER_SIZE + BUFFER_SIZE];
uint32_t sequenceNumber = 0;
// WIFI CONNECTION
bool connectWiFi() {
Serial.printf(
"Connecting to WiFi: %s\n",
ssid
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
unsigned long start = millis();
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
if (millis() - start > 30000) {
Serial.println("\nWiFi connection timeout!");
return false;
Serial.println("\nWiFi connected!");
Serial.print("ESP32 IP: ");
Serial.println(WiFi.localIP());
Serial.print("PC destination: ");
Serial.println(pcIP);
Serial.print("UDP port: ");
Serial.println(udpPort);
return true;
// I2S INITIALIZATION
bool setupI2SInput() {
Serial.println("\nInitializing I2S...");
i2sConfig = i2s.defaultConfig(RX_MODE);
i2sConfig.copyFrom(info);
i2sConfig.pin_bck = I2S_BCK_PIN;
i2sConfig.pin_ws = I2S_WS_PIN;
i2sConfig.pin_data = I2S_TX_PIN;
i2sConfig.pin_data_rx = I2S_RX_PIN;
// XVF3800 supplies BCLK and LRCLK
i2sConfig.is_master = false;
if (!i2s.begin(i2sConfig)) {
Serial.println("I2S initialization failed!");
return false;
Serial.println("I2S initialized successfully");
Serial.println("Sample rate: 48000 Hz");
Serial.println("Channels: 2");
Serial.println("Bit depth: 32-bit");
return true;
// SEND ONE UDP AUDIO PACKET
bool sendAudioPacket(
const uint8_t* data,
size_t length
if (length == 0 || length > BUFFER_SIZE) {
return false;
// Header magic
memcpy(
packetBuffer,
PACKET_MAGIC,
4
// Sequence number, little-endian
memcpy(
packetBuffer + 4,
&sequenceNumber,
4
// Audio payload
memcpy(
packetBuffer + HEADER_SIZE,
data,
length
if (!udp.beginPacket(pcIP, udpPort)) {
return false;
size_t headerWritten = udp.write(
packetBuffer,
HEADER_SIZE
size_t audioWritten = udp.write(
length
int result = udp.endPacket();
if (headerWritten != HEADER_SIZE ||
audioWritten != length ||
result != 1) {
Serial.printf(
"UDP send failed at packet %lu\n",
(unsigned long)sequenceNumber
return false;
sequenceNumber++;
return true;
// RECORD AND TRANSMIT AUDIO
void recordAndSendAudio() {
Serial.println("\n================================");
Serial.println("STARTING AUDIO TRANSMISSION");
Serial.println("================================");
Serial.printf(
"Recording duration: %d seconds\n",
RECORD_SECONDS
Serial.printf(
"Expected audio: %lu bytes\n",
(unsigned long)TOTAL_BYTES
size_t totalSent = 0;
uint32_t successfulPackets = 0;
uint32_t failedPackets = 0;
unsigned long startTime = millis();
while (totalSent < TOTAL_BYTES) {
size_t remaining = TOTAL_BYTES - totalSent;
size_t requestSize =
(remaining > BUFFER_SIZE)
? BUFFER_SIZE
: remaining;
// Read I2S audio
size_t bytesRead = i2s.readBytes(
audioBuffer,
requestSize
if (bytesRead == 0) {
delay(1);
continue;
// Preserve complete stereo frames
bytesRead -= bytesRead % FRAME_BYTES;
continue;
// Send via UDP
if (sendAudioPacket(audioBuffer, bytesRead)) {
totalSent += bytesRead;
successfulPackets++;
} else {
failedPackets++;
// Do not advance totalSent.
