reSpeaker XVF3800 USB Mic Array with XIAO ESP32S3 UDP Audio Streaming
Overview
This project demonstrates real-time audio streaming using the ReSpeaker XVF3800 microphone array with a XIAO ESP32S3 board. The audio is captured via I2S, and transmitted over UDP to a server running on a local machine, where it can be stored and processed as a .wav file.
Functionality Overview
This sketch performs the following tasks:
  • Connects to the specified Wi-Fi network.
  • Connects to a UDP server (e.g., Python script running on the host PC).
  • Captures real-time audio via I2S from the ReSpeaker XVF3800 using the XIAO ESP32S3.
  • Transmits the captured audio as raw data.
Arduino Code
Update these fields before uploading:
// WiFi credentials
const char* ssid = "Your-SSID";
const char* password = "WIFI-PASSWORD";
// UDP target
const char* udpAddress = "192.168.X.X"; // Change to PC/server IP
const int udpPort = 12345; // Port to send audio
Full Code (Streams ~5 seconds of audio)
#include "WiFi.h"
#include "WiFiUdp.h"
#include "AudioTools.h"
// WiFi credentials
// UDP target
const char* udpAddress = "192.168.x.x";
WiFiUDP udp;
// Audio: 16kHz, stereo, 32-bit
AudioInfo info(16000, 2, 32);
I2SStream i2s_in;
I2SConfig i2s_config;
// Buffer for reading audio
#define BUFFER_SIZE 1024
uint8_t buffer[BUFFER_SIZE];
// 5 seconds of audio = 16000 Hz × 2 channels × 4 bytes = 128,000 bytes/sec
// 5 seconds = 640,000 bytes
#define TOTAL_BYTES 640000
void connectWiFi() {
Serial.printf("Connecting to WiFi: %s\n", ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
Serial.println("\nConnected!");
Serial.printf("IP Address: %s\n", WiFi.localIP().toString().c_str());
void setupI2SInput() {
i2s_config = i2s_in.defaultConfig(RX_MODE);
i2s_config.copyFrom(info);
// XVF3800 pins
i2s_config.pin_bck = 8;
i2s_config.pin_ws = 7;
i2s_config.pin_data = 44;
i2s_config.pin_data_rx = 43;
i2s_config.is_master = true;
i2s_in.begin(i2s_config);
Serial.println("I2S input started.");
while(!Serial);
AudioLogger::instance().begin(Serial, AudioLogger::Info);
connectWiFi();
setupI2SInput();
// Wait a bit for I2S to stabilize
delay(500);
Serial.printf("Sending 5 seconds of audio via UDP to %s:%d\n", udpAddress, udpPort);
size_t total_sent = 0;
size_t bytes_read = 0;
// Send audio in chunks
while (total_sent < TOTAL_BYTES) {
// Read audio data
bytes_read = i2s_in.readBytes(buffer, BUFFER_SIZE);
if (bytes_read > 0) {
// Send via UDP
udp.beginPacket(udpAddress, udpPort);
udp.write(buffer, bytes_read);
udp.endPacket();
total_sent += bytes_read;
// Progress indicator
if (total_sent % 64000 == 0) {
Serial.printf("Sent %d bytes (%.1f seconds)\n", total_sent, total_sent / 128000.0);
} else {
Serial.println("Warning: No data read from I2S");
delay(10);
Serial.printf("Finished! Sent %d bytes total\n", total_sent);
// Nothing - runs once
Use Serial Monitor (115200 baud) to confirm connection and streaming status.
Python Script (To Receive and Save the Audio)
import socket
import wave
import time
# UDP settings
udp_ip = "0.0.0.0"
udp_port = 12345
# Audio settings (must match ESP32)
SAMPLE_RATE = 16000
CHANNELS = 2
SAMPLE_WIDTH = 4 # 32-bit = 4 bytes
# Expected data size (5 seconds)
EXPECTED_BYTES = 640000
sock = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
sock.bind((udp_ip, udp_port))
sock.settimeout(2.0) # 2 second timeout
print(f"Listening for audio on {udp_ip}:{udp_port}...")
audio_data = bytearray()
last_packet_time = time.time()
try:
while True:
try:
data, addr = sock.recvfrom(4096)
if data:
audio_data.extend(data)
# Progress
if len(audio_data) % 64000 < 4096:
print(f"Received {len(audio_data)} bytes ({len(audio_data) / 128000:.1f} seconds)")
except socket.timeout:
# No data for 2 seconds - assume transmission complete
if len(audio_data) > 0:
print("Timeout - assuming transmission complete")
break
else:
print("Waiting for data...")
continue
except KeyboardInterrupt:
print("\nStopped by user")
# Save as WAV file
print(f"\nTotal received: {len(audio_data)} bytes")
print("Saving to output.wav...")
with wave.open("output.wav", "wb") as wav_file:
wav_file.setnchannels(CHANNELS)
wav_file.setsampwidth(SAMPLE_WIDTH)
wav_file.setframerate(SAMPLE_RATE)
wav_file.writeframes(bytes(audio_data))
print("Done! Audio saved to output.wav")
else:
print("No data received!")
sock.close()
Listening to the Audio
Once the file is saved (output.wav), simply open it using any audio player such as:
  • VLC
  • Windows Media Player
  • Audacity (for inspection)
