Connecting to Helium
Helium console is a management platform in the Helium network for registering, configuring, and routing data from LoRaWAN devices, enabling rapid IoT deployment. This section will teach you how to quickly integrate your device into Helium.
Device Configuration
Before connecting to Helium, you need to configure the basic parameters of your device on SenseCraft APP, check Get Started for more details.
  • Set the platform to Helium, and then copy the Device EUI/App EUI/App Key.
Helium Console Configuration
note
The Helium console is no longer open for new accounts. The description for how to connect a T2000 to the Helium Console remains here for users that already have an account. For new users, please refer to the ChirpStack LNS steps below or determine the necessary steps for your particular LNS based on the two existing examples here.
Step 1: Add New Device
Log into your Helium console, then go to Devices section and click on Add device button.
Fill the required fields such as the device name, the LoRaWAN credentials, etc.
Then click the Save Device button.
Step 2: Create the Decoder Function
The next step is to setup the function that will decode the raw bytes into a human readable form.
Head to Function tab on the panel at the left side. Then click the Add New Function button and give it a name:
Copy the following code to fill in the CUSTOM SCRIPT and then save the changes.
Decoder for Helium
function Decoder (bytes, port) {
const bytesString = bytes2HexString(bytes)
const originMessage = bytesString.toLocaleUpperCase()
const decoded = {
valid: true,
err: 0,
payload: bytesString,
messages: []
let measurement = messageAnalyzed(originMessage)
if (measurement.length === 0) {
decoded.valid = false
return { data: decoded }
for (let message of measurement) {
if (message.length === 0) {
continue
let elements = []
for (let element of message) {
if (element.errorCode) {
decoded.err = element.errorCode
decoded.errMessage = element.error
} else {
elements.push(element)
if (elements.length > 0) {
decoded.messages.push(elements)
function messageAnalyzed (messageValue) {
try {
let frames = unpack(messageValue)
let measurementResultArray = []
for (let i = 0; i < frames.length; i++) {
let item = frames[i]
let dataId = item.dataId
let dataValue = item.dataValue
let measurementArray = deserialize(dataId, dataValue)
measurementResultArray.push(measurementArray)
return measurementResultArray
} catch (e) {
return e.toString()
function unpack (messageValue) {
let frameArray = []
const FIXED_LENGTH_PACKAGES = {
'27': 92, '28': 60, '29': 24, '2A': 12, '2B': 46, '2E': 34, '31': 30, '32': 18
const DYNAMIC_LENGTH_PACKAGES = {
'2C': {minLen: 32, scanCountPos: [30, 32], baseLen: 23, itemLen: 7},
'2D': {minLen: 32, scanCountPos: [30, 32], baseLen: 23, itemLen: 7},
'2F': {minLen: 20, scanCountPos: [18, 20], baseLen: 17, itemLen: 7},
'30': {minLen: 20, scanCountPos: [18, 20], baseLen: 17, itemLen: 7}
for (let i = 0; i < messageValue.length; i++) {
let remainMessage = messageValue
let dataId = remainMessage.substring(0, 2).toUpperCase()
let dataValue
let dataObj = {}
if (dataId === '0C') {
dataValue = ''
messageValue = remainMessage.substring(2)
dataObj = {'dataId': dataId, 'dataValue': ''}
} else if (dataId === '0D') {
dataValue = remainMessage.substring(2, 10)
messageValue = remainMessage.substring(10)
dataObj = {'dataId': dataId, 'dataValue': dataValue}
} else if (FIXED_LENGTH_PACKAGES[dataId]) {
let packageLen = FIXED_LENGTH_PACKAGES[dataId]
if (remainMessage.length < packageLen) {
return frameArray
dataValue = remainMessage.substring(2, packageLen)
messageValue = remainMessage.substring(packageLen)
} else if (DYNAMIC_LENGTH_PACKAGES[dataId]) {
let config = DYNAMIC_LENGTH_PACKAGES[dataId]
if (remainMessage.length < config.minLen) {
return frameArray
let scanCount = parseInt(remainMessage.substring(config.scanCountPos[0], config.scanCountPos[1]), 16)
