Customization: Add a Custom AT Command
A concrete, end-to-end walkthrough of adding a new AT command to the Clip firmware. We add a trivial-but-real command, AT+ECHO=<msg>, that replies:
{"ok":true,"data":{"echo":"<msg>"}}\n
The same recipe scales to real commands that touch config, storage, audio, or the event system.
AI prompt​
You can copy this prompt into an AI coding agent to reproduce the same customization workflow in the firmware repository:
You are working in the reSpeaker Clip firmware repository.
Use the repository Skill before editing:
1. Read `skills/clip-dev/SKILL.md` completely and follow it for firmware AT
command development, build, flash, and validation.
2. For AT protocol work, also read the referenced BLE/AT guidance from that
Skill when needed.
3. If the new command requires a Python SDK API or CLI support, read
`skills/clip-sdk/SKILL.md` and update `sdk/` plus `docs/protocol.md`
according to that Skill.
Task:
Add a new AT command named `ECHO` to the Clip firmware.
Expected behavior:
- `AT+ECHO=hello` returns `{"ok":true,"data":{"echo":"hello"}}`
- `AT+ECHO=` returns `{"ok":false,"msg":"Missing message"}`
- `AT+ECHO` returns `{"ok":false,"msg":"Use AT+ECHO=<msg>"}`
Implementation constraints:
- Modify `applications/clip/src/at_commands.c`.
- Add a `cmd_echo_handler(struct at_cmd_ctx *ctx, char *response, size_t len)`.
- Use `create_json_response(...)` so the response format matches existing
commands.
- Register the command in `at_commands_register()` with
`AT_CMD_SET | AT_CMD_EXEC`.
- Keep the example minimal. It may use `%s` for the demo response, but document
that real free-form string commands must validate or escape JSON-sensitive
input first.
- Do not change BLE, UDP, or USB transport code unless the source proves it is
necessary.
Validation:
- Build a pristine firmware image for `clip/nrf5340/cpuapp`.
- If hardware is available, flash the image and test `AT+ECHO=hello`,
`AT+ECHO=`, and bare `AT+ECHO` over at least one transport.
- Also check representative existing commands such as `AT+GSTAT`, `AT+MODE?`,
and `AT+VERSION`.
- Report exactly what was tested and do not claim hardware validation unless it
actually ran on a device.
1. Goal​
Add AT+ECHO=<msg> so that:
AT+ECHO=hello     -> {"ok":true,"data":{"echo":"hello"}}
AT+ECHO= -> {"ok":false,"msg":"Missing message"}
AT+ECHO -> {"ok":false,"msg":"Use AT+ECHO=<msg>"}
It is intentionally minimal: one SET command with a small EXEC usage hint, no side effects, verifiable on all three transports. ECHO does not collide with any registered command (see the registry in at_commands_register() below).
2. Current data flow​
An inbound AT line travels through these layers (function names are real):
transport (BLE / UDP / USB CDC)
-> at_server_submit_cmd() applications/clip/src/at_server.c
-> at_server_thread_func() dequeues from its k_msgq
-> parse_command() splits name / args / type (SET|TEST|EXEC)
-> cmd->handler(&ctx, buf, len) matched in the cmd_registry
-> create_json_response(...) builds {"ok":..,"msg":..,"data":..}
-> SEND_RESPONSE() routes the buffer back to the
transport the command arrived on
Two points matter for the customizer:
  • Parsing is shared. parse_command() (at_server.c) owns the AT+NAME=args grammar and the =, ? type detection. You never parse the AT+ prefix yourself — your handler receives ctx->args already split out.
  • Responses are auto-routed. The SEND_RESPONSE() macro in at_server.c dispatches by the command's originating transport: TRANSPORT_TYPE_USB -> usb_cdc_send_response(), TRANSPORT_TYPE_UDP -> transport_udp_send_response(), otherwise -> transport_send_to(item->transport_type, ...). Your handler only fills the response buffer; it does no transport work, and the same JSON goes out identically over BLE, UDP, and USB.
