RobStride Control Library - Complete Technical Documentation
High-performance RobStride motor control baseline with implementations in Python, C++, Rust, and Arduino
License Platform Language
📋 Table of Contents
🎯 Project Overview
RobStride Control Library is a high-performance motor control library specifically designed for RobStride series motors. This project provides a complete motor control solution supporting multiple programming languages and hardware platforms, suitable for robotics, automation control, precision positioning, and various other application scenarios.
Core Features
  • Multi-language Support: Implementations in Python, C++, Rust, and Arduino
  • Multiple Control Modes: MIT Mode, Position Mode, Speed Mode
  • Real-time Performance: 50-200Hz control frequency with low latency
  • Industrial-grade Stability: Supports continuous long-term operation
  • Cross-platform Compatibility: Linux systems, ESP32, and other embedded platforms
  • Standardized Interface: Unified API design for easy language switching
Technical Advantages
  • High Performance: Direct SocketCAN communication with no middleware overhead
  • Memory Safety: Rust implementation provides memory safety guarantees
  • Real-time Control: C++ implementation achieves 200Hz control frequency
  • Ease of Use: Python implementation provides friendly interactive interface
  • Embedded Friendly: Arduino implementation suitable for resource-constrained environments
Supported Motor Models
ModelMax TorqueMax SpeedKP RangeKD Range
RS-0017 Nm50 rad/s500.05.0
RS-0117 Nm44 rad/s500.05.0
RS-0217 Nm44 rad/s500.05.0
RS-0360 Nm50 rad/s5000.0100.0
RS-04120 Nm15 rad/s5000.0100.0
RS-0517 Nm33 rad/s500.05.0
RS-0660 Nm20 rad/s5000.0100.0
Technical Architecture
System Architecture Diagram
graph TB
A[Application Layer] --> B[Control Library]
B --> C[CAN Protocol Layer]
C --> D[Hardware Interface Layer]
D --> E[CAN Hardware]
B --> F[Python Implementation]
B --> G[C++ Implementation]
B --> H[Rust Implementation]
B --> I[Arduino Implementation]
C --> J[MIT Mode]
C --> K[Position Mode]
C --> L[Speed Mode]
Communication Protocol
  • Physical Layer: CAN 2.0B Standard
  • Data Link Layer: Extended Frame Format (29-bit ID)
  • Application Layer: Custom RobStride Protocol
  • Transmission Rate: 1 Mbps
Control Mode Details
1. MIT Mode (Mode 0)
  • Features: Direct torque control with high response speed
  • Use Cases: Applications requiring fast response
  • Control Parameters: P, D, T, Position, Velocity
2. Position Mode (Mode 1)
  • Features: Position closed-loop control with precise positioning
  • Use Cases: Precision positioning, robot joint control
  • Control Parameters: Position, Velocity, Max Torque
3. Speed Mode (Mode 2)
  • Features: Speed closed-loop control with stable speed regulation
  • Use Cases: Applications requiring constant speed
  • Control Parameters: Velocity, Max Torque
Quick Start
Environment Setup
# Ubuntu/Debian system dependencies
sudo apt-get update
sudo apt-get install -y \
build-essential cmake \
python3 python3-pip \
rustc cargo \
can-utils \
gcc-avr avr-libc arduino-core
# CAN interface setup
sudo modprobe can
sudo ip link set up can0
Clone Project
git clone https://github.com/Seeed-Projects/RobStride_Control.git
cd RobStride_Control
Choose Your Language Implementation
LanguageControl FrequencyMemory UsageUse Cases
Python50-100Hz~50MBRapid prototyping, algorithm validation
C++200Hz~10MBHigh-performance applications, real-time control
Rust150Hz~8MBSafety-critical, memory safety requirements
Arduino100Hz~2KBEmbedded, resource-constrained environments
Install Dependencies
cd python
Basic Usage
#!/usr/bin/env python3
from robstride_dynamics import RobstrideBus
# Initialize CAN bus
bus = RobstrideBus('can0')
# Scan for motors
motors = bus.scan_channel()
print(f"Found motors: {motors}")
# MIT mode position control
motor_id = 1
target_position = 0.0
while True:
# Send control command
bus.write_operation_frame(
motor_id=motor_id,
p_des=target_position,
v_des=0.0,
kp=30.0,
kd=0.5,
t_ff=0.0
# Read status
response = bus.read_frame(motor_id)
print(f"Position: {response['position']:.3f} rad")
time.sleep(0.01) # 100Hz control frequency
Interactive Interface
# Run MIT position control (with interactive interface)
python3 src/position_control.py 1
# Run speed control
python3 src/velocity_control.py 1
Interactive Commands
# Interactive commands in MIT mode
kp 30.0 # Set position gain
kd 0.5 # Set velocity gain
pos 1.0 # Set target position
vel 2.0 # Set target velocity
tor 5.0 # Set feed-forward torque
quit # Exit program
Advanced Features
# Multi-motor synchronous control
motors = [1, 2, 3, 4]
bus.enable_motors(motors)
# Synchronous parameter setting
for motor_id in motors:
bus.set_motor_param(motor_id, kp=50.0, kd=1.0)
# Synchronous control
while True:
for i, motor_id in enumerate(motors):
position = math.sin(time.time() + i * math.pi/2)
bus.write_operation_frame(motor_id, position, 0, 50.0, 1.0, 0)
C++ Implementation
Build
cd cpp
mkdir build && cd build
cmake ..
