Grove - Loudness Sensor
The Grove - Loudness Sensor is designed to detect the sound of environment. Based on LM2904 amplifier and a built-in microphone, it amplifies and filters the high frequency signal that received from the microphone, and outputs a positive envelop. This is used for Arduino’s signal acquisition. The output value depends on the level of sound input. In order to avoid unnecessary signal disturbances, input signal will go through two times’ filtering inside the module. There is a screw potentiometer that enables manual adjustments to the output gain.
Version
Product VersionChangesReleased Date
Grove-Loudness Sensor V0.9bInitialDec 2012
  • Grove Interface
  • Easy to use
  • Basic Grove element
More details about Grove modules please refer to [Grove System](https://wiki.seeedstudio.com/Grove_System/)
Specifications
ParameterValue/Range
Voltage3.5~10 VDC
Working Frequency5~2000 Hz
Sensitivity-60~-56dBV/Pa
Signal-to-noise Ratio>58 dB
Output Signal rangeAnalog Signal (0-1023)
Platforms Supported
ArduinoRaspberry Pi
caution
Getting Started
note
If this is the first time you work with Arduino, we firmly recommend you to see [Getting Started with Arduino](https://wiki.seeedstudio.com/Getting_Started_with_Arduino/) before the start.
Play With Arduino
Hardware
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove-Loudness Sensor
Get One NowGet One NowGet One Now
  • Step 2. Connect Grove-Loudness Sensor to A0 port of Grove-Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove-Loudness Sensor to Seeeduino as below.
SeeeduinoGrove-Loudness Sensor
5VRed
GNDBlack
NCWhite
A0Yellow
Software
  • Step 1. Please copy below code to Arduio IDE and upload to arduino. If you do not know how to upload the code, please check how to upload code.
int loudness;
Serial.begin(9600);
loudness = analogRead(0);
Serial.println(loudness);
delay(200);
  • Step 2. Open the serial to monitor the output. It will be a significant change when blow to the sensor.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Loudness Sensor
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove Base Hat into Raspberry Pi.
  • Step 3. Connect the Grove - Loudness Sensor to to the A0 port of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
Software
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below command to run the code.
cd grove.py/grove
python grove_loudness_sensor.py 0
Following is the grove_water_sensor.py code.
import math
import sys
import time
from grove.adc import ADC
class GroveLoudnessSensor:
def __init__(self, channel):
self.channel = channel
self.adc = ADC()
@property
def value(self):
return self.adc.read(self.channel)
Grove = GroveLoudnessSensor
def main():
if len(sys.argv) < 2:
print('Usage: {} adc_channel'.format(sys.argv[0]))
sys.exit(1)
sensor = GroveLoudnessSensor(int(sys.argv[1]))
print('Detecting loud...')
while True:
value = sensor.value
if value > 10:
print("Loud value {}, Loud Detected.".format(value))
time.sleep(.5)
if __name__ == '__main__':
main()
If everything goes well, you will be able to see the following result:
pi@raspberrypi:~/grove.py/grove $ python grove_loudness_sensor.py 0
Detecting loud...
Loud value 15, Loud Detected.
Loud value 11, Loud Detected.
Loud value 250, Loud Detected.
Loud value 429, Loud Detected.
Loud value 203, Loud Detected.
Loud value 16, Loud Detected.
File "grove_loudness_sensor.py", line 68, in <module>
main()
File "grove_loudness_sensor.py", line 65, in main
time.sleep(.5)
KeyboardInterrupt
You can use this sensor to detect the loudness. Press ++ctrl+c++ to quit.
note
    You may have noticed that for the analog port, the silkscreen pin number is something like **A1, A0**, however in the command we use parameter **0** and **1**, just the same as digital port. So please make sure you plug the module into the correct port, otherwise there may be pin conflicts.
Play With Raspberry Pi(with GrovePi_Plus)
Hardware
Raspberry piGrovePi_PlusGrove-Loudness Sensor
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove-Loudness Sensor to A0 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC through USB cable.
Software
  • Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
  • Step 3. Excute below commands to monitor the loudness.
cd ~/GrovePi/Software/Python
Here is the grove_loudness_sensor.py code.
import time
import grovepi
# Connect the Grove Loudness Sensor to analog port A0
# SIG,NC,VCC,GND
loudness_sensor = 0
while True:
try:
# Read the sound level
sensor_value = grovepi.analogRead(loudness_sensor)
print("sensor_value = %d" %sensor_value)
time.sleep(.5)
except IOError:
print ("Error")
  • Step 4. We will see the loudness status as below.
pi@raspberrypi:~/GrovePi/Software/Python $ python grove_loudness_sensor.py
sensor_value = 135
sensor_value = 23
sensor_value = 196
sensor_value = 258
sensor_value = 98
sensor_value = 131
  • Q1: What is the difference between Grove-Loudness sensor and Grove - Sound Sensor?
    • A1: The Grove-Loudness sensor have screw potentiometer to adjust the output gain.
Schematic Online Viewer
Projects
Solar Powered Environmental Monitoring Kit: A solar-powered open source kit for monitoring air quality, sound level, humidity, and temperature.
The Da Vinci Code: The work combines art and electronics. The art part makes the skeleton and consists of 11 layers of medium density fiberboard.