// The same audio data will be retried.
static size_t lastProgress = 0;
if (totalSent - lastProgress >= BYTES_PER_SECOND) {
lastProgress = totalSent;
Serial.printf(
"Sent: %lu / %lu bytes (%.2f sec)\n",
(unsigned long)totalSent,
(unsigned long)TOTAL_BYTES,
(float)totalSent / BYTES_PER_SECOND
unsigned long elapsed = millis() - startTime;
Serial.println("TRANSMISSION COMPLETE");
Serial.printf(
"Total audio bytes: %lu\n",
Serial.printf(
"Successful packets: %lu\n",
(unsigned long)successfulPackets
Serial.printf(
"Failed packets: %lu\n",
(unsigned long)failedPackets
Serial.printf(
"Elapsed time: %.2f seconds\n",
elapsed / 1000.0
Serial.printf(
"Average data rate: %.2f KB/s\n",
elapsed > 0
? (float)totalSent / elapsed
: 0.0f
Serial.println("UDP transmission finished.");
// SETUP
while (!Serial) {
delay(10);
AudioLogger::instance().begin(
Serial,
AudioLogger::Info
Serial.println("\nReSpeaker 44mm UDP Audio Test");
// 1. Connect WiFi
if (!connectWiFi()) {
while (true) delay(1000);
// 2. Initialize UDP
if (!udp.begin(0)) {
Serial.println("UDP initialization failed!");
Serial.println("UDP initialized");
// 3. Initialize I2S
if (!setupI2SInput()) {
delay(500);
// 4. Record and transmit
recordAndSendAudio();
// LOOP
// One-time recording test
Open the Serial Monitor at 115200 baud to confirm the Wi-Fi connection and the streaming progress.
Packet Format
| Bytes | Field | Value |
| 0–3 | Magic | AUD0 (ASCII) |
| 4–7 | Sequence number | Little-endian uint32, starts at 0 |
| 8–1031 | Audio payload | 1024 bytes of raw 32-bit stereo PCM |
With 48 kHz × 2 channels × 4 bytes, one second is 384,000 bytes; five seconds is 1,920,000 bytes, or 1,875 packets of 1024 bytes.
Python Script (receive and save the audio)
Save this as udp_receiver.py and run it on the PC before resetting the board.
import socket
import struct
import wave
import time
# UDP CONFIGURATION
UDP_IP = "0.0.0.0"
UDP_PORT = 12345
PC_IP = "192.168.1.100"
# AUDIO CONFIGURATION
SAMPLE_RATE = 48000
CHANNELS = 2
SAMPLE_WIDTH = 4
RECORD_SECONDS = 5
BYTES_PER_SECOND = (
SAMPLE_RATE * CHANNELS * SAMPLE_WIDTH
EXPECTED_BYTES = BYTES_PER_SECOND * RECORD_SECONDS
# Arduino sends 1024-byte audio chunks
CHUNK_SIZE = 1024
EXPECTED_PACKETS = EXPECTED_BYTES // CHUNK_SIZE
# Packet header:
# 4 bytes magic + 4 bytes sequence number
HEADER_SIZE = 8
OUTPUT_FILE = "respeaker_recording.wav"
# UDP SOCKET
sock = socket.socket(
socket.AF_INET,
socket.SOCK_DGRAM
# Allow reuse of port
sock.setsockopt(
socket.SOL_SOCKET,
socket.SO_REUSEADDR,
1
sock.bind((UDP_IP, UDP_PORT))
sock.settimeout(5.0)
print("======================================")
print("ReSpeaker 44mm UDP Audio Receiver")
print(f"Listening on: {UDP_IP}:{UDP_PORT}")
print(f"PC IP: {PC_IP}")
print(f"Sample rate: {SAMPLE_RATE}")
print(f"Channels: {CHANNELS}")
print(f"Bit depth: {SAMPLE_WIDTH * 8}")
print(f"Expected duration: {RECORD_SECONDS} seconds")
print(f"Expected packets: {EXPECTED_PACKETS}")
print("\nWaiting for ESP32 audio transmission...")
# AUDIO STORAGE
audio_data = bytearray()
expected_sequence = 0
received_packets = 0
missing_packets = 0
duplicate_packets = 0
invalid_packets = 0
end_received = False
last_packet_time = time.time()
# RECEIVE UDP PACKETS
try:
while True:
try:
data, addr = sock.recvfrom(2048)
# Check packet size
if len(data) < HEADER_SIZE:
invalid_packets += 1
continue
# Decode packet header
magic, sequence = struct.unpack(
"<4sI",
data[:HEADER_SIZE]
# End-of-transmission marker
if magic == b"END0":
print("\nEnd-of-transmission received.")
