Connect to AWS IoT Core
AWS IoT provides the cloud services that connect your IoT devices to other devices and AWS cloud services. AWS IoT provides device software that can help you integrate your IoT devices into AWS IoT-based solutions. If your devices can connect to AWS IoT, AWS IoT can connect them to the cloud services that AWS provides.
Login to AWS IoT console
If you do not have an AWS account, click here to create one.
Add Gateway
Navigate to Internet of Things, then click IoT Core.
On the left menu, select LPWAN devices → Gateways, click Add gateway
Gateway's EUI: The EUI of your gateway, you can find it on the device label.
Frequency: The gateway's frequency band.
Name: Name your gateway(optional)
SubBand: Optionally, you can also specify LoRaWAN configuration data such as the subbands that you want to use and filters that can control the flow of traffic. For more information, see Configure position of wireless resources with AWS IoT Core for LoRaWAN.
Configure your gateway
Gateway Certificate
To authenticate your gateway so that it can securely communicate with AWS IoT, your LoRaWAN gateway must present a private key and certificate to AWS IoT Core for LoRaWAN.
Click Create certificate.
Download and save the certificate files and the server trust certificates.
There shoule be four files inside, you'll use them later to configure the gateway.
Gateway Permission
If you haven't created the IoTWirelessGatewayCertManagerRole IAM role for your account, create the role before you continue adding the gateway. Your gateways won't be able to communicate with AWS IoT without this role.
Choose the Role: IoT Wireless Gateway Cert Manager Role, then submit the configuration.
Copy the CUPS URL, we will use it in the next step.
Gateway Configuration
Login to the Luci configure page of the gateway, check Get_Started for more details.
Navigate to LoRa > LoRa Network.
Mode: Basic Station
Gateway EUI: Your gateway eui
Server: CUPS Server
URL: The CUPS URL we copied before
Authentication Mode: TLS Server and Client Authentication
Copy the content of the certificate file we downloaded before(the certificate can be opened in text form).
Navigate to the Gateways page and choose the gateway you've added.
In the LoRaWAN specific details section of the Gateway details page, you'll see the connection status and the date and time the last uplink was received.
Add Profiles
Device and service profiles can be defined to describe common device configurations. These profiles describe configuration parameters that are shared by devices to make it easier to add those devices. AWS IoT Core for LoRaWAN supports device profiles and service profiles.
Add Devices Profiles
Navigate to Devices > Profiles, click Add device profile.
Provide a Device profile name, select the Frequency band (RfRegion) that you're using for the device and gateway, and keep the other settings to the default values.
Add Service Profiles
Navigate to Devices > Profiles, click Add service profile
It's recommend that you leave the setting Add gateway meta data enabled so that you'll receive additional gateway meta data for each payload, such as RSSI and SNR for the data transmission.
Add Destination
Navigate to LPWAN Devices > Destination, click Add destination.
Here select Publish to AWS IoT Core Message Broker and name the destination's MQTT topic
Permissions: Select an existing service role > IoT Wireless Gateway Cert Manager Role
A destination name can only have alphanumeric, - (hyphen) and _ (underscore) characters and it can't have any spaces.
Add LoRaWAN Devices
Add Wireless Device
Navigate to LPWAN devices > LoRaWAN> Devices, click Add wireless device.
Wireless device specification: OTAA v1.0x
DevEUI / AppEUI / AppKey: can be found in the SenseCraft APP, check Get_Started for more details.
Select the device profile and destination you created in the previous step.
Navigate to the Devices page and choose the device you added before.
In the Details section of the Wireless devices details page, you'll see the date received.
Configure the decoder
Create Message Rules
Navigate to Message routing tab → Rules, and click Create Rule button.
Name your rule and submit it.
SQL version: 2016-03-23
SQL statement: SELECT * FROM "YourDestinationTopic"
Here we fill in t2000-raw according to Add Destination
Scroll down to Rule actions section, and select Lambda from Action 1, then click Create a Lambda function.
Function name: Name your function.
Runtime: Node.js 24.x
Architexture: x86_64
Click Create function button to create a new function.
After creating the function, it goes to the function's config page. We will configure it later so just go back to the rules page.