let packageLen = (config.baseLen + (scanCount - 1) * config.itemLen) * 2
return frameArray
} else {
return frameArray
if (dataValue.length < 2 && dataObj.dataId !== '0C') {
break
frameArray.push(dataObj)
return frameArray
function deserialize (dataId, dataValue) {
let measurementArray = []
let eventList = []
let timestamp = 0
let value = null
let motionId = 0
let scanMax = 0
let interval = 0
let workMode = 0
let heartbeatInterval = 0
let periodicInterval = 0
let eventInterval = 0
switch (dataId) {
case '0C':
measurementArray.push({type: "timeSync"})
break
case '0D':
let errorCode = getInt(dataValue)
let error = ''
switch (errorCode) {
case 1:
error = 'FAILED TO OBTAIN THE UTC TIMESTAMP'
break
case 2:
error = 'ALMANAC TOO OLD'
break
case 3:
error = 'DOPPLER ERROR'
break
measurementArray.push({errorCode, error})
break
case '27':
measurementArray.push(...getUpT2000(dataValue))
break
case '28':
interval = 0
workMode = getInt(dataValue.substring(0, 2))
heartbeatInterval = getMinsByMin(dataValue.substring(4, 8))
periodicInterval = getMinsByMin(dataValue.substring(8, 12))
eventInterval = getMinsByMin(dataValue.substring(12, 16))
switch (workMode) {
case 0:
interval = heartbeatInterval
break
case 1:
interval = periodicInterval
break
case 2:
interval = eventInterval
break
measurementId: '3940', measurementValue: workMode
measurementId: '3965', measurementValue: getPositioningStrategy(dataValue.substring(2, 4))
measurementId: '3942', measurementValue: heartbeatInterval
measurementId: '3943', measurementValue: periodicInterval
measurementId: '3944', measurementValue: eventInterval
measurementId: '3974', measurementValue: getInt(dataValue.substring(16, 18))
measurementId: '3976', measurementValue: getInt(dataValue.substring(18, 20))
measurementId: '3977', measurementValue: getInt(dataValue.substring(20, 22))
measurementId: '3900', measurementValue: interval
measurementId: '3978', measurementValue: getInt(dataValue.substring(22, 24))
measurementId: '3979', measurementValue: dataValue.substring(26, 26 + getInt(dataValue.substring(24, 26)) * 2)
// measurementArray.push(measurement)
break
case '29':
measurementId: '3946', measurementValue: getInt(dataValue.substring(0, 2))
measurementId: '3947', measurementValue: getSensorValue(dataValue.substring(2, 6), 1)
measurementId: '3948', measurementValue: getMinsByMin(dataValue.substring(6, 10))
measurementId: '3949', measurementValue: getInt(dataValue.substring(10, 12))
measurementId: '3950', measurementValue: getMinsByMin(dataValue.substring(12, 16))
measurementId: '3951', measurementValue: getInt(dataValue.substring(16, 18))
measurementId: '3952', measurementValue: getInt(dataValue.substring(18, 22))
break
case '2A':
measurementId: '3000', measurementValue: getBattery(dataValue.substring(0, 2))
measurementId: '3940', measurementValue: getWorkingMode(dataValue.substring(2, 4))
measurementId: '3965', measurementValue: getPositioningStrategy(dataValue.substring(4, 6))
measurementId: '3974', measurementValue: getInt(dataValue.substring(6, 8))
measurementId: '3976', measurementValue: getInt(dataValue.substring(8, 10))
break
case '2B':
eventList = getEventStatus(dataValue.substring(0, 4))
motionId = getMotionId(dataValue.substring(4, 6))
timestamp = getUTCTimestamp(dataValue.substring(6, 14))
parseAccelerometerData(dataValue, 14, timestamp, motionId, measurementArray)
parseLocationData(dataValue, 26, timestamp, motionId, measurementArray)
parseBatteryData(dataValue, 42, timestamp, motionId, measurementArray)
parseEventData(eventList, timestamp, motionId, measurementArray)
break
case '2C':
case '2D':
parseBatteryData(dataValue, 26, timestamp, motionId, measurementArray)
scanMax = getInt(dataValue.substring(28, 30))
parseScanData(scanMax, dataValue, 30, dataId === '2C' ? '5001' : '5002', timestamp, motionId, measurementArray)
break
case '2E':
parseLocationData(dataValue, 14, timestamp, motionId, measurementArray)
parseBatteryData(dataValue, 30, timestamp, motionId, measurementArray)
break
case '2F':
case '30':
parseBatteryData(dataValue, 14, timestamp, motionId, measurementArray)
scanMax = getInt(dataValue.substring(16, 18))
parseScanData(scanMax, dataValue, 18, dataId === '2F' ? '5001' : '5002', timestamp, motionId, measurementArray)
break
case '31':
eventList = getEventStatus(dataValue.substring(2, 6))
measurementId: '3576',
timestamp,
motionId,
measurementValue: getPositingStatus(dataValue.substring(0, 2))
break
case '32':
timestamp,
motionId,
break
if (measurementArray.length > 0) {
for (let frag of measurementArray) {
if (frag.measurementId) {
frag.type = getTypeByMeasurementId(frag.measurementId)
return measurementArray
function parseAccelerometerData (dataValue, startPos, timestamp, motionId, measurementArray) {
const accelerometerIds = ['4210', '4211', '4212']
for (let i = 0; i < 3; i++) {
let value = getSignSensorValue(dataValue.substring(startPos + i * 4, startPos + (i + 1) * 4), 1)
if (value !== null) {
measurementId: accelerometerIds[i],
timestamp,
motionId,
measurementValue: value
function parseBatteryData (dataValue, pos, timestamp, motionId, measurementArray) {
timestamp,
motionId,
measurementValue: '' + getBattery(dataValue.substring(pos, pos + 2))
function parseEventData (eventList, timestamp, motionId, measurementArray) {
if (eventList && eventList.length > 0) {
measurementId: '4200',
timestamp,
motionId,
measurementValue: eventList
function parseLocationData (dataValue, startPos, timestamp, motionId, measurementArray) {
measurementId: '4197',
timestamp,
motionId,
measurementValue: '' + getSensorValue(dataValue.substring(startPos, startPos + 8), 1000000)
measurementId: '4198',
timestamp,
motionId,
measurementValue: '' + getSensorValue(dataValue.substring(startPos + 8, startPos + 16), 1000000)
function parseScanData (scanMax, dataValue, startPos, measurementId, timestamp, motionId, measurementArray) {
if (scanMax && scanMax > 0) {
measurementId,
timestamp,
motionId,
measurementValue: getMacAndRssiObj(dataValue.substring(startPos))
function getTypeByMeasurementId (measurementId) {
const TYPE_MAP = {
'3000': 'Battery',
'3502': 'Firmware Version',
'3001': 'Hardware Version',
'3940': 'Work Mode',
'3965': 'Positioning Strategy',
'3942': 'Heartbeat Interval',
'3943': 'Periodic Interval',
'3944': 'Event Interval',
'3974': '3X Sensor Enable',
'3976': 'Anti-Theft',
'3977': 'GNSS Scan Timeout',
'3900': 'Uplink Interval',
'3978': 'BLE Scan Timeout',
'3979': 'UUID Filter',
'3946': 'Motion Enable',
'3947': 'Any Motion Threshold',
'3948': 'Motion Start Interval',
'3949': 'Static Enable',
'3950': 'Device Static Timeout',
'3951': 'Shock Enable',
'3952': 'Shock Threshold',
'4210': 'AccelerometerX',
'4211': 'AccelerometerY',
'4212': 'AccelerometerZ',
'4197': 'Longitude',
'4198': 'Latitude',
'4200': 'Event Status',
'5001': 'Wi-Fi Scan',
'5002': 'BLE Scan',
'3576': 'Positioning Status'
return TYPE_MAP[measurementId] || ''
function getMotionId (str) {
return getInt(str)
function getPositingStatus (str) {
let status = getInt(str)
const STATUS_MAP = {
0: "locate successful.",
1: "The GNSS scan timed out.",
2: "The Wi-Fi scan timed out.",
3: "The Wi-Fi + GNSS scan timed out.",
4: "The GNSS + Wi-Fi scan timed out.",
5: "The Bluetooth scan timed out.",
6: "The Bluetooth + Wi-Fi scan timed out.",
7: "The Bluetooth + GNSS scan timed out.",
8: "The Bluetooth + Wi-Fi + GNSS scan timed out.",
9: "Location Server failed to parse the GNSS location.",
10: "Location Server failed to parse the Wi-Fi location.",
11: "Location Server failed to parse the Bluetooth location.",
12: "Failed to parse location due to the poor accuracy.",
13: "Time synchronization failed.",
14: "Failed due to the old Almanac.",
15: "The GNSS +Bluetooth scan timed out."
