Factory Firmware Command Reference
Symbol Conventions​
SymbolMeaningExample
[ ]Optional parameter; the default applies when omitted[-p <port>]
< >A concrete value you must supply-g <gpio>
|Choose one of the listed values<0|1>
Words without bracketsRequiredping <host>
cmd>Firmware prompt; do not type itcmd> help
Values are always written as -flag value, for example gpio_set -g 4 -l 1. Where the firmware also registers a long form, the long form is listed next to the short one in the parameter table.
Command Index​
CategoryCommandsWhat it verifiesSection
General1Serial link and on-device helpGeneral
LoRa / RF7Sub-GHz and 2.4 GHz transmit, receive, CW and FLRCLoRa / RF
BLE2Advertising state and connection statusBLE
Wi-Fi & network14STA and AP modes, scanning, protocol version, pingWi-Fi & network
IO expander8Pin levels, bus scan and switched railsIO expander
Battery1Cell voltage and charge estimateBattery
OLED3Display patterns and panel healthOLED
Camera5Initialization, status and HTTP previewCamera
Audio7Record, play and streamAudio
Flash3JEDEC ID, speed and enduranceFlash
General​
1. help​
List every registered command with a one-line description.
This command takes no parameters.
Example:
help
LoRa / RF​
These seven commands drive the on-board LR2021 transceiver through two modulation schemes: LoRa for range and FLRC for speed. Every transmit command needs an antenna on the matching connector: SUB-1G for sub-GHz carrier frequencies and LR-2.4G for the 2400 ~ 2500 MHz band. A two-board link test needs identical radio parameters on both sides.
Note: lora_rx, flrc_rx, lora_tx -n 0 and flrc_tx -c 0 run until you press Ctrl+C.
1. lora_tx​
lora_tx [-f <freq_hz>] [-s <5-12>] [-b <0-9>] [-c <1-7>] [-p <dbm>] [--crc <0|1>] [--hdr <0|1>] [--iq <0|1>] [--net <0|1>] [-i <interval_ms>] [-d <text>] [-n <count>] [-hp <n>] [-dc <n>] [-lf <n>]
Send LoRa packets with the configured frequency, spreading factor and power.
ItemDescriptionData
-f <freq_hz>Transmit frequency150000000 ~ 2500000000 Hz; default: 868000000
-s <5-12>Spreading factor5 ~ 12; higher is slower and reaches further; default: 7
-b <0-9>Bandwidth index0=31k, 1=41k, 2=62k, 3=125k (default), 4=200k, 5=250k, 6=400k, 7=500k, 8=800k, 9=1000k
-c <1-7>Coding rate1 ~ 7; 1=4/5 is the fastest, 4=4/8 the most robust; default: 1
-p <dbm>Transmit powerSub-GHz -10 ~ +22 dBm, 2.4 GHz -17 ~ +12 dBm; default: 10
--crc <0|1>CRC check0=off, 1=on; default: 1
--hdr <0|1>Header type0=implicit, 1=explicit; default: 1
--iq <0|1>IQ mode0=standard, 1=inverted; default: 0
--net <0|1>Network type and sync word0=private (sync word 0x12), 1=public (sync word 0x34); default: 1
-i <interval_ms>Interval between packetsMilliseconds; default: 200; 0=back-to-back
-d <text>Payload textDefault: hello
-n <count>Number of packets0=send until Ctrl+C; default: 10
-hp <n>PA half-power registerDebug only; leave unset in normal use
-dc <n>PA duty-cycle registerDebug only; leave unset in normal use
-lf <n>PA low-frequency slice registerDebug only; leave unset in normal use
Example:
lora_tx -f 868000000 -s 7 -b 3 -p 14 -d hello -n 10
note
Fit the antenna first, and start lora_rx with the same -f, -s, -b, -c, --hdr, --crc, --iq and --net values on the second board. An out-of-range value prints an out of bounds warning and the command falls back: -f to the default frequency, -s to 7, -b to 3, -c to 1; -p is clamped to the band limit. A non-numeric -f, or a negative -i or -n, aborts the command and sends nothing.
