ePaper Driver Board Overview
Introduction
The ePaper Driver Board series is engineered for versatile, low-power ePaper applications. These boards support a wide range of ePaper displays—from universal 24-pin and 50-pin screens to specialized large-format displays like 10.3” (High Speed refresh) and 13.3” (Spectra™ 6). Each board shares core functionalities, including a JST 2.0mm battery connector with a power switch, an integrated charging IC, a reset button, and three user-configurable buttons. Powered by diverse microcontrollers (e.g., XIAO ESP32-S3 Plus, XIAO nRF52840 Plus), some models also feature NFC capabilities, making them ideal for digital signage, electronic shelf labels, portable dashboards, and other energy-efficient display projects.
XIAO ePaper Display Board EE02
The EE02 is a high-performance E-ink screen driver board specifically designed for 13.3-inch electronic paper displays. Powered by the ESP32-S3 chip, it supports Wi-Fi and Bluetooth connectivity, making it an ideal solution for wireless display applications.
Feature
- Powerful Controller: Built around the ESP32-S3, offering robust processing power and wireless capabilities.
- Dedicated for Large Screens: Specifically optimized to drive 13.3-inch E-ink displays with high stability and clarity.
- Wireless Connectivity: Supports Wi-Fi and Bluetooth 5.0 (LE), enabling remote data updates and cloud integration.
- Low Power Consumption: Designed for energy efficiency, suitable for battery-powered applications.
- Easy Integration: Compatible with SenseCraft HMI for drag-and-drop interface design and remote management.
- Versatile Interfaces: Includes Type-C for power/programming and standard connectors for E-ink screens.
XIAO ePaper Display Board EE03
Powered by XIAO ESP32-S3 Plus, the ePaper driver board EE03 supports 10.3 Monochrome ePaper Display. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital photo frames and information boards.
Feature
- Built in XIAO ESP32-S3 Plus: Works immediately when connected to a compatible ePaper display.
- Dedicated 10.3" Monochrome ePaper Display Support: Specifically designed for 10.3" high-speed refresh epaper display, ensuring quick setup and stable operation.
- High-Speed Refresh Enabled: Integrated T-CON timing control ensures precise high-speed driving, while the onboard SHT40 provides real-time temperature sensing for waveform compensation.
- BAT Connector with Switch: Provides simple battery connection and integrates a switch, enabling efficient power management and energy savings.
- User-Friendly Buttons: Features 1 reset button and 3 user-programmable buttons, providing flexibility for project acceleration and customizable functions.
XIAO ePaper Display Board EE04
Powered by XIAO ESP32-S3 Plus, the display board EE04 supports both 24-pin and 50-pin ePaper displays. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital signage, electronic labels, and portable information boards.
Feature
- Powered by XIAO ESP32-S3 Plus: Works immediately when connected to a compatible ePaper display.
- Versatile Display Support: Compatible with a wide range of ePaper screens, supporting both 24-Pin and 50-Pin interfaces with easy switching via jumper caps.
- User-Friendly Buttons: Includes 1 reset button and 3 user-programmable buttons, offering flexibility for project acceleration and customizable functions.
XIAO ePaper Display Board EN04
Powered by XIAO nRF52840 Plus, the display board EN04 supports both 24-pin and 50-pin ePaper displays. It features a JST 2.0 mm battery connector with power switch, built-in charging IC, NFC function and comes with one reset and three user buttons. Well-suited for low-power ePaper projects such as digital signage, electronic labels, and portable information boards.
Feature
- Powered by XIAO nRF52840 Plus: Works immediately when connected to a compatible ePaper display.
Applications
The reTerminal E Series ePaper Display supports multiple development platforms and frameworks:
EE04 Driver Board works with platformio
Explains how to plug the EN04 getting start with PlatformIO.
EE04 Driver Board works with ESPHome in Home Assistant
Explains how to plug the EN04 into Home Assistant and write simple programs to draw simple graphs in ESPHome via YAML.
EE04 Driver Board works with TRMNL
Utilize the dedicated TRMNL framework for simplified development and rapid deployment.
