reSpeaker Clip Control with Python
Introduction
The reSpeaker Clip SDK provides a Python interface for communicating with reSpeaker Clip devices over Bluetooth Low Energy (BLE) or WiFi.
Using this SDK you can:
  • Connect to a reSpeaker Clip
  • Read device information
  • Configure recording parameters
  • Start and stop recordings
  • Add bookmarks
  • Synchronize recordings
  • Control the device using Python
  • Use ready-made command line tools
  • Access the device through a web interface
Installation
Requirements
  • Python 3.10+
  • Bluetooth adapter (BLE mode)
  • WiFi adapter (WiFi mode)
Clone the Repository
git clone <repository-url>
cd applications/clip/tests
Install Dependencies
Project Structure
applications/clip/tests/
├── clip/
│ ├── client.py
│ ├── commands.py
│ ├── transfer.py
│ ├── codec.py
│ ├── wifi.py
│ ├── progress.py
│ ├── utils.py
│ └── exceptions.py
├── tools/
│ ├── clip-cli.py
│ ├── clip-web.py
│ ├── record.py
│ ├── sync.py
│ ├── udp_sync.py
│ ├── ble_terminal.py
│ └── decode_opus.py
├── requirements.txt
├── README.md
└── EXAMPLES.md
SDK Modules
ModuleDescription
client.pyBLE device communication
commands.pyHigh-level AT commands
transfer.pyFile synchronization
codec.pyAudio encoding/decoding
wifi.pyWiFi transport
progress.pyProgress display
utils.pyHelper functions
exceptions.pyException classes
Getting Started
Connect to the Device
import asyncio
from clip import ClipDevice, ClipCommands
async def main():
async with ClipDevice() as device:
cmds = ClipCommands(device)
state = await cmds.get_state()
print(state.battery)
asyncio.run(main())
The SDK automatically searches for nearby devices named:
Clip XXXX
Connect to a Specific Device
device = ClipDevice(
address="AA:BB:CC:DD:EE:FF"
await device.connect()
Device Information
Read Firmware Version
version = await cmds.get_version()
print(version.firmware)
print(version.hardware)
Read Device State
print(state.state)
print(state.mode)
Read Device Time
timestamp = await cmds.get_time()
Set Device Time
import time
await cmds.set_time(
int(time.time())
Recording Audio
Start Recording
session_id = await cmds.start_recording("normal")
Stop Recording
await cmds.stop_recording()
Pause Recording
await cmds.pause_recording()
Resume Recording
await cmds.resume_recording()
Add Bookmark
bookmark = await cmds.add_bookmark()
print(bookmark.offset)
Example Recording Session
session = await cmds.start_recording("normal")
await asyncio.sleep(10)
File Synchronization
List Sessions
sessions = await cmds.list_sessions()
for s in sessions:
print(s.id)
Synchronize a Session (BLE)
from clip import SessionSync
session_id = "20260326120000" # obtained from cmds.list_sessions()
sync = SessionSync(device)
await sync.sync(
session_id,
Path("recordings")
Resume Interrupted Download
await sync.sync(
session_id,
Path("recordings"),
start_file="0015.opus"
Keep Files on Device
await sync.sync(
session_id,
Path("recordings"),
delete_after=False
Configuration Management
Set Parameters
await cmds.set_mode("enhanced")
await cmds.set_bitrate(32000)
await cmds.set_complexity(10)
await cmds.set_noise_suppression(30)
Read Parameters
mode = await cmds.get_mode()
bitrate = await cmds.get_bitrate()
Batch Configuration
await cmds.set_config_dict({
"mode":"enhanced",
"bitrate":32000,
"complexity":10
WiFi Communication
The reSpeaker Clip can communicate over WiFi using UDP.