3. Extension point: the registration pattern​
Everything below is quoted from real source. The contract lives in applications/clip/include/at_server.h.
3.1 The handler signature​
From at_server.h:
typedef int (*at_cmd_handler_t)(struct at_cmd_ctx *ctx, char *response, size_t len);
The context your handler receives (at_server.h):
struct at_cmd_ctx {
const char *name; /* Command name (e.g., "ECHO") */
uint8_t type; /* Command type (SET/QUERY/EXEC) */
const char *args; /* Arguments string */
uint8_t transport_type; /* Transport type for response */
ctx->type is one of AT_CMD_TYPE_TEST (0), AT_CMD_TYPE_SET (1), AT_CMD_TYPE_EXEC (2) — also AT_CMD_TYPE_READ (3, same as TEST). Args live in ctx->args (already past the =). A real handler using exactly this shape is cmd_mode_handler (at_commands.c:422):
static int cmd_mode_handler(struct at_cmd_ctx *ctx, char *response, size_t len)
if (ctx->type == AT_CMD_TYPE_SET) {
if (!ctx->args || strlen(ctx->args) == 0) {
return create_json_response(false, "Missing mode value", NULL, response, len);
/* ...validate, mutate state... */
char data[32];
snprintf(data, sizeof(data), "{\"mode\":\"%s\"}", mode_str);
return create_json_response(true, NULL, data, response, len);
} else {
/* AT+MODE? */
char data[32];
3.2 The create_json_response helper​
From at_commands.c (the static helper every handler uses):
static int create_json_response(bool success, const char *message,
const char *data, char *response, size_t len);
Behavior (read from its body):
  • Emits {"ok":true or {"ok":false.
  • If message is non-NULL, appends ,"msg":"<message>".
  • If data is non-NULL, appends ,"data":<data> verbatim — data must be a complete JSON object you formatted yourself (e.g. {"echo":"hello"}), not a bare value or a format string. This is the common gotcha.
  • Closes with }\n and returns the total length; returns AT_ERR_NOMEM on truncation. The server thread treats ret < 0 as an error and substitutes at_server_err_msg(-ret).
So the response shape is fixed: success -> {"ok":true,...,"data":{...}}, failure -> {"ok":false,...,"msg":"..."}. There are no numeric error codes and no error field (see protocol.md).
3.3 The command struct and registration​
From at_server.h:
struct at_command {
const char *name; /* Command name */
uint8_t flags; /* Supported operations */
at_cmd_handler_t handler; /* Command handler */
Flags (bitmask; at_server.h):
#define AT_CMD_SET    (1 << 0)  /* Supports AT+CMD=... */
#define AT_CMD_QUERY (1 << 1) /* Supports AT+CMD? */
#define AT_CMD_EXEC (1 << 2) /* Supports AT+CMD */
Registration (at_server.c) — note the registry is capped at 32 commands:
int at_server_register_cmd(const struct at_command *cmd);
A real registration block, exactly as it appears in at_commands.c:1769:
/* GSTAT - Get device status */
static const struct at_command gstat_cmd = {
.name = "GSTAT",
.flags = AT_CMD_EXEC,
.handler = cmd_gstat_handler,
err = at_server_register_cmd(&gstat_cmd);
if (err) return err;
4. Files to modify​
Only one source file: applications/clip/src/at_commands.c.
4.1 Add the handler​
Place it among the other static int cmd_*_handler(...) definitions (the existing handlers sit above at_commands_register()). Modeled on cmd_mode_handler:
/* ECHO Command Handler - customization example.
