ROS2 Voice Pipeline on reSpeaker
Introduction​
This project turns your voice into TurtleSim control using a reSpeaker microphone array and ROS2. Say “Hey Jarvis” followed by a command, and Jarvis records audio, transcribes it with Groq Whisper, interprets intent with Groq LLaMA, and responds with Groq Orpheus TTS. It supports forward/backward motion, angle turns, DoA-based facing, and instant stop commands. The system integrates wake-word detection, audio capture, ROS2 topics, and simulator command publishing in one seamless pipeline. It is designed for fast setup with Ubuntu and ROS2 Humble, making voice-driven robot experiments easy to run.
reSpeaker Flex XVF3800 CircularreSpeaker XVF3800
OR
Part 1 — Install ROS2 Humble​
Skip this part if ROS2 Humble is already installed on your machine. Check by running: ros2 --version
1.1 Set up the ROS2 apt repository
# Make sure your system is up to date
sudo apt update && sudo apt upgrade -y
# Install required tools
sudo apt install -y software-properties-common curl
# Add the ROS2 GPG key
sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key \
-o /usr/share/keyrings/ros-archive-keyring.gpg
# Add the ROS2 repository to your sources
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] \
http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" \
| sudo tee /etc/apt/sources.list.d/ros2.list > /dev/null
1.2 Install ROS2 Humble Desktop
sudo apt update
sudo apt install -y ros-humble-desktop
The desktop variant includes TurtleSim, RViz, and all tools you need. This download is around 1 GB — it may take a few minutes.
1.3 Install build tools
sudo apt install -y python3-colcon-common-extensions python3-rosdep
1.4 Source ROS2 automatically on every terminal
echo "source /opt/ros/humble/setup.bash" >> ~/.bashrc
source ~/.bashrc
1.5 Verify the installation
ros2 --version
# Expected output: ros2 cli version 0.18.x (or similar)
Then test TurtleSim to confirm everything works:
# Terminal 1
ros2 run turtlesim turtlesim_node
# Terminal 2
ros2 run turtlesim turtle_teleop_key
You should see a window with a turtle you can drive with arrow keys. Press Ctrl+C in both terminals when done.
Part 2 — Create a udev Rule for the Device​
Create a new udev rule to ensure proper permissions for the reSpeaker USB Mic Array:
sudo nano /etc/udev/rules.d/50-respeaker.rules
Add the following lines to the file:
# ReSpeaker USB Mic Array
SUBSYSTEM=="usb", ATTR{idVendor}=="2886", ATTR{idProduct}=="0018", MODE="0666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTR{idVendor}=="2886", ATTR{idProduct}=="001a", MODE="0666", GROUP="plugdev"
Reload udev Rules and Restart the Service
Reload the udev rules and restart the service for changes to take effect:
sudo udevadm control --reload-rules
sudo udevadm trigger
sudo service udev restart
Unplug and replug your reSpeaker USB Mic Array to apply the new rules.
Part 3 — Get a Groq API Key​
This project uses Groq's free cloud API for:
  • Whisper — speech-to-text
  • LLaMA 3 — understanding your commands
  • Orpheus — Jarvis's voice reply
  1. Go to console.groq.com and create a free account
  2. Click API Keys in the left sidebar
  3. Click Create API Key, give it a name (e.g. "jarvis"), and copy it
  4. Save it somewhere safe — you will paste it into config.env shortly
The Groq free tier is generous enough for development and testing. No credit card is required to get started.
Part 4 — Install Python Dependencies (System-Wide)​
Important: Do NOT use a virtual environment for this project. ROS2 uses the system Python and cannot see packages installed inside a venv. We install everything with --break-system-packages to make them available to ROS2 nodes.
pip install \
groq \
openwakeword \
pyaudio \
numpy<2 \
python-dotenv \
pyusb \
Download the "Hey Jarvis" wake word model
python3 -c "import openwakeword; openwakeword.utils.download_models()"
This downloads pre-trained models to ~/.openwakeword/. It takes about 30 seconds.
Install PortAudio (required by PyAudio)
sudo apt install -y portaudio19-dev python3-pyaudio
Part 5 — Create Your ROS2 Workspace​
Skip to Part 6 if you already have a ~/ros2_ws workspace.
# Create the workspace directory
mkdir -p ~/ros2_ws/src
cd ~/ros2_ws
# Build the empty workspace to set it up
colcon build
# Source it and add to .bashrc so it loads automatically
echo "source ~/ros2_ws/install/setup.bash" >> ~/.bashrc
source ~/.bashrc
Part 6 — Clone and Configure the Project​
6.1 Clone the repository
If you are using Flex
cd ~/ros2_ws/src
git clone https://github.com/KasunThushara/ros_voice_controller_flex.git my_robot_controller
If you are using XVF3800
cd ~/ros2_ws/src
git clone https://github.com/KasunThushara/ros_voice_controller.git my_robot_controller
Your workspace should now look like this:
~/ros2_ws/
└── src/
└── my_robot_controller/
├── my_robot_controller/
│ ├── voice_node.py
│ ├── rotate_doa.py
│ ├── wakeword.py
├── launch/
│ └── jarvis.launch.py
└── config.env.example
6.2 Create your config file
cd ~/ros2_ws/src/my_robot_controller
cp config.env.example config.env
nano config.env
Open the file and fill in your values:
# ── Groq API (required) ────────────────────────────────
GROQ_API_KEY=gsk_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx ← paste your key here
# ── Microphone ─────────────────────────────────────────
MIC_INDEX=1 ← find the correct number in Step 6.3 below
WAKEWORD_THRESHOLD=0.5
WAKEWORD_COOLDOWN=2
# ── Recording ──────────────────────────────────────────
RECORDING_SECONDS=4
SAMPLE_RATE=16000
# ── Models ─────────────────────────────────────────────
WAKEWORD_MODEL=hey jarvis
LLM_MODEL=llama-3.1-8b-instant
STT_MODEL=whisper-large-v3-turbo
TTS_MODEL=canopylabs/orpheus-v1-english
TTS_VOICE=autumn
Save with Ctrl+O, Enter, Ctrl+X.
