reSpeaker XVF3800 USB Audio Bridge with XIAO ESP32S3
Overview
This project provides Arduino firmware for an ESP32-S3 USB audio and control bridge connected to a reSpeaker XVF3800. A single native USB connection provides stereo capture, stereo playback, and a CDC serial interface for reSpeaker XVF3800 control over I2C.
Firmware Features
- USB Audio Class 1 (UAC1) capture and playback over Full-Speed USB.
- Stereo signed 32-bit little-endian PCM, with 32-bit Philips I2S slots.
- Compile-time selection of 16 kHz or 48 kHz operation and the I2S clock source.
- Simultaneous USB capture and playback. USB and I2S use the same nominal sample rate.
- Playback buffering and software clock drift correction, with USB host volume and mute controls for the master and individual channels.
- Capture without playback volume processing or software resampling.
- USB CDC commands forwarded to the reSpeaker XVF3800 I2C control interface, with a Python host utility and read-only audio/USB diagnostics.
- A project-local TinyUSB DWC2 driver and USB descriptors that fit duplex audio and CDC into the ESP32-S3 hardware FIFO budget.
Audio Modes
Set BRIDGE_MODE in bridge_config.h, then rebuild the complete sketch. Master and Slave in the macro names describe the reSpeaker XVF3800 role. The ESP32-S3 uses the opposite role.
| Mode | Sample rate | reSpeaker role | ESP32-S3 role | Clock source |
BRIDGE_I2S_MASTER_48K | 48 kHz | Master | Slave | reSpeaker |
BRIDGE_I2S_MASTER_16K | 16 kHz | Master | Slave | reSpeaker |
BRIDGE_I2S_SLAVE_16K | 16 kHz | Slave | Master | ESP32-S3 |
The reSpeaker XVF3800 must run firmware configured for the matching sample rate and I2S role. The bridge does not configure or flash the reSpeaker. Mode selection requires recompilation; there is no runtime rate switch or 16/48 kHz conversion.
Requirements
- An ESP32-S3 board with native USB; the supplied profile targets the Seeed Studio XIAO ESP32S3.
- Arduino IDE or Arduino CLI with the Espressif board package available.
- Arduino-ESP32 3.3.11.
No separate USB audio library is required. Use the pinned core version: the local USB driver override and descriptors depend on its TinyUSB implementation.
Build Settings (Arduino IDE)
Open reSpeaker_ESP32S3_USB_BRIDGE.ino, install/select Arduino-ESP32 3.3.11, and use these settings:
| Setting | Value |
| Board | Seeed Studio XIAO_ESP32S3 |
| USB Mode | USB-OTG (TinyUSB) |
| USB CDC On Boot | Disabled |
| Upload Mode | USB-OTG CDC (TinyUSB) |
| USB Firmware MSC On Boot | Disabled |
| USB DFU On Boot | Disabled |
| CPU Frequency | 240 MHz |
| PSRAM | Disabled |
In short: USB Mode = USB-OTG (TinyUSB); CDC/MSC/DFU On Boot = Disabled; CPU = 240 MHz; PSRAM = Disabled.
The firmware creates its own CDC interface, so CDC On Boot must remain disabled. In the pinned CLI profile, CDCOnBoot=cdc corresponds to Disabled. The sketch checks these three USB settings at compile time. Upload Mode is checked through ARDUINO_FQBN, because the core does not define a separate upload-mode macro. The CLI profile explicitly selects UploadMode=cdc to request the 1200-baud reset and wait for the download port.
Select Verify to compile, then Upload.
Download and Install
- Download the firmware from GitHub: reSpeaker_ESP32S3_USB_BRIDGE.
- Copy the entire contents of the downloaded repository into a new folder
Documents\Arduino\reSpeaker_ESP32S3_USB_BRIDGE. Include all files: the.ino, headers,.cppfiles,sketch.yaml,host\,src\, anddocs. Copying only the.inofile is insufficient. - Edit
bridge_config.hin the new folder to select the 16 kHz mode, If you are using:
// #define BRIDGE_MODE BRIDGE_I2S_MASTER_48K
#define BRIDGE_MODE BRIDGE_I2S_SLAVE_16K
- In Arduino IDE, open File > Sketchbook > reSpeaker_ESP32S3_USB_BRIDGE (the folder name now matches the
.ino).
Check USB Enumeration
Disconnect and reconnect the USB cable. You should see:
- A CDC serial port (for example,
COM5on Windows) — this is the control port. - An audio device named
BRIDGE I2S Slave 16k(stereo, 32-bit, 16 kHz in and out).
Close any program (such as a serial monitor) that is holding the port before continuing.
Verify the Control Side (Host Tool)
From the repository, enter the host folder and install the dependency:
cd host
python -m venv .venv
.venv\Scripts\activate.bat
python -m pip install -r requirements.txt
python bridge_host.py --list-ports
python bridge_host.py --port COMx --ping
python bridge_host.py --port COMx VERSION
Replace x in COMx with your actual COM port number. On Linux or macOS, activate the virtual environment with source .venv/bin/activate and use a path such as /dev/ttyACM0 or /dev/cu.usbmodemXXXX instead of COMx.
Expected Results
Test Audio
- Playback: play a stereo 32-bit 16 kHz WAV file to the
BRIDGE I2S Slave 16koutput; sound should come from the reSpeaker codec/speaker. - Capture: record 16 kHz stereo 32-bit audio from its input.
Reference Audacity Snapshot
- reSpeaker_ESP32S3_USB_BRIDGE firmware (GitHub)
README.md— firmware overview, audio modes, and build instructions.PLAYBACK.md— audio wiring, playback buffering, diagnostics, and audio/USB status.CONTROL.md— I2C wiring, the Python host utility, and the CDC serial protocol.