Click the Refresh button and select the Lambda function you create before. Then click Next to Step 4.
Check that all details of the rule are correct, then click Create to create the rule.
Configure the Lambda Function
Back to Message routing tab → Rules, select the rule you created before.
Click Lambda from Actions and then click the link to go to the Lambda function configuration page.
On the following funcition config page, rename the index.mjs file to index.js, remove all the code and replace it with the script from Resource, then click Deploy button.
Decoder for AWS
const {IoTDataPlaneClient, PublishCommand} = require("@aws-sdk/client-iot-data-plane");
const client = new IoTDataPlaneClient({
//Replace the region according to your device.
"region": "us-east-1"
function decodeUplink (input) {
const bytes = Buffer.from(input, 'base64');
console.log("bytes: ", bytes)
const bytesString = bytes2HexString(bytes)
const originMessage = bytesString.toLocaleUpperCase()
const decoded = {
valid: true,
err: 0,
payload: bytesString,
messages: []
let measurement = messageAnalyzed(originMessage)
if (measurement.length === 0) {
decoded.valid = false
return { data: decoded }
for (let message of measurement) {
if (message.length === 0) {
continue
let elements = []
for (let element of message) {
if (element.errorCode) {
decoded.err = element.errorCode
decoded.errMessage = element.error
} else {
elements.push(element)
if (elements.length > 0) {
decoded.messages.push(elements)
function messageAnalyzed (messageValue) {
try {
let frames = unpack(messageValue)
let measurementResultArray = []
for (let i = 0; i < frames.length; i++) {
let item = frames[i]
let dataId = item.dataId
let dataValue = item.dataValue
let measurementArray = deserialize(dataId, dataValue)
measurementResultArray.push(measurementArray)
return measurementResultArray
} catch (e) {
return e.toString()
function unpack (messageValue) {
let frameArray = []
const FIXED_LENGTH_PACKAGES = {
'27': 92, '28': 60, '29': 24, '2A': 12, '2B': 46, '2E': 34, '31': 30, '32': 18
const DYNAMIC_LENGTH_PACKAGES = {
'2C': {minLen: 32, scanCountPos: [30, 32], baseLen: 23, itemLen: 7},
'2D': {minLen: 32, scanCountPos: [30, 32], baseLen: 23, itemLen: 7},
'2F': {minLen: 20, scanCountPos: [18, 20], baseLen: 17, itemLen: 7},
'30': {minLen: 20, scanCountPos: [18, 20], baseLen: 17, itemLen: 7}
for (let i = 0; i < messageValue.length; i++) {
let remainMessage = messageValue
let dataId = remainMessage.substring(0, 2).toUpperCase()
let dataValue
let dataObj = {}
if (dataId === '0C') {
dataValue = ''
messageValue = remainMessage.substring(2)
dataObj = {'dataId': dataId, 'dataValue': ''}
} else if (dataId === '0D') {
dataValue = remainMessage.substring(2, 10)
messageValue = remainMessage.substring(10)
dataObj = {'dataId': dataId, 'dataValue': dataValue}
} else if (FIXED_LENGTH_PACKAGES[dataId]) {
let packageLen = FIXED_LENGTH_PACKAGES[dataId]
if (remainMessage.length < packageLen) {
return frameArray
dataValue = remainMessage.substring(2, packageLen)
messageValue = remainMessage.substring(packageLen)
} else if (DYNAMIC_LENGTH_PACKAGES[dataId]) {
let config = DYNAMIC_LENGTH_PACKAGES[dataId]
if (remainMessage.length < config.minLen) {
return frameArray
let scanCount = parseInt(remainMessage.substring(config.scanCountPos[0], config.scanCountPos[1]), 16)
let packageLen = (config.baseLen + (scanCount - 1) * config.itemLen) * 2
return frameArray
} else {
return frameArray
if (dataValue.length < 2 && dataObj.dataId !== '0C') {
break
frameArray.push(dataObj)
return frameArray
function deserialize (dataId, dataValue) {
let measurementArray = []
let eventList = []
let timestamp = 0
let value = null
let motionId = 0
let scanMax = 0
let interval = 0
let workMode = 0
let heartbeatInterval = 0
let periodicInterval = 0
let eventInterval = 0
switch (dataId) {
case '0C':
measurementArray.push({type: "timeSync"})
break
case '0D':
let errorCode = getInt(dataValue)
let error = ''
switch (errorCode) {
case 1:
error = 'FAILED TO OBTAIN THE UTC TIMESTAMP'
break
case 2:
error = 'ALMANAC TOO OLD'
break
case 3:
error = 'DOPPLER ERROR'
break
measurementArray.push({errorCode, error})
break
case '27':
measurementArray.push(...getUpT2000(dataValue))
break
case '28':
interval = 0
workMode = getInt(dataValue.substring(0, 2))
heartbeatInterval = getMinsByMin(dataValue.substring(4, 8))
periodicInterval = getMinsByMin(dataValue.substring(8, 12))
eventInterval = getMinsByMin(dataValue.substring(12, 16))
switch (workMode) {
case 0:
interval = heartbeatInterval
break
case 1:
interval = periodicInterval
break
case 2:
interval = eventInterval
break
measurementId: '3940', measurementValue: workMode
measurementId: '3965', measurementValue: getPositioningStrategy(dataValue.substring(2, 4))
measurementId: '3942', measurementValue: heartbeatInterval
measurementId: '3943', measurementValue: periodicInterval
measurementId: '3944', measurementValue: eventInterval
measurementId: '3974', measurementValue: getInt(dataValue.substring(16, 18))
measurementId: '3976', measurementValue: getInt(dataValue.substring(18, 20))
measurementId: '3977', measurementValue: getInt(dataValue.substring(20, 22))
measurementId: '3900', measurementValue: interval
measurementId: '3978', measurementValue: getInt(dataValue.substring(22, 24))
measurementId: '3979', measurementValue: dataValue.substring(26, 26 + getInt(dataValue.substring(24, 26)) * 2)
// measurementArray.push(measurement)
break
case '29':
measurementId: '3946', measurementValue: getInt(dataValue.substring(0, 2))
measurementId: '3947', measurementValue: getSensorValue(dataValue.substring(2, 6), 1)
measurementId: '3948', measurementValue: getMinsByMin(dataValue.substring(6, 10))
measurementId: '3949', measurementValue: getInt(dataValue.substring(10, 12))
measurementId: '3950', measurementValue: getMinsByMin(dataValue.substring(12, 16))
measurementId: '3951', measurementValue: getInt(dataValue.substring(16, 18))
measurementId: '3952', measurementValue: getInt(dataValue.substring(18, 22))
break
case '2A':
measurementId: '3000', measurementValue: getBattery(dataValue.substring(0, 2))
measurementId: '3940', measurementValue: getWorkingMode(dataValue.substring(2, 4))
measurementId: '3965', measurementValue: getPositioningStrategy(dataValue.substring(4, 6))
measurementId: '3974', measurementValue: getInt(dataValue.substring(6, 8))
measurementId: '3976', measurementValue: getInt(dataValue.substring(8, 10))
break
case '2B':
eventList = getEventStatus(dataValue.substring(0, 4))
motionId = getMotionId(dataValue.substring(4, 6))
timestamp = getUTCTimestamp(dataValue.substring(6, 14))
parseAccelerometerData(dataValue, 14, timestamp, motionId, measurementArray)
parseLocationData(dataValue, 26, timestamp, motionId, measurementArray)
parseBatteryData(dataValue, 42, timestamp, motionId, measurementArray)
parseEventData(eventList, timestamp, motionId, measurementArray)
break
case '2C':
case '2D':
parseBatteryData(dataValue, 26, timestamp, motionId, measurementArray)
scanMax = getInt(dataValue.substring(28, 30))
parseScanData(scanMax, dataValue, 30, dataId === '2C' ? '5001' : '5002', timestamp, motionId, measurementArray)
break
case '2E':
parseLocationData(dataValue, 14, timestamp, motionId, measurementArray)
parseBatteryData(dataValue, 30, timestamp, motionId, measurementArray)
break
case '2F':
case '30':
parseBatteryData(dataValue, 14, timestamp, motionId, measurementArray)
scanMax = getInt(dataValue.substring(16, 18))
parseScanData(scanMax, dataValue, 18, dataId === '2F' ? '5001' : '5002', timestamp, motionId, measurementArray)
break
case '31':
eventList = getEventStatus(dataValue.substring(2, 6))
measurementId: '3576',
timestamp,
motionId,
measurementValue: getPositingStatus(dataValue.substring(0, 2))
break
case '32':
timestamp,
motionId,
break
if (measurementArray.length > 0) {
for (let frag of measurementArray) {
if (frag.measurementId) {
frag.type = getTypeByMeasurementId(frag.measurementId)
return measurementArray
function parseAccelerometerData (dataValue, startPos, timestamp, motionId, measurementArray) {
const accelerometerIds = ['4210', '4211', '4212']
for (let i = 0; i < 3; i++) {
let value = getSignSensorValue(dataValue.substring(startPos + i * 4, startPos + (i + 1) * 4), 1)
if (value !== null) {
measurementId: accelerometerIds[i],
timestamp,
motionId,
measurementValue: value
function parseBatteryData (dataValue, pos, timestamp, motionId, measurementArray) {
timestamp,
motionId,
measurementValue: '' + getBattery(dataValue.substring(pos, pos + 2))
function parseEventData (eventList, timestamp, motionId, measurementArray) {
if (eventList && eventList.length > 0) {
measurementId: '4200',
timestamp,
motionId,
measurementValue: eventList
function parseLocationData (dataValue, startPos, timestamp, motionId, measurementArray) {
measurementId: '4197',
timestamp,
motionId,
measurementValue: '' + getSensorValue(dataValue.substring(startPos, startPos + 8), 1000000)
measurementId: '4198',
timestamp,
motionId,
measurementValue: '' + getSensorValue(dataValue.substring(startPos + 8, startPos + 16), 1000000)
function parseScanData (scanMax, dataValue, startPos, measurementId, timestamp, motionId, measurementArray) {
if (scanMax && scanMax > 0) {
measurementId,
timestamp,
motionId,
measurementValue: getMacAndRssiObj(dataValue.substring(startPos))
function getTypeByMeasurementId (measurementId) {
const TYPE_MAP = {
'3000': 'Battery',
'3502': 'Firmware Version',
'3001': 'Hardware Version',
'3940': 'Work Mode',
'3965': 'Positioning Strategy',
'3942': 'Heartbeat Interval',
'3943': 'Periodic Interval',
'3944': 'Event Interval',
'3974': '3X Sensor Enable',
'3976': 'Anti-Theft',
'3977': 'GNSS Scan Timeout',
'3900': 'Uplink Interval',
'3978': 'BLE Scan Timeout',
'3979': 'UUID Filter',
'3946': 'Motion Enable',
'3947': 'Any Motion Threshold',
'3948': 'Motion Start Interval',
'3949': 'Static Enable',
'3950': 'Device Static Timeout',
'3951': 'Shock Enable',
'3952': 'Shock Threshold',
'4210': 'AccelerometerX',
'4211': 'AccelerometerY',
'4212': 'AccelerometerZ',
'4197': 'Longitude',
'4198': 'Latitude',
'4200': 'Event Status',
'5001': 'Wi-Fi Scan',
'5002': 'BLE Scan',
'3576': 'Positioning Status'
return TYPE_MAP[measurementId] || ''
function getMotionId (str) {
return getInt(str)
function getPositingStatus (str) {
let status = getInt(str)
const STATUS_MAP = {
0: "locate successful.",
1: "The GNSS scan timed out.",
2: "The Wi-Fi scan timed out.",
3: "The Wi-Fi + GNSS scan timed out.",
4: "The GNSS + Wi-Fi scan timed out.",
5: "The Bluetooth scan timed out.",
6: "The Bluetooth + Wi-Fi scan timed out.",
7: "The Bluetooth + GNSS scan timed out.",
8: "The Bluetooth + Wi-Fi + GNSS scan timed out.",
9: "Location Server failed to parse the GNSS location.",
10: "Location Server failed to parse the Wi-Fi location.",
11: "Location Server failed to parse the Bluetooth location.",
12: "Failed to parse location due to the poor accuracy.",
13: "Time synchronization failed.",
14: "Failed due to the old Almanac.",
15: "The GNSS +Bluetooth scan timed out."
if (STATUS_MAP[status] !== undefined) {
return {id: status, statusName: STATUS_MAP[status]}
return getInt(str)
function getUpT2000 (messageValue) {
let interval = 0
let workMode = getInt(messageValue.substring(10, 12))
let heartbeatInterval = getMinsByMin(messageValue.substring(14, 18))
let periodicInterval = getMinsByMin(messageValue.substring(18, 22))
let eventInterval = getMinsByMin(messageValue.substring(22, 26))
switch (workMode) {
case 0:
break
case 1:
break
case 2:
break
let data = [
measurementId: '3000', measurementValue: getBattery(messageValue.substring(0, 2))
measurementId: '3502', measurementValue: getSoftVersion(messageValue.substring(2, 6))
measurementId: '3001', measurementValue: getHardVersion(messageValue.substring(6, 10))
measurementId: '3965', measurementValue: getPositioningStrategy(messageValue.substring(12, 14))
measurementId: '3974', measurementValue: getInt(messageValue.substring(26, 28))
measurementId: '3976', measurementValue: getInt(messageValue.substring(28, 30))
measurementId: '3977', measurementValue: getInt(messageValue.substring(30, 32))
measurementId: '3978', measurementValue: getInt(messageValue.substring(54, 56))
measurementId: '3979', measurementValue: messageValue.substring(58, 58 + getInt(messageValue.substring(56, 58)) * 2)
let motionSetting = getMotionSetting(messageValue.substring(32, 42))
let staticsSetting = getStaticSetting(messageValue.substring(42, 48))
let shockSetting = getShockSetting(messageValue.substring(48, 54))
data = [...data, ...motionSetting, ...staticsSetting, ...shockSetting]
return data
function getMotionSetting (str) {
return [
{measurementId: '3946', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3947', measurementValue: getSensorValue(str.substring(2, 6), 1)},
{measurementId: '3948', measurementValue: getMinsByMin(str.substring(6, 10))},
function getStaticSetting (str) {
return [
{measurementId: '3949', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3950', measurementValue: getMinsByMin(str.substring(2, 6))}
function getShockSetting (str) {
return [
{measurementId: '3951', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3952', measurementValue: getInt(str.substring(2, 6))}
function getBattery (batteryStr) {
return loraWANV2DataFormat(batteryStr)
function getSoftVersion (softVersion) {
return `${loraWANV2DataFormat(softVersion.substring(0, 2))}.${loraWANV2DataFormat(softVersion.substring(2, 4))}`
function getHardVersion (hardVersion) {
return `${loraWANV2DataFormat(hardVersion.substring(0, 2))}.${loraWANV2DataFormat(hardVersion.substring(2, 4))}`
function getMinsByMin (str) {
return getInt(str)
function getSensorValue (str, dig) {
if (str === '8000') {
return null
} else {
return loraWANV2DataFormat(str, dig)
function isNull (str) {
if (str.substring(0, 1) !== '8') {
return false
for (let i = 1; i < str.length; i++) {
if (str.substring(i, i + 1) !== '0') {
return false
return true
function getSignSensorValue (str, dig = 1) {
if (isNull(str)) {
return null
function bytes2HexString (arrBytes) {
var str = ''
for (var i = 0; i < arrBytes.length; i++) {
var tmp
var num = arrBytes[i]
if (num < 0) {
tmp = (255 + num + 1).toString(16)
} else {
tmp = num.toString(16)
if (tmp.length === 1) {
tmp = '0' + tmp
str += tmp
return str
function loraWANV2DataFormat (str, divisor = 1) {
let strReverse = bigEndianTransform(str)
let str2 = toBinary(strReverse)
if (str2.substring(0, 1) === '1') {
let arr = str2.split('')
let reverseArr = arr.map((item) => {
if (parseInt(item) === 1) {
return 0
} else {
return 1
str2 = parseInt(reverseArr.join(''), 2) + 1
return parseFloat('-' + str2 / divisor)
return parseInt(str2, 2) / divisor
function bigEndianTransform (data) {