if (STATUS_MAP[status] !== undefined) {
return {id: status, statusName: STATUS_MAP[status]}
return getInt(str)
function getUpT2000 (messageValue) {
let interval = 0
let workMode = getInt(messageValue.substring(10, 12))
let heartbeatInterval = getMinsByMin(messageValue.substring(14, 18))
let periodicInterval = getMinsByMin(messageValue.substring(18, 22))
let eventInterval = getMinsByMin(messageValue.substring(22, 26))
switch (workMode) {
case 0:
break
case 1:
break
case 2:
break
let data = [
measurementId: '3000', measurementValue: getBattery(messageValue.substring(0, 2))
measurementId: '3502', measurementValue: getSoftVersion(messageValue.substring(2, 6))
measurementId: '3001', measurementValue: getHardVersion(messageValue.substring(6, 10))
measurementId: '3965', measurementValue: getPositioningStrategy(messageValue.substring(12, 14))
measurementId: '3974', measurementValue: getInt(messageValue.substring(26, 28))
measurementId: '3976', measurementValue: getInt(messageValue.substring(28, 30))
measurementId: '3977', measurementValue: getInt(messageValue.substring(30, 32))
measurementId: '3978', measurementValue: getInt(messageValue.substring(54, 56))
measurementId: '3979', measurementValue: messageValue.substring(58, 58 + getInt(messageValue.substring(56, 58)) * 2)
let motionSetting = getMotionSetting(messageValue.substring(32, 42))
let staticsSetting = getStaticSetting(messageValue.substring(42, 48))
let shockSetting = getShockSetting(messageValue.substring(48, 54))
data = [...data, ...motionSetting, ...staticsSetting, ...shockSetting]
return data
function getMotionSetting (str) {
return [
{measurementId: '3946', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3947', measurementValue: getSensorValue(str.substring(2, 6), 1)},
{measurementId: '3948', measurementValue: getMinsByMin(str.substring(6, 10))},
function getStaticSetting (str) {
return [
{measurementId: '3949', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3950', measurementValue: getMinsByMin(str.substring(2, 6))}
function getShockSetting (str) {
return [
{measurementId: '3951', measurementValue: getInt(str.substring(0, 2))},
{measurementId: '3952', measurementValue: getInt(str.substring(2, 6))}
function getBattery (batteryStr) {
return loraWANV2DataFormat(batteryStr)
function getSoftVersion (softVersion) {
return `${loraWANV2DataFormat(softVersion.substring(0, 2))}.${loraWANV2DataFormat(softVersion.substring(2, 4))}`
function getHardVersion (hardVersion) {
return `${loraWANV2DataFormat(hardVersion.substring(0, 2))}.${loraWANV2DataFormat(hardVersion.substring(2, 4))}`
function getMinsByMin (str) {
return getInt(str)
function getSensorValue (str, dig) {
if (str === '8000') {
return null
} else {
return loraWANV2DataFormat(str, dig)
function isNull (str) {
if (str.substring(0, 1) !== '8') {
return false
for (let i = 1; i < str.length; i++) {
if (str.substring(i, i + 1) !== '0') {
return false
return true
function getSignSensorValue (str, dig = 1) {
if (isNull(str)) {
return null
function bytes2HexString (arrBytes) {
var str = ''
for (var i = 0; i < arrBytes.length; i++) {
var tmp
