Grove - Differential Amplifier v1.2
This Grove is designed for precise differential-input amplification. Input the differential signals of your sensor to this module through the male pins, then your Arduino will get a precisely amplified output from the Grove interface. The gain scale factor is selectable. You can get a 35 times or 1085 times amplification via a switch on the board.
  • High amplifying precision
  • Selectable scale factor
  • Can be conveniently read by Arduino
More details about Grove modules please refer to [Grove System](https://wiki.seeedstudio.com/Grove_System/)
Applications
  • Data acquisition
  • Battery operated systems
  • Pressure and temperature bridge amplifiers
  • General purpose instrumentation
Specifications
ItemMinTypicalMaxUnit
Operating Voltage2.75.05.5VDC
Input Voltage0.1\\(Vcc-0.8)/GainmV
Output Voltage0\\Vcc-0.80mV
GainSelect 35/35//
Select 1085/1085/
Platforms Supported
ArduinoRaspberry Pi
caution
Usage
1. Sensor Choosing
The amplifier can turn signals in mA scale up to A scale. Before using it, make sure the output range of your sensor is in mA scale. For example, Weight Sensor is one of them.
2. Connector Reforming
To pair the weight sensor up with the male pins on the amplifier, female connectors need to be soldered on its wires.
3. Hardware Hookup
Connect the weight sensor to the amplifier as the picture depicts below.
4. Measurement
Copy and paste the demo code below to Arduino IDE and upload it.
Serial.begin(9600);
Serial.println("start");
int i;
int value;
float V,Vo;
float Sum=0;
for(i=0;i<10;i++)
value=analogRead(4);
V=value*5.00/1023;
Sum+=V;
delay(10);
Vo=Sum/10;
Serial.print("Output score:");
Serial.println(Vo);
You can view the amplified signals via serial monitor. For the value of the input signal, you need to use the multimeter to measure the voltage difference between VIN+ and VIN-.
Schematic Online Viewer