make
Basic Usage
#include <iostream>
#include <thread>
#include <chrono>
#include <atomic>
class RobStrideMotor {
private:
int can_socket;
int motor_id;
std::atomic<bool> running;
public:
RobStrideMotor(int id) : motor_id(id), running(false) {
can_socket = socket(PF_CAN, SOCK_RAW, CAN_RAW);
// ... initialization code
void start() {
running = true;
std::thread control_thread(&RobStrideMotor::control_loop, this);
control_thread.detach();
void set_position(double position, double kp, double kd) {
uint8_t data[8];
// ... pack data
struct can_frame frame;
frame.can_id = 0x200 + motor_id;
frame.can_dlc = 8;
memcpy(frame.data, data, 8);
write(can_socket, &frame, sizeof(frame));
Performance Optimization
// High-performance configuration
static constexpr int CONTROL_FREQ = 200; // 200Hz
static constexpr auto CONTROL_PERIOD =
std::chrono::microseconds(1000000 / CONTROL_FREQ);
// Real-time control loop
void control_loop() {
auto next_time = std::chrono::steady_clock::now();
while (running) {
// Control logic
send_command();
// Precise timing control
next_time += CONTROL_PERIOD;
std::this_thread::sleep_until(next_time);
Run
# Requires administrator privileges
sudo ./build/robstride-mit-position 1
Rust Implementation
Build
cd rust
cargo build --release
Basic Usage
use socketcan::{CanSocket, CanFrame, EmbeddedFrame};
use std::sync::{Arc, Mutex};
use std::thread;
struct RobStrideController {
socket: Arc<Mutex<CanSocket>>,
motor_id: u8,
impl RobStrideController {
fn new(interface: &str, motor_id: u8) -> Result<Self, Box<dyn std::error::Error>> {
let socket = CanSocket::open(interface)?;
Ok(Self {
socket: Arc::new(Mutex::new(socket)),
motor_id,
fn send_position_command(
&self,
position: f32,
velocity: f32,
kp: f32,
kd: f32,
torque: f32,
) -> Result<(), Box<dyn std::error::Error>> {
let data: [u8; 8] = [
(position * 1000.0) as u8,
((position * 1000.0) / 256.0) as u8,
((position * 1000.0) / 65536.0) as u8,
((position * 1000.0) / 16777216.0) as u8,
(velocity * 1000.0) as u8,
(kp * 5.0) as u8,
(kd * 500.0) as u8,
(torque * 10.0) as u8,
let frame = CanFrame::new(
socketcan::CanId::new(0x200 + self.motor_id as u32).unwrap(),
&data,
let socket = self.socket.lock().unwrap();
socket.write_frame(&frame)?;
Ok(())
Memory Safety Features
// Multi-thread safe shared CAN interface
let controller = Arc::new(RobStrideController::new("can0", motor_id)?);
// Control thread
let ctrl_clone = Arc::clone(&controller);
thread::spawn(move || {
loop {
ctrl_clone.send_command()?;
thread::sleep(Duration::from_millis(10));
// Monitoring thread
let monitor_clone = Arc::clone(&controller);
loop {
let status = monitor_clone.read_status()?;
println!("Motor status: {:?}", status);
thread::sleep(Duration::from_millis(50));
Run
cargo run --release -- 1
Hardware Configuration
ESP32           CAN Transceiver      RobStride Motor
GPIO5 <---> TX CAN H
GPIO4 <---> RX CAN L
5V <---> VCC Power Supply
GND <---> GND Ground
Basic Code
#include <ESP32-TWAI-CAN.h>
private:
TWAI_CAN can;
uint8_t motor_id;
public:
RobStrideMotor(uint8_t id) : motor_id(id) {}
bool begin() {
can.begin(TWAI_SPEED_1000KBPS, 4, 5); // GPIO4=RX, GPIO5=TX
return true;
void send_position_command(float position, float velocity, float kp, float kd, float torque) {
can_frame_t frame;
