Lekiwi with Sound Follow
Introduction
The Lewiki Robot Kit, integrated with the ReSpeaker Mic Array v2.0, gains voice interaction and sound navigation capabilities. This guide details the step-by-step process for configuring both hardware and software environments to achieve sound-following functionality on the robot.
| Lekiwi Robot Kit | ReSpeaker Mic Array v2.0 | reComputer Mini J4012 |
Prerequisites
- Lewiki Robot Kit
- ReSpeaker Mic Array v2.0
Considering future functional expansions, this wiki uses the reComputer Jetson Mini J4012 as the robot's main control device. You can also achieve all the functionalities described in this wiki using a Raspberry Pi 5.
Hardware Connection
- Please refer to this wiki to prepare the Lekiwi robot, including the assembly of the mechanical structure and the configuration of the motors.
- Use 3D-printed connectors to mount the reSpeaker onto the Lekiwi.
- Use USB cables to connect the reSpeaker and the servo controller to the reComputer.
Prepare the Software Environment
Lerobot Virtual Env
If you have already set up the Lerobot virtual environment on your reComputer during the Lekiwi assembly process, you may skip to the next section. Otherwise, you can configure the Lerobot virtual environment using the following commands:
Step1. Install Miniconda
mkdir -p ~/miniconda3
wget https://repo.anaconda.com/miniconda/Miniconda3-latest-Linux-aarch64.sh -O ~/miniconda3/miniconda.sh
bash ~/miniconda3/miniconda.sh -b -u -p ~/miniconda3
rm ~/miniconda3/miniconda.sh
source ~/.bashrc
Step2. Create conda environment for lerobot
conda create -y -n lerobot python=3.10
conda activate lerobot
git clone https://github.com/huggingface/lerobot.git ~/lerobot
conda install ffmpeg -c conda-forge
cd ~/lerobot && pip install -e ".[feetech]"
reSpeaker Dependencies
Install the reSpeaker dependencies in the lerobot virtual environment.
Setp1. Install pyusb
pip install pyusb==1.0.2
Setp2. Configure USB device access permissions
echo 'SUBSYSTEM=="usb", ATTRS{idVendor}=="2886", MODE="0666"' | sudo tee /etc/udev/rules.d/51-mic-usb.rules
sudo chmod +x /etc/udev/rules.d/51-mic-usb.rules
sudo udevadm control --reload-rules && sudo udevadm trigger
Install the Application Software
Navigate to the lerobot/lerobot/common/robots/lekiwi/ directory and create a new Python script named sound_follow.py in this location.
Then, copy the following content into sound_follow.py.
sound_follow.py
#!/usr/bin/env python3
import logging
import time
import sys
import struct
import usb.core
import usb.util
from .config_lekiwi import LeKiwiConfig
from .lekiwi import LeKiwi
class Tuning:
TIMEOUT = 100000
def __init__(self, dev):
self.dev = dev
self.PARAMETERS = {
'AECFREEZEONOFF': (18, 7, 'int', 1, 0, 'rw', 'Adaptive Echo Canceler updates inhibit.', '0 = Adaptation enabled', '1 = Freeze adaptation, filter only'),
'AECNORM': (18, 19, 'float', 16, 0.25, 'rw', 'Limit on norm of AEC filter coefficients'),
'AECPATHCHANGE': (18, 25, 'int', 1, 0, 'ro', 'AEC Path Change Detection.', '0 = false (no path change detected)', '1 = true (path change detected)'),
'RT60': (18, 26, 'float', 0.9, 0.25, 'ro', 'Current RT60 estimate in seconds'),
'HPFONOFF': (18, 27, 'int', 3, 0, 'rw', 'High-pass Filter on microphone signals.', '0 = OFF', '1 = ON - 70 Hz cut-off', '2 = ON - 125 Hz cut-off', '3 = ON - 180 Hz cut-off'),