2. lora_rx​
lora_rx [-f <freq_hz>] [-s <5-12>] [-b <0-9>] [-c <1-7>] [--crc <0|1>] [--hdr <0|1>] [--plen <0-255>] [--iq <0|1>] [--net <0|1>]
Receive LoRa packets continuously and count them.
ItemDescriptionData
-f <freq_hz>Receive frequency150000000 ~ 2500000000 Hz; default: 868000000
-s <5-12>Spreading factor5 ~ 12; default: 7
-b <0-9>Bandwidth index0=31k, 3=125k (default), 9=1000k
-c <1-7>Coding rate1 ~ 7; default: 1
--plen <0-255>Payload length the receiver expectsBytes; 0=any length in explicit mode, implicit mode assumes 5 when omitted; default: 0
--net <0|1>Network type and sync word0=private (0x12), 1=public (0x34); default: 1
Example:
lora_rx -f 868000000 -s 7 -b 3
note
The command blocks the console until Ctrl+C, which prints rx_done, rx_hdr_err and rx_crc_err. Both boards must use the same --hdr value; implicit on one side and explicit on the other never receives. In implicit mode set --plen to the transmitter's payload length: a longer value appends garbage to the tail and a shorter one drops it. Implicit mode with --crc 1 produced CRC failures in testing, so pair --hdr 0 with --crc 0. Long runs of hdr err at close range mean the packets arrive back-to-back; raise the transmitter's -i to 100 ~ 200 and keep it longer than one packet's air time.
3. lora_cw​
lora_cw [-f <freq_hz>] [-p <dbm>]
Transmit an unmodulated continuous wave for RF power measurements.
ItemDescriptionData
-f <freq_hz>Carrier frequency150000000 ~ 2500000000 Hz; default: 868000000; an out-of-range or non-numeric value aborts the command
-p <dbm>Transmit powerSub-GHz -10 ~ +22 dBm, 2.4 GHz -17 ~ +12 dBm; default: 10; clamped to the band limit
Example:
lora_cw -f 868000000 -p 10
note
The carrier runs until lora_cw_stop is entered. To change power or frequency mid-test, run lora_cw again with the new value; the configuration restarts by itself.
4. lora_cw_pa​
lora_cw_pa [-f <freq_hz>] [-p <dbm>] [-h <n>] [-d <0-31>] [-l <0-15>]
Transmit a continuous wave with direct PA register control.
ItemDescriptionData
-h <n>PA half-power value0.5 dB steps; sub-GHz -19 ~ 44, 2.4 GHz -39 ~ 24
-d <0-31>PA duty cycle0 ~ 31
-l <0-15>PA low-frequency slices0 ~ 15
Example:
lora_cw_pa -f 868000000 -h 22 -d 0 -l 0
note
Supplying any one of -h, -d or -l switches the command to direct parameter mode and overrides the power table. Out-of-range values are clamped to the band limit with an out of bounds warning. Stop the carrier with lora_cw_stop.
5. lora_cw_stop​
lora_cw_stop
Stop a continuous wave started by lora_cw or lora_cw_pa.
Example:
lora_cw_stop
6. flrc_tx​
flrc_tx [-f <freq_hz>] [-p <dbm>] [-b <0-7>] [-l <1-255>] [-c <count>]
Send FLRC packets with an incrementing payload, one packet per second.
ItemDescriptionData
-f <freq_hz>Transmit frequency415000000 ~ 940000000 Hz; default: 915000000; out of range falls back to the default
-p <dbm>Transmit power-10 ~ +22 dBm; default: 22; clamped to the limit
-b <0-7>Rate and bandwidth combination0=2.6 Mbps (fastest) through 7=0.26 Mbps; default: 0; out of range falls back to 7
-l <1-255>Packet lengthBytes; default: 200; out of range falls back to the default
-c <count>Number of packetsDefault: 100; 0=send until Ctrl+C; values above 500 are capped at 500
Example:
flrc_tx -f 868000000 -p 14 -l 200 -c 100
note
One packet leaves every second, so a one-minute run sends about sixty packets. Set -c 0 to transmit without a stop until Ctrl+C.
