reSpeaker Clip Basic SDK Guide
reSpeaker Clip
Version: matches clip package __version__ = 1.0.0
Product: reSpeaker Clip wearable recorder
Overview​
The reSpeaker Clip Basic SDK Guide explains how host-side applications communicate with and control the device through BLE, Wi-Fi, AT commands, GATT, and file-transfer workflows. The Python SDK is provided as the primary reference implementation, together with CLI and Web-based tools.
This guide covers:
  • Transports — BLE and Wi-Fi/UDP communication channels.
  • Communication protocols — AT commands, GATT characteristics, and file-transfer framing.
  • Recording model — recording modes, device state machine, and file format.
  • End-to-end data flow — from connect to downloaded audio output.
  • Reference implementations — Python SDK (clip package), CLI tools, and a Web interface.
The Basic SDK focuses on using the device's current capabilities from the host side. It does not include cloud transcription, AI summarization, account management, or mobile app services by themselves. Those workflows should be built on top of the downloaded audio files or integrated with another service.
Where This Guide Fits​
If you are new to reSpeaker Clip, first read the reSpeaker Clip Getting Started Guide.
The Getting Started Guide introduces the product, target scenarios, hardware capabilities, and normal user workflows.
This guide focuses on application-side development:
  • communicating with the device over BLE or Wi-Fi;
  • controlling recording and device configuration;
  • managing and downloading recording sessions;
  • understanding AT commands, GATT, and file-transfer protocols;
  • integrating these capabilities through Python, CLI, or Web tools.
Choose the Right reSpeaker Clip Guide​
The reSpeaker Clip documentation is organized by development layer. Start with Getting Started for product setup and normal workflows. Use the Basic SDK when a host application needs to control the device or download recordings. Continue to Service Integration when a long-running service needs to own the device connection and expose APIs. Use the Firmware SDK only when you need to change device-side behavior, protocols, or audio processing.
Installation​
Requirements​
  • Python 3.10+
  • Bluetooth adapter (BLE mode)
  • Wi-Fi adapter (Wi-Fi mode)
Clone the Repository​
You can find the GitHub repository here.
git clone <repository-url>
Install Dependencies​
After activating the virtual environment, install the required dependencies:
Project Structure​
applications/clip/tests/
├── clip/ SDK library (importable)
│ ├── __init__.py
│ ├── client.py BLE connection + AT command transport
│ ├── commands.py High-level AT command wrappers
│ ├── transfer.py BLE file transfer + SessionSync
│ ├── codec.py Opus/Ogg codec utilities
│ ├── wifi.py WiFi UDP transport + WiFiSync
│ ├── progress.py Progress bar helpers
│ ├── utils.py File merge, formatting utilities
│ └── exceptions.py Custom exception classes
├── tools/ CLI & utility scripts
│ ├── clip-cli.py Main CLI (BLE + WiFi + USB)
│ ├── clip-web.py Web interface
│ ├── record.py Recording control tool
│ ├── sync.py File sync helper
│ ├── udp_sync.py WiFi UDP sync
│ ├── udp_terminal.py WiFi UDP terminal
│ ├── ble_terminal.py BLE interactive terminal
│ ├── serial_terminal.py USB CDC serial terminal
│ └── decode_opus.py Opus decode utility
├── tests/ Test suite
│ ├── conftest.py Shared fixtures (device_session, mock_device)
│ ├── test_basic.py AT commands: VERSION, STATE, TIME, PAIR, errors
│ ├── test_config.py Configuration: MODE, AUTODEL, BRIGHTNESS
│ ├── test_recording.py Recording: START/STOP, bookmarks, state transitions
│ ├── test_storage.py Storage: LIST, DELETE, persistence, file count
│ ├── test_transfer.py Transfer: download, sync, progress, concurrent
│ └── test_unit.py Unit tests (no device required)
├── workspace/ Example workspace scripts
│ └── complete_example.py
├── requirements.txt
├── README.md
└── pytest.ini
SDK Modules​
ModuleDescription
client.pyBLE device communication
commands.pyHigh-level AT commands
transfer.pyFile synchronization
codec.pyAudio encoding/decoding
wifi.pyWiFi transport
progress.pyProgress display
utils.pyHelper functions
exceptions.pyException classes
SDK Capabilities​
The Python SDK supports the following workflows:
  • Configure the device: recording mode, bitrate, complexity, auto-delete policy, OLED brightness, BLE device name, and related settings.
  • Control recording: start, stop, pause, resume, and add bookmarks.
  • Manage sessions: list, query, delete, purge, and format the SD card.
  • Download files: transfer recordings over BLE or Wi-Fi/UDP, with resume support.
  • Convert audio: re-container device raw Opus data into OGG/Opus, or decode to 16 kHz mono WAV through an Opus decoding path.
  • Read status and events: battery level, charging state, device state, state-machine changes, and real-time audio-visualization callbacks.
Transport choice matters:
  • Use BLE through ClipDevice for portable configuration, recording control, and small downloads.
  • Use Wi-Fi/UDP through WiFiDevice or WiFiSync for bulk downloads. It is faster and more stable for large recording sessions.
  • Recording control is BLE-only. File download works on both BLE and Wi-Fi.
Core Concepts​
This section describes the host-side view used by the Basic SDK. For the device-side implementation details, see the matching Firmware Development Guide sections:
Basic SDK topicDetailed firmware explanation
TransportsCommunication Protocol
Recording modesRecording Modes
Device stateEvent and State Model
File format and sessionsSession, Chunking, and Storage Model
AT command protocolAT Command Grammar, JSON Response Contract, and Registered Command Reference
GATT characteristicsBLE GATT Service
File transfer and resumeUDP Frame Types and Session and File Addressing
End-to-end data flowSystem Architecture and Audio Pipeline
Transports​
TransportClassUse caseNotes
BLEClipDeviceConfiguration, recording control, session downloadPortable and required for recording control. Bulk download can be slower and may drop notifications under load.
Wi-Fi/UDPWiFiDevice / WiFiSyncBulk session downloadFaster and more stable for large files. Requires enabling Wi-Fi on the device and joining ClipAP_XXXX.
Recording Modes​
ModeDescription
normalStandard recording path without SpeexDSP noise suppression / dereverb. Device AGC, high-pass, and limiter may still be enabled by firmware.
enhancedEnhanced path with SpeexDSP noise suppression and dereverb enabled.
set_mode() accepts only normal and enhanced. start_recording() also accepts the aliases stereo and merge; stereo maps to normal, and merge maps to enhanced.
Both modes output mono 16 kHz Opus by default.
Device State​
A recording is represented as a session. A session ID is usually a timestamp-style string such as YYYYMMDDHHMMSS.
IDLE --start_recording--> RECORDING --stop_recording--> IDLE
| pause / resume
v
PAUSED
Common device states include IDLE, RECORDING, TRANSMITTING, PAUSED, and ERROR.
On connection, the SDK can synchronize the device clock through AT+TIME. The device timezone may still differ from the host timezone.
File Format​
The device stores recording data as raw Opus frames, not as an OGG container. The raw format is a sequence of length-prefixed Opus frames:
[2-byte little-endian length][opus frame][2-byte little-endian length][opus frame]...
Use convert_to_ogg_opus() to write a valid .ogg file before passing the recording to tools that expect OGG/Opus input. WAV decoding requires an Opus decoder path such as opuslib.
AT Command Protocol​
  • The SDK writes a UTF-8 AT string, for example AT+MODE=enhanced, to the CMD characteristic.
  • Responses are JSON notifications on RESP_SEND, for example {"ok":true,"data":{...}}.
  • Unsolicited events, such as state changes, look like {"event":"state","state":"RECORDING",...} and are dispatched through event_callback.
GATT Characteristics​
CharacteristicUUIDPropertiesPurpose
Service6E400001-B5A3-F393-E0A9-E50E24DCCA9EPrimary ServiceCustom BLE communication service
CMD6E400002-B5A3-F393-E0A9-E50E24DCCA9EWrite Without Response (Encrypted)Central → device: write AT command strings
RESP_SEND6E400003-B5A3-F393-E0A9-E50E24DCCA9ENotify (CCC Encrypted)Device → central: JSON responses and event notifications
FILE_DATA6E400004-B5A3-F393-E0A9-E50E24DCCA9ENotify (CCC Encrypted)Device → central: binary file-transfer frame notifications
AUDIO_VIS6E400005-B5A3-F393-E0A9-E50E24DCCA9ENotify (CCC Encrypted)Device → central: real-time audio-visualization notifications
File-Transfer Protocol​
File data is delivered as binary frames on FILE_DATA.
FrameTypeLayout
FILE_START0x10type(1) + fn_len(1) + filename(N) + file_size(4, LE)
DATA0x01type(1) + seq(2, LE) + len(2, LE) + data(N)
FILE_END0x11type(1) + crc32(4, LE)
TRANSFER_DONE0x12type(1) + sid_len(1) + session_id(N) + file_count(4, LE)
Each file is verified with CRC32. Only verified files should be treated as successfully saved.
Resume​
SessionSync.sync() is resume-aware. It can detect existing local .opus files, query the device's synced-file counter, compute start_file, and continue a previous download. Use force=True to start from scratch.
Data Flow​
reSpeaker Clip data flow
Complete Example​
This example demonstrates a typical workflow:
  1. Auto-connect via BLE
  2. Check battery level
  3. Set recording mode to enhanced
  4. Start a 10-second recording
  5. Add a bookmark mid-recording
  6. Stop recording
  7. Sync the session files to recordings/<session_id>/
Complete workflow: connect → config → record → bookmark → stop → sync
Usage:
python workspace/complete_example.py
import asyncio
import sys
from pathlib import Path
# Ensure the parent 'tests/' directory (which contains clip/) is on sys.path
sys.path.insert(0, str(Path(__file__).parent.parent))
from clip import ClipDevice, ClipCommands, SessionSync
from clip import ConnectionError, TimeoutError, CommandError
async def main():
try:
async with ClipDevice() as device:
cmds = ClipCommands(device)
# 1. Check battery and current settings
state = await cmds.get_state()
print(f"Battery: {state.battery}%, Mode: {state.mode}")
# 2. Configure (only MODE, AUTODEL, BRIGHTNESS work on current firmware)
await cmds.set_config_dict({"mode": "enhanced"})
# 3. Start recording in enhanced mode
session_id = await cmds.start_recording("enhanced")
print(f"Recording started: {session_id}")
# 4. Wait and add a bookmark
await asyncio.sleep(5)
bookmark = await cmds.add_bookmark()
print(f"Bookmark added at {bookmark.offset}s")
# 5. Let it record more, then stop
await cmds.stop_recording()
print("Recording stopped")
# 6. Sync session via BLE
sync = SessionSync(device)
result = await sync.sync(session_id, Path("recordings"))
print(
f"Downloaded {result['file_count']} file(s)"
f" → recordings/{session_id}/"
except ConnectionError:
print("Could not find device. Is it powered on and paired?")
except TimeoutError:
print("Device did not respond. Try restarting the Clip.")
except CommandError as e:
print(f"Command error: {e.message}")
if __name__ == "__main__":
asyncio.run(main())
Expected output
Battery: 85%, Mode: normal
Recording started: 20260710_144500
Bookmark added at 5s
Recording stopped
Downloaded 2 file(s) → recordings/20260710_144500/
Snippets Overview​
Connection​
Connect to the Device​
import asyncio
async def main():
print(state.battery)
asyncio.run(main())
The SDK auto-discovers nearby devices whose name contains Clip.
Connect to a Specific Device​
import asyncio
async def main():
device = ClipDevice(address="AA:BB:CC:DD:EE:FF")
await device.connect()
# ... use device ...
await device.disconnect()
asyncio.run(main())
Device Information​
Read Firmware Version​
version = await cmds.get_version()
print(version.firmware) # e.g. "v1.0.0"
print(version.hardware) # e.g. "Clip v0.0.5"
Read Device State​
print(state.state) # IDLE, RECORDING, TRANSMITTING, PAUSED, ERROR
print(state.battery) # 0-100
print(state.mode) # normal, enhanced
print(state.bitrate) # Opus bitrate in bps
Read / Set Device Time​
import time
timestamp = await cmds.get_time() # returns int (Unix timestamp)
await cmds.set_time(int(time.time())) # returns True
Recording Audio​
Start / Stop Recording​
session_id = await cmds.start_recording("normal")   # returns str (session ID)
# ... record ...
await cmds.stop_recording() # returns dict with session info
"normal" is mono, "enhanced" enables DSP preprocessing (noise suppression, AGC).