'RT60ONOFF': (18, 28, 'int', 1, 0, 'rw', 'RT60 Estimation for AES. 0 = OFF 1 = ON'),
'AECSILENCELEVEL': (18, 30, 'float', 1, 1e-09, 'rw', 'Threshold for signal detection in AEC [-inf .. 0] dBov (Default: -80dBov = 10log10(1x10-8))'),
'AECSILENCEMODE': (18, 31, 'int', 1, 0, 'ro', 'AEC far-end silence detection status. ', '0 = false (signal detected) ', '1 = true (silence detected)'),
'AGCONOFF': (19, 0, 'int', 1, 0, 'rw', 'Automatic Gain Control. ', '0 = OFF ', '1 = ON'),
'AGCMAXGAIN': (19, 1, 'float', 1000, 1, 'rw', 'Maximum AGC gain factor. ', '[0 .. 60] dB (default 30dB = 20log10(31.6))'),
'AGCDESIREDLEVEL': (19, 2, 'float', 0.99, 1e-08, 'rw', 'Target power level of the output signal. ', '[-inf .. 0] dBov (default: -23dBov = 10log10(0.005))'),
'AGCGAIN': (19, 3, 'float', 1000, 1, 'rw', 'Current AGC gain factor. ', '[0 .. 60] dB (default: 0.0dB = 20log10(1.0))'),
'AGCTIME': (19, 4, 'float', 1, 0.1, 'rw', 'Ramps-up / down time-constant in seconds.'),
'CNIONOFF': (19, 5, 'int', 1, 0, 'rw', 'Comfort Noise Insertion.', '0 = OFF', '1 = ON'),
'FREEZEONOFF': (19, 6, 'int', 1, 0, 'rw', 'Adaptive beamformer updates.', '0 = Adaptation enabled', '1 = Freeze adaptation, filter only'),
'STATNOISEONOFF': (19, 8, 'int', 1, 0, 'rw', 'Stationary noise suppression.', '0 = OFF', '1 = ON'),
'GAMMA_NS': (19, 9, 'float', 3, 0, 'rw', 'Over-subtraction factor of stationary noise. min .. max attenuation'),
'MIN_NS': (19, 10, 'float', 1, 0, 'rw', 'Gain-floor for stationary noise suppression.', '[-inf .. 0] dB (default: -16dB = 20log10(0.15))'),
'NONSTATNOISEONOFF': (19, 11, 'int', 1, 0, 'rw', 'Non-stationary noise suppression.', '0 = OFF', '1 = ON'),
'GAMMA_NN': (19, 12, 'float', 3, 0, 'rw', 'Over-subtraction factor of non- stationary noise. min .. max attenuation'),
'MIN_NN': (19, 13, 'float', 1, 0, 'rw', 'Gain-floor for non-stationary noise suppression.', '[-inf .. 0] dB (default: -10dB = 20log10(0.3))'),
'ECHOONOFF': (19, 14, 'int', 1, 0, 'rw', 'Echo suppression.', '0 = OFF', '1 = ON'),
'GAMMA_E': (19, 15, 'float', 3, 0, 'rw', 'Over-subtraction factor of echo (direct and early components). min .. max attenuation'),
'GAMMA_ETAIL': (19, 16, 'float', 3, 0, 'rw', 'Over-subtraction factor of echo (tail components). min .. max attenuation'),
'GAMMA_ENL': (19, 17, 'float', 5, 0, 'rw', 'Over-subtraction factor of non-linear echo. min .. max attenuation'),
'NLATTENONOFF': (19, 18, 'int', 1, 0, 'rw', 'Non-Linear echo attenuation.', '0 = OFF', '1 = ON'),
'NLAEC_MODE': (19, 20, 'int', 2, 0, 'rw', 'Non-Linear AEC training mode.', '0 = OFF', '1 = ON - phase 1', '2 = ON - phase 2'),
'SPEECHDETECTED': (19, 22, 'int', 1, 0, 'ro', 'Speech detection status.', '0 = false (no speech detected)', '1 = true (speech detected)'),
'FSBUPDATED': (19, 23, 'int', 1, 0, 'ro', 'FSB Update Decision.', '0 = false (FSB was not updated)', '1 = true (FSB was updated)'),
'FSBPATHCHANGE': (19, 24, 'int', 1, 0, 'ro', 'FSB Path Change Detection.', '0 = false (no path change detected)', '1 = true (path change detected)'),
'TRANSIENTONOFF': (19, 29, 'int', 1, 0, 'rw', 'Transient echo suppression.', '0 = OFF', '1 = ON'),
'VOICEACTIVITY': (19, 32, 'int', 1, 0, 'ro', 'VAD voice activity status.', '0 = false (no voice activity)', '1 = true (voice activity)'),
'STATNOISEONOFF_SR': (19, 33, 'int', 1, 0, 'rw', 'Stationary noise suppression for ASR.', '0 = OFF', '1 = ON'),
