Wio-S3 Wireless Module Command List
Serial Debugging Command List​
System Command​
1. help [<string>] [-v <0|1>]
Print the summary of all registered commands if no arguments are given, otherwise print summary of given command.
ItemDescriptionData
<string>Name of commandOptional. If provided, display description for the specified command
-v, --verbose=<0|1>If specified, list console commands with given verbose level0 or 1
Examples:
  • help : Show all available commands.
  • help lora_tx : Show detailed information for the lora_tx command.
  • help -v 1 : Show full command list with verbose mode enabled.
LoRa Command​
1. lora_tx [-f <f>] [-s <6-12>] [-b <0|1|2>] [-c <1|2|3|4>] [-p] [--crc=<0|1>] [--iq=<0|1>] [--net=<0|1>] [-i <t>] [-d <d>] [-n <n>]
Send LoRa data packets with configurable radio parameters.
ItemDescriptionData
-f, --freq=<f>Set radio frequency in Hz415000000 ~ 940000000 Hz,
default: 868000000
-s, --sf=<6-12>Set LoRa SF6 ~ 12, default: 7
-b, --bw=<0|1|2>Set LoRa Bandwidth0:125KHz, 1:250KHz, 2:500KHz,
default: 0
-c, --cr=<1|2|3|4>Set LoRa Coding Rate1:CR_4_5, 2:CR_4_6, 3:CR_4_7, 4:CR_4_8, default: 1
-p, --power=Set radio powerLPA: -17 ~ +14 dB, HPA: -9 ~ +22 dB, default: 10
--crc=<0|1>Set LoRa CRC0:DISABLE, 1:ENABLE, default: 1
--iq=<0|1>Set LoRa IQ mode0:STANDARD, 1:INVERTED, default: 0
--net=<0|1>Set Public Network0:Private Network, 1:Public Network, default: 0
-i, --interval=<t>Set TX interval (ms)default: 0
-d, --txt=<d>Set text data to senddefault: hello
-n, --num=<n>Number of packets sent0: Keep sending, default: 1
Example: lora_tx -f 868000000 -s 7 -b 0 -c 1 -p 10 -d hello
Send a LoRa packet with frequency 868000000 Hz, SF7, 125 kHz bandwidth, coding rate 4/5, and send "hello" at TX power 10 dB.
2. lora_rx [-f <f>] [-s <6~12>] [-b <0|1|2>] [-c <1|2|3|4>] [--crc=<0|1>] [--iq=<0|1>] [--net=<0|1>] [--boosted=<0|1>]
Receive LoRa packets with configurable radio parameters.
ItemDescriptionData
-f, --freq=<f>Set radio frequency in Hz415000000 ~ 940000000 Hz, default: 868000000
-s, --sf=<6~12>Set LoRa SF6 ~ 12, default: 7
-b, --bw=<0|1|2>Set LoRa Bandwidth0:125KHz, 1:250KHz, 2:500KHz, default: 0
-c, --cr=<1|2|3|4>Set LoRa Coding Rate1:CR_4/5, 2:CR_4/6, 3:CR_4/7, 4:CR_4/8, default: 1
Example: lora_rx -f 868000000 -s 7 -b 0
Receive LoRa packets at frequency 868000000 Hz, SF7, 125 kHz bandwidth in normal RX mode.
3. lora_cw [-f <f>] [-p] [-o]
Transmit a continuous wave signal for RF testing and spectrum measurement.
ItemDescriptionData
-p, --power=<f>Set radio powerLPA: -17 ~ +14 dB, HPA: -9 ~ +22 dB, default: 10
-o, --ocp=<f>Set current limit step0 ~ 63, step 2.5mA, default: 24
Example: lora_cw -f 868000000 -p 10 -o 24
Transmit continuous wave signal at 868 MHz with 10 dB TX power and 60 mA OCP current limit for RF testing.
4. lora_fcc_fhss [-m <0|1>] [-s <6~12>] [-c <1|2|3|4>] [-p] [--crc=<0|1>] [--iq=<0|1>] [--net=<0|1>] [-i <t>] [-d <d>]
Transmit LoRa packets using frequency hopping mode for FCC compliance and RF certification testing.