let dataArray = []
for (let i = 0; i < data.length; i += 2) {
dataArray.push(data.substring(i, i + 2))
return dataArray
function toBinary (arr) {
let binaryData = arr.map((item) => {
let data = parseInt(item, 16)
.toString(2)
let dataLength = data.length
if (data.length !== 8) {
for (let i = 0; i < 8 - dataLength; i++) {
data = `0` + data
return data
return binaryData.toString().replace(/,/g, '')
function getMacAndRssiObj (pair) {
let pairs = []
if (pair.length % 14 === 0) {
for (let i = 0; i < pair.length; i += 14) {
let mac = getMacAddress(pair.substring(i, i + 12))
if (mac) {
let rssi = getInt8RSSI(pair.substring(i + 12, i + 14))
pairs.push({mac: mac, rssi: rssi})
} else {
continue
return pairs
function getMacAddress (str) {
if (str.toLowerCase() === 'ffffffffffff') {
return null
let macArr = []
if (i % 2 === 1) {
macArr.push(str.substring(i - 1, i + 1))
let mac = ''
for (let i = 0; i < macArr.length; i++) {
mac = mac + macArr[i]
if (i < macArr.length - 1) {
mac = mac + ':'
return mac
function getInt8RSSI (str) {
return loraWANV2DataFormat(str)
function getInt (str) {
return parseInt(str, 16)
function getEventStatus (str) {
let bitStr = getByteArray(str)
let bitArr = []
for (let i = 0; i < bitStr.length; i++) {
bitArr[i] = bitStr.substring(i, i + 1)
bitArr = bitArr.reverse()
const EVENT_MAP = {
0: {id: 1, eventName: "Start moving event."},
1: {id: 2, eventName: "End movement event."},
2: {id: 3, eventName: "Motionless event."},
3: {id: 4, eventName: "Shock event."},
4: {id: 5, eventName: "Temperature event."},
5: {id: 6, eventName: "Light event."},
6: {id: 7, eventName: "SOS event."},
7: {id: 8, eventName: "Press once event."},
8: {id: 9, eventName: "disassembled event"}
let event = []
for (let i = 0; i < bitArr.length; i++) {
if (bitArr[i] === '1' && EVENT_MAP[i]) {
event.push(EVENT_MAP[i])
return event
function getByteArray (str) {
let bytes = []
for (let i = 0; i < str.length; i += 2) {
bytes.push(str.substring(i, i + 2))
return toBinary(bytes)
function getWorkingMode (workingMode) {
return getInt(workingMode)
function getPositioningStrategy (strategy) {
return getInt(strategy)
function getUTCTimestamp(str){
return parseInt(loraWANV2PositiveDataFormat(str)) * 1000
function loraWANV2PositiveDataFormat (str, divisor = 1) {
exports.handler = async (event) => {
try {
const lorawan_info = event["WirelessMetadata"]["LoRaWAN"];
const lorawan_data = event["PayloadData"];
const resolved_data = decodeUplink(lorawan_data, lorawan_info["FPort"])["data"];
console.log("decoded message:", JSON.stringify(resolved_data))
// publish all measurement data
const input = { // PublishRequest
topic: 'tracker/measurement',
qos: 0,
retain: false,
payload: JSON.stringify({
eui: lorawan_info["DevEui"],
timestamp: lorawan_info["Timestamp"],
data: resolved_data
const command = new PublishCommand(input);
const response = await client.send(command);
console.log("response: " + JSON.stringify(response));
return {
statusCode: 200,
body: 'Message published successfully' + JSON.stringify(event)
} catch (error) {
console.error('Error publishing message:', error);
return {
statusCode: 500,
body: 'Error publishing message'
After configuring the decoder, Click Configuration → Permissions → Edit.
Click View the xxxxxxxxxxx role at the bottom.
Click Add permissions → Attach policies.
Search AdministratorAccess, check the box left it, and then click Add Permissions.
Check the data
Check the data on page MQTT test client, input # and click Subscribe button, you will see the data.
The raw payload of T2000 Tracker publish from t2000-raw and the decoded data publish from tracker/measurement.
Resource
SenseCAP T2000 Tracker Decoder for AWS