var num = arrBytes[i]
if (num < 0) {
tmp = (255 + num + 1).toString(16)
} else {
tmp = num.toString(16)
if (tmp.length === 1) {
tmp = '0' + tmp
str += tmp
return str
function loraWANV2DataFormat (str, divisor = 1) {
let strReverse = bigEndianTransform(str)
let str2 = toBinary(strReverse)
if (str2.substring(0, 1) === '1') {
let arr = str2.split('')
let reverseArr = arr.map((item) => {
if (parseInt(item) === 1) {
return 0
} else {
return 1
str2 = parseInt(reverseArr.join(''), 2) + 1
return parseFloat('-' + str2 / divisor)
return parseInt(str2, 2) / divisor
function bigEndianTransform (data) {
let dataArray = []
for (let i = 0; i < data.length; i += 2) {
dataArray.push(data.substring(i, i + 2))
return dataArray
function toBinary (arr) {
let binaryData = arr.map((item) => {
let data = parseInt(item, 16)
.toString(2)
let dataLength = data.length
if (data.length !== 8) {
for (let i = 0; i < 8 - dataLength; i++) {
data = `0` + data
return data
return binaryData.toString().replace(/,/g, '')
function getMacAndRssiObj (pair) {
let pairs = []
if (pair.length % 14 === 0) {
for (let i = 0; i < pair.length; i += 14) {
let mac = getMacAddress(pair.substring(i, i + 12))
if (mac) {
let rssi = getInt8RSSI(pair.substring(i + 12, i + 14))
pairs.push({mac: mac, rssi: rssi})
} else {
continue
return pairs
function getMacAddress (str) {
if (str.toLowerCase() === 'ffffffffffff') {
return null
let macArr = []
if (i % 2 === 1) {
macArr.push(str.substring(i - 1, i + 1))
let mac = ''
for (let i = 0; i < macArr.length; i++) {
mac = mac + macArr[i]
if (i < macArr.length - 1) {
mac = mac + ':'
return mac
function getInt8RSSI (str) {
return loraWANV2DataFormat(str)
function getInt (str) {
return parseInt(str, 16)
function getEventStatus (str) {
let bitStr = getByteArray(str)
let bitArr = []
for (let i = 0; i < bitStr.length; i++) {
bitArr[i] = bitStr.substring(i, i + 1)
bitArr = bitArr.reverse()
const EVENT_MAP = {
0: {id: 1, eventName: "Start moving event."},
1: {id: 2, eventName: "End movement event."},
2: {id: 3, eventName: "Motionless event."},
3: {id: 4, eventName: "Shock event."},
4: {id: 5, eventName: "Temperature event."},
5: {id: 6, eventName: "Light event."},
6: {id: 7, eventName: "SOS event."},
7: {id: 8, eventName: "Press once event."},
8: {id: 9, eventName: "disassembled event"}
let event = []
for (let i = 0; i < bitArr.length; i++) {
if (bitArr[i] === '1' && EVENT_MAP[i]) {
event.push(EVENT_MAP[i])
return event
function getByteArray (str) {
let bytes = []
for (let i = 0; i < str.length; i += 2) {
bytes.push(str.substring(i, i + 2))
return toBinary(bytes)
function getWorkingMode (workingMode) {
return getInt(workingMode)
function getPositioningStrategy (strategy) {
return getInt(strategy)
function getUTCTimestamp(str){
return parseInt(loraWANV2PositiveDataFormat(str)) * 1000
function loraWANV2PositiveDataFormat (str, divisor = 1) {
Step 3: Check the Data
When the device tries to connect to the network, the green breathing light will flash. If the device joins the network successfully, the green light will flash 5 times quickly.
Then you can check the data on the Helium console.
