Training SoArm101 Policy with IsaacLab
Introduction
This wiki introduces how to use Isaac Lab to train and test SO-ARM100/101 robotic arm policies with reinforcement learning.
📌Prerequisites
- An Ubuntu PC with Nvidia GPU
If you don’t have CUDA drivers or Conda installed, please set them up first.
Getting Started
🚀 Step 1. Install Isaac Lab
NVIDIA Isaac™ Lab is an open-source unified framework for robot learning that helps researchers and developers efficiently train robotic policies.
Run the following commands in the Ubuntu PC terminal:
# Create and activate Conda environment
conda create -n isaaclab python=3.10
conda activate isaaclab
# Install PyTorch (GPU version)
pip install torch==2.7.0 torchvision==0.22.0 --index-url https://download.pytorch.org/whl/cu128
# Upgrade pip
pip install --upgrade pip
# Install Isaac Sim (with extensions)
pip install 'isaacsim[all,extscache]==4.5.0' --extra-index-url https://pypi.nvidia.com
# Clone IsaacLab repository
cd ~/Documents
git clone https://github.com/isaac-sim/IsaacLab.git
# Install dependencies
sudo apt install cmake build-essential
# Initialize setup
cd IsaacLab
./isaaclab.sh --install
Run the following command to verify installation:
./isaaclab.sh -p scripts/tutorials/00_sim/create_empty.py
If successful, an empty Isaac Sim window should appear.
🤖 Step 2. Install isaac_so_arm101 Project
This repository implements tasks for the SO‑ARM100 and SO‑ARM101 robots using Isaac Lab. It serves as the foundation for several tutorials in the LycheeAI Hub series Project: SO‑ARM101 × Isaac Sim × Isaac Lab.
Run the following commands:
cd ~/Documents
git clone https://github.com/MuammerBay/isaac_so_arm101.git
cd isaac_so_arm101
# Install project dependencies
python -m pip install -e source/SO_100
# Test environments
python scripts/list_envs.py
If the isaac_so_arm101 project is successfully installed, the terminal window will print the following log:
🎯 Step 3. Start Training
Launch training with:
python scripts/rsl_rl/train.py --task SO-ARM100-Reach-v0
This will open an Isaac Sim window where you can observe the training process in real time. You can add the --headless parameter to the launch command to speed up the training process.
After training, the model weights will be saved under:
~/Documents/isaac_so_arm101/logs/rsl_rl/so_arm100_reach
🧪 Step 4. Test the Model
Test the trained model with:
python scripts/rsl_rl/play.py --task SO-ARM100-Reach-Play-v0
During testing, target positions are randomly generated within a defined range, and the trained model drives the robotic arm to reach those targets.
References
- https://lycheeai-hub.com/project-so-arm101-x-isaac-sim-x-isaac-lab-tutorial-series
- https://github.com/MuammerBay/isaac_so_arm101
- https://github.com/huggingface/lerobot
- https://github.com/isaac-sim/IsaacLab
- https://github.com/leggedrobotics/rsl_rl
