How to use a CM4 without eMMC on the Dual Gigabit Ethernet Carrier Board
If you want to use a Compute Module 4 without eMMC on the Dual Gigabit Ethernet Carrier Board, then you need to flash OpenWrt on to a micro-SD card and insert it into the board. Follow the steps below according to your operating system.
Step 1. Insert a micro-SD card to the computer using a micro-SD card reader connected to the computer, or by using a built-in card reader on a laptop
Step 2. Download balenaEtcher software by visiting this link according to your operating system
Step 3. Run balenaEtcher as administrator
Step 4. Click Flash from file and point to the OpenWrt image file that you downloaded before
Step 5. Click Select target and select the connected micro-SD card
Step 6. Finally, click Flash!
Please wait a few minutes until the flashing process is complete.
- Step 7. Eject the micro-SD card from computer and insert it into the Dual Gigabit Ethernet Carrier Board