6.3 Find your correct MIC_INDEX
Run this helper to list all audio input devices:
python3 -c "
import pyaudio
p = pyaudio.PyAudio()
print('\nAvailable INPUT devices:\n')
for i in range(p.get_device_count()):
d = p.get_device_info_by_index(i)
if d['maxInputChannels'] > 0:
print(f' [{i}] {d[\"name\"]}')
print(f' channels={int(d[\"maxInputChannels\"])} rate={int(d[\"defaultSampleRate\"])}Hz')
p.terminate()
Example output:
[0] HDA Intel PCH: ALC897 Analog
channels=2 rate=44100Hz
[1] reSpeaker Flex XVF3800
channels=6 rate=16000Hz ← this is the one you want
[2] USB PnP Sound Device
channels=2 rate=16000Hz
Find the line that says reSpeaker Flex or reSpeaker Flex XVF3800. Note the number in brackets — that is your MIC_INDEX. Update config.env with that number.
Part 7 — Build the Package​
cd ~/ros2_ws
colcon build --packages-select my_robot_controller
source ~/.bashrc
Expected output:
Starting >>> my_robot_controller
Finished <<< my_robot_controller [3.2s]
Summary: 1 package finished [3.5s]
You must run colcon build and source ~/.bashrc every time you change any Python file.
Part 8 — Run the Project​
ros2 launch my_robot_controller jarvis.launch.py
You should see three processes start:
[turtlesim_node-1]   [INFO] Spawning turtle [turtle1] at x=[5.54], y=[5.54]
[angle_controller-2] [INFO] AngleController ready — listening on /target_angle
[voice_command-3] [INFO] reSpeaker Flex XVF3800 found — DoA ready
[voice_command-3] [WakeWord] Listening on device 1 (6ch → mono) for 'hey jarvis' ...
[voice_command-3] [INFO] Jarvis is listening ...
A window will open showing the turtle. Now speak:
"Hey Jarvis, move forward"
Jarvis will reply "Moving forward!" and the turtle will move.
Voice Command Reference​
Say thisWhat happens
"Hey Jarvis, move forward"Turtle moves forward 1 step
"Hey Jarvis, move backward"Turtle moves backward 1 step
"Hey Jarvis, turn left"Turtle rotates left 90°
"Hey Jarvis, turn left 45"Turtle rotates left 45°
"Hey Jarvis, turn right"Turtle rotates right 90°
"Hey Jarvis, turn right 30 degrees"Turtle rotates right 30°
"Hey Jarvis, turn to my direction"Turtle faces toward your voice (DoA)
"Hey Jarvis, face me"Same as above
"Hey Jarvis, turn to 90"Turtle rotates to absolute 90°
"Hey Jarvis, face 180 degrees"Turtle rotates to absolute 180°
"Hey Jarvis, spin around"Turtle does a full 360° spin
"Hey Jarvis, do a 360"Same as above
"Hey Jarvis, stop"Turtle stops immediately
Project File Structure​
├── my_robot_controller/ # Python package (ROS2 nodes)
│ ├── __init__.py
│ ├── voice_node.py # Main voice pipeline node
│ ├── rotate_doa.py # PID angle controller node
│ ├── wakeword.py # Wake word detection (openwakeword)
│ ├── audio_recorder.py # Mic recording after wake word
│ ├── stt.py # Speech-to-text (Groq Whisper)
│ ├── llm.py # Intent parsing (Groq LLaMA)
│ ├── tts.py # Text-to-speech (Groq Orpheus)
│ └── config.py # Loads settings from config.env
├── launch/
│ └── jarvis.launch.py # Starts all 3 nodes together
├── config.env # Your secrets (not in git)
├── config.env.example # Template — copy to config.env
├── package.xml
└── setup.py
How the nodes connect​
reSpeaker Flex (USB)
├── [voice_command node]
│ openwakeword → Groq Whisper → Groq LLaMA → Groq Orpheus
│ │ publishes /target_angle (Float32) │ speaks reply
│ │ publishes /turtle1/cmd_vel (Twist) │
│ ▼ Speaker output
└── [angle_controller node]
subscribes /target_angle
subscribes /turtle1/pose
PID control → publishes /turtle1/cmd_vel
[turtlesim_node]
Configuration Reference​
All settings live in config.env. Edit and rebuild to apply changes.
VariableDefaultDescription
GROQ_API_KEY(required)Your Groq API key
MIC_INDEX1PyAudio device index of the reSpeaker
WAKEWORD_MODELhey jarvisWake word phrase
WAKEWORD_THRESHOLD0.5Detection sensitivity (0.0–1.0, lower = more sensitive)
WAKEWORD_COOLDOWN2Seconds before wake word can re-trigger
RECORDING_SECONDS4How long to record after wake word fires
SAMPLE_RATE16000Audio sample rate in Hz
LLM_MODELllama-3.1-8b-instantGroq LLM model for intent parsing
STT_MODELwhisper-large-v3-turboGroq Whisper model for transcription
TTS_MODELcanopylabs/orpheus-v1-englishGroq TTS model
TTS_VOICEautumnVoice for speech output (tara, leah, leo, dan, mia)
Resources​
Built with:
