How to Run VLM on reComputer with Jetson Platform Services
Introduction
vision language models (VLMs) are multi modal models supporting images, video and text and using a combination of large language models and vision transformers. Based on this capability, they are able to support text prompts to query videos and images thereby enabling capabilities such as chatting with the video, and defining natural language based alerts. The VLM AI service, enables quick deployment of VLMs with Jetson Platform Services for video insight applications. The VLM service exposes REST API endpoints to configure the video stream input, set alerts and ask questions in natural language about the input video stream.
This wiki provides a tutorial on how to run VLM on reComputer J4012 Jetson Orin NX.
Requirements
Before proceeding with the setup process, please ensure that your system meets the following prerequisites:
A reComputer J4012 Orin NX 16G running Ubuntu
22.04orlater. -
Driver Version:
535.113.01, Jetpack6.0and CUDA Version:12.2. -
Make sure that JetPack and the related Jetson services packages are installed.
sudo apt-get install nvidia-jetpack
sudo apt install nvidia-jetson-services -
IP cameras or local videos can be streamed via RTSP. (We recommend using our provided NVStreamer tutorial for RTSP streaming.)
Getting Started
Step 1: Download the application package vlm-1.1.0.tar.gz from NGC to your Jetson using this link: NGC Reference Workflow and Resources. You will need to enter your NGC credentials. On the page, use one of the options available in the Download menu (top right corner):
tar -xvf vlm-1.1.0.tar.gz
cd ~/vlm/example_1
Step 2: The VLM AI service will use the jetson-ingress and jetson-monitoring services. You need to configure these two services to integrate with the VLM AI service. Copy the provided default configuration to the corresponding service configuration directory:
sudo cp config/vlm-nginx.conf /opt/nvidia/jetson/services/ingress/config
sudo cp config/prometheus.yml /opt/nvidia/jetson/services/monitoring/config/prometheus.yml
sudo cp config/rules.yml /opt/nvidia/jetson/services/monitoring/config/rules.yml
Step 3: Run the basic services:
sudo systemctl start jetson-ingress
sudo systemctl start jetson-monitoring
sudo systemctl start jetson-sys-monitoring
sudo systemctl start jetson-gpu-monitoring
sudo systemctl start jetson-redis
sudo systemctl start jetson-vst
Step 4: When starting the VLM service for the first time, it will automatically download and quantize the VLM. This process may take some time. If deploying on Orin NX16, you might need to mount more SWAP space because the quantization process can consume a large amount of memory. Run the following commands to mount more swap space:
sudo fallocate -l 10G /data/10GB.swap
sudo mkswap /data/10GB.swap
sudo swapon /data/10GB.swap
Step 5: Start the VLM AI service:
cd ~/vlm/example_1
sudo docker compose up -d
To check if all required containers have started, you can run the following command:
sudo docker ps
Add the RTSP stream input
You can first add an RTSP stream for the VLM model to use with the following curl command. It is recommended to use the NVStreamer tutorial for streaming.
Step 1: Replace
0.0.0.0with your Jetson IP and theliveStreamUrllink with your RTSP link, then enter the following command in the terminal:curl --location 'http://0.0.0.0:5010/api/v1/live-stream' \
--header 'Content-Type: application/json' \
--data '{
"liveStreamUrl": "rtsp://0.0.0.0:31554/nvstream/root/store/nvstreamer_videos/car.mp4"
}'Note: Besides the curl command, you can also directly test the REST API through the API documentation page, which is available at
http://0.0.0.0:5010/docswhen the zero-shot detection service is started. -
Step 2: After executing the first step, an ID will be returned. You need to record this ID for use in subsequent steps:
{"id": "a782e200-eb48-4d17-a1b9-5ac0696217f7"}You can also obtain the ID later using the following command:
curl --location 'http://0.0.0.0:5010/api/v1/live-stream'To delete a stream by its ID, you can use the following command:
curl --location --request DELETE 'http://0.0.0.0:5010/api/v1/live-stream/{id}'
Set Alerts
Alerts are questions that the VLM will continuously evaluate on the live stream input. For each alert rule set, the VLM will try to decide if it is True or False based on the most recent frame from of the live stream. These True and False states as determined by the VLM, are sent to a websocket and the jetson monitoring service.
When setting alerts, the alert rule should be phrased as a yes/no question. Such as “Is there fire?” or “Is there smoke?”. The body of the request must also have the “id” field that corresponds to the stream ID that was returned when the RTSP stream was added.
By default, the VLM service supports up to 10 alert rules. This can be increased by adjusting the configuration files.
Step 1: Replace 0.0.0.0 with your reComputer IP address, modify alerts to include the objects you need to alerts, use the id returned in the previous step. After completing the command, enter the following in the terminal:
curl --location 'http://0.0.0.0:5010/api/v1/alerts' \
--data '{
"alerts": ["is there a fire?", "is there smoke?"],
View RTSP Stream Result
The detection output will be streamed through rtsp://reComputer_ip:5011/out. We provide a Python script for visualizing the video stream output, You need to install the opencv-python library in advance and then run the following Python script:
Step 1: Install the opencv-python library:
pip install opencv-python -
Step 2: Run the following Python script:
import cv2
rtsp_url = "rtsp://reComputer_ip:5011/out"
cap = cv2.VideoCapture(rtsp_url)
if not cap.isOpened():
print("Cannot open RTSP stream")
exit()
while True:
ret, frame = cap.read()
if not ret:
print("Failed to retrieve frame")
break
cv2.imshow('RTSP Stream', frame)
if cv2.waitKey(1) & 0xFF == ord('q'):
break
cap.release()
cv2.destroyAllWindows()
Shut Down
To stop the zero-shot detection service, run the following command in the same directory where the compose.yaml file is located:
sudo docker compose down
More Details
Visual Language Models (VLM) with Jetson Platform Services: https://docs.nvidia.com/jetson/jps/inference-services/vlm.html