frame.identifier = 0x200 + motor_id;
frame.extd = true;
frame.data_length_code = 8;
// Pack data
int32_t pos_int = (int32_t)(position * 1000.0);
frame.data[0] = pos_int & 0xFF;
frame.data[1] = (pos_int >> 8) & 0xFF;
frame.data[2] = (pos_int >> 16) & 0xFF;
frame.data[3] = (pos_int >> 24) & 0xFF;
frame.data[4] = (uint8_t)(velocity * 1000.0);
frame.data[5] = (uint8_t)(kp * 5.0);
frame.data[6] = (uint8_t)(kd * 500.0);
frame.data[7] = (uint8_t)(torque * 10.0);
can.writeFrame(&frame);
void enable_motor() {
can_frame_t frame;
frame.extd = true;
memset(frame.data, 0xFF, 8); // Enable command
Arduino Control Example
RobStrideMotor motor(1);
motor.begin();
// Enable motor
motor.enable_motor();
delay(100);
Serial.println("Motor enabled, starting control loop...");
static float phase = 0.0;
float target_pos = sin(phase) * 3.14159; // ±π radians
motor.send_position_command(target_pos, 0, 30.0, 0.5, 0);
phase += 0.01;
delay(10); // 100Hz control frequency
if (phase > 2 * 3.14159) {
phase = 0;
Protocol Details
CAN Frame Format
FieldSizeDescription
ID29 bitsExtended frame identifier
DLC4 bitsData length (fixed to 8)
Data8 bytesControl data
CRC16 bitsCyclic redundancy check
ID Allocation Rules
  • 0x200 + ID: MIT mode control commands
  • 0x300 + ID: Position mode control commands
  • 0x400 + ID: Speed mode control commands
  • 0x500 + ID: System status queries
  • 0x600 + ID: System configuration commands
Data Packet Format
MIT Mode Control Command (8 bytes)
struct mit_command_t {
int32_t p_des; // Target position (rad)
int16_t v_des; // Target velocity (rad/s)
uint16_t kp; // Position gain
uint16_t kd; // Velocity gain
int16_t t_ff; // Feed-forward torque (Nm)
Motor Status Feedback (8 bytes)
struct motor_status_t {
int32_t position; // Current position (rad)
int16_t velocity; // Current velocity (rad/s)
int16_t torque; // Current torque (Nm)
uint8_t mode; // Current mode
uint8_t error; // Error code
Communication Timing
sequenceDiagram
participant Host
participant Motor
Host->>Motor: Enable Command (0x200+ID)
Motor-->>Host: Enable Ack
loop Control Loop
Host->>Motor: Position Command (100Hz)
Motor-->>Host: Status Feedback
end
Host->>Motor: Disable Command
Motor-->>Host: Disable Ack
System Tuning
1. Linux Kernel Parameter Optimization
# Real-time priority setting
echo 'KERNEL=="can0", MODE="0666"' > /etc/udev/rules.d/99-can.rules
# CPU affinity binding
sudo taskset -cp 0-3 $(pgrep robstride-control)
# Memory locking (optional)
sudo sysctl -w vm.swappiness=1
2. Real-time Scheduling
#include <sched.h>
#include <sys/mman.h>
struct sched_param param;
param.sched_priority = 99;
sched_setscheduler(0, SCHED_FIFO, &param);
mlockall(MCL_CURRENT | MCL_FUTURE);
Performance Benchmarks
LanguageControl FrequencyCPU UsageLatencyMemory Usage
Python50-100Hz15-20%2-5ms~50MB
C++200Hz5-8%0.5-1ms~10MB
Rust150Hz8-12%1-2ms~8MB
Arduino100Hz40-60%1-3ms~2KB
Optimization Tips
Python Optimization
# Use C extensions for acceleration
# Pre-allocate arrays
import numpy as np
position_buffer = np.zeros(1000)
# Async I/O
import asyncio
async def control_loop():
while True:
await send_command()
await asyncio.sleep(0.01)
C++ Optimization
// Zero-copy optimization
static_assert(sizeof(motor_command_t) == 8, "Command size mismatch");
// Memory pool
class MemoryPool {
