SenseCraft Model Assistant Getting Start with Seeed Studio XIAO ESP32S3
Introduction
SenseCraft Model Assistant is an open-source project focused on embedded AI. We have optimized excellent algorithms from OpenMMLab for real-world scenarios and made implemention more user-friendly, achieving faster and more accurate inference on embedded devices.
Hardware Required
Software Required
- ESP-IDF v4.4
- SenseCraft Model Assistant v0.1.0
- Example Code: SenseCraft Model Assistant-example-esp32
How to Install
Install ESP-IDF
Follow the instructions of the ESP-IDF get started guide to setup the toolchain and the ESP-IDF itself.
The next steps assume that this installation is successful and the IDF environment variables are set. Specifically,
- the
IDF_PATHenvironment variable is set - the
idf.pyand Xtensa-esp32 tools (e.g.,xtensa-esp32-elf-gcc) are in$PATH
get submodules
cd to the root directory of the project and run the following command to get the submodules:
git clone https://github.com/Seeed-Studio/edgelab-example-esp32 && cd edgelab-example-esp32
git submodule init
git submodule update
How to Use
Build the example
Go to example directory (examples/<example_name>) and build the example.
Set the IDF_TARGET (For ESP32-S3 target, IDF version release/v4.4 is needed)
idf.py set-target esp32s3
Configure the example
idf.py menuconfig
- Select the Camera Module in
Component config->SenseCraft Model Assistant Configuration->Camera Configuration->Select Camera Pinout
- Select the LCD Module in
Component config->SenseCraft Model Assistant Configuration->LCD Configuration->Select LCD Pinout
To build this, run:
idf.py build
Load and run the example
To flash (replace /dev/ttyUSB0 with the device serial port):
idf.py --port /dev/ttyUSB0 flash
Monitor the serial output:
idf.py --port /dev/ttyUSB0 monitor
