reSpeaker Clip AI Chat System Architecture
A plain-language guide to how the reSpeaker Clip AI Agent chat system works. Everything here is derived from the README and the actual code in backend/.
reSpeaker Clip
1. Overview​
The system is a voice-first AI assistant built on Flask + LangGraph + Groq. You speak or type a message, the agent decides how to handle it, optionally calls tools, produces an answer, and speaks the reply back to you.
The pipeline at a glance:
Three ideas make this work:
  • A router classifies every request into one of three paths.
  • An agent on one of those paths can call tools (web search, calculator, Notion, past-conversation search).
  • A vector store + memory layer lets the agent recall your past conversations and long-term facts.
2. System Architecture Diagram​
The pieces fit together like this:
  • Flask is the API surface (chat, streaming, voice, TTS).
  • LangGraph is the state machine that routes the request and runs the chosen node.
  • Groq provides the LLM, speech-to-text (Whisper), and text-to-speech (Orpheus).
  • Mem0 supplies long-term memory; Pinecone + local embeddings supply past-conversation search.
  • Supabase (with a SQLite fallback) stores conversations, messages, and summaries.
3. The Three Routing Paths​
Every request is routed to exactly one of three nodes. The code maps the route string to a node in backend/graph/graph.py:
simple — No-context chat​
  • A plain LLM response. No tools, no special personality.
  • Used for general questions, explanations, and normal conversation.
  • Node: simple_node (backend/graph/nodes/simple.py), LLM = the main Groq model.
context — Agentic (tool-enabled)​
  • The request may need external information or a tool (web, math, Notion, past conversations).
  • This node builds a LangChain agent with create_agent and lets the model call tools in a loop.
  • Node: agentic_node (backend/graph/nodes/agentic.py), LLM = a dedicated tool-calling model (gpt-oss-20b).
persona — Styled​
  • The user explicitly asks for a style, personality, role, or teaching style.
  • Same mechanics as simple, but with a different system prompt that tells the model to adapt its tone.
  • Node: persona_node (backend/graph/nodes/persona.py), LLM = the main Groq model.
4. Classification Logic​
Routing happens in router_node (backend/graph/router.py) using a keyword pre-check followed by an LLM classification.
  1. Keyword pre-check (fast path). The transcript is scanned for tool keywords. If any match, the route is forced to context and the LLM is skipped entirely:
    notion, to-do, todo, task list, to do list, calendar,
    schedule, reminder, note down, create a task, add a task
    Example: "add a task to my to-do list" never even reaches the classifier.
  2. LLM classification. Otherwise the request is sent to the main Groq model with the ROUTER_PROMPT, which is a classifier prompt returning exactly one word:
    RouteTriggering input
    simpleGeneral questions, explanations, normal conversation, no tools/persona needed
    contextMay need external info/tools, data management (Notion/calendar), questions about the user's device/files/stored info
    personaUser explicitly requests a style, personality, teaching style, role or behavior
  3. Fallback. The output is lower-cased and trimmed. Anything not in {simple, context, persona} falls back to simple.
5. The Agentic Tool System​
How tool calling works​
The context path uses LangChain's create_agent (backend/graph/nodes/agentic.py). The loop looks like:
Details worth noting:
  • The agent is cached and rebuilt only if the tool signature changes (_get_agent).
  • Retry logic: up to MAX_RETRIES = 3 attempts; transient tool_use_failed errors are retried with a 1s sleep.
  • Guard rail: recursion is capped at MAX_AGENT_ITERATIONS = 10. If the limit is hit, the agent returns a fixed "I hit my limit…" message instead of crashing.
  • The system prompt tells the model to use the minimum number of tool calls and answer as soon as it has enough info.
  • During SSE streaming, each tool call is surfaced to the UI as a thinking event ({"tool": "web_search"}).