Pause / Resume Recording​
await cmds.pause_recording()
await cmds.resume_recording()
Add Bookmark (during recording)​
print(bookmark.offset) # seconds from recording start
Full Recording Example​
await asyncio.sleep(10)
File Synchronization​
List Sessions​
sessions = await cmds.list_sessions()
for s in sessions:
print(s.id, s.files, s.size)
Sync a Session (BLE)​
from clip import SessionSync
session_id = "20260326120000" # from cmds.list_sessions()
Resume Interrupted Download​
await sync.sync(
session_id,
Path("recordings"),
start_file="0015.opus" # pick up where you left off
Keep Files on Device After Sync​
await sync.sync(
session_id,
Path("recordings"),
delete_after=False # default: False (keep on device)
Sync All Sessions​
results = await sync.sync_all(Path("recordings"))
Configuration Management​
Set Parameters (working commands)​
await cmds.set_mode("enhanced")          # normal | enhanced
await cmds.set_auto_delete(7) # days (0-30), pass -1 to disable
await cmds.set_brightness(128) # 0-255
Read Parameters​
mode        = await cmds.get_mode()          # returns str
auto_delete = await cmds.get_auto_delete() # returns bool
brightness = await cmds.get_brightness() # returns int
Batch Configuration​
"mode": "enhanced",
"auto_delete": 7,
"brightness": 128,
WiFi Communication​
The Clip can communicate over WiFi UDP when its AP is enabled.
ParameterValue
SSIDClipAP_XXXX
Password12345678 (default)
IP192.168.4.1
Port8089
Connect and Send AT Commands​
from clip import WiFiDevice
async def main():
async with WiFiDevice("192.168.4.1", 8089) as device:
resp = await device.send_command("AT+GSTAT")
print(resp)
asyncio.run(main())
Sync a Session over WiFi (blocking API)​
from clip import WiFiSync
sync = WiFiSync("192.168.4.1", 8089)
sync.connect()
sync.download_session(session_id, Path("recordings"))
sync.disconnect()
WiFiSync is synchronous (blocking sockets) — no need for async/await.
Error Handling​
try:
print("Device not found or could not connect")
print("Device did not respond in time")
print(f"Command failed: {e.message}")
Command Line Tools​
The SDK includes several ready-to-use utilities.
clip-cli -Unified CLI​
BLE (default)​
General-purpose CLI.
tools/clip-cli.py status
Expected output
Device Connection
tools/clip-cli.py version
tools/clip-cli.py list
Expected output
Device Connection
tools/clip-cli.py record --duration 60
Expected output
Device Connection
tools/clip-cli.py sync --session 20260326120000
Expected output
Device Connection
tools/clip-cli.py sync --session 20260326120000 --delete
Expected output
Device Connection
tools/clip-cli.py config get
Expected output
Device Connection
tools/clip-cli.py bookmark
tools/clip-cli.py terminal
Expected output
Device Connection
WiFi​
 tools/clip-cli.py wifi on
Expected output
Device Connection
tools/clip-cli.py --transport wifi status
Expected output
Device Connection
tools/clip-cli.py  wifi off
Expected output
Device Connection
record.py​
Automatically records audio and synchronizes it.
python tools/record.py
python tools/record.py --duration 60
python tools/record.py --mode enhanced
Expected output
Device Connection
sync.py​
Synchronize recordings via BLE.
python tools/sync.py
python tools/sync.py --all-sessions
Expected output
Device Connection
udp_sync.py​
Synchronize recordings via WiFi.
python tools/udp_sync.py
python tools/udp_sync.py --session 20260326120000
Expected output
Device Connection
ble_terminal.py​
Interactive AT command terminal.
python tools/ble_terminal.py
Expected output
Device Connection
decode_opus.py​
Convert Opus recordings to WAV.
python tools/decode_opus.py <input_file.opus> <output_file.wav>
Web Interface​
Launch the built-in web application.