Default settings:
ParameterValue
SSIDClipAP_XXXX
Password12345678
Port8089
Connect
from clip import WiFiDevice
async with WiFiDevice(
"192.168.4.1",
8089
) as device:
await device.send_command("AT+GSTAT")
Synchronize over WiFi
from clip import WiFiSync
sync = WiFiSync(
"192.168.4.1",
8089
sync.connect()
sync.download_session(
session_id,
Path("recordings")
sync.disconnect()
Command Line Tools
The SDK includes several ready-to-use utilities.
clip-cli
General-purpose CLI.
clip-cli status
clip-cli version
clip-cli list
clip-cli record --duration 60
clip-cli sync --session 20260326120000
clip-cli config get
clip-cli bookmark
clip-cli terminal
record.py
Automatically records audio and synchronizes it.
python tools/record.py
python tools/record.py --duration 60
python tools/record.py --mode enhanced
sync.py
Synchronize recordings via BLE.
python tools/sync.py
python tools/sync.py --all-sessions
udp_sync.py
Synchronize recordings via WiFi.
python tools/udp_sync.py
python tools/udp_sync.py --session 20260326120000
ble_terminal.py
Interactive AT command terminal.
python tools/ble_terminal.py
decode_opus.py
Convert Opus recordings to WAV.
python tools/decode_opus.py input.opus output.wav
Web Interface
Launch the built-in web application.
BLE mode:
python tools/clip-web.py
WiFi mode:
python tools/clip-web.py --transport wifi
Then open:
http://localhost:5000
  • Device status
  • Recording control
  • Session management
  • Audio visualization
  • Configuration editor
  • Sync progress
REST API
MethodEndpoint
GET/api/status
GET/api/version
GET/api/sessions
POST/api/record/start
POST/api/record/stop
POST/api/record/bookmark
POST/api/sync/{id}
DELETE/api/sessions/{id}
GET/api/config
PUT/api/config
WS/ws
Error Handling
from clip import (
ConnectionError,
TimeoutError,
CommandError
try:
except ConnectionError:
except TimeoutError:
except CommandError:
Complete Example
This example demonstrates a typical workflow:
  1. Connect to the device
  2. Check battery level
  3. Configure recording parameters
  4. Start recording
  5. Add bookmarks
  6. Stop recording
  7. Synchronize the recorded session
import asyncio
from pathlib import Path
from clip import ClipDevice, ClipCommands, SessionSync
async def record_and_sync():
print(f"Battery: {state.battery}%")
"mode": "enhanced",
"bitrate": 32000,
"complexity": 10
print(f"Recording started: {session_id}")
print("Bookmark added")
await asyncio.sleep(5)
print("Recording stopped")
await sync.sync(session_id, Path("recordings"))
print(f"Session {session_id} synchronized")
asyncio.run(record_and_sync())
API Reference
ClipDevice
Purpose: BLE device communication and connection management.
class ClipDevice:
def __init__(self, address: str = None) -> None
async def connect() -> None
async def disconnect() -> None
async def __aenter__() -> ClipDevice
async def __aexit__(...) -> None
ClipCommands
Purpose: High-level AT commands for device control.
class ClipCommands:
def __init__(self, device: ClipDevice) -> None
async def get_state() -> DeviceState
async def get_version() -> Version
async def get_time() -> int
async def set_time(timestamp: int) -> None
async def start_recording(mode: str) -> str
async def stop_recording() -> None
async def pause_recording() -> None
async def resume_recording() -> None
async def add_bookmark() -> Bookmark
async def list_sessions() -> list[Session]
async def set_mode(mode: str) -> None
async def get_mode() -> str
async def set_bitrate(bitrate: int) -> None
async def get_bitrate() -> int
async def set_complexity(level: int) -> None
async def set_noise_suppression(level: int) -> None
async def set_config_dict(config: dict) -> None
SessionSync
Purpose: File synchronization over BLE.
class SessionSync:
async def sync(session_id: str, path: Path, delete_after: bool = True, start_file: str = None) -> None
WiFiDevice
Purpose: WiFi transport layer using UDP.
class WiFiDevice:
def __init__(self, host: str, port: int) -> None
async def send_command(cmd: str) -> str
async def __aenter__() -> WiFiDevice
WiFiSync
Purpose: File synchronization over WiFi.
class WiFiSync:
def download_session(session_id: str, path: Path) -> None
Exceptions
ExceptionDescription
ClipErrorBase exception for all errors
ConnectionErrorBLE/WiFi connection failure
TimeoutErrorCommand timeout
CommandErrorInvalid or failed AT command