std::array<motor_command_t, 100> pool;
std::mutex mutex;
public:
motor_command_t* acquire() { /* ... */ }
void release(motor_command_t* ptr) { /* ... */ }
Rust Optimization
// Pre-allocate capacity
let mut frames: Vec<CanFrame> = Vec::with_capacity(1000);
// Avoid heap allocation
#[repr(C, packed)]
struct MotorCommand {
p_des: i32,
v_des: i16,
kp: u16,
kd: u16,
t_ff: i16,
Troubleshooting
Common Issues
1. CAN Communication Failure
# Check CAN interface status
ip -details link show can0
# Monitor CAN traffic
candump can0
# Reset CAN interface
sudo ip link set can0 down
sudo ip link set can0 up type can bitrate 1000000
2. Motor No Response
# Scan devices on bus
python3 -c "
print(f'Found motors: {motors}')
3. Performance Issues
# Check CPU usage
top -p $(pgrep robstride-control)
# Check real-time
sudo chrt -f 99 $(pgrep robstride-control)
Error Codes
CodeDescriptionSolution
0x01Communication timeoutCheck CAN connection
0x02Parameter out of rangeCheck control parameter ranges
0x03Motor overcurrentCheck load and torque limits
0x04Position overflowCheck limits and target position
0x05Temperature too highCheck cooling and load
Debug Tools
# Real-time CAN bus monitoring
candump -t A can0
# Send test frame
cansend can0 211#FFFFFFFF
# Network topology detection
canbusload can0@1000000
# Error statistics
cangen can0 -I 211 -D r
Development Guide
Project Structure
RobStride_Control/
├── cpp/ # C++ implementation
│ ├── src/ # Source code
│ ├── include/ # Header files
│ ├── tests/ # Test code
│ └── examples/ # Example code
├── python/ # Python implementation
│ ├── examples/ # Example code
│ └── tests/ # Test code
├── rust/ # Rust implementation
├── arduino/ # Arduino implementation
│ └── mi_motor_control/# ESP32 library
├── docs/ # Documentation
├── scripts/ # Utility scripts
└── tools/ # Helper tools
Contributing Guidelines
  1. Code Style
    • Python: Follow PEP 8
    • C++: Follow Google C++ Style Guide
    • Rust: Use rustfmt
    • Arduino: Follow Arduino Style Guide
  2. Commit Convention
    feat: Add new feature
    fix: Bug fix
    docs: Update documentation
    style: Code formatting changes
    refactor: Code refactoring
    test: Add tests
    chore: Build process or auxiliary tool changes
  3. Testing Requirements
    # Run all tests
    python3 -m pytest python/tests/
    cd cpp && make test
    cd rust && cargo test
Build Scripts
#!/bin/bash
# scripts/build-all.sh
echo "Building all implementations..."
# Python
cd python
python3 setup.py build
cd ..
# C++
cd cpp
mkdir -p build && cd build
cmake ..
make -j$(nproc)
cd ../..
# Rust
cd rust
cd ..
# Arduino (requires Arduino IDE)
echo "Arduino build requires Arduino IDE"
echo "Open arduino/mi_motor_control/mi_motor_control.ino"
echo "Build completed!"
Deployment Guide
Ubuntu/Debian
# Install dependencies
sudo apt-get install -y build-essential can-utils
# Build C++ version (fastest)
cd cpp/build
sudo make install
# Create system service
sudo cp scripts/robstride.service /etc/systemd/system/
sudo systemctl enable robstride
sudo systemctl start robstride
Docker
FROM ubuntu:22.04
RUN apt-get update && apt-get install -y \
rustc cargo \
can-utils
WORKDIR /app
COPY . .
# Build all versions
RUN scripts/build-all.sh
CMD ["./cpp/build/robstride-mit-position", "1"]
