reSpeaker XVF3800 USB Mic Array with XIAO ESP32S3 HTTP Audio Streaming
Introduction
This guide describes how to capture audio from an XVF3800 microphone array using an ESP32-S3 (XIAO ESP32S3), record 5 seconds of 16 kHz stereo 32-bit PCM audio, and store the data in PSRAM to handle large audio buffers. The recorded audio is then uploaded over Wi-Fi to a Python-based Flask HTTP server, where it is received and saved as a standard WAV file. This setup is well suited for applications such as voice capture, remote audio logging, and speech processing pipelines including speech-to-text (STT) and machine-learning–based audio analysis.
Arduino Code
note
You must enable PSRAM, otherwise malloc() will fail.
Update these fields before uploading:
// WiFi credentials
const char* ssid = "your SSID";
const char* password = "your password";
// HTTP server (your PC)
const char* serverUrl = "http://<flask-server>:8000/upload"; // please replace with your PC IP /flask server
Full Arduino Code
#include "WiFi.h"
#include "HTTPClient.h"
#include "AudioTools.h"
// WiFi credentials
// Audio: 16kHz, stereo, 32-bit
AudioInfo info(16000, 2, 32);
I2SStream i2s_in;
I2SConfig i2s_config;
// 5 seconds of audio = 640,000 bytes
#define RECORDING_SECONDS 5
#define BYTES_PER_SECOND 128000
#define TOTAL_BYTES (RECORDING_SECONDS * BYTES_PER_SECOND)
// Buffer for recording
uint8_t* audioBuffer = nullptr;
void connectWiFi() {
Serial.printf("Connecting to WiFi: %s\n", ssid);
WiFi.begin(ssid, password);
int attempts = 0;
while (WiFi.status() != WL_CONNECTED && attempts < 20) {
delay(500);
Serial.print(".");
attempts++;
if (WiFi.status() == WL_CONNECTED) {
Serial.println("\nConnected!");
Serial.printf("IP Address: %s\n", WiFi.localIP().toString().c_str());
} else {
Serial.println("\nFailed to connect!");
void setupI2SInput() {
i2s_config = i2s_in.defaultConfig(RX_MODE);
i2s_config.copyFrom(info);
// XVF3800 pins
i2s_config.pin_bck = 8;
i2s_config.pin_ws = 7;
i2s_config.pin_data = 44;
i2s_config.pin_data_rx = 43;
i2s_config.is_master = true;
i2s_in.begin(i2s_config);
Serial.println("I2S input started.");
while(!Serial);
AudioLogger::instance().begin(Serial, AudioLogger::Info);
// Allocate memory for audio buffer
audioBuffer = (uint8_t*)malloc(TOTAL_BYTES);
if (!audioBuffer) {
Serial.println("Failed to allocate memory!");
return;
connectWiFi();
setupI2SInput();
// Wait for I2S to stabilize
delay(500);
// Record audio
Serial.printf("Recording %d seconds of audio...\n", RECORDING_SECONDS);
size_t total_read = 0;
size_t bytes_read = 0;
unsigned long start_time = millis();
while (total_read < TOTAL_BYTES) {
bytes_read = i2s_in.readBytes(audioBuffer + total_read,
min(4096, (int)(TOTAL_BYTES - total_read)));
if (bytes_read > 0) {
total_read += bytes_read;
// Progress indicator
if (total_read % BYTES_PER_SECOND == 0) {
Serial.printf("Recorded %.1f seconds\n", total_read / (float)BYTES_PER_SECOND);
unsigned long record_time = millis() - start_time;
Serial.printf("Recording complete! %d bytes in %lu ms\n", total_read, record_time);
// Send via HTTP POST
HTTPClient http;
Serial.printf("Sending audio to %s\n", serverUrl);
http.begin(serverUrl);
http.addHeader("Content-Type", "application/octet-stream");
http.addHeader("X-Sample-Rate", String(info.sample_rate));
http.addHeader("X-Channels", String(info.channels));
http.addHeader("X-Bits-Per-Sample", String(info.bits_per_sample));
int httpResponseCode = http.POST(audioBuffer, total_read);
if (httpResponseCode > 0) {
Serial.printf("HTTP Response code: %d\n", httpResponseCode);
String response = http.getString();
Serial.println("Response: " + response);
} else {
Serial.printf("Error code: %d\n", httpResponseCode);
Serial.println("Error: " + http.errorToString(httpResponseCode));
http.end();
} else {
Serial.println("WiFi not connected!");
// Free memory
free(audioBuffer);
Serial.println("Done!");
// Nothing - runs once
Expected Output
Python Server Code (Flask)
You need to install flask run on your environment pip install flask
from flask import Flask, request, jsonify
import wave
import datetime
app = Flask(__name__)
@app.route('/upload', methods=['POST'])
def upload_audio():
try:
# Get audio parameters from headers
sample_rate = int(request.headers.get('X-Sample-Rate', 16000))
channels = int(request.headers.get('X-Channels', 2))
bits_per_sample = int(request.headers.get('X-Bits-Per-Sample', 32))
# Get raw audio data
audio_data = request.data
print(f"Received {len(audio_data)} bytes")
print(f"Format: {sample_rate}Hz, {channels} channels, {bits_per_sample}-bit")
# Generate filename with timestamp
timestamp = datetime.datetime.now().strftime("%Y%m%d_%H%M%S")
filename = f"recording_{timestamp}.wav"
# Save as WAV file
with wave.open(filename, 'wb') as wav_file:
wav_file.setnchannels(channels)
wav_file.setsampwidth(bits_per_sample // 8) # Convert bits to bytes
wav_file.setframerate(sample_rate)
wav_file.writeframes(audio_data)
duration = len(audio_data) / (sample_rate * channels * (bits_per_sample // 8))
print(f"Saved to {filename} ({duration:.2f} seconds)")
return jsonify({
'status': 'success',
'filename': filename,
'bytes_received': len(audio_data),
'duration_seconds': duration
}), 200
except Exception as e:
print(f"Error: {str(e)}")
return jsonify({'status': 'error', 'message': str(e)}), 500
@app.route('/', methods=['GET'])
def index():
return "Audio Upload Server Running"
if __name__ == '__main__':
print("Starting HTTP server on port 8000...")
print("Waiting for audio uploads from ESP32...")
app.run(host='0.0.0.0', port=8000, debug=True)
Expected Output
