Zephyr Development
How ZephCore relates to MeshCore​
MeshCore lets LoRa devices exchange messages off-grid. ZephCore project is a community port of MeshCore built on the Zephyr operating system. You can try ZephCore on one device and send a message to a friend running MeshCore. Both radios need matching settings.
ZephCore GitHub project
What changes for you?MeshCore firmwareZephCore firmware
Firmware PlatformArduino-based MeshCore firmwareA port built on Zephyr RTOS
LoRa NetworkA MeshCore LoRa meshThe same MeshCore mesh
Mobile APPMeshCore app with a BLE CompanionSame app with a supported BLE Companion build
What is Zephyr?​
Zephyr is an open-source real-time operating system for small devices. On a tracker, it can wake the processor when a button is pressed, read a GPS receiver, or update a display. ZephCore uses those services to run a mesh node.
Choose your device​
Choose Companion if you want to send messages from your phone over Bluetooth. Choose Repeater if you want the device to forward messages for nearby nodes.
DeviceImageBoard name in ZephCore
Wio Tracker L1 Pro
Wio Tracker L1 Pro in the MeshCore getting started guide
wio_tracker_l1
SenseCAP MeshTracker X1
SenseCAP MeshTracker X1 in the MeshCore getting started guide
meshtracker_x1
SenseCAP T1000-E
SenseCAP T1000-E in the MeshCore getting started guide
t1000_e
SenseCAP Solar Node P1 Pro
SenseCAP Solar Node P1 Pro in the MeshCore getting started guide
sensecap_solar is the related board name
Check which builds are available for your board in the board list and firmware releases.
Flash ZephCore​
Before switching firmware, save your radio settings and back up your node identity if you want to keep it. Switching firmware requires setting up the node again.
  1. Connect. Plug the device into your computer with a USB data cable. Open the ZephCore Web Flasher in Chrome or Edge.
  2. Select. Choose your exact board and role using the table above.
Seeed Studio devices in the ZephCore Web Flasher
  1. Flash. Follow the prompts to select the USB device and install the firmware. Wait for the flasher to report completion.
  2. Test. Select the same regional radio preset as a nearby MeshCore node. For a Companion, pair in the MeshCore app, send a message, and ask for a reply. For a Repeater, check that a message reaches a second node through the relay.
ZephCore startup screen on the L1 Pro
What can you try with ZephCore?​
Measure battery use​
Listening for LoRa packets uses power even when nobody sends a message. On supported SX126x radios, ZephCore can listen in short windows to reduce average current.
Check the L1 Pro without taking out your phone​
On the L1 Pro, use the joystick to browse the OLED status screens and check the battery level on the device. This is handy when the tracker is in your hand and your phone is packed away. On the screenless X1 and T1000-E, use the MeshCore app to view Companion status.
ZephCore menu on the L1 Pro OLED
Explore games on Zephyr​
ZephCore game demonstration
Build your first ZephCore firmware​
Install Git, the Zephyr tools, and the SDK required by your ZephCore revision. ZephCore build instructions
From a new folder, download the project and its dependencies:
git clone https://github.com/liquidraver/ZephCore.git zephcore
west init -l zephcore
west update
From the same folder, build the L1 Pro firmware:
west build -b wio_tracker_l1 zephcore --pristine
Here, west is Zephyr’s command-line tool and -b selects the board. The command compiles the firmware on your computer. To try a first edit, change a label on the L1 Pro status screen, rebuild, and follow the project’s instructions to install your local build. The new label gives you a visible check that your own firmware is running.
As you explore the source, look for Devicetree to see how hardware is connected and Kconfig to see which features a build enables.