ChirpStack LNS
For new users, to receive the data from a device on the Helium network it must be associated with an LNS (LoraWAN Network Server), typically use one of the public LNSs, many of which use ChirpStack, but it's also possible to connect one's own LNS to Helium.
For those familiar with the general process the TL;DR; is:
  • create an device profile with the appropriate region and the codec (see source below)
  • create device with devEUI, appKey, and a app_eui variable with the AppEUI, all three values coming from the SenseCraft App
Step 1: Add Device Profile
The first step is to add a device profile for the T2000 Tracker to your ChirpStack LNS. This tells the LNS how to decode the packets it receives from a T2000 as well as a number of other settings.
In the ChirpStack dashboard select the Device Profiles and click Add device profile.
On the general tab, enter a device profile name you will recognize and select the appropriate region parameters.
note
LoRaWAN MAC version: 1.0.4
The expected uplink interval can be set too, the main thing it controls is when the LNS user interface shows the device as active vs. inactive. It has no effect on the delivery of packets through the LNS.
Click Submit, then you can see Device profile created.
On the Codec tab select JavaScript functions and enter the codec:
Decoder for Chirpstack V4
function decodeUplink (input) {
const bytes = input['bytes']
const decoded = {
valid: true,
err: 0,
messages: []
continue
let elements = []
} else {
try {
} catch (e) {
return e.toString()
let frameArray = []
let dataValue
let dataObj = {}
dataValue = ''
return frameArray
return frameArray
return frameArray
} else {
return frameArray
break
return frameArray
let eventList = []
let timestamp = 0
let value = null
let motionId = 0
let scanMax = 0
let interval = 0
let workMode = 0
switch (dataId) {
case '0C':
break
case '0D':
let error = ''
case 1:
break
case 2:
break
case 3:
break
break
case '27':
break
case '28':
interval = 0
switch (workMode) {
case 0:
break
case 1:
break
case 2:
break
break
case '29':
break
case '2A':
break
case '2B':
break
case '2C':
case '2D':
break
case '2E':
break
case '2F':
case '30':
break
case '31':
timestamp,
motionId,
break
case '32':
timestamp,
motionId,
break
timestamp,
motionId,
timestamp,
motionId,
timestamp,
motionId,
timestamp,
motionId,
timestamp,
motionId,
measurementId,
timestamp,
motionId,
const TYPE_MAP = {
'3000': 'Battery',
'4198': 'Latitude',
'5002': 'BLE Scan',
return getInt(str)
return getInt(str)
let interval = 0
switch (workMode) {
case 0:
break
case 1:
break
case 2:
break
let data = [
return data
return [
return [
return [
return getInt(str)
return null
} else {
return false
return false
return true
if (isNull(str)) {
return null
var str = ''
var tmp
if (num < 0) {
} else {
tmp = '0' + tmp
str += tmp
return str
return 0
} else {
return 1
let dataArray = []
return dataArray
.toString(2)
data = `0` + data
return data
let pairs = []
if (mac) {
} else {
continue
return pairs
return null
let macArr = []
if (i % 2 === 1) {
let mac = ''
mac = mac + ':'
return mac
let bitArr = []
const EVENT_MAP = {
let event = []
return event
let bytes = []
Step 2: Add Application and Your Device
The next step is to create an application and add actual devices to it.
Go to the Applications section and add a new application.
Then add a device to the application and enter the devEUI as captured in the SenseCraft App earlier.
On the variables tab add a variable called app_eui with the AppEUI from the SenseCraft app as value:
Hitting submit will bring up a page asking for the AppKey, again as captured earlier using the SenseCraft app.
Step 3: View the Device Connection
On the LoRaWAN frames tab you will see a spinner and then packets show up as they are received/sent.
When you see JoinAccept and JoinRequest, it indicates that the T2000 has successfully joined the network.
Once the join process has been performed the T1000 sends data. The LNS responds back with some information about the network frequencies and such, but subsequent to that there should only be uplinks with data.
On the Events page, you can view the decoded data from the device.
image image
Resource
SenseCAP T2000 Tracker Decoder for Helium
