Seeed ePaper Displays — Product Matrix Overview
Introduction​
ePaper (electronic paper) only consumes power when its content changes, which makes it the ideal display technology for always-on information panels — digital signage, smart-home dashboards, electronic shelf labels, meeting-room boards, photo frames, and more.
Seeed Studio offers an end-to-end ePaper portfolio organized around three product lines:
  1. reTerminal E Series — fully integrated, ready-to-use ePaper terminals (just power them on).
  2. Driver / Expansion Boards — pair an MCU with universal or large-format ePaper screens to build your own product.
  3. DIY Kits & Bare Panels — designed for the maker community, optimized for specific platforms such as TRMNL or XIAO.
All three lines share the same software ecosystem: SenseCraft Seeedash (no-code), Home Assistant / ESPHome, TRMNL, Arduino / ESP-IDF / PlatformIO, Zephyr, plus visual UI tools like SquareLine Vision, EEZ Studio, and Lopaka. Pick a hardware family, and the rest of the toolchain stays the same.
Choose by Form-Factor​
If you are not sure where to start, use this decision matrix:
I want to…Recommended product lineWhy
Power on an ePaper dashboard out of the box, no soldering, no extra wiringreTerminal E Series →Battery, enclosure, T/H sensor, buzzer, buttons, and Wi-Fi all integrated. Ships with SenseCraft Seeedash firmware.
Pair an existing ePaper screen (24-pin, 50-pin, 13.3", 10.3", etc.) with an MCU and batteryDriver / Expansion Board Series →Driver boards (EE0x for ESP32-S3, EN0x for nRF52840) provide JST battery connector, charging IC, reset button, and user buttons.
Build a TRMNL-compatible dashboard with a maker-friendly DIY kitTRMNL 7.5" (OG) DIY Kit →Pre-tuned for the TRMNL platform; supports ESPHome and Arduino too.
Plug a 7.5" ePaper panel directly into a Seeed Studio XIAO moduleXIAO 7.5" ePaper Panel →Bare panel + breakout that mates with any XIAO board; minimal footprint.
reTerminal E Series — Integrated ePaper Terminals​
Four ESP32-S3 powered terminals, sharing the same enclosure family, software stack, and battery design. Differences are screen size, color vs. monochrome, touch, and battery life.
reTerminal E1001reTerminal E1002reTerminal E1003reTerminal E1004
7.5" Monochrome
4-level grayscale
~3-month battery
7.3" Full Color
E Ink Spectra 6
~3-month battery
10.3" Monochrome
16-level grayscale + Touch
~6-month battery
13.3" Full Color
E Ink Spectra 6
~6-month battery
E1001 Wiki →E1002 Wiki →E1003 Wiki →E1004 Wiki →
For a side-by-side specification comparison (resolution, refresh time, partial-refresh support, certifications, MSRP, etc.) and detailed software-support matrix, head to the dedicated reTerminal E Series Overview.
Driver / Expansion Board Series — BYO Screen​
If you already have (or want to source separately) a 24-pin, 50-pin, 10.3", or 13.3" ePaper panel, the driver-board family gives you the carrier electronics — battery management, buttons, charging IC, and the MCU.
ESP32-S3 driver boards (Wi-Fi / BLE, SenseCraft Seeedash)​
BoardTargeted screensHighlightsWiki
EE0213.3" Spectra 6Dedicated large-format color driver; Wi-Fi + BLE; ideal for digital signage.EE02 →
EE0310.3" Monochrome (high-speed refresh)Built-in T-CON timing; onboard SHT40 for waveform compensation; XIAO ESP32-S3 Plus.EE03 →
EE0424-pin / 50-pin universalJumper-selectable pin layout; works with most off-the-shelf small ePaper screens.EE04 →
EE0524-pin universal (latest)Refreshed layout of EE04; same XIAO ESP32-S3 base, latest firmware support.EE05 →
nRF52840 driver boards (BLE / NFC, ultra-low-power)​
EN0424-pin / 50-pin universalBluetooth LE + NFC; XIAO nRF52840 Plus; ideal for ESLs and offline tags.EN04 →
EN0524-pin universal (latest)Refreshed layout of EN04; same nRF52840 base with latest firmware support.EN05 →
Boards designed for XIAO modules​
BoardDescriptionWiki
XIAO eInk Expansion Board v2Plug-and-play expansion board for any XIAO module; supports popular small ePaper screens.v2 →
XIAO ePaper Breakout BoardThe original breakout board for XIAO + ePaper; well documented with OpenEpaperLink (OEPL) support.Breakout →
A consolidated ePaper Driver Board Overview is also available, with feature lists for each board side-by-side.
DIY Kits & Bare Panels​
For makers who prefer assembling everything themselves, two flexible options:
ProductWhat is in the box / what it isBest forWiki
7.5" monochrome ePaper + ESP32 driver board + acrylic stand. Pre-tuned for the TRMNL cloud platform; also runs ESPHome and Arduino.The fastest path to a TRMNL-style dashboard at the lowest BOM cost.TRMNL Kit →
Bare 7.5" ePaper panel with an FPC connector that mates directly to a XIAO module footprint.Compact, low-cost projects where you already have a XIAO and want to add a screen.XIAO Panel →
Software Ecosystem at a Glance​
Every Seeed ePaper product converges into the same software ecosystem. Pick the workflow that matches your skill level — you can mix and match:
Tool / PlatformTypeWhat it doesCompatible with
SenseCraft SeeedashNo-code (cloud)AI Generator, Gallery, Canvas, RSS / Web Content, OTA deployment. The default firmware on reTerminal E Series.reTerminal E1001 / E1002 / E1003 / E1004 · EE02 · EE03 · EE04 · EE05
ESPHome / Home AssistantYAML-basedNative Home Assistant integration; build dashboards declaratively in YAML.reTerminal E1001 / E1002 / E1004 · EE04 · TRMNL DIY Kit · XIAO 7.5" Panel
TRMNLCloud dashboardPlug-in driven dashboards (calendar, news, weather, finance, custom data).reTerminal E1001 · E1002 (mono mode) · TRMNL 7.5" DIY Kit · XIAO 7.5" Panel
Arduino / PlatformIO / ESP-IDFCode (C/C++)Full programmatic control: GPIO, sensors, network, custom rendering.All ESP32-S3 products (E1001–E1004, EE02–EE05, TRMNL Kit, XIAO Panel)
Zephyr RTOSRTOSUpstream Zephyr board workflow with west, device tree, kernel services, drivers, flashing, and debugging.reTerminal E1001 / E1002 / E1003
SquareLine VisionVisual UI designDrag-and-drop LVGL UI in the browser, then export ready-to-compile code.reTerminal E1001 / E1002
EEZ StudioVisual UI designDesign HMI screens visually and deploy through Arduino IDE.reTerminal E1001 / E1002 · EE04
LopakaVisual UI designWeb-based drawing tool that exports code for monochrome and color ePaper layouts.reTerminal E1001 / E1002
OpenEPaperLink / OpenDisplayOpen-source firmware (BLE)BLE-driven open-source ePaper firmware. OpenDisplay targets EN04 out of the box; OEPL Config Builder targets the Breakout Board + XIAO nRF52840 DIY path.EN04 · XIAO ePaper Breakout Board
Application Tutorials Index​
Each tutorial below walks through one platform end-to-end:
Smart-home & dashboard frameworks​
No-code / visual UI design tools​
Code-based development​
Open-source ESL / OEPL​
Resources​
