ROS2 on reSpeaker XVF3800
Introduction
This project demonstrates the integration of the ReSpeaker XVF3800 with ROS2 for robotic applications, focusing on speech detection and Direction of Arrival (DOA) estimation. Using the Turtlesim node, we simulate robotic control based on speech input, enabling precise movement through PID control. The tutorial covers the setup of the ROS2 environment, configuration of the ReSpeaker XVF3800, and how to apply speech commands for controlling a robot. By the end, users will understand how to connect voice interfaces with robotics and use basic control algorithms for navigation.
How to Install ROS 2 on the Host Computer
For this project, we use ROS 2 Humble as the middleware. If you are installing ROS 2 for the first time, please follow the official installation guide for detailed steps:
ROS 2 Humble Installation Guide (Ubuntu)
Set Up ReSpeaker USB Mic Array
If you're using the ReSpeaker USB Mic Array for your robot or voice applications, follow these steps to configure it on your Ubuntu system.
Find Your Device's Vendor and Product IDs
To find your device's IDs, run:
lsusb
Look for the ReSpeaker device (e.g., vendor 0x2886, product 0x001A).
Create a udev Rule for the Device
Create a new udev rule to ensure proper permissions for the ReSpeaker Mic Array:
sudo nano /etc/udev/rules.d/50-respeaker.rules
Add the following lines to the file:
# ReSpeaker USB Mic Array
SUBSYSTEM=="usb", ATTR{idVendor}=="2886", ATTR{idProduct}=="0018", MODE="0666", GROUP="plugdev"
SUBSYSTEM=="usb", ATTR{idVendor}=="2886", ATTR{idProduct}=="001a", MODE="0666", GROUP="plugdev"
Reload udev Rules and Restart the Service
Reload the udev rules and restart the service for changes to take effect:
sudo udevadm control --reload-rules
sudo udevadm trigger
sudo service udev restart
Unplug and replug your ReSpeaker USB Mic Array to apply the new rules.
Setting Up ROS2 Workspace and Controlling Your Robot with ROS2
This guide walks you through the process of setting up a ROS2 workspace, creating a custom ROS2 package, controlling a robot using Python, and configuring the ReSpeaker USB Mic Array for use in your ROS2 project.
Install Required Dependencies
Install Python Colcon Extension
First, ensure that the necessary Python extensions for building ROS2 packages are installed:
sudo apt install python3-colcon-common-extensions
Configure Colcon Auto-completion (Optional)
If you need to set up auto-completion for colcon:
cd /usr/share/colcon_argcomplete/hook/
ls
gedit ~/.bashrc
clear
Then, add source ~/.bashrc to reload the environment:
source ~/.bashrc
Create a ROS2 Workspace
Create a new ROS2 workspace and prepare the environment:
mkdir ros2_ws
cd ros2_ws/
mkdir src
colcon build
Source the ROS2 Workspace
After building the workspace, source it to set up the environment variables:
source ~/ros2_ws/install/setup.bash
You can add this line to your ~/.bashrc to source the workspace automatically every time you open a new terminal:
echo "source ~/ros2_ws/install/setup.bash" >> ~/.bashrc
source ~/.bashrc
Create a New ROS2 Package
Now, let's create a new ROS2 package for your robot controller. This package will use ament_python for building and rclpy as a dependency:
cd ~/ros2_ws/src
ros2 pkg create my_robot_controller --build-type ament_python --dependencies rclpy
Add Python Script for Robot Control
Navigate into your newly created package, and create a Python script (e.g., rotate_doa.py) to control the robot:
cd my_robot_controller/
touch rotate_doa.py
chmod +x rotate_doa.py
Edit the script with your desired control logic (e.g., using an editor like VS Code):
cd ..
code .
