Home Assistant and Sound Event Detection Module
Introduction
A compact edge audio board provides real-time sound detection with strong local data privacy protection. It can detect five abnormal sound events—Baby Cry, Glass Break, Gunshot, T3/T4 alarms, and Snore—enabling immediate response and reliable early warning. In this tutorial, we will learn how to compile and upload the firmware to a XIAO ESP32 board.
Hardware Required
ReSpeaker XVF3800 Home Assistant Yellow KitXiao ESP32S3
Install ESPHome Builder
Settings → Add-ons → Click on Add-on Store → Install ESPHome Device Builder add-on.
Go to Home Assistant > Settings > Add-ons.
Click Add-on Store (usually at the bottom right)
Under Official add-ons, search for and install ESPHome Device Builder.
After installation, click Start to run the ESPHome add-on.
Enable Start on Boot, Watchdog, and Show in Sidebar for easier access.
From the Home Assistant sidebar, go to ESPHome Builder.
Add Sound event device
Click + NEW DEVICE.
Click Continue → New Device Setup, then provide an appropriate name for the device.
In this demo, we are using the XIAO ESP32-S3, so we will select ESP32-S3 as the target board. This may differ depending on the board you are using.
Select your new device entry and click Edit. Delete the entire YAML template, then copy and paste the provided YAML file into the editor.
Sound Event YAML
# Sound Event Sensor - ESPHome Configuration
# Sensor: XU316 / AudioEventSensor (Seeed)
# Communication: UART via AT Commands
# No external .h file needed - pure YAML + inline lambdas
esphome:
friendly_name: Sound Event Sensor
on_boot:
priority: -100 # Run after everything else is initialized
then:
- logger.log: "=== Sound Event Sensor Booting ==="
# Step 1: Wait for sensor to be ready
- delay: 2s
# Step 2: Reset device for clean state
- logger.log: "Resetting device..."
- uart.write:
data: "AT+RESET\r\n"
- delay: 3s # Wait for device to come back up after reset
- logger.log: "Device reset complete."
# Step 3: Get and log firmware version
- logger.log: "Requesting firmware version..."
- uart.write:
data: "AT+GETFWVERSION\r\n"
- delay: 500ms
# Step 4: Apply all settings from the configurable values below
- script.execute: apply_all_settings
- logger.log: "=== Setup complete. Monitoring for events... ==="
# Hardware Settings - Change these to match YOUR wiring
esp32:
board: esp32-s3-devkitc-1
variant: esp32s3
framework:
type: arduino
version: recommended
# Network
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
ap:
ssid: "SoundSensor Fallback"
password: "soundsensor123"
captive_portal:
ota:
- platform: esphome
password: !secret ota_password
api:
logger:
level: DEBUG # Set to INFO to reduce log noise after testing
# UART - The serial link to your sensor
# Adjust tx_pin / rx_pin to match your wiring
uart:
tx_pin: GPIO43 # ← CHANGE to your TX pin
rx_pin: GPIO44 # ← CHANGE to your RX pin
baud_rate: 115200
debug: # Remove this block after testing
direction: BOTH
dummy_receiver: false
# Global Variables (internal state)
globals:
# UART line receive buffer
- id: uart_rx_buffer
type: std::string
restore_value: no
initial_value: '""'
# SCRIPTS
script:
- id: apply_all_settings
then:
# ── Build detect types from whichever switches are ON ──
- lambda: |-
std::string types = "";
auto add = [&](bool on, const char* name) {
if (on) { types += (types.empty() ? "" : ","); types += name; }
add(id(sw_detect_baby_cry).state, "baby_cry");
add(id(sw_detect_glass_break).state, "glass_break");
add(id(sw_detect_gunshot).state, "gunshot");
add(id(sw_detect_snore).state, "snore");
add(id(sw_detect_t3).state, "T3");