7. flrc_rx​
flrc_rx [-f <freq_hz>] [-b <0-7>]
Receive FLRC packets and count good packets, header errors and CRC errors.
ItemDescriptionData
-f <freq_hz>Receive frequency415000000 ~ 940000000 Hz; default: 915000000; out of range falls back to the default
-b <0-7>Rate and bandwidth combination0 ~ 7; default: 0; out of range falls back to 7
Example:
flrc_rx -f 868000000 -b 0
note
Ctrl+C stops the receiver and prints the counters.
BLE​
Bluetooth is not started at boot. The first ble -a 1 initializes the BLE stack and starts advertising; ble -a 0 stops advertising and unloads the stack to free its memory. The device name starts with wio-lr2021- and the advertisement accepts connections.
1. ble​
ble -a <0|1>
Turn Bluetooth advertising on or off.
ItemDescriptionData
-a <0|1>Advertising switch1=start advertising (initializes the stack on first use), 0=stop advertising and release the stack; required
Example:
ble -a 1
note
Search for wio-lr2021- from a phone with nRF Connect; the device is healthy when it appears in the list. After connecting, the app can send commands to the device and read the log lines it prints.
2. ble_status​
ble_status
Print device name, MAC address, TX power, advertising parameters and connection state.
Example:
ble_status
note
If Bluetooth has not been initialized, the command asks you to run ble -a 1 first.
Wi-Fi & network​
Wi-Fi is initialized and started automatically at boot, so none of these commands needs a manual wifi init. Most of them wrap Espressif's Wi-Fi test component and carry many options; the parameter tables below list the documented ones. Joining a router requires your own 2.4 GHz access point and its password.
1. wifi​
wifi <status|stop|start|restart|init|deinit>
Query Wi-Fi state or start, stop and reinitialize the radio.
ItemDescriptionData
statusShow initialization state and connection infoMost common query
stop, startStop or start the radio, driver retainedPower tests and interference removal
restartFull restart: stop, deinit, init, startRecovery after deinit
init, deinitInitialize or unload the driverR&D debugging only
Example:
wifi status
note
Running wifi init on an already-initialized system is skipped with a single WiFi already initialise. warning. wifi deinit stops the radio first when it is still running, and wifi status prints initialized and started separately.
2. wifi_count​
wifi_count [query|clear]
Print or reset the Wi-Fi transmit and receive packet counters.
ItemDescriptionData
queryPrint the countersDefault when no argument is given
clearReset both counters to zero—
Example:
wifi_count
3. wifi_mode​
wifi_mode <sta|ap|apsta>
Set the Wi-Fi role of the device.
ItemDescriptionData
staJoin another hotspot, like a phone—
apAct as a hotspot—
apstaBoth roles at once—
Example:
wifi_mode sta
4. wifi_protocol​
wifi_protocol [protocol] [-i <ap|sta>]
Query or set the 802.11 protocol combination.
ItemDescriptionData
<protocol>Protocol combinationb, b/g, b/g/n; default: query the current value
-i <ap|sta>Interface to apply the setting toap or sta; default: sta
Example:
wifi_protocol b/g/n
5. wifi_bandwidth​
wifi_bandwidth [20|40] [-i <ap|sta>]
Query or set the channel bandwidth.
ItemDescriptionData
<20|40>Channel bandwidth in MHz20 or 40; default: query the current value
Example:
wifi_bandwidth 20
6. wifi_ps​
wifi_ps <0|1|2>
Set the Wi-Fi power-save level.
ItemDescriptionData
0No power saving, highest performanceRequired
1Moderate saving—
2Maximum saving—
Example:
wifi_ps 0
7. wifi_country​
wifi_country [code] [-s <start_channel>] [-n <channel_count>] [-p <auto|manual>]
Query or set the country code and the usable channel range.