rotate_doa.py
import sys
import struct
import usb.core
import usb.util
import time
import rclpy
from rclpy.node import Node
from geometry_msgs.msg import Twist
from turtlesim.msg import Pose
from std_msgs.msg import Float32
import math
# name, resid, cmdid, length, type
PARAMETERS = {
"VERSION": (48, 0, 4, "ro", "uint8"),
"AEC_AZIMUTH_VALUES": (33, 75, 16 + 1, "ro", "radians"),
"DOA_VALUE": (20, 18, 4 + 1, "ro", "uint16"),
class ReSpeaker:
TIMEOUT = 100000
def __init__(self, dev):
self.dev = dev
def write(self, name, value):
pass
def read(self, name):
try:
data = PARAMETERS[name]
except KeyError:
return
resid = data[0]
cmdid = 0x80 | data[1]
length = data[2]
response = self.dev.ctrl_transfer(
usb.util.CTRL_IN | usb.util.CTRL_TYPE_VENDOR | usb.util.CTRL_RECIPIENT_DEVICE,
0, cmdid, resid, length, self.TIMEOUT)
if data[4] == 'uint8':
result = response.tolist()
elif data[4] == 'radians':
byte_data = response.tobytes()
float1, float2, float3, float4 = struct.unpack('<ffff', byte_data[1:17])
result = [float1 * 180 / 3.1415926,
float2 * 180 / 3.1415926,
float3 * 180 / 3.1415926,
float4 * 180 / 3.1415926]
elif data[4] == 'uint16':
return result
def close(self):
close the interface
usb.util.dispose_resources(self.dev)
def find(vid=0x2886, pid=0x001A):
dev = usb.core.find(idVendor=vid, idProduct=pid)
if not dev:
return None
return ReSpeaker(dev)
class AngleController(Node):
def __init__(self):
super().__init__('angle_controller')
self.target_angle = 0.0
self.pose_sub = self.create_subscription(Pose, '/turtle1/pose', self.pose_callback, 10)
self.cmd_pub = self.create_publisher(Twist, '/turtle1/cmd_vel', 10)
# PID params
self.kp = 1.5
self.ki = 0.0
self.kd = 0.2
self.integral = 0.0
self.prev_error = 0.0
self.prev_time = self.get_clock().now()
def publish_angle(self, angle_deg: float):
self.target_angle = math.radians(angle_deg) # Convert to radians
self.get_logger().info(f"New target angle: {angle_deg:.2f}°")
def pose_callback(self, msg: Pose):
current_yaw = msg.theta
error = self.normalize_angle(self.target_angle - current_yaw)
now = self.get_clock().now()
dt = (now - self.prev_time).nanoseconds / 1e9
self.prev_time = now
self.integral += error * dt
derivative = (error - self.prev_error) / dt if dt > 0 else 0.0
control = self.kp * error + self.ki * self.integral + self.kd * derivative
twist = Twist()
twist.angular.z = control
self.cmd_pub.publish(twist)
self.prev_error = error
@staticmethod
def normalize_angle(angle):
while angle > math.pi:
angle -= 2.0 * math.pi
while angle < -math.pi:
angle += 2.0 * math.pi
return angle
def main(args=None):
rclpy.init(args=args)
node = AngleController()
# Setup ReSpeaker device
dev = find()
if not dev:
node.get_logger().error("No ReSpeaker device found")
return
# Function to handle publishing DOA angle when speech is detected
def publish_doa_angle():
result = dev.read("DOA_VALUE")
if result:
speech_detected = result[3]
doa_angle = result[1]
if speech_detected: # If speech is detected
node.publish_angle(doa_angle)
node.get_logger().info(f"Speech detected, DOA angle: {doa_angle}°")
# Timer to check for DOA updates every 1 second
timer = node.create_timer(1.0, publish_doa_angle)
rclpy.spin(node)
node.destroy_node()
rclpy.shutdown()
dev.close()
if __name__ == '__main__':
main()
Add this dependancies to package.xml
  <depend>rclpy</depend>
<depend>geometry_msgs</depend>
<depend>turtlesim</depend>
<depend>std_msgs</depend>
Add this endpoint to package.xml
entry_points={
'console_scripts': [
'rotate_doa = my_controller.rotate_doa:main',
Build and Run the Package
After editing your Python script, build the package:
colcon build
Finally, run the package with:
ros2 run my_robot_controller rotate_doa
In another terminal, you can also run a basic ROS2 node (e.g., turtlesim for testing):
ros2 run turtlesim turtlesim_node
