GPIO controlling reSpeaker Flex with Xiao ESP32S3
Objective​
This guide explains how to read and control GPIO pins on the XVF3800 voice processor using the I2C interface. You’ll learn how to:
  • Read GPI and GPO pin statuses
  • Understand GPIO mappings and their purpose
reSpeaker Flex XVF3800 Linear with XIAO ESP32S3 reSpeaker Flex XVF3800 Circular with XIAO ESP32S3
GPIO Overview​
Pin NameDirectionFunction
X1D09Input (RO)Boot button status / GPI0
X1D13Input (RO)Floating / GPI1
X1D34Input (RO)Floating / GPI2
X0D11Output (RW)Floating / GPO, shared with SPI MOSI
X0D30Output (RW)SD/FAULT control
X0D31Output (RW)PA / amplifier control
X0D32Output (RW)XMOS GPIO 1
X0D33Output (RW)XMOS GPIO 2
X0D39Output (RW)Floating / GPO, shared with SPI MISO
Read GPO Pin States​
Goal: Check logic levels of all output-capable GPIOs (GPOs). Code Highlights:
  • Sends a read request using:
    • Resource ID: 20 (GPO)
    • Command ID: 0 (GPO_READ_VALUES)
  • Reads 5 GPO pins statues in order: X0D11 → X0D30 → X0D31 → X0D33 → X0D39
  • Includes a status byte to validate the response
#include <Wire.h>
#define XMOS_ADDR 0x2C // I2C 7-bit address
#define GPO_SERVICER_RESID 20
#define GPO_SERVICER_RESID_GPO_READ_VALUES 0
#define GPO_GPO_READ_NUM_BYTES 5
while (!Serial);
Wire.begin();
Serial.println("XVF3800 GPO Read Test Starting...");
uint8_t gpo_values[GPO_GPO_READ_NUM_BYTES] = {0};
uint8_t status = 0xFF;
bool success = read_gpo_values(gpo_values, &status);
if (success) {
Serial.print("I2C Communication SUCCESS. Status byte: 0x");
Serial.print(status, HEX);
Serial.print(" | GPO Output Values: ");
for (uint8_t i = 0; i < GPO_GPO_READ_NUM_BYTES; i++) {
Serial.print("0x");
Serial.print(gpo_values[i], HEX);
Serial.print(" ");
Serial.println();
} else {
Serial.println("Failed to read GPO values.");
bool read_gpo_values(uint8_t *buffer, uint8_t *status) {
const uint8_t resid = GPO_SERVICER_RESID;
const uint8_t cmd = GPO_SERVICER_RESID_GPO_READ_VALUES | 0x80;
const uint8_t read_len = GPO_GPO_READ_NUM_BYTES;
// Step 1: Write command
Wire.beginTransmission(XMOS_ADDR);
Wire.write(resid);
Wire.write(cmd);
Wire.write(read_len + 1);
uint8_t result = Wire.endTransmission();
if (result != 0) {
Serial.print("I2C Write Error: ");
Serial.println(result);
return false;
// Step 2: Read response (status + payload)
Wire.requestFrom(XMOS_ADDR, (uint8_t)(read_len + 1));
if (Wire.available() < read_len + 1) {
Serial.println("I2C Read Error: Not enough data received.");
return false;
*status = Wire.read();
for (uint8_t i = 0; i < read_len; i++) {
buffer[i] = Wire.read();
return true;
Read GPI Pin States​
Goal: Check states of input-capable GPIOs (e.g., mute button status). Code Highlights:
  • Sends command to:
    • Resource ID: 36 (IO_CONFIG)
    • Command ID: 6 (GPI_VALUE_ALL)
  • Receives 3 GPI representing the state of X1D09, X1D13, and X1D34
#include <Wire.h>
#define XMOS_ADDR 0x2C // I2C 7-bit address of XVF3800
// Resource and command IDs for GPI
#define IO_CONFIG_SERVICER_RESID 36
#define IO_CONFIG_SERVICER_RESID_GPI_READ_VALUES 0
#define GPI_READ_NUM_BYTES 3 // From header: IO_CONFIG_SERVICER_RESID_GPI_READ_VALUES_NUM_VALUES
while (!Serial);
Wire.begin();
Serial.println("XVF3800 GPI Read Test Starting...");
uint8_t gpi_values[GPI_READ_NUM_BYTES] = {0};
bool success = read_gpi_values(gpi_values, &status);
if (success) {
Serial.print(" | GPI Input Values: ");
for (uint8_t i = 0; i < GPI_READ_NUM_BYTES; i++) {
Serial.print("0x");
Serial.print(gpi_values[i], HEX);
Serial.print(" ");
Serial.println();
} else {
Serial.println("Failed to read GPI values.");
bool read_gpi_values(uint8_t *buffer, uint8_t *status) {
const uint8_t resid = IO_CONFIG_SERVICER_RESID;
const uint8_t cmd = IO_CONFIG_SERVICER_RESID_GPI_READ_VALUES | 0x80; // Read command
const uint8_t read_len = GPI_READ_NUM_BYTES;
// Step 1: Send the command
Wire.write(resid);
Wire.write(cmd);
Wire.write(read_len + 1); // +1 for status byte
if (result != 0) {
return false;
return false;
*status = Wire.read(); // first byte is status
return true;
Once you press the boot button, the state will change.