ItemDescriptionData
<code>Two-letter country codeFor example US; default: query the current value
-s <start_channel>First channel of the allowed rangeChannel number; default: not set
-n <channel_count>Number of channels in the rangeCount; default: not set
-p <auto|manual>Channel plan selectionauto or manual; default: not set
Example:
wifi_country US
8. ap_set​
ap_set <ssid> [pass] [-a <authmode>] [-n <channel>] [-m <max_conn>]
Turn the device into a Wi-Fi hotspot so a phone or PC can join it.
ItemDescriptionData
<ssid>Hotspot nameRequired
<pass>Hotspot passwordAt least 8 characters; optional
-a <authmode>Security modeopen, wep, wpa2; an unrecognized name is reported and the hotspot falls back to open; default: not set
-n <channel>Hotspot channelChannel number; default: not set
-m <max_conn>Maximum simultaneous clientsDefault: 2
Example:
ap_set MyTestAP 12345678
Alias: ap (same as ap_set).
note
Change the password before leaving the hotspot up on a shared network, and stop it when the test ends.
9. ap_query​
ap_query
Show the current hotspot configuration and how many clients are connected.
Example:
ap_query
10. sta_connect​
sta_connect <ssid> <pass> [-n <channel>]
Join a Wi-Fi hotspot you provide, as a station.
ItemDescriptionData
<pass>Hotspot passwordRequired
-n <channel>Channel to join onOptional; a known channel speeds up the connection
Example:
sta_connect MyHomeWiFi 12345678
Expected output:
got ip:192.168.<x>.<y>
The IP address changes with every network; the success criterion is the got ip: line, which appears among the connection log lines.
Alias: sta (same as sta_connect).
note
Wi-Fi must be initialized and started, which is the state at boot. After wifi stop or wifi deinit, the command is refused with a hint to run wifi restart first. Run sta_disconnect before joining a different network.
11. sta_disconnect​
sta_disconnect
Disconnect from the current network and stop auto-reconnect.
Example:
sta_disconnect
Alias: disconnect (same as sta_disconnect).
12. sta_scan​
sta_scan [<ssid>] [-n <channel>] [-h]
Scan for nearby hotspots and print name, signal strength and channel.
ItemDescriptionData
<ssid>Show only the hotspot with this nameOptional filter
-n <channel>Scan a single channelChannel number; optional
-hInclude hidden networks; the long form --show-hidden does the sameNo value
Example:
sta_scan
Aliases: wifi_scan and scan (same as sta_scan).
note
A scan is the fastest check of the Wi-Fi antenna and receive path: an empty list means the radio is not receiving.
13. wifi_txpower​
wifi_txpower [-u <value>] [--reset]
Read or set the Wi-Fi transmit power.
ItemDescriptionData
-u <value>Transmit power in 0.25 dBm unitsFor example 80 = 20 dBm; default: read the current value
--resetRestore the default powerNo value
Example:
wifi_txpower -u 68
14. ping​
ping <host> [-c <count>] [-i <interval_s>] [-s <bytes>] [-W <timeout_s>] [--abort]
Send ICMP echo requests to a host and report the latency.
ItemDescriptionData
<host>Target IP address or domainRequired
-c <count>Number of echo requestsDefault: 5
-i <interval_s>Seconds between requestsDefault: 1
-s <bytes>Payload size per requestDefault: 64
-W <timeout_s>Reply timeout in secondsDefault: not set
--abortStop a running pingNo value
Example:
ping 192.168.1.1 -c 4 -i 1
note
Wi-Fi is initialized at boot; run sta_connect first so the device has an address and a route.
IO expander​
GPIO numbers are ESP32-S3 GPIO numbers; the pin functions are listed on the Wio-LR2021 Dev Kit Pin Map. The IO expander is the PCA9535 at I²C address 0x21. It exposes 16 pins numbered 0 ~ 15; four of them switch the camera, audio, OLED and Grove rails.
note
A pin that no peripheral claims stays a floating input after power-on (pull resistors off), so a raw gpio_get reads noise. Run gpio_config first: -m 0 for input with an optional pull, -m 1 for push-pull output, -m 2 for open-drain output.
1. gpio_set​
gpio_set -g <gpio> -l <0|1>
Drive a GPIO high or low.