BLE mode:
python tools/clip-web.py
Wi-Fi mode:
python tools/clip-web.py --transport wifi
Then open:
http://localhost:5000
Features​
  • Device status
  • Recording control
  • Session management
  • Audio visualization
  • Configuration editor
  • Sync progress
REST API​
MethodEndpoint
GET/api/status
GET/api/version
GET/api/sessions
POST/api/record/start
POST/api/record/stop
POST/api/record/bookmark
POST/api/sync/{id}
DELETE/api/sessions/{id}
GET/api/config
PUT/api/config
WS/ws
Core Modules​
ModuleMain purpose
ClipDeviceBLE connection, pairing, AT command transport, notifications, and transfer progress
ClipCommandsHigh-level wrapper for device AT commands
FileTransfer / SessionSyncBLE session download and resume-aware synchronization
WiFiDevice / WiFiSyncWi-Fi/UDP download workflow for larger transfers
codecRaw Opus frame parsing and OGG/Opus writing
utilsSession ID parsing, formatting helpers, config loading, progress reporting, and file utilities
exceptionsSDK-specific exception classes
API Reference​
ClipDevice​
BLE device communication and connection management.
SignatureReturnsNotes
ClipDevice(address=None, name_filter="Clip", debug=False)ClipDeviceAuto-discovers if address is None
await connect(timeout=10.0, sync_time=True, lazy_device_name=False)None3 retries; sync_time auto-sets device clock
await disconnect()NoneStops all BLE notifications
await send_command(command, timeout=10.0)dictSend AT command, get JSON response
is_connectedboolProperty — checks both _connected and client.is_connected
device_name`strNone`
await __aenter__() / await __aexit__()ClipDevice / NoneAsync context manager
ClipCommands​
High-level AT command interface.
await get_version()VersionInfo.firmware, .hardware, .sdk, .build
await get_state()DeviceState.state, .battery, .mode, .bitrate, .charging, .free_space
await get_time()intUnix timestamp
await set_time(timestamp)boolConverts to AT+TIME=<ts>
await get_pairing_status()Dict[str, Any]BLE pairing status + peer address
await reboot()NoneDevice reboot
Recording
await start_recording(mode="normal")strmode: normal, enhanced, stereo, merge. Returns session ID.
await stop_recording()Dict[str, Any]Session summary; handles device-not-recording gracefully
await pause_recording()bool
await resume_recording()bool
await add_bookmark()BookmarkInfo.offset in seconds from session start
await get_bookmarks(session_id, fetch_all=True)List[BookmarkInfo]Paginated, auto-fetches all pages
await get_bookmarks_count(session_id)intFast count without details
Sessions
await list_sessions(page=1, per_page=10)List[SessionInfo].id, .files, .size, .synced_files, .mode
await list_all_sessions(per_page=15)List[SessionInfo]Auto-paginates all
await get_session_info(session_id)SessionInfoIncludes synced_files count
await list_session_files(session_id)List[str]Filenames for all files in session
await delete_session(session_id)bool
await purge_all_sessions()bool
await format_sd_card()bool
Configuration
await get_mode()str
await set_mode(mode)bool"normal" or "enhanced" only
await get_auto_delete()bool
await set_auto_delete(days)booldays: 0–30, pass -1 to disable
await get_brightness()int0–255
await set_brightness(value)bool0–255
await get_device_name()strBLE device name
await set_device_name(name)boolMax 15 chars
await get_config_dict()Dict[str, Any]All settings; unsupported keys return None
await set_config_dict(config, ignore_errors=True)NoneSkips None values; silently drops unsupported keys
get/set_bitrate()—Firmware: unsupported — raises CommandError
get/set_complexity()—Firmware: unsupported — raises CommandError
get/set_chunk_size()—Firmware: unsupported — raises CommandError
get/set_noise_suppression()—Firmware: unsupported — raises CommandError
get/set_agc()—Firmware: unsupported — raises CommandError
get/set_dereverb()—Firmware: unsupported — raises CommandError
Transfer control
await get_progress()Dict[str, Any]Download progress
await pause_transfer()bool
await resume_transfer()bool
await cancel_transfer()bool
WiFi / USB
await wifi_on()bool20+ second timeout for nRF7002 init
await wifi_off()bool
await get_wifi_status()Dict[str, Any].running, .ssid, .clients
await usb_on()boolCDC + MSC
await usb_off()bool
await get_usb_status()bool
Helpers
await ensure_idle()NoneStops recording if needed; retries up to 5x
await wait_for_state(target, timeout=10.0)boolPolls until state matches
await wait_for_recording_to_start(timeout=5.0)bool
await wait_for_recording_to_stop(timeout=5.0)bool
await get_battery_status()BatteryStatus.percent, .charging, .voltage
SessionSync​
File synchronization over BLE with resume support.