add(id(sw_detect_t4).state, "T4");
if (types.empty()) types = "gunshot"; // safety fallback
std::string cmd = "AT+SETDETECT=" + types + "\r\n";
ESP_LOGI("sound", "Setting detect types: %s", types.c_str());
id(uart_bus).write_array((const uint8_t*)cmd.c_str(), cmd.length());
- delay: 400ms
# ── Set thresholds for all 6 event types ──────────────
- lambda: |-
int val = (int) id(num_thr_baby_cry).state;
std::string cmd = "AT+SETEVENTTHRESHOLD=baby_cry," + std::to_string(val) + "\r\n";
ESP_LOGI("sound", "baby_cry threshold -> %d", val);
- delay: 400ms
- lambda: |-
int val = (int) id(num_thr_glass_break).state;
std::string cmd = "AT+SETEVENTTHRESHOLD=glass_break," + std::to_string(val) + "\r\n";
ESP_LOGI("sound", "glass_break threshold -> %d", val);
- delay: 400ms
- lambda: |-
int val = (int) id(num_thr_gunshot).state;
std::string cmd = "AT+SETEVENTTHRESHOLD=gunshot," + std::to_string(val) + "\r\n";
ESP_LOGI("sound", "gunshot threshold -> %d", val);
- delay: 400ms
- lambda: |-
int val = (int) id(num_thr_snore).state;
std::string cmd = "AT+SETEVENTTHRESHOLD=snore," + std::to_string(val) + "\r\n";
ESP_LOGI("sound", "snore threshold -> %d", val);
- delay: 400ms
- lambda: |-
int val = (int) id(num_thr_t3).state;
std::string cmd = "AT+SETEVENTTHRESHOLD=T3," + std::to_string(val) + "\r\n";
ESP_LOGI("sound", "T3 threshold -> %d", val);
- delay: 400ms
- lambda: |-
int val = (int) id(num_thr_t4).state;
std::string cmd = "AT+SETEVENTTHRESHOLD=T4," + std::to_string(val) + "\r\n";
ESP_LOGI("sound", "T4 threshold -> %d", val);
- delay: 400ms
# ── Save to sensor flash ───────────────────────────────
- logger.log: "Saving config to sensor..."
- uart.write:
data: "AT+SAVECONFIG\r\n"
- delay: 500ms
- logger.log: "Settings applied and saved!"
# INTERVAL - Parse incoming UART lines every 50ms
interval:
- interval: 50ms
then:
- lambda: |-
while (id(uart_bus).available()) {
uint8_t b;
id(uart_bus).read_byte(&b);
char c = (char)b;
if (c == '\n') {
std::string line = id(uart_rx_buffer);
id(uart_rx_buffer) = "";
if (!line.empty() && line.back() == '\r') line.pop_back();
if (line.empty()) continue;
ESP_LOGD("uart_rx", "<- %s", line.c_str());
// ── +EVENT: id,confidence ─────────────────────
if (line.size() > 7 && line.substr(0, 7) == "+EVENT:") {
std::string payload = line.substr(7);
while (!payload.empty() && payload[0] == ' ') payload.erase(0,1);
size_t comma = payload.find(',');
if (comma != std::string::npos) {
int event_id = std::stoi(payload.substr(0, comma));
int pct = (int) std::stof(payload.substr(comma + 1));
// ID map matches AudioEventSensor.cpp
const char* label_map[] = {"", "baby_cry", "glass_break", "gunshot", "snore", "T3", "T4"};
std::string name = (event_id >= 1 && event_id <= 6) ? label_map[event_id] : "unknown";
std::string full = name + " " + std::to_string(pct) + "% confidence";
id(txt_last_event_full).publish_state(full);
id(txt_last_event_name).publish_state(name);
id(sen_confidence).publish_state((float)pct);
ESP_LOGI("sound", "EVENT: %s", full.c_str());
// ── +GETFWVERSION:1.0.0 ───────────────────────
else if (line.size() > 14 && line.substr(0, 14) == "+GETFWVERSION:") {
std::string ver = line.substr(14);
while (!ver.empty() && ver[0] == ' ') ver.erase(0,1);
id(txt_firmware_version).publish_state(ver);
ESP_LOGI("sound", "Firmware: %s", ver.c_str());
else if (line == "OK") {
ESP_LOGD("sound", "<- OK");
} else if (line.size() >= 5 && line.substr(0, 5) == "ERROR") {
ESP_LOGW("sound", "<- ERROR: %s", line.c_str());
} else if (c != '\r') {
id(uart_rx_buffer) += c;