Available tools​
get_available_tools() (backend/tools/registry.py) returns everything the agent can call:
ToolBacking servicePurposeConfig key(s)
calculatorlocal, safe AST evalMath via a whitelisted + - * / ** % evaluator— (always available)
search_conversationsPinecone + local embeddingsFind the user's own past conversations by relevancePINECONE_API_KEY
composio_searchComposioSearch for Composio app tools matching a natural-language requestCOMPOSIO_API_KEY
composio_executeComposioRun a matched tool by slug with JSON argssame
composio_connectComposioAuthorize a toolkit (e.g. github) via a Connect Linksame
web_searchTavilyLive/current web info (news, firmware, product details)TAVILY_API_KEY
add_todoNotionAdd a task to the to-do listNOTION_API_KEY / NOTION_DATABASE_ID
list_todosNotionList tasks with statussame
complete_todoNotionMark a task done (matches by name/keyword)same
delete_todoNotionDelete a task (matches by name/keyword)same
  • The Notion tools are only added if Notion is configured.
  • Tools that are unconfigured return a friendly message (for example, "Web search is unavailable…"), so the system degrades gracefully.
Configured Tools​
6. Vector Search Deep Dive​
Configuration​
All vector settings live in config.py / .env:
SettingDefaultMeaning
PINECONE_API_KEY—Enables vector search
PINECONE_INDEX_NAMEconversationsPinecone index name
PINECONE_CLOUDawsServerless cloud provider
PINECONE_REGIONus-east-1Serverless region
EMBEDDING_MODELall-MiniLM-L6-v2Local sentence-transformers model
EMBEDDING_DIM384Vector dimension (must match the index)
On startup, init_index() auto-creates the Pinecone index if it doesn't exist (dimension 384, metric cosine, serverless).
What gets embedded vs. stored as metadata​
The design keeps vectors small and puts everything else in metadata:
  • Embedded (vector): "<title>\n\n<overview>" — a short semantic summary of the conversation.
  • Metadata: user_id, conversation_id, title, created_at.
  • Not in the vector store at all: the full transcript. The actual conversation turns live in Supabase/SQLite and are fetched by id after a match.
The vector id is "{user_id}-{conversation_id}", so it's stable per user per conversation.
Vector creation (write path)​
After every chat/voice turn, the system fires a background thread (index_conversation_async → summarize_and_index in backend/services/conversation_service.py):
Details:
  • Conversations with fewer than MIN_TURNS = 2 turns are skipped.
  • The title/overview is generated by the main Groq LLM using a two-line prompt (Title: / Overview:).
  • Embeddings are normalized (cosine-friendly).
  • All of this is async (a daemon thread), so the user's response is never blocked on indexing.
Vector query (read path)​
When the agent calls search_conversations, the flow is:
Key points:
  • The query is embedded with the same local model, then searched with a user_id filter so users only ever see their own conversations.
  • Matching returns id + score + metadata; the full summaries are pulled from the relational store by id.
  • Matches are formatted with their similarity score so the agent can judge relevance.
7. Memories System​
Long-term memory uses Mem0, scoped to a single user (MEM0_USER_ID, default user-1).
Memory categories​
There are no hard-coded buckets in code; instead, MEM0_CUSTOM_INSTRUCTIONS tells Mem0 which durable facts to extract, in priority order:
  1. Health constraints & allergies — especially anything a doctor advised (interpreted as applying to the user).
  2. Schedule — meetings, appointments, reminders.
  3. Preferences and personal details.
Explicitly excluded: the assistant's own responses/recipes/explanations, and transient one-off requests.
Memory retrieval in chat​
Proactive recall happens on every request, before routing (recall(text) in backend/routes/chat.py):
  1. The incoming message is sent to Mem0's semantic search (top_k = 5).
  2. Results are filtered by a two-tier relevance check on the score breakdown:
    • semantic ≥ 0.28 → keep, OR
    • semantic ≥ 0.24 and bm25 > 0.01 (a keyword-boosted hit) → keep.