SessionSync(device, commands=None)SessionSyncExtends FileTransfer
await sync(session_id, output_dir, delete_after=False, continuous=False, force=False, progress_callback=None, session_info=None, start_file=None)Dict[str, Any]Resume auto-detected; returns file_count, total_size, files, merged_file
await sync_all(output_dir, delete_after=False, progress_callback=None)List[Dict]Syncs all sessions
await download_session(session_id, output_dir, progress_callback=None, stop_recording=False, continuous=False, timeout=300.0, start_file=None, session_info=None)Dict[str, Any]Lower-level; also saves session.json + bookmarks.json
await cancel()NoneThread-safe cancel
WiFiDevice​
WiFi UDP transport (async) — compatible with ClipDevice.send_command.
WiFiDevice(host="192.168.4.1", port=8089, timeout=10.0)WiFiDevice
await connect(timeout=None)NoneStarts recv + heartbeat worker threads
await send_command(command, timeout=None)dictJSON-parsed AT response
await __aenter__() / await __aexit__()—Async context manager
WiFiSync​
WiFi UDP file sync (blocking/synchronous — no async needed).
WiFiSync(host="192.168.4.1", port=8089, timeout=120.0)WiFiSync
connect()boolBlocking
disconnect()None
download_session(session_id, output_dir, convert_ogg=True, start_file=None, delete_after=False, progress_callback=None, cancel_after=None)boolCRC-verified; tqdm progress; press 'c' to cancel
list_sessions()List[dict]Paginated
Exceptions​
ExceptionBaseDescription
ClipErrorExceptionBase for all library errors
ConnectionErrorClipErrorBLE or WiFi connection failure
DisconnectedErrorClipErrorUnexpected disconnect
CommandErrorClipErrorAT command returned error; .command attribute
TransferErrorClipErrorFile transfer operation failed
TimeoutErrorClipErrorCommand/transfer timed out
ResponseErrorClipErrorInvalid or unexpected response
StateErrorClipErrorDevice in wrong state for operation
Troubleshooting​
Q1: Commands hang or time out after connecting.
The command characteristic requires an encrypted BLE link. The SDK can initiate pairing, but the operating system may show a Bluetooth pairing or authorization dialog. Confirm it manually. If the connection is still stuck, remove stale bonds and reconnect.
Q2: Download reports CRC mismatch or zero files.
BLE stacks may occasionally deliver duplicate notifications or drop frames under load. Disconnect, reconnect, and retry. Use SessionSync so the transfer can resume where possible.
Q3: Download is slow or drops halfway.
Use SessionSync for resume-aware BLE transfer. For large recording volumes, use Wi-Fi download through WiFiSync: enable Wi-Fi on the Clip, join ClipAP_XXXX, then download over Wi-Fi.
Q4: delete_after=True deleted a session that did not fully download.
Use the safer pattern: sync(force=True, delete_after=False), verify that the local merged_file exists and is non-empty, then manually call cmds.delete_session(session_id).
Q5: AT+NOISE, AT+DEREVERB, or AT+AGC returns Unknown command.
The current firmware may not register those optional commands. The SDK keeps wrappers for compatible firmware versions. If restoring a config, set_config_dict(..., ignore_errors=True) can skip unsupported values.
Q6: bleak raises errors such as 'BleakClient' object has no attribute 'get_services' or 'get_mtu'.
bleak APIs differ across versions. Use the SDK-tested dependency set after the installation package is released.
Q7: Recording is silent or quality is poor.
Check microphone distance and orientation, battery level, and recording mode. enhanced mode can suppress noise more aggressively, which may over-process very clean speech.
Q8: The session ID timestamp does not match local time.
The device clock or timezone may differ from the host. The SDK can sync time on connect. You can also call await cmds.set_time(int(time.time())).
Q9: How do I convert Opus to WAV for STT or ML?
Use convert_to_ogg_opus() for OGG/Opus output. For WAV, decode the raw Opus stream with an Opus decoder such as opuslib.
Q10: Logs are flooded by audio-visualization events during recording.
AUDIO_VIS notifications fire frequently. Only register the audio-visualization callback when you need it, and keep the callback lightweight.