ItemDescriptionData
-g <gpio>GPIO numberRequired
-l <0|1>Output level1=high (about 3.3 V), 0=low (0 V); required
Example:
gpio_set -g 4 -l 1
note
Configure the direction with gpio_config -m 1 before driving the pin, and verify the level with a multimeter or a loopback wire into another GPIO.
2. gpio_get​
gpio_get -g <gpio>
Read the current level of a GPIO.
ItemDescriptionData
Example:
gpio_get -g 4
3. gpio_config​
gpio_config -g <gpio> -m <0|1|2> [-p <0|1|2|3>]
Set the direction and the pull resistors of a GPIO.
ItemDescriptionData
-m <0|1|2>Direction0=input, 1=output, 2=open-drain output; required
-p <0|1|2|3>Pull resistors0=floating (default), 1=pull-up, 2=pull-down, 3=both enabled
Example:
gpio_config -g 5 -m 0 -p 1
4. i2c_scan​
i2c_scan [-b <0|1>]
Scan one or both I²C buses and list the addresses that respond.
ItemDescriptionData
-b <0|1>Bus number to scan0 or 1; default: scan both
Example:
i2c_scan -b 0
note
On a healthy board, bus 0 shows the PCA9535 at 0x21 and, once the display rail is on, the OLED at 0x3D. A missing address means the chip is not soldered, not powered, or not responding.
5. io_exp_set​
io_exp_set -i <0-15> -l <0|1>
Drive one pin of the IO expander high or low.
ItemDescriptionData
-i <0-15>Expander pin number0 ~ 15; required
-l <0|1>Output level1=high, 0=low; required
Example:
io_exp_set -i 3 -l 1
note
Pins 0 ~ 3 switch peripheral rails; driving them changes the power state of the camera, audio, OLED and Grove connectors.
6. io_exp_get​
io_exp_get -i <0-15>
Read one pin of the IO expander.
ItemDescriptionData
Example:
io_exp_get -i 3
7. io_exp_config​
io_exp_config -i <0-15> -m <0|1>
Set one pin of the IO expander as input or output.
ItemDescriptionData
-m <0|1>Direction0=input, 1=output; required
Example:
io_exp_config -i 3 -m 1
8. io_exp_print​
io_exp_print
Print the direction and level of all 16 expander pins in one table.
Example:
io_exp_print
Battery​
1. battery_get​
battery_get
Read the cell voltage in millivolts and estimate the state of charge.
Example:
battery_get
note
A cell must be connected to the BAT-3.7V connector for a meaningful reading; the charger reports its own state on expander pins 11 and 12.
OLED​
The first OLED command of a session powers the display rail and initializes the panel, so no separate preparation step is needed. The panel is 128 × 64 pixels and sits on the internal I²C bus at 0x3D.
1. oled_test​
oled_test -m <mode>
Draw one test pattern on the OLED panel.
ItemDescriptionData
-m <mode>Pattern to drawclear=all pixels off
solid=all pixels on
checker=checkerboard
stripes=vertical stripes
border=black background with a border
text=status text such as OLED OK and the resolution
scan=scan lines; required
Example:
oled_test -m text
note
-m text is the fastest pass/fail check of the panel: the text pattern is drawn by the same driver that draws every other pattern.
2. oled_line_demo​
oled_line_demo -m <checker|scan>
Refresh the panel segment by segment through a small line buffer.
ItemDescriptionData
-m <checker|scan>Pattern to refreshchecker=checkerboard, scan=scan lines; required
Example:
oled_line_demo -m checker
3. oled_cycle​
oled_cycle [-d <dwell_ms>]
Play six test patterns in sequence and finish on its own.
ItemDescriptionData
-d <dwell_ms>Time each pattern stays on screenMilliseconds; default: 800
Example:
oled_cycle -d 1500
note
The sequence is clear, border, text, checkerboard, stripes and scan lines. One pass covers the whole panel, which is why the production line uses it for visual inspection.