  3. Surviving memories are sorted by created_at (newest first) and formatted as:
    Relevant context from your past conversations:
    - <memory text> (created 2026-08-30)
  4. That block is prepended to the user message before it reaches any node — so the LLM sees it as context but is told to use it only when directly relevant to the topic.
Writing happens after every exchange (save_exchange): the user/assistant pair is sent to Mem0 with the custom instructions. Memory save and recall both fail gracefully (logged, ignored) if the Mem0 key is missing.
8. Chat Session and Context​
Session structure​
A "session" is a conversation stored relationally (Supabase PostgreSQL, or SQLite fallback). The schema:
  • users — id, email (single user, user-1, seeded).
  • conversations — id, user_id, title, overview, action_items, timestamps.
  • messages/turns — conversation_id, role (user/assistant), content, timestamp.
Flow for one turn:
  1. Create (or reuse) a conversation → conversation_id.
  2. Load context: recall() memories + get_recent_messages(conversation_id, 10) history.
  3. Build the AgentState, run it through the LangGraph.
  4. After the response: save both turns, save the exchange to Mem0, and kick off async vector indexing.
Context window​
The context assembled for the LLM is intentionally small and layered:
ComponentSourceSize
System promptper-path constant (simple/persona/agent SYSTEM_PROMPT)fixed
Conversation historyget_recent_messages(conversation_id, 10)last 10 turns (10 user + 10 assistant messages), chronological
Recalled memoriesMem0 recall(), top-5, filteredup to 5 memories
Current user messageformat_memories(...) + transcriptthe request
Notes:
  • History comes from the relational store, not the vector store (the vector store holds summaries, not turns).
  • Memories are injected inline with the user message, so the model treats them as "relevant context from your past conversations."
  • The agent path builds messages as [history..., ("user", memories + transcript)] and lets the agent loop with tools.
9. System Prompt Structure​
There are four system prompts:
PromptWhereUsed byJob
ROUTER_PROMPTbackend/graph/router.pyrouter classificationReturn one word: simple / context / persona
SIMPLE_PROMPT (simple.py)backend/graph/nodes/simple.pysimple_nodeHelpful voice assistant, plain chat
PERSONA_PROMPT (persona.py)backend/graph/nodes/persona.pypersona_nodeSame as simple but adapts style/teaching to the user's request
SYSTEM_PROMPT (agentic)backend/graph/nodes/agentic.pyagentTool-enabled assistant; explains each tool and when to use it
The simple, persona, and agentic prompts share a common house style tail:
  • Respond in 2–3 short sentences maximum.
  • Plain text only — no markdown, no asterisks, no emojis.
  • Recalled memories are used only when directly relevant to the topic (schedule vs. food separation is explicitly enforced).
  • On conflicts, trust the most recently created memory.
  • When the user states a new fact, acknowledge only that fact — don't echo unrelated memories.
The agentic prompt additionally:
  • Names the tools (web_search, calculator, search_conversations, Notion tools).
  • Instructs minimal tool calls — stop once enough information is gathered.
  • Keeps the short, plain-text answer format.
10. LLM Models Used​
All models run on Groq. Defined in backend/llm/client.py, config.py, and groq_client.py:
RoleEnv varDefault modelTemperatureNotes
Main LLM (router, simple, persona, summaries)GROQ_LLM_MODELqwen/qwen3.6-27b0.7ChatGroq instance llm
Agent / tool-calling LLMGROQ_AGENT_MODELopenai/gpt-oss-20b0.0ChatGroq instance agent_llm, used by create_agent
Speech-to-textGROQ_STT_MODELwhisper-large-v30.0Whisper transcription
Text-to-speechGROQ_TTS_MODELcanopylabs/orpheus-v1-english—Voice = TTS_VOICE (autumn)
Embeddings (local, not Groq)EMBEDDING_MODELall-MiniLM-L6-v2—sentence-transformers, 384-dim, normalized
LLM inference defaults (via groq_client.chat): max_completion_tokens = 2048, top_p = 1.0, temperature overridable.
11. Agent Call Demonstration​
Read Email​
Add Calendar​
