reSpeaker Flex control with Python
Introduction​
In this section, we are going to talk about how to control your reSpeaker Flex using the Python SDK. It makes development more convenient for users who want to build their own applications. For instance, you can detect where the voice is coming from, perform voice activity detection (VAD), control LEDs, and much more.
Python SDK​
We have a comprehensive Python guide on how to communicate with the Flex using the USB firmware. This Python script can be run in your favorite IDE without requiring the Flex XVF_Host. You can find more commands from this link.
You need to install the pyusb library.
How to get DOA and VAD​
import sys
import struct
import argparse
import usb.core
import usb.util
import time
try:
import libusb_package
except ImportError:
libusb_package = None
DEFAULT_VID = 0x2886
# name, resid, cmdid, length, type
PARAMETERS = {
"VERSION": (48, 0, 3, "ro", "uint8"),
"AEC_AZIMUTH_VALUES": (33, 75, 16, "ro", "radians"),
"DOA_VALUE": (20, 18, 4, "ro", "uint16"),
"REBOOT": (48, 7, 1, "wo", "uint8"),
class ReSpeaker:
TIMEOUT = 100000
def __init__(self, dev):
self.dev = dev
def write(self, name, data_list):
try:
data = PARAMETERS[name]
except KeyError:
return
if data[3] == "ro":
raise ValueError('{} is read-only'.format(name))
if len(data_list) != data[2]:
raise ValueError('{} value count is not {}'.format(name, data[2]))
windex = data[0] # resid
wvalue = data[1] # cmdid
data_type = data[4] # type
data_cnt = data[2] # cnt
payload = []
if data_type == 'float' or data_type == 'radians':
for i in range(data_cnt):
payload += struct.pack(b'f', float(data_list[i]))
elif data_type == 'char' or data_type == 'uint8':
payload += data_list[i].to_bytes(1, byteorder='little')
else:
payload += struct.pack(b'i', data_list[i])
print("WriteCMD: cmdid: {}, resid: {}, payload: {}".format(wvalue, windex, payload))
self.dev.ctrl_transfer(
usb.util.CTRL_OUT | usb.util.CTRL_TYPE_VENDOR | usb.util.CTRL_RECIPIENT_DEVICE,
0, wvalue, windex, payload, self.TIMEOUT)
def read(self, name):
try:
except KeyError:
return
resid = data[0]
cmdid = 0x80 | data[1]
length = data[2] + 1 # 1 byte for status
response = self.dev.ctrl_transfer(
usb.util.CTRL_IN | usb.util.CTRL_TYPE_VENDOR | usb.util.CTRL_RECIPIENT_DEVICE,
0, cmdid, resid, length, self.TIMEOUT)
if data[4] == 'uint8':
result = response.tolist()
elif data[4] == 'radians':
byte_data = response.tobytes()
num_values = ( length - 1 ) / 4
match_str = '<'
for i in range(int(num_values)):
match_str += 'f'
result = struct.unpack(match_str, byte_data[1:length])
elif data[4] == 'uint16':
return result
def close(self):
close the interface
usb.util.dispose_resources(self.dev)
def find(vid=DEFAULT_VID, pid=None):
if sys.platform.startswith('win') and libusb_package is None:
raise RuntimeError("Windows requires libusb-package. Install it with: pip install libusb-package")
usb_find = libusb_package.find if sys.platform.startswith('win') else usb.core.find
if pid is not None:
dev = usb_find(idVendor=vid, idProduct=pid)
if not dev:
return None
return ReSpeaker(dev)
devices = list(usb_find(find_all=True, idVendor=vid) or [])
if not devices:
return None
devices.sort(key=lambda device: getattr(device, 'idProduct', 0))
return ReSpeaker(devices[0])
def main():
parser = argparse.ArgumentParser(description='Read DoA values from ReSpeaker over USB control interface')
parser.add_argument('--vid', type=lambda x: int(x, 0), default=DEFAULT_VID,
help='usb vendor ID (default: 0x2886)')
parser.add_argument('--pid', type=lambda x: int(x, 0), default=None,
help='usb product ID; if omitted, auto-discover by VID for compatibility across firmware PIDs')
parser.add_argument('--interval', type=float, default=1.0,
help='read interval in seconds (default: 1.0)')
args = parser.parse_args()
dev = find(vid=args.vid, pid=args.pid)
if not dev:
if args.pid is None:
print(f'No device found for VID=0x{args.vid:04x}')
else:
print(f'No device found for VID=0x{args.vid:04x}, PID=0x{args.pid:04x}')
sys.exit(1)
print(f'Connected device VID=0x{dev.dev.idVendor:04x}, PID=0x{dev.dev.idProduct:04x}')
print('{}: {}'.format("VERSION", dev.read("VERSION")))
while True:
result = dev.read("DOA_VALUE")
print(result)
print('{}: {}, {}: {}'.format("SPEECH_DETECTED", result[3], "DOA_VALUE", result[1] + result[2] * 256))
time.sleep(args.interval)
dev.close()
if __name__ == '__main__':
main()