Camera​
The camera is the 2 MP GC2145 on the Media HAT; the factory firmware reads it as RGB565 and streams JPEG frames. camera_http_start is the shortest end-to-end check because it brings up the hotspot, the camera and the web server with one command.
1. camera_start​
camera_start [-q <1-100>] [-r <qqvga|qvga|vga>] [-F <hz>]
Power up and initialize the camera.
ItemDescriptionData
-q <1-100>JPEG compression quality1 ~ 100; default: 80
-r <qqvga|qvga|vga>Capture resolutionqqvga=160×120, qvga=320×240 (default), vga=640×480
-F <hz>Camera control bus (I²C) clockHz; default: 100000
Example:
camera_start -r vga
note
Running camera_start again with a different -r or -F restarts the camera and switches the setting. The first frames after startup are discarded as warm-up. The command is also the quickest way to confirm that the camera initializes.
2. camera_stop​
camera_stop
Stop the camera and power it off.
Example:
camera_stop
3. camera_http_start​
camera_http_start [-s <ssid>] [-p <pwd>] [-c <1-13>] [-q <1-100>] [-f <1-30>] [-P <port>] [-r <qqvga|qvga|vga>] [-F <hz>]
Start the hotspot, the camera and the MJPEG web preview with one command.
ItemDescriptionData
-s <ssid>Hotspot nameDefault: wio-lr2021-camera
-p <pwd>Hotspot password8 ~ 63 characters, empty for an open network; default: 12345678
-c <1-13>Hotspot channel1 ~ 13; default: 1
-q <1-100>JPEG qualityHigher is clearer and uses more bandwidth; default: 80
-f <1-30>Frame rate capFrames per second; default: 20
-P <port>Web server portThe video stream uses this port plus one; changing it while running restarts the web service, and an out-of-range value warns and falls back; default: 80
-r <qqvga|qvga|vga>Stream resolutionDefault: qvga
Example:
camera_http_start -q 60 -f 10
note
After you change -s, -p or -c and run the command again, disconnect and reconnect the phone or PC from the hotspot. Otherwise the client still shows a connection while the board is unreachable.
Usage: join the hotspot wio-lr2021-camera with password 12345678, then open http://192.168.4.1 in a browser. A live image means the camera and the Wi-Fi path both work.
note
The web page has no authentication. Keep the hotspot off any shared or office network, and close it with camera_http_stop.
4. camera_http_stop​
camera_http_stop
Stop the web server and turn off the camera and the hotspot.
Example:
camera_http_stop
5. camera_status​
camera_status
Print camera, hotspot and web server state, resolution and quality.
Example:
camera_status
Audio​
An audio slot is a recording buffer in RAM, so no SD card is needed: record into the slot, then play it back or stream it to a PC over the device hotspot.
1. audio_init​
audio_init
Power up the audio circuitry and initialize the codec and microphone.
Example:
audio_init
note
The firmware runs this once at boot; use it to recover after audio_deinit.
2. audio_deinit​
audio_deinit
Power down the audio circuitry.
Example:
audio_deinit
note
Recording and playback stay unavailable until audio_init runs again. Use it for power-consumption measurements. If audio was never initialized since boot, the command is refused, so a second audio_deinit in a row does nothing.
3. audio_slot_record​
audio_slot_record [-d <100-60000>] [-m <20.0-37.5>]
Record from the microphone into the audio slot.
ItemDescriptionData
-d <100-60000>Recording durationMilliseconds; 100 ~ 60000; default: 10000
-m <20.0-37.5>Microphone gaindB; 20.0 ~ 37.5; default: 37.5 (maximum)
Example:
audio_slot_record -d 5000 -m 30
note
The slot holds raw microphone data with no software processing. Speak close to the microphone during the recording. Audio is initialized at boot; after audio_deinit, run audio_init first or the command is refused.
4. audio_slot_play​
audio_slot_play [-v <0-100>]
Play the recorded slot through the speaker.
ItemDescriptionData
-v <0-100>Playback volume0 ~ 100; default: keep the current volume
Example:
audio_slot_play -v 80
note
Attach a speaker to the SPK connector on the Media HAT. The command plays whatever the slot currently holds, so record first; it is refused when audio is not initialized or the slot is empty.