ItemDescriptionData
-m, --mode=<0|1>Set FHSS mode0: FHSS_125K_MODE, 1: FHSS_500K_MODE, default: 0
-s, --sf=<6~12>Set LoRa SF6 ~ 12, default: 10
-d, --txt=<d>Set text data to senddefault: hello seeed! 1234567
Example: lora_fcc_fhss -m 1 -s 10 -c 1 -p 14 --crc=1 --iq=0 --net=0 -i 1000 -d test
Transmit FHSS LoRa packets using FHSS_500K_mode, SF10, coding rate 4/5, 14 dB TX power, CRC enabled, standard IQ mode, private network mode, and send payload "test" every 1000 ms.
GPIO Command​
1. gpio [-p <0~48>] [-d <0|1>] [-v <0|1>]
Control GPIO pins for input/output testing and hardware validation.
ItemDescriptionData
-p, --pin=<0~48>GPIO pin number0 ~ 48, default: 0
-d, --direction=<0|1>Set GPIO direction0: INPUT, 1: OUTPUT, default: 1
-v, --value=<0|1>Set GPIO output value0: LOW, 1: HIGH, default: 0
Example: gpio -p 10 -d 1 -v 1
Set GPIO 10 as output mode and drive the pin output to high level.
Flash Command​
1. flash [-b <100~1000>]
Test flash memory read and write performance using block operations.
ItemDescriptionData
-b, --block=<100~1000>Block number to run read/write test100 ~ 1000, default: 100
Example: flash -b 500
Perform flash memory read/write test using 500 data blocks.
WiFi Command​
1. ap_set <ssid> [<pass>] [-a <authmode>] [-n <channel>] [-m <max_conn>]
Configure the device to operate in WiFi AP mode with custom SSID, password, authentication type, and channel settings.
ItemDescriptionData
<ssid>SSID of APRequired
<pass>Password of APOptional
-a, --authmode=<authmode>WiFi authentication typeopen / wep / wpa2 / wpa2_enterprise
-n, --channel=<channel>WiFi channelOptional
-m, --max_conn=<max_conn>Max station numberdefault: 2
Example: ap_set MyAP 12345678 -a wpa2 -n 6 -m 4
Create a WPA2 WiFi AP named "MyAP" on channel 6 with maximum 4 client connections.
2. ap_query
Display current AP configuration and disconnect station mode connection.
Example: ap_query
3. wifi <action> [--espnow_enc=<int>] [--storage=<str>]
WiFi operation actions.
ItemDescriptionData
<action>WiFi operation actioninit / deinit / start / stop / restart / status
--espnow_enc=<int>ESP-NOW encryptiononly for init / restart
--storage=<str>WiFi storage typeflash / ram
Example: wifi init --storage=flash
Initialize WiFi subsystem and store configuration in flash memory.
4. wifi_count [<action>]
WiFi count statistics.
ItemDescriptionData
<action>Counter operationquery(default) / clear
Example: wifi_count clear : Clear current WiFi count statistics.
5. wifi_mode <mode>
Set WiFi mode.
ItemDescriptionData
<mode>WiFi modeap / sta / apsta
Example: wifi_mode apsta : Enable simultaneous AP and Station mode.
6. wifi_protocol [<protocol>] [--2g=<2g_proto>] [--5g=<5g_proto>] [-i <interface>]
Configure the WiFi protocol supported by the selected interface (AP or STA).
Two configuration methods are available:
  • <protocol>: Configure WiFi protocol using esp_wifi_set_protocol()
  • --2g / --5g: Configure protocols separately for the 2.4 GHz and 5 GHz bands using esp_wifi_set_protocols()
Note:
  • esp_wifi_set_protocol() and esp_wifi_set_protocols() cannot be used simultaneously.
  • If no parameters are provided, the current WiFi protocol configuration will be displayed.
ItemDescriptionData
<protocol>Configure WiFi protocol using esp_wifi_set_protocol()Example: b, b/g, b/g/n
g/n is invalid.
--2g=<2g_proto>Configure 2.4 GHz protocol using esp_wifi_set_protocols()API: esp_wifi_set_protocols.
Protocol string: 'lr', 'b', 'g', 'n', 'ax'
Combine with lr mode: 'lr/b', 'lr/g', etc.