# SWITCHES
# All 6 events ON by default — user can disable any in HA
# After changing: press the "Apply Settings" button
switch:
- platform: template
name: "Detect Baby Cry" # Class ID 1
icon: mdi:baby-face-outline
optimistic: true
restore_mode: RESTORE_DEFAULT_ON # ← ON by default
name: "Detect Glass Break" # Class ID 2
icon: mdi:glass-fragile
optimistic: true
name: "Detect Gunshot" # Class ID 3
icon: mdi:target
optimistic: true
name: "Detect Snore" # Class ID 4
icon: mdi:sleep
optimistic: true
name: "Detect T3" # Class ID 5 (custom event)
icon: mdi:waveform
optimistic: true
name: "Detect T4" # Class ID 6 (custom event)
icon: mdi:waveform
optimistic: true
# NUMBER SLIDERS - Confidence thresholds
# All default to 80% — adjust per event in HA
number:
name: "Baby Cry Threshold"
icon: mdi:tune
unit_of_measurement: "%"
min_value: 0
max_value: 100
step: 5
initial_value: 80 # ← Default 80%
restore_value: true
optimistic: true
name: "Glass Break Threshold"
icon: mdi:tune
min_value: 0
max_value: 100
step: 5
restore_value: true
optimistic: true
name: "Gunshot Threshold"
icon: mdi:tune
min_value: 0
max_value: 100
step: 5
restore_value: true
optimistic: true
name: "Snore Threshold"
icon: mdi:tune
min_value: 0
max_value: 100
step: 5
restore_value: true
optimistic: true
name: "T3 Threshold"
icon: mdi:tune
min_value: 0
max_value: 100
step: 5
restore_value: true
optimistic: true
name: "T4 Threshold"
icon: mdi:tune
min_value: 0
max_value: 100
step: 5
restore_value: true
optimistic: true
# BUTTONS
button:
name: "Apply Settings"
icon: mdi:content-save-cog
on_press:
icon: mdi:restart
on_press:
- logger.log: "Manual reset triggered"
- uart.write:
- delay: 3s
name: "Save Sensor Config"
on_press:
- uart.write:
name: "Get Firmware Version"
icon: mdi:information
on_press:
- uart.write:
- platform: restart
icon: mdi:restart-alert
entity_category: config
# TEXT SENSORS
text_sensor:
name: "Last Sound Event"
icon: mdi:ear-hearing
# Example: "glass_break 87% confidence"
icon: mdi:waveform
# Example: "gunshot"
# Use this in HA automations → trigger when state = "gunshot"
icon: mdi:chip
entity_category: diagnostic
- platform: wifi_info
ip_address:
icon: mdi:ip-network
ssid:
icon: mdi:wifi
# SENSORS
sensor:
name: "Event Confidence"
icon: mdi:percent
accuracy_decimals: 0
- platform: wifi_signal
update_interval: 60s
icon: mdi:wifi-strength-2
note
In this example, we are using the XIAO ESP32S3, so you may need to update the following parameters in the YAML file according to your board and wiring configuration
board: esp32-s3-devkitc-1   # your board name
tx_pin: GPIO43 # your TX pin connection
rx_pin: GPIO44 # your RX pin connection
Once your YAML is saved, click INSTALL.
Choose Manual Download
Wait for the firmware to compile.
Download the generated .bin firmware file to your computer from Factory Format.
Connect the embedded sound sensor ESP32-S3 board to your PC using a USB Type-C cable.
Open Web ESPHome in Google Chrome.
Click Connect and choose the correct serial port from the list.
Once connected, click INSTALL
Select the .bin file you just downloaded.
Wait for the installation to complete (may take a few minutes).
After success, you’ll see a confirmation message.
Return to Home Assistant > Settings > Devices & Services.
You should see ESPHome listed as a discovered integration.
Click Add, then Submit to finish setup.
Then, you will be able to interact with the device through the Home Assistant interface and create your own automations with other peripherals. For example, you can trigger a buzzer when glass break is detected, or automatically play calm lullaby music on a smart speaker when a baby’s cry is detected.
Demo
