XIAO ESP32C6 with Visual Studio
This walkthrough builds on the XIAO ESP32C6 Wi-Fi scan example. You’ll upload an Arduino sketch that classifies the strongest sampled 2.4 GHz signal, then stop at the comparison and see the value change as you step through it. The XIAO’s built-in USB JTAG works through the same USB data cable you use to upload the sketch. Espressif’s built-in USB JTAG reference
What you need
- A Seeed Studio XIAO ESP32C6 and a USB-C data cable connected directly to your Windows computer.
- Microsoft Visual Studio 2022 or 2026 with the Desktop development with C++ workload and the Visual Micro extension. Visual Micro is a third-party extension with a trial and paid licences.
- An active 2.4 GHz Wi-Fi access point in range. The sketch scans nearby networks without joining them.
Select the board and port
- In the Visual Micro toolbar, select the Arduino environment you want to use. The Arduino 2 option uses your Arduino IDE 2 configuration. If esp32 by Espressif Systems is already installed in that environment, go to step 2. Otherwise, use Micro Explorer → Board Manager to install the stable package. If Espressif is missing from Board Manager, add the package index from Seeed’s instructions in IDE Locations → Additional board manager JSON URLs, save and choose Check for Updates in Board Manager. Seeed’s board setup · Visual Micro Board Manager
- Choose vMicro → New Arduino Project and name it
XiaoC6WifiSignal. SelectXIAO_ESP32C6as the board and the COM port that appears when you connect the XIAO. - Set USB CDC On Boot to Enabled in vMicro → Board Options. This routes the sketch’s
Serialoutput to the XIAO’s USB connector.
Upload the Wi-Fi sketch
Replace the contents of XiaoC6WifiSignal.ino with the sketch below. It scans for networks, records the strongest sampled RSSI in dBm, and compares it with -70 dBm. A reading of -70 dBm or higher counts as strong.
#include <WiFi.h>
volatile int32_t thresholdDbm = -70;
volatile int32_t strongestDbm = -127;
volatile bool strongSignal = false;
WiFi.STA.begin(false);
const int count = WiFi.scanNetworks();
if (count > 0) {
// WiFi.RSSI() takes an 8-bit scan-result index.
const int sampleCount = min(count, 256);
int32_t bestDbm = WiFi.RSSI(0);
for (int index = 1; index < sampleCount; ++index) {
const int32_t rssi = WiFi.RSSI(index);
if (rssi > bestDbm) {
bestDbm = rssi;
strongestDbm = bestDbm;
strongSignal = strongestDbm >= thresholdDbm; // Set a breakpoint here.
Serial.printf("%ld dBm (%s)\n", static_cast<long>(strongestDbm),
strongSignal ? "strong" : "weak");
} else {
Serial.println(count == 0 ? "No networks found" : "Wi-Fi scan failed");
WiFi.scanDelete();
delay(4000);
Choose vMicro → Build & Upload. Open the Visual Micro Serial Monitor for the board’s COM port, set it to 115200 baud and click Connect. After a scan, expect a line such as -68 dBm (strong) or -71 dBm (weak). Enable Auto-Recon if you want an open monitor to reconnect after the port is released by a later upload.
Step through the signal comparison
Select the Debug build configuration. In the Visual Micro toolbar, set the debugger mode to Hardware and choose ESP32C6-USB. Keep the board set to
XIAO_ESP32C6. To match the board test, select vMicro → Debugger → Disable Optimization → No Project + Libraries Optimization.
Click in the left margin of the line
strongSignal = strongestDbm >= thresholdDbm;to set a breakpoint. Press F5 to start debugging. The sketch pauses on that line once a scan finds a network. -
In Visual Studio, open Debug → Windows → Watch → Watch 1. Add
strongestDbm,thresholdDbmandstrongSignal. At this point,strongSignalstill holds its previous value. -
Press F10 once to execute the comparison. The debugger moves to the
Serial.printfline. In the board test shown below,strongestDbmwas-71,thresholdDbmwas-70, and the assignment changedstrongSignalfromtruetofalse. Your result will depend on the networks around you. The screenshot shows the values in Autos.
Press F5 to resume. The Serial Monitor prints the classification. The sketch then waits four seconds and starts another scan. To leave it scanning without pausing, clear the breakpoint and press F5 again.
The screenshots show the original on-board test. The sketch above uses the same comparison and limits the number of scan results it indexes to 256. That revision was compiled with Arduino-ESP32 3.3.13.
Troubleshooting
- The breakpoint never hits. The comparison runs only when the scan finds at least one network. If the Serial Monitor says
No networks found, move the XIAO closer to a 2.4 GHz access point. If you need to connect the monitor manually while the sketch is paused, resume with F5 before clicking Connect. - The COM port is missing or the upload times out. Check that the cable carries data, reconnect the board and select the current COM port. If Windows still does not detect it, follow Seeed’s bootloader recovery steps.
- USB JTAG disconnects or the debugger stalls. Unplug and reconnect the XIAO, then wait for Windows to recognise it. If the debugger is still waiting, stop debugging and start a fresh session with F5. For OpenOCD errors or debugger profile checks, see ESP32-C6 USB JTAG troubleshooting.