'NONSTATNOISEONOFF_SR': (19, 34, 'int', 1, 0, 'rw', 'Non-stationary noise suppression for ASR.', '0 = OFF', '1 = ON'),
'GAMMA_NS_SR': (19, 35, 'float', 3, 0, 'rw', 'Over-subtraction factor of stationary noise for ASR. ', '[0.0 .. 3.0] (default: 1.0)'),
'GAMMA_NN_SR': (19, 36, 'float', 3, 0, 'rw', 'Over-subtraction factor of non-stationary noise for ASR. ', '[0.0 .. 3.0] (default: 1.1)'),
'MIN_NS_SR': (19, 37, 'float', 1, 0, 'rw', 'Gain-floor for stationary noise suppression for ASR.', '[-inf .. 0] dB (default: -16dB = 20log10(0.15))'),
'MIN_NN_SR': (19, 38, 'float', 1, 0, 'rw', 'Gain-floor for non-stationary noise suppression for ASR.', '[-inf .. 0] dB (default: -10dB = 20log10(0.3))'),
'GAMMAVAD_SR': (19, 39, 'float', 1000, 0, 'rw', 'Set the threshold for voice activity detection.', '[-inf .. 60] dB (default: 3.5dB 20log10(1.5))'),
# 'KEYWORDDETECT': (20, 0, 'int', 1, 0, 'ro', 'Keyword detected. Current value so needs polling.'),
'DOAANGLE': (21, 0, 'int', 359, 0, 'ro', 'DOA angle. Current value. Orientation depends on build configuration.')
def write(self, name, value):
try:
data = self.PARAMETERS[name]
except KeyError:
return
if data[5] == 'ro':
raise ValueError('{} is read-only'.format(name))
id = data[0]
# 4 bytes offset, 4 bytes value, 4 bytes type
if data[2] == 'int':
payload = struct.pack(b'iii', data[1], int(value), 1)
else:
payload = struct.pack(b'ifi', data[1], float(value), 0)
self.dev.ctrl_transfer(
usb.util.CTRL_OUT | usb.util.CTRL_TYPE_VENDOR | usb.util.CTRL_RECIPIENT_DEVICE,
0, 0, id, payload, self.TIMEOUT)
def read(self, name):
try:
except KeyError:
return
id = data[0]
cmd = 0x80 | data[1]
cmd |= 0x40
length = 8
response = self.dev.ctrl_transfer(
usb.util.CTRL_IN | usb.util.CTRL_TYPE_VENDOR | usb.util.CTRL_RECIPIENT_DEVICE,
0, cmd, id, length, self.TIMEOUT)
# response = struct.unpack(b'ii', response.tostring())
response = struct.unpack(b'ii', response.tobytes() if sys.version_info[1]>=2 else response.tostring())
result = response[0]
else:
result = response[0] * (2.**response[1])
return result
def set_vad_threshold(self, db):
self.write('GAMMAVAD_SR', db)
def is_voice(self):
return self.read('VOICEACTIVITY')
@property
def direction(self):
return self.read('DOAANGLE')
@property
def version(self):
return self.dev.ctrl_transfer(
0, 0x80, 0, 1, self.TIMEOUT)[0]
def close(self):
close the interface
usb.util.dispose_resources(self.dev)
class SoundFollowingRobot:
def __init__(self):
logging.info("Configuring LeKiwi")
self.robot = LeKiwi(LeKiwiConfig())
logging.info("Connecting LeKiwi")
self.robot.connect(False)
# scale factor
self.scale_factor = 2
self.angle_threshold = 5.0
self.mic = self.find()
def find(self, vid=0x2886, pid=0x0018):
dev = usb.core.find(idVendor=vid, idProduct=pid)
if not dev:
return
return Tuning(dev)
def get_sound_direction(self):
return self.mic.read("DOAANGLE")
def robot_turn(self, speed):
data = {'x.vel': 0.0, 'y.vel': 0.0, 'theta.vel': int(speed/self.scale_factor)}
_action_sent = self.robot.send_action(data)
def run(self):
try:
self.mic.set_vad_threshold(5)
while True:
if robot.mic.is_voice():
sound_angle = self.get_sound_direction()
angle_diff = sound_angle - 90
if angle_diff > 180:
angle_diff -= 360
elif angle_diff < -180:
angle_diff += 360
if abs(angle_diff) < self.angle_threshold:
self.robot_turn(0)
else:
self.robot_turn(angle_diff)
print(f"voice angle: {sound_angle}")
else:
print('No voice detected!')
