Grove - Collision Sensor
Grove - Collision Sensor can detect whether any collision movement or vibration happens. It will output a low pulse signal when vibration is detected. To make the output signal more reliable and neat, we added a necessary exterior circuit to reduce the noise impact. So, normal shaking will not cause any output. The sensor has a high sensitivity. You can use it to apply to your project, such as automatic wake-up and power-down for battery management.
Its working voltage is 5V which makes it compatible with standard Arduino/Seeeduino 5V system.
Specifications
  • Voltage: 3.3/5V
More details about Grove modules please refer to [Grove System](https://wiki.seeedstudio.com/Grove_System/)
Platforms Supported
ArduinoRaspberry Pi
caution
Getting Started
###Play With Arduino
Based on the output signal will change when a collision happens, we design this demo: each time the sensor detects collision, the LED will light up. Here the LED is as a managed device, and you can refer to the demo to control your device, such as bicycle light.
The procedure is as follows:
1.Connect the collision sensor to the Digital port 2 of Grove - Basic Shield using a Grove cable and connect an LED to Pin 13.
2.Plug the Grove - Basic Shield into Arduino.
3.Connect Arduino/Seeeduino to PC by using a USB cable.
4.Copy and paste code below to a new Arduino sketch. And upload it to your Arduino.
// Test Grove - Collision Sensor
#define LED 13 //the onboard LED of Arduino or Seeeduino
#define COLLISION_SENSOR 2//collision sensor is connected with D2 of Arduino
pins_init();
if(isTriggered())
turnOnLED();
delay(2000);
else turnOffLED();
void pins_init()
pinMode(LED,OUTPUT);
turnOffLED();
pinMode(COLLISION_SENSOR,INPUT);
boolean isTriggered()
if(!digitalRead(COLLISION_SENSOR))
delay(50);
return true;//the collision sensor triggers
return false;
void turnOnLED()
digitalWrite(LED,HIGH);//the LED is on
void turnOffLED()
digitalWrite(LED,LOW);//the LED is off
5.Now you can check the status of LED. The LED should light up every time you drum fingers on the table.
You can adjust the sensor sensitivity by changing the function delay(50) in code.
return false;
Play with Codecraft
Hardware
Step 1. Connect a Grove - Collision Sensor to port D2 of a Base Shield.
Step 2. Plug the Base Shield to your Seeeduino/Arduino.
Step 3. Link Seeeduino/Arduino to your PC via an USB cable.
Software
Step 1. Open Codecraft, add Arduino support, and drag a main procedure to working area.
note
If this is your first time using Codecraft, see also [Guide for Codecraft using Arduino](https://wiki.seeedstudio.com/Guide_for_Codecraft_using_Arduino/).
Step 2. Drag blocks as picture below or open the cdc file which can be downloaded at the end of this page.
Upload the program to your Arduino/Seeeduino.
When the code finishes uploaded, the LED on the pin 13 of Arduino will goes on when Collision Sensor detects collision.
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Collision Sensor
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove Base Hat into Raspberry.
  • Step 3. Connect the Grove - Collision Sensor to D5 port of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
note
For step 3 you are able to connect the Grove - Collision Sensor to **any GPIO Port** but make sure you change the command with the corresponding port number.
Software
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below commands to run the code.
cd grove.py/grove
python grove_collision_sensor.py 5
Following is the grove_collision_sensor.py code.
import time
from grove.gpio import GPIO
class GroveCollisionSensor(GPIO):
def __init__(self, pin):
super(GroveCollisionSensor, self).__init__(pin, GPIO.IN)
self._last_time = time.time()
self._on_collision = None
self._on_NoCollision = None
self.collisionState = False
@property
def on_collision(self):
return self._on_collision
@on_collision.setter
def on_collision(self, callback):
if not callable(callback):
return
if self.on_event is None:
self.on_event = self._handle_event
self._on_collision = callback
@property
def on_NoCollision(self):
return self._on_NoCollision
@on_NoCollision.setter
def on_NoCollision(self, callback):
return
self._on_NoCollision = callback
def _handle_event(self, pin, value):
t = time.time()
dt, self._last_time = t - self._last_time, t
if not value:
if callable(self._on_collision):
self._on_collision(dt)
else:
if callable(self._on_NoCollision):
self._on_NoCollision(dt)
Grove = GroveCollisionSensor
def main():
import sys
if len(sys.argv) < 2:
print('Usage: {} pin'.format(sys.argv[0]))
sys.exit(1)
button = GroveCollisionSensor(int(sys.argv[1]))
def on_collision(t):
print('Collision')
def on_NoCollision(t):
print("No Collision")
button.on_collision = on_collision
# button.on_NoCollision = on_NoCollision
while True:
time.sleep(1)
if __name__ == '__main__':
main()
If everything goes well, you will be able to see the following result
pi@raspberrypi:~/grove.py/grove $ python grove_collision_sensor.py 5
Collision
Collision
Collision
Collision
Collision
Collision
Collision
File "grove_collision_sensor.py", line 112, in <module>
main()
File "grove_collision_sensor.py", line 108, in main
time.sleep(1)
KeyboardInterrupt
You can quit this program by simply press ++ctrl+c++.
Play With Raspberry Pi (with GrovePi_Plus)
1.You should have got a raspberry pi and a grovepi or grovepi+.
2.You should have completed configuring the development enviroment, otherwise follow here.
3.Connection
  • Plug the sensor to grovepi socket D2 by using a grove cable.
4.Navigate to the demos' directory:
  • To see the code
nano grove_collision_sensor.py   # "Ctrl+x" to exit #
import time
import grovepi
# Connect the Grove Collision Sensor to digital port D2
# SIG,NC,VCC,GND
collision_sensor = 2
grovepi.pinMode(collision_sensor,"INPUT")
while True:
try:
print grovepi.digitalRead(collision_sensor)
time.sleep(.5)
except IOError:
print "Error"
5.Run the demo.
sudo python grove_collision_sensor.py
Schematic Online Viewer
