Use SQLite on reComputer
Introduction
This wiki explains how to use the SQlite on reComputer box. SQLite is a lightweight, embedded relational database management system widely used in mobile devices, desktop applications, and embedded systems. It does not require a separate server process; the database is stored directly in a single ordinary disk file. SQLite is simple to use and offers excellent performance. It supports standard SQL syntax and is suitable for small to medium-sized data storage needs. Due to its zero-configuration and easy deployment features, SQLite has become the preferred database engine for many projects.
Prepare Hardware
| reComputer R1125 | reComputer AI R2130 | reComputer AI Industrial R2145 |
| reComputer Industrial R20xx | reComputer Industrial R21xx |
Prepare software
update the system
sudo date -s "$(wget -qSO- --max-redirect=0 google.com 2>&1 | grep Date: | cut -d' ' -f5-8)Z"
sudo apt update
sudo apt full-upgrade
Install SQlite
sudo apt-get install sqlite3
Creat database
sqlite3 sensordata.db
With the .help command you can be quickly reminded of all the supported commands and their respective usage.
sqlite> .help
Then use .quit to quit SQlite shell.
sqlite> .quit
Using SQL
SQL creat table
Then use command like below to creat a new table.
ain@raspberrypi:~ $ sqlite3 sensordata.db
SQLite version 3.40.1 2022-12-28 14:03:47
Enter ".help" for usage hints.
sqlite> BEGIN;
sqlite> CREATE TABLE dhtreadings (
...> id INTEGER PRIMARY KEY AUTOINCREMENT,
...> temperature NUMERIC,
...> humidity NUMERIC,
...> currentdate DATE,
...> currenttime TIME,
...> device TEXT
sqlite> COMMIT;
Check the table
You can use the following command to view the created table.
sqlite> .tables
dhtreadings
sqlite> .fullschema
humidity NUMERIC,
currentdate DATE,
currenttime TIME,
device TEXT
/* No STAT tables available */
SQL insert
To insert new temperature and humidity readings in the database, you could do something like this:
sqlite> BEGIN;
sqlite> INSERT INTO dhtreadings(temperature, humidity, currentdate, currenttime, device) values(22.4, 48, date('now'), time('now'), "manual");
sqlite> COMMIT;
SQL select
To access the data stored in the database, you use the SELECT SQL statement:
sqlite> SELECT * FROM dhtreadings;
1|22.4|48|2025-09-26|01:23:37|manual
So far, you only have 1 reading inserted in the database. You can insert a new reading as follows:
sqlite> BEGIN;
sqlite> INSERT INTO dhtreadings(temperature, humidity, currentdate, currenttime, device) values(22.5, 48.7, date('now'), time('now'), "manual");
sqlite> COMMIT;
And when you SELECT the data stored in the table, it returns 2 readings:
2|22.5|48.7|2025-09-26|02:06:35|manual
SQL drop
If you want to completely delete the table from your database, you can use the DROP TABLE command.
NOTE: the next command will completely delete the dhtreadings table:
sqlite> DROP TABLE dhtreadings;
Now, if you type the ‘.tables‘ command:
sqlite> .tables
It doesn’t return anything, because your table was completely deleted.
Use Python with SQLite
Using Python to interact with SQLite like below:
test_sqlite.py
import sqlite3
from datetime import datetime
import os
def create_connection(db_file="dht_readings.db"):
"""Create a database connection to the SQLite database"""
conn = None
try:
conn = sqlite3.connect(db_file)
print(f"Connected to SQLite database: {db_file}")
except sqlite3.Error as e:
print(f"Error connecting to database: {e}")
return conn
def create_table(conn):
"""Create the dhtreadings table if it doesn't exist"""
try:
sql_create_dhtreadings_table = """
CREATE TABLE IF NOT EXISTS dhtreadings (
temperature REAL NOT NULL,
humidity REAL NOT NULL,
currentdate TEXT NOT NULL,
currenttime TEXT NOT NULL,
device TEXT NOT NULL
conn.cursor().execute(sql_create_dhtreadings_table)
conn.commit()
print("DHT readings table created successfully")
print(f"Error creating table: {e}")
def insert_dht_reading(conn, temperature, humidity, device):
"""Insert a new DHT reading into the dhtreadings table"""
sql_insert = """INSERT INTO dhtreadings(temperature, humidity, currentdate, currenttime, device)
VALUES(?, ?, date('now'), time('now'), ?);"""
try:
cursor = conn.cursor()
cursor.execute(sql_insert, (temperature, humidity, device))
conn.commit()
print(f"New record created successfully with ID: {cursor.lastrowid}")
return cursor.lastrowid
print(f"Error inserting data: {e}")
return None
def select_all_readings(conn):
"""Query all DHT readings in the dhtreadings table"""
try:
cursor.execute("SELECT * FROM dhtreadings ORDER BY currentdate DESC, currenttime DESC")
rows = cursor.fetchall()
print("\nAll DHT readings:")
print("ID | Temperature | Humidity | Date | Time | Device")
print("-" * 60)
for row in rows:
print(f"{row[0]} | {row[1]} | {row[2]} | {row[3]} | {row[4]} | {row[5]}")
print(f"Error fetching data: {e}")
def main():
# Create a database connection
database = "dht_readings.db"
conn = create_connection(database)
# Create table
if conn is not None:
create_table(conn)
# Insert a sample reading as specified in your requirement
insert_dht_reading(conn, 22.5, 48.7, "manual")
# Insert some additional sample data for testing
insert_dht_reading(conn, 23.1, 45.2, "sensor1")
insert_dht_reading(conn, 21.8, 50.3, "sensor2")
# Display all readings
# Close the connection
conn.close()
print("\nDatabase connection closed.")
else:
print("Error! Cannot create database connection.")
if __name__ == '__main__':
main()