end_received = True
break
# Check packet identifier
if magic != b"AUD0":
print("Invalid packet identifier")
continue
payload = data[HEADER_SIZE:]
if len(payload) != CHUNK_SIZE:
print(
f"Unexpected payload size: {len(payload)}"
continue
# Handle missing packets
if sequence > expected_sequence:
lost = sequence - expected_sequence
missing_packets += lost
print(
f"Missing {lost} packet(s) before "
f"sequence {sequence}"
# Insert silence for missing audio
audio_data.extend(
bytes(lost * CHUNK_SIZE)
# Ignore duplicate or out-of-order packets
elif sequence < expected_sequence:
duplicate_packets += 1
print(
f"Duplicate/late packet: {sequence}"
continue
# Store audio payload
audio_data.extend(payload)
expected_sequence = sequence + 1
received_packets += 1
# Progress
if received_packets % 375 == 0:
duration = (
len(audio_data) / BYTES_PER_SECOND
print(
f"Received: {received_packets} packets | "
f"{duration:.2f} seconds"
except socket.timeout:
if received_packets > 0:
print("\nReceiver timeout.")
break
print("Still waiting for ESP32...")
except KeyboardInterrupt:
print("\nRecording stopped by user.")
finally:
sock.close()
# SAVE WAV FILE
print("\n======================================")
print("RECORDING STATISTICS")
print(f"Received packets: {received_packets}")
print(f"Missing packets: {missing_packets}")
print(f"Duplicate packets: {duplicate_packets}")
print(f"Invalid packets: {invalid_packets}")
print(f"End marker received: {end_received}")
print(f"Total audio bytes: {len(audio_data)}")
print(
f"Audio duration: "
f"{len(audio_data) / BYTES_PER_SECOND:.2f} seconds"
if len(audio_data) > 0:
# Ensure complete stereo frames
audio_data = audio_data[
:len(audio_data) - len(audio_data) % 8
print(f"\nSaving WAV: {OUTPUT_FILE}")
with wave.open(OUTPUT_FILE, "wb") as wav:
wav.setnchannels(CHANNELS)
wav.setsampwidth(SAMPLE_WIDTH)
wav.setframerate(SAMPLE_RATE)
wav.writeframes(audio_data)
print("WAV saved successfully!")
else:
print("No audio received!")
print("\nReceiver finished.")
The receiver ends on the 5-second socket timeout rather than an end marker, because the sketch does not send the optional END0 packet. End marker received: False in the statistics is therefore normal.
Expected Output
Arduino Serial Monitor:
Connecting to WiFi: Your-SSID
WiFi connected!
ESP32 IP: 192.168.1.42
PC destination: 192.168.1.100
UDP port: 12345
UDP initialized
Initializing I2S...
Channels: 2
Bit depth: 32-bit
Recording duration: 5 seconds
Expected audio: 1920000 bytes
Sent: 384000 / 1920000 bytes (1.00 sec)
Sent: 768000 / 1920000 bytes (2.00 sec)
Sent: 1152000 / 1920000 bytes (3.00 sec)
Sent: 1536000 / 1920000 bytes (4.00 sec)
Sent: 1920000 / 1920000 bytes (5.00 sec)
Total audio bytes: 1920000
Successful packets: 1875
Failed packets: 0
Elapsed time: 5.02 seconds
Average data rate: 382.47 KB/s
Python receiver:
Listening on: 0.0.0.0:12345
PC IP: 192.168.1.100
Sample rate: 48000
Channels: 2
Bit depth: 32
Expected duration: 5 seconds
Expected packets: 1875
Received: 375 packets | 1.00 seconds
Received: 750 packets | 2.00 seconds
Received: 1125 packets | 3.00 seconds
Received: 1500 packets | 4.00 seconds
Received: 1875 packets | 5.00 seconds
Receiver timeout.
Received packets: 1875
Missing packets: 0
Duplicate packets: 0
Invalid packets: 0
Audio duration: 5.00 seconds
Saving WAV: respeaker_recording.wav
Receiver finished.
Listening to the Audio
Open respeaker_recording.wav in any audio player — VLC, Windows Media Player, or Audacity for inspection. It is 48 kHz, stereo, 32-bit PCM.