Protocol bitmap value: raw bitmap value with hex, eg: 0x40
--5g=<5g_proto>Configure 5 GHz protocolSame format as --2g
-i, --interface=<interface>Select WiFi interfaceap, sta, default: sta
Example: wifi_protocol --2g=lr/b/g/n -i sta
Configure the STA interface to support LR, 802.11b, 802.11g, and 802.11n protocols on the 2.4 GHz band.
7. wifi_bandwidth [<cbw>] [--2g=<2g_cbw>] [--5g=<5g_cbw>] [-i <interface>]
Configure WiFi bandwidth.
  • <cbw>: Configure bandwidth using esp_wifi_set_bandwidth()
  • --2g / --5g: Configure bandwidth separately for 2.4 GHz and 5 GHz bands using esp_wifi_set_bandwidths()
Note:
  • esp_wifi_set_bandwidth() and esp_wifi_set_bandwidths() cannot be used simultaneously.
  • If no parameters are provided, the current WiFi bandwidth configuration will be displayed.
ItemDescriptionData
<cbw>Bandwidth using esp_wifi_set_bandwidth()20, 40
--2g=<2g_cbw>2.4 GHz bandwidth using esp_wifi_set_bandwidths()20, 40
--5g=<5g_cbw>5 GHz bandwidth using esp_wifi_set_bandwidths()20, 40
Example: wifi_bandwidth --2g=20 -i sta
Configure the 2.4 GHz band to use a 20 MHz channel bandwidth.
8. wifi_ps <type>
Set WiFi power mode. This command configures the WiFi Power Save mode of the device. Different modes balance power consumption and network performance differently.
TypeModeLatencyDescription
0WIFI_PS_NONELowestNo power saving, full performance
1WIFI_PS_MIN_MODEMMediumBalanced power saving and performance
2WIFI_PS_MAX_MODEMHighestMaximum power saving, higher delay
Example: wifi_ps 1 : Set WiFi power save mode to minimum modem power saving.
9. wifi_country [<code>] [-s <int>] [-n <int>] [-p <str>]
Set or get WiFi country configuration. This command configures the WiFi regulatory domain, including allowed channels and transmit rules based on country regulations.
ItemDescriptionData
<code>Country code setting (or query current country if not provided)CN / US / JP / etc.
-s, --schan=<int>Start WiFi channel numberInteger (e.g. 1)
-n, --nchan=<int>Total number of supported channelsInteger (e.g. 13)
-p, --policy=<str>Country policy modeauto (default) / manual
Example: wifi_country CN -s 1 -n 13 -p auto
Set WiFi country to CN, enable channels 1-13, and use automatic regulatory policy.
10. sta_connect <ssid> [<pass>] [-b <bssid>] [-n <channel>] [-no-disconnect] [-no-reconnect] [-full-scan] [-failure_retry=<int>] [-5g-offset=<rssi_5g_offset>]
Connect the device in STA mode to a specified WiFi access point.
ItemDescriptionData
<ssid>SSID of WiFi APString (WiFi name)
<pass>Password of APString (WiFi password)
-b, --bssid=<bssid>Specific AP MAC addressMAC address (xx:xx:xx:xx:xx:xx)
-n, --channel=<channel>AP WiFi channelInteger
--no-disconnectFor test: do not run esp_wifi_disconnect before connect/
--no-reconnectDisable auto-reconnect in wifi disconnect handler/
--full-scanEnable full channel scan during sta connection/
--failure_retry=<int>Number of retry attempts after connection failureInteger
--5g-offset=<rssi_5g_offset>Offset value for 5g ssid when do full scan connectInteger
Example: sta_connect MyWiFi 12345678 -n 6 --failure_retry=3 --full-scan : Connect STA mode to specified WiFi AP with optional scan, retry, and connection behavior control.
11. sta_disconnect
Disconnect the device from the current WiFi AP or stop reconnect.
Example: sta_disconnect
12. sta_scan [-h] [<ssid>] [-b <bssid>] [-n <int>] [--max=<int>] [--min=<int>] [--passive] [--passive-time=<int>] [--dwell=<int>] [-2 <int/hex>] [-5 <int/hex>] [--count-only]
Scan available WiFi access points in station mode.
