Wio-LR2021 Dev Kit FLRC Image Transmission Demo
Introduction​
Two Wio-LR2021 Dev Kits are enough to build a complete wireless camera link. One kit captures a 320 × 240 frame, runs a small detector on the ESP32-S3, draws the result, and compresses the frame as JPEG. It sends the JPEG over FLRC at 2.6 Mbps. The second kit reassembles the image in PSRAM and serves it from a web page. A phone or laptop joins the receiver's access point and watches the link in a browser, with no application to install. The result is a sequence of still images, not a video stream.
The demo has four transmitter builds. Three run a model: face detection, hand-gesture recognition, and water-meter reading. The fourth sends the camera image without inference and sets the baseline for the link. You flash one build at a time, so the same transmitter hardware can show any of the four modes.
note
The face build is a face detector, not a face-recognition system. It finds a face and draws a box around it. It does not identify who the person is, and it is not suitable for authentication.
What You Will Build​
  • A transmitter that captures an image, runs a Swift-YOLO model, draws boxes and labels, and sends the annotated JPEG over FLRC.
  • A receiver that reassembles the image, checks it, and publishes the newest complete frame over Wi-Fi.
  • A browser view at 192.168.4.1 that shows the image, the completed-image count and the current frame rate.
How It Works​
Block diagram of the FLRC camera link: camera, ESP32-S3 inference and JPEG, LR2021 transmitter, FLRC burst, LR2021 receiver, PSRAM reassembly, SoftAP and browser
Transmitter Path​
The transmitter runs the whole pipeline on one board:
  1. The GC2145 camera on the Media HAT captures a 320 × 240 RGB565 frame.
  2. The ESP32-S3 resizes the frame to the model input and runs inference.
  3. The firmware draws each detection on the frame, including the class label and a confidence percentage. The water-meter build also draws a per-digit score and a READING: line.
  4. The annotated frame is compressed as JPEG.
  5. The LR2021 splits the JPEG into fragments, adds an image ID and a CRC32, and sends the image in an FLRC burst.
The camera and the JPEG encoder are fixed in this firmware build.
Receiver Path​
The receiver does not run a model. It listens on the same FLRC frequency and moves received packets into PSRAM with SPI DMA. The ESP32-S3 reassembles the fragments, checks the size and CRC32, and publishes the newest complete image. An incomplete image is discarded instead of being shown in parts.
The ESP32-S3 also runs a SoftAP and a small HTTP server. The page requests the newest JPEG and the counters about every 200 ms, so the browser always shows the latest complete frame. All inference and drawing happen before transmission; the browser receives a finished JPEG.
Why FLRC​
LoRa trades data rate for range. FLRC does the opposite: it sends a short burst at a high rate and accepts a shorter range. At 2.6 Mbps, one 320 × 240 JPEG takes a fraction of a second of air time. That is what makes a camera demo possible on a LoRa-class radio.
The 2.6 Mbps figure is the FLRC air rate, not the frame rate. Capture, inference, JPEG encoding, transmission and reassembly all add time. The Performance section shows the receiver-side rates measured in the clips.
Hardware Preparation​
What You Need​
ItemQuantityNotes
Wio-LR2021 Dev Kit2One transmitter, one receiver
Media HAT with GC2145 camera1Fits the transmitter only
Sub-GHz antenna2One on each board, marked SUB-1G
2.4 GHz antenna1Receiver only; fits the ESP32-S3 2.4 GHz U.FL pad, not the LR-2.4G SMA
USB-C cable2Data-capable, not charge-only
USB power source25 V; a computer port is enough
Phone or laptop12.4 GHz Wi-Fi
Step 1 — Fit the Antennas​
Screw the sub-GHz antenna onto the SUB-1G connector on each board. Tighten by hand only. On the receiver, fit the 2.4 GHz antenna to the ESP32-S3 U.FL pad marked 2.4G. Leave the LR-2.4G SMA empty.
caution
Transmitting into an open antenna port can stress the power amplifier. Fit the antenna before you power on either board.
Step 2 — Fit the Camera HAT to the Transmitter​
Line up the two 16-pin sockets on the Media HAT with the headers on the transmitter, pin 1 to pin 1. Press down evenly on both ends. The camera is part of the HAT, so no separate FPC cable is needed.
caution
Do not connect or remove the camera HAT while the board is powered. Power off the board and unplug USB-C first.
Leave the receiver without a camera HAT. It uses the sub-GHz antenna, the 2.4 GHz antenna and power, but no camera.
Step 3 — Mark the Roles​
Label the boards before you flash them:
  • Transmitter: camera HAT, sub-GHz antenna, USB-C for power and flashing.
  • Receiver: sub-GHz antenna, 2.4 GHz antenna on the ESP32-S3 U.FL pad, USB-C to a computer or charger.
Both boards look the same, and the firmware is different. A label on the back saves a reflash later.
Step 4 — Power Both Boards​
Connect USB-C to both boards. The receiver needs power for the access point and the web server; the transmitter needs power for the camera and the radio. The recorded demo uses USB power.