* AT+ECHO=<msg> -> {"ok":true,"data":{"echo":"<msg>"}} */
static int cmd_echo_handler(struct at_cmd_ctx *ctx, char *response, size_t len)
if (ctx->type != AT_CMD_TYPE_SET) {
return create_json_response(false, "Use AT+ECHO=<msg>", NULL, response, len);
return create_json_response(false, "Missing message", NULL, response, len);
char data[160];
int n = snprintf(data, sizeof(data), "{\"echo\":\"%s\"}", ctx->args);
if (n < 0 || n >= (int)sizeof(data)) {
return AT_ERR_NOMEM;
Gotcha for real commands: ctx->args is raw user input. Interpolating it with %s (as the trivial example does) lets a " in the message break the JSON. For any command that accepts free-form strings, validate/escape the input first. The shipped commands that use %s (e.g. MODE, LOG) do so only against a fixed enumeration they already checked.
4.2 Register it​
Inside at_commands_register(void) (at_commands.c:1761) — the single init function that registers every command and is itself called once from main.c (at_commands_register() at main.c:286). Add the block alongside the others (e.g. right after the LOG block near at_commands.c:2030):
/* ECHO - echo a message back (customization example) */
static const struct at_command echo_cmd = {
.name = "ECHO",
.flags = AT_CMD_SET | AT_CMD_EXEC,
.handler = cmd_echo_handler,
err = at_server_register_cmd(&echo_cmd);
AT_CMD_EXEC is required because the handler intentionally returns a friendly usage message for bare AT+ECHO. If the registration only uses AT_CMD_SET, the dispatcher rejects AT+ECHO before the handler can run. Because the server auto-routes the response (Section 2), no BLE/UDP/USB code changes are needed.
5. Compatibility impact​
Adding a command is additive — existing commands and their JSON shapes are untouched. Keep the response contract intact:
  • Success: {"ok":true,"data":{...}}
  • Failure: {"ok":false,"msg":"..."}
  • No numeric error codes, no request ID, no error field. (See protocol.md.)
If the new command should also be reachable from the host tooling, you need Python SDK parity, not just firmware. Per the skills/clip-sdk/ rule, read the current at_commands.c registrations before changing the SDK, and treat docs/protocol.md + firmware source as the protocol contract — update both the SDK (in sdk/) and protocol.md when the firmware contract changes. Do not emulate removed legacy commands (BITRATE, COMPLEXITY, NOISE, AGC, DEREVERB, PURGE).
6. Build​
Source the NCS v3.3.0 environment, set the module path as an env var (Kconfig discovery runs before CMake), then build:
source ~/ncs/v3.3.0/zephyr/zephyr-env.sh
export ZEPHYR_EXTRA_MODULES=$(pwd)
west build --build-dir build-clip --pristine --board clip/nrf5340/cpuapp applications/clip
Per CLAUDE.md, the project builds with zero warnings — fix any compiler warning before committing. (The handler above introduces none.)
7. On-device verify​
Flash (note: west flash --reset does not work on this board — reset separately):
west flash --build-dir build-clip && nrfutil device reset
minicom -D /dev/ttyACM0 -b 921600
Then exercise the command on each transport and confirm the JSON is identical:
BLE (interactive shell — clip-cli.py terminal opens an AT prompt over BLE):
python applications/clip/tests/tools/clip-cli.py terminal
# at the prompt:
UDP (WiFi AP mode — send AT+WIFI=on over BLE first, then join the returned SSID/password and target 192.168.4.1:8089):
python applications/clip/tests/tools/udp_terminal.py
AT+ECHO=hello
USB CDC (open the CDC-ACM serial port; USB must be enabled first via AT+USB=on over BLE, or hold the user button while plugging in):
AT+ECHO=hello
The response string must match byte-for-byte across all three. Also confirm no existing command regressed — e.g. AT+GSTAT, AT+MODE?, AT+VERSION.
8. Recovery​
If the new build misbehaves, recover over USB serial DFU (1200-baud trigger into MCUboot recovery, PID 0x8069), BLE OTA, or a programmer — see usb_dfu.md. The bootloader partition is never touched by an app OTA; the signature is verified by MCUboot.