ItemDescriptionData
-b, --bssid=<bssid>BSSID of APMAC address (xx:xx:xx:xx:xx:xx)
-n, --channel=<int>Channel of APInteger
-h, --show-hiddenShow hidden APs/
--max=<int>Maximum active scan timeInteger (ms)
--min=<int>Minimum active scan timeInteger (ms)
--passiveSet scan type to passive/
--passive-timePassive scan timeInteger (ms)
--dwell=<int>Home channel dwell timeInteger (ms)
-2, --bitmap-2g=<int/hex>2.4GHz channel scan bitmapHex/int (e.g. 0x842 for ch1/6/11)
-5, --bitmap-5g=<int/hex>5GHz channel scan bitmapHex/int (e.g. 0x6 for ch36/40)
--count-onlyFor test: do scan ap count only./
Example: sta_scan -h --passive --passive-time=120 --dwell=30 -2 0x842 -5 0x6
Perform a full passive WiFi scan showing hidden APs, scanning selected 2.4GHz and 5GHz channels.
13. wifi_txpower [-u <unit>] [--reset]
Set WiFi transmit power or reset to default.
ItemDescription
-u, --unitTX power value, each unit = 0.25 dBm (e.g. 8 = 2 dBm)
--resetReset TX power to default value from SDK configuration
Example: wifi_txpower -u 8 : Set WiFi transmit power to 2 dBm.
Network Command​
1. ping [-W <timeout>] [-i <interval>] [-s <size>] [-c <count>] [-Q <n>] [host] [--abort]
Send ICMP ECHO_REQUEST packets to a network host.
ItemDescriptionData
-W, --timeout=<timeout>Time to wait for responseInteger (seconds)
-i, --interval=<interval>Interval between sending packetsFloat/Integer (seconds)
-s, --packetsize=<size>Use <size> as number of data bytes to be sentInteger (bytes)
-c, --count=<count>Number of packets to send, stop after <count> repliesInteger, default: 5
-Q, --tos=<n>IP Type of Service field valueInteger
hostTarget IP address or domain nameString
--abortStop running ping processping abort -> esp_ping_stop
Example: ping -c 4 8.8.8.8 : Send 4 ICMP echo requests to 8.8.8.8.
2. iperf [-suV] [-c <host>] [-p <port>] [-l <length>] [-i <interval>] [-t <time>] [-b <bandwidth>] [-f <format>] [--abort]
Measure network performance (throughput, bandwidth, and latency) using TCP or UDP.
ItemDescriptionData
-c, --clientRun in client mode and connect to serverIP/domain
-s, --serverRun in server mode/
-u, --udpUse UDP instead of TCP/
-V, --ipv6_domainUse IPv6 protocol/
-p, --port=<port>Server port numberInteger
-l, --len=<length>Buffer length for transmissionInteger (bytes), Defaults: TCP=16384, IPv4 UDP=1470, IPv6 UDP=1450
-i, --interval=<interval>Seconds between periodic bandwidth reportsFloat/Integer (seconds)
-t, --time=<time>Test durationInteger (seconds), default 10s
-b, --bandwidth=<bandwidth>Target bandwidthMbits/sec
-f, --format=<format>Output formatString, k = Kbits/sec, m = Mbits/sec
--abortStop running iperf test/
Example: iperf -c 192.168.1.10 -t 10 -i 1: Run a TCP bandwidth test for 10 seconds against server 192.168.1.10, reporting results every 1 second.
BLE Command​
1. ble [-a <0|1>]
Control BLE advertising state for Bluetooth testing and discovery.
ItemDescriptionData
-a, --adv=<0|1>BLE advertising control0: Advertising Stop, 1: Advertising Begin, default: 0
Example: ble -a 1 : Start BLE advertising mode for device discovery.
Power Mode Command​
1. sleep [-m <0|1|2>]
Configure device sleep mode for low power testing.
ItemDescriptionData
-m, --mode=<0|1|2>Configure device sleep mode for low power testing.0: standby, 1: light sleep, 2: deep sleep, default: 0
Example: sleep -m 2 : Switch device into deep sleep mode.
Please submit any technical issue into our forum.