Software Preparation​
Download the firmware for the Receiver:
Download the firmware for the Transmitter:
Flash the Receiver​
Close any serial terminal that is using the port, then run:
python -m esptool -p <PORT> -b 115200 --before default-reset --after hard-reset write-flash 0x0 flrc-rx-260914-1522.bin
Replace <PORT> with the port of the board:
SystemPort
WindowsCOM5 or the number in Device Manager
macOS/dev/cu.usbmodem*
Linux/dev/ttyACM0
Flash the Transmitter​
Repeat the same procedure with one transmitter build. Start with the face build:
python -m esptool -p <PORT> -b 115200 --before default-reset --after hard-reset write-flash 0x0 flrc-tx-face-detection-260914-1520.bin
To change the mode, flash a different transmitter build. The receiver stays as it is.
caution
Write the merged image at 0x0. Do not use the bootloader or application offsets from a split build. Do not unplug the board while the write is in progress. Flashing replaces the factory firmware.
Open the Serial Log​
Both builds print boot and status messages at 115200 baud rate, 8 data bits, no parity and 1 stop bit. The port is USB CDC, so the baud rate is nominal.
  • The AI transmitters print the model name, the camera mode and the FLRC settings.
  • The receiver prints the access point, the image counter and any discarded images.
Run the Demo​
Step 1 — Boot the Receiver​
Connect the receiver to USB-C and press RESET once. Wait for the access point to appear. The SSID starts with Wio-LR2021-FLRC-RX- and ends with four hex characters derived from the receiver's Wi-Fi MAC address. The password is 12345678.
If the network does not appear, open the serial log and look for the access-point message. Check that the receiver build is flashed and that the 2.4 GHz antenna is fitted to the ESP32-S3 U.FL pad. Confirm that the board has a stable 5 V supply.
Step 2 — Connect Your Browser Device​
Join the Wio-LR2021-FLRC-RX-xxxx network from a phone or laptop. Keep the device on this network; it does not need internet access.
On some phones, mobile data takes over when the access point has no internet. Turn off mobile data for the test, or choose the option that keeps the Wi-Fi connection.
Step 3 — Open the Page​
Open a browser and go to:
http://192.168.4.1
The page shows a black background, two lines of white text and the newest image. There is no login and no control panel.
Step 4 — Point the Transmitter​
Power the transmitter and point the camera at the subject. The first image may take a few seconds. For the best result:
  • Keep the subject inside the frame and at a comfortable distance.
  • Use even lighting. Strong backlight or glare hides the subject.
What You See​
The Page Header​
The page shows two counters and a rate above the image:
Received frames: 174 (image 23)
FPS: 2.22
  • Received frames counts the JPEG images the receiver has completed.
  • image is the image ID assigned by the transmitter.
  • FPS is the end-to-end rate the receiver measured.
The frame count and image ID are separate and do not need to match. They can differ after a reset.
Face Detection​
The face build draws a magenta box around the detected face and a label bar with face and a confidence percentage. The bar sits at the top-left corner of the box. The page does not rotate frames; mount the camera in the orientation you want to see.
The detector does not identify the person. Two different people produce the same face label.
Gesture Recognition​
The gesture build draws a box around the hand and labels it paper, rock or scissors. In this frame the model returned two overlapping candidates for the same fist, so the transmitter drew two boxes and two labels. The firmware does not merge duplicate candidates. The larger score is the better candidate.
Show one hand at a time and keep the fingers inside the frame. Avoid a busy background. The model is trained on the three gestures, not on arbitrary hand poses.
Water-Meter Reading​
The water-meter build draws a box around each digit and prints a score above the box. It adds a yellow READING: line at the bottom of the image. The reading is assembled from the detected digits. It can change from frame to frame when the meter is angled or the digits are partly hidden.
This is a reading aid, not a certified meter reader. Check the reading against the meter before you use it in any billing or reporting workflow.
Raw Camera Baseline​
The raw build sends the camera image without inference. It is the fastest mode in the demo and the best way to check the link before you add a model. The clip shows an inverted image; the receiver displays the JPEG as it arrives and does not rotate it. Mount the camera upright for an upright view.
Performance​
These rates were read from the receiver page in the demo clips. They are end-to-end rates: capture, inference, drawing, JPEG encoding, FLRC transmission and reassembly are all included.
Transmitter buildOn-device workObserved rate
Raw cameraCapture, JPEG, FLRC7.6–9.9 fps, peak 11.27 fps
Face detection96 × 96 model, draw, JPEG, FLRCabout 2.2 fps
Gesture recognition192 × 192 model, draw, JPEG, FLRCabout 0.9 fps
Water-meter reading192 × 192 model, draw, JPEG, FLRCabout 0.8 fps
In this demo, the raw build is the ceiling for the pipeline, not a guaranteed rate. The AI builds are slower because the model runs on every frame. The 192 × 192 models also take longer than the 96 × 96 face model. The 2.6 Mbps FLRC rate is not the frame rate; the image size and per-frame processing dominate.
Resources​
Firmware​