5. audio_slot_send​
audio_slot_send [-p <port>]
Stream the slot over the device hotspot to a PC as a WAV file.
ItemDescriptionData
-p <port>TCP port the PC connects toDefault: 3444
Example:
audio_slot_send
Usage: join the hotspot wio-lr2021-audio (password 12345678) from the PC, then run python tools/recv_wav_from_device.py -o slot.wav. The script connects to 192.168.4.1:3444, reads an 8-byte header (AUDF magic plus the audio length) and then the audio bytes; the file plays as soon as it is written.
note
The command returns immediately and the transfer runs in the background. The hotspot does not close when the transfer ends, so several recordings can be sent in a row; stop it with audio_slot_stop.
6. audio_slot_stop​
audio_slot_stop
Stop any running transfer and close the audio hotspot.
Example:
audio_slot_stop
note
Safe to run with no transfer in progress; the only effect is closing the hotspot.
7. audio_slot_info​
audio_slot_info
Print slot state: whether a recording exists, its length, sample rate, channels, duration and free memory.
Example:
audio_slot_info
Flash​
The flash endurance and speed tests work only inside the dedicated flashtest partition, so the firmware image and user data are never touched. flash_endurance runs as a background task and keeps writing while the console stays usable.
1. flash_info​
flash_info
Read the flash JEDEC ID, vendor and capacity and verify the start and end of the test partition.
Example:
flash_info
note
Return code 0 means pass; the boundary write check catches a flash chip with an overstated capacity.
2. flash_endurance​
flash_endurance -a <start|stop|status> [-m <minutes>] [-s <sectors>] [-d <ms>]
Run an erase, write and read-back soak test in the flash test partition.
ItemDescriptionData
-a <start|stop|status>Actionstart, stop or status; required
-m <minutes>Run durationMinutes; 0 runs until stopped; default: 1440
-s <sectors>Sectors written per round0=the whole test partition; default: 0
-d <ms>Delay between sectorsMilliseconds; 0=full speed; default: 0
Example:
flash_endurance -a start -m 60
note
The command returns immediately and the soak runs in the background; check progress with -a status and end it with -a stop. Every round wears the flash, so run it on samples rather than on every board.
3. flash_speed​
flash_speed [-t <kb>]
Measure page-program time, sector-erase time and read/write throughput.
ItemDescriptionData
-t <kb>Amount of data used for the throughput testKB; default: 64
Example:
flash_speed -t 128
note
Return code 0 means every measurement is inside the datasheet limits.
Aliases​
Five compatibility aliases are registered. They call exactly the same function as the primary command; use the primary name in scripts and documentation.
AliasPrimary commandNote
apap_setSame function; prefer the primary name.
stasta_connectSame function; prefer the primary name.
disconnectsta_disconnectSame function; prefer the primary name.
wifi_scansta_scanSame function; prefer the primary name.
Result Strings and Return Codes​
The firmware reports results as plain text lines on the serial port and then returns to the cmd> prompt. The markers below are the ones documented for firmware V2.1.0; the full inventory of log prefixes is pending a serial capture on hardware.
MarkerWhere it appearsMeaning
cmd>Every commandPrompt; the firmware is ready for the next command
got ip:sta_connectThe station obtained an address; the connection succeeded
Return code 0flash_info, flash_speedEvery check passed; any other code is a failure
AUDFaudio_slot_send receiver headerMagic at the start of the 8-byte header, followed by the audio length
Alias ofhelp listingThe entry is a compatibility alias, not a separate command
out of boundsParameter warningsThe value was clamped or replaced; the command still runs
rx_done / rx_hdr_err / rx_crc_errlora_rx exitReceive counters printed after Ctrl+C
WiFi already initialise.wifi initThe driver was already initialized, so the call is skipped
A value that cannot be parsed aborts the command and prints an English error line; an out-of-range value usually logs out of bounds and falls back to a documented default. The wording differs per command, so correct the flagged value and run the command again rather than matching on the sentence.
