How to set up Rclone from web UI
Rclone is a program to manage files on cloud storage drives. You can use it to make sure your cloud files are always in sync with the local storage.
Eventhough there is a UI to configure Rclone within OpenWrt Luci interface, you need to first do all the configurations within a command line. After that only you will be able to view your files by using the web UI.
Please follow the steps below:
Step 1. Visit OpenWrt Luci web UI and navigate to
Services > Terminal -
Step 2. Log in with your OpenWrt credentials
Step 3. Start the rclone configuration process by typing the following
rclone config
Step 4. Press n and press Enter to create a new remote.
Step 5. Type a name of your choice for the new remote
- Step 6. Find the type of storage you are creating a remote connection to, and enter the corresponding number from the long list
Note: Here number 13 is chosen for Google Drive as an example
Step 7. When you are prompted for a Client ID, press Enter to accept the default
Step 8. When you are prompted for a Client Secret, press Enter to accept the default
Step 9. Choose 1 as the scope that rclone should use when requesting access from the drive
Note: This will give full access to all the files in the drive
Step 10. When you are prompted for root folder ID, press Enter to accept the default
Step 11. When you are prompted for service account credentials JSON file path, press Enter to accept the default
Step 12. On Edit advanced config prompt, press Enter which selects No by default
Step 13. On Use auto config menu, press n and then press Enter
Step 14. Copy and paste the link shown on a web browser
Step 15. Sign in to your Google account and Allow access
Step 16. Copy the code shown on the Google sign in page and paste it inside the command line that we used before
Step 17. On Configure as a team drive press Enter to accept the default
Step 18. Press Enter to confirm the creation of the remote
You will see the output as follows:
Step 19. Type q to quit the configuration
Step 20. Navigate to
NAS > Rclone, check the box next to run Rclone as daemon and click SAVE & APPLY -
Step 21. Copy the rclone address
Step 22. Click WEBUI REACT and a new web page will open
Step 23. Paste the previously copied rclone address on to the first blank column
Step 24. Type admin for both username and password, and press Verify
You will see the following output if the connection is verified
Step 25. Click Login and go to Explore from the side menu
Step 26. Type the name of the remote we created before and click Open
Now you will see all your files in available in your drive