time.sleep(0.2)
except KeyboardInterrupt:
print("Finish")
except Exception as e:
print(f"Exception occurred: {e}")
finally:
self.close()
def close(self):
self.robot_turn(0)
self.robot.disconnect()
self.mic.close()
if __name__ == "__main__":
robot = SoundFollowingRobot()
robot.run()
Since our hardware setup does not utilize a camera or the SOArm101 robotic arm, we need to comment out the related configurations.
lerobot/lerobot/common/robots/lekiwi/config_lekiwi.py
def lekiwi_cameras_config() -> dict[str, CameraConfig]:
return {
# "front": OpenCVCameraConfig(
# index_or_path="/dev/video0", fps=30, width=640, height=480, rotation=Cv2Rotation.ROTATE_180
# "wrist": OpenCVCameraConfig(
# index_or_path="/dev/video2", fps=30, width=480, height=640, rotation=Cv2Rotation.ROTATE_90
lerobot/lerobot/common/robots/lekiwi/lekiwi.py
motors={
# # arm
# "arm_shoulder_pan": Motor(1, "sts3215", norm_mode_body),
# "arm_shoulder_lift": Motor(2, "sts3215", norm_mode_body),
# "arm_elbow_flex": Motor(3, "sts3215", norm_mode_body),
# "arm_wrist_flex": Motor(4, "sts3215", norm_mode_body),
# "arm_wrist_roll": Motor(5, "sts3215", norm_mode_body),
# "arm_gripper": Motor(6, "sts3215", MotorNormMode.RANGE_0_100),
# base
"base_left_wheel": Motor(7, "sts3215", MotorNormMode.RANGE_M100_100),
"base_back_wheel": Motor(8, "sts3215", MotorNormMode.RANGE_M100_100),
"base_right_wheel": Motor(9, "sts3215", MotorNormMode.RANGE_M100_100),
Modify the send_action function to disable/remove the robotic arm-related code sections.
def send_action(self, action: dict[str, Any]) -> dict[str, Any]:
if not self.is_connected:
raise DeviceNotConnectedError(f"{self} is not connected.")
base_goal_vel = {k: v for k, v in action.items() if k.endswith(".vel")}
base_wheel_goal_vel = self._body_to_wheel_raw(base_goal_vel["x.vel"], base_goal_vel["y.vel"], base_goal_vel["theta.vel"])
# Send goal position to the actuators
self.bus.sync_write("Goal_Velocity", base_wheel_goal_vel)
return {**base_goal_vel}
Launch the Application
Run the following command to start the robot:
sudo chmod 666 /dev/ttyACM*
python -m lerobot.common.robots.lekiwi.sound_follow
Effect Demonstration
After launching the program, the robot will rotate toward sound sources, continuously aligning its "head" with the direction of incoming audio.
References
- https://wiki.seeedstudio.com/ReSpeaker_Mic_Array_v2.0/#version
- https://github.com/respeaker/usb_4_mic_array
