Wio Terminal Displaying Accelerator Readings
Overview
This example demonstrates how to draw line graph on Wio Terminal. In this example, the 3-axis accelerator readings(3 sets of data) are plotted into one line graph to show the real-time positioning of the Wio Terminal!
3-axis accelerator readings displaying in one Line graph
Real time positioning of the Wio Terminal
Arduino libraries needed
Visit Seeed_Arduino_Linechart and download the entire repo to your local drive.
Install the on-board accelerator library
Seeed_Arduino_LIS3DHTR
, Please visit Seeed_Arduino_LIS3DHTR for more information.
Arduino Instructions
Download the
AcceratorReadings.ino
file and upload to your Wio Terminal throughArduino IDE
. Make sure you installed all the libraries.Move Wio Terminal in different axis and see what it displays, and you could also open
Serial Plotter
to check the effect!
Code
- To initialize LCD and Accelerator
#include"LIS3DHTR.h" //include the accelerator library
#include"seeed_line_chart.h" //include the line chart library
TFT_eSPI tft;
LIS3DHTR<TwoWire> lis;
#define MAX_SIZE 50 //maximum size of data
doubles accelerator_readings[3];
TFT_eSprite spr = TFT_eSprite(&tft); // Sprite
tft.begin();
tft.setRotation(3);
spr.createSprite(TFT_HEIGHT,TFT_WIDTH);
spr.setRotation(3);
lis.begin(Wire1);
lis.setOutputDataRate(LIS3DHTR_DATARATE_25HZ);
lis.setFullScaleRange(LIS3DHTR_RANGE_2G);
- Reading Accelerator data and loading data
Please refer to Line Charts for more information.
spr.fillSprite(TFT_WHITE);
float x_raw = lis.getAccelerationX();
float y_raw = lis.getAccelerationY();
float z_raw = lis.getAccelerationZ();
if (accelerator_readings[0].size() == MAX_SIZE) {
for (uint8_t i = 0; i<3; i++){
accelerator_readings[i].pop(); //this is used to remove the first read variable
accelerator_readings[0].push(x_raw); //store x-axis readings
accelerator_readings[1].push(y_raw); //store y-axis readings
accelerator_readings[2].push(z_raw); //store z-axis readings
- Title configurations
auto header = text(0, 0)
.value("Accelerator Readings")
.align(center)
.valign(vcenter)
.width(spr.width())
.thickness(2);
header.height(header.font_height(&spr) * 2);
header.draw(&spr); // Header height is the twice the height of the font
- Line Chart configurations
To draw multiple lines in one graph, you can pass doubles array into the line graph like content.value({doubles[0],doubles[1],doubles[2]...})
as shown below. Can also set the color for each line using .color()
where the order of color will match the order of data passing.
auto content = line_chart(20, header.height()); //(x,ywhere the line graph begins
content
.height(spr.height() - header.height() * 1.5) //actual height of the line chart
.width(spr.width() - content.x() * 2) //actual width of the line chart
.based_on(-2.0) //Starting point of y-axis, must be a float
.show_circle(false) //drawing a cirle at each point, default is on.
.value({accelerator_readings[0],accelerator_readings[1], accelerator_readings[2]}) //passing through the data to line graph
.max_size(MAX_SIZE)
.color(TFT_BLUE, TFT_RED, TFT_GREEN)
.backgroud(TFT_WHITE)
.draw(&spr);
Complete code
TFT_eSPI tft;
tft.begin();
tft.setRotation(3);
spr.setRotation(3);
lis.begin(Wire1);
//This is used to print out on Serial Plotter, check Serial Plotter!
Serial.print(x_raw);
Serial.print(",");
Serial.print(y_raw);
Serial.print(",");
Serial.println(z_raw);
accelerator_readings[0].push(x_raw); //read variables and store in data
//Settings for the line graph title
.align(center)
.valign(vcenter)
.width(spr.width())
.thickness(2);
auto content = line_chart(20, header.height()); //(x,y) where the line graph begins
content
.max_size(MAX_SIZE)
.draw(&spr);
spr.pushSprite(0, 0);
delay(50);
