Seeeduino Stalker v1.0
enter image description here
This is not the latest version of Seeeduino Stalker and has been discontinued. The latest version can be found here: Seeeduino Stalker v2.1 Look Arduino for comparison between v1.0, v2.0 and v2.1.
Link to product page for this device (follow this link to buy): Seeeduino Stalker Atmega 168P v1.0Model: ARD125B5P
Seeeduino Stalker is a feature rich Arduino compatible Wireless Sensor Network node. It's modular structure and onboard peripherals makes it convenient to log time stamp sensor data on a periodic basis. The Seeeduino Stalker is a good candidate for all your tracking, monitoring and control projects.
  • Arduino compatible, based on Seeeduino
  • Onboard microcontroller: ATmega168P or ATmega328P (both variants available for purchase)
  • Dual mode of operation: As a standalone Arduino or as a Shield stacked ontop of Arduino. (Pinheader locations are Arduino Duemilanove compatible)
  • Onboard Real Time Clock chip with CR2032 coin cell as backup power source
  • Serial interface with DTR for auto reset during programming when operating in standalone mode. (For programming, UartSBee must be bought separately)
  • microSD card socket
  • I2C Pin header (operation voltage is selectable: 5.0V or 3.3V)
  • User defined switch and LED
  • Bee series socket - 2*10 pin 2.0mm pitch (which will mate with - one at a time - any of the wireless modules: XBee , BluetoothBee , GPSBee or RFBee . Please note that UartSBee is incompatible with this socket - a separate serial interface connector (as mentioned above) is provided for UartSBee
Applications
  • Wireless Sensor Network (using XBee - bought seperately)
  • GPS Logging (using GPSBee - bought seperately)
  • Data Acquisition System capable of communicating with an App running on iPhone/Android Phone/Nokia Phone (using BluetoothBee - bought seperately)
  • RF Remote Control (using RFBee (title=undefined) - bought seperately)
  • As a simple standalone Arduino compatible physical computing platform (UartSBee must be bought seperately for programming)
Cautions
  • The product is provided as is. Please observe ESD precautions specially in dry (low humidity) weather.
  • Please disable bluetooth serial ports when using a Windows based development machine to prevent the Arduino IDE from freezing.
Block Diagram
Schematics
Schematics for Seeeduino Stalker v1.0 (PDF)
Specifications
Key Technical Specifications
Microprocessor:ATMega168P or ATmega328P
PCB size:6.8cm x 5.5cm x 0.16cm
Indicators:Reset, Power, LED on PB5 (Arduino Pin 13)
Power supply:5V or 7-12V
Power Connector:2 pin JST/ USB
I/O counts:20
ADC input:Dedicated 2 channel (10 bit resolution)
Connectivity:I2C, UART, SPI
RoHS:Yes
Electrical Characterstics
SpecificationsMinNormMaxUnits
Input voltage5912Volts (DC)
Global Current Consumption-3001000mA
3.3V I2C voltage3.23.33.5Volts (DC)
5.0V I2C voltage4.64.75Volts (DC)
UART Baud Rate(while programming)--115200bps
Usage
Application Notes
Connection Notes
  • Bee series socket - 2*10 pin 2.0mm pitch (which will mate with - one at a time - any of the wireless modules: XBee, BluetoothBee , GPSBeeor RFBee .) Communication with these modules are done through UART.
  • Serial interface – To save space and lower costs, USB<->Serial connectivity is not provided by default. You may use the FT232 based UartSBee (title=undefined) or other USB to serial adapter to do the programming or communicate with the PC.
  • User LED and Switch – An LED and a Switch have been provided onboard for use in your application as desired.
  • Master switch – Removes power from the Seeeduino Stalker board. RTC will remain working if a CR2032 battery has been installed.
  • Interrupt Jumper – Mount this jumper if you want to allow the module inserted in the Bee series socket to interrupt the microcontroller on any data reception event. This is useful in sensor network application to wake up the microcontroller from sleep mode.
  • I2C Interface: Onboard I2C level shifter IC provides voltage translation between 3.3V and 5V devices. This allows you to connect 5.0 Volt I2 ICs to you microcontroller when its operating on 3.3 Volts.
Datasheets of Components
  • ATmega168 - 8-bit AVR Microcontroller present onboard Seeeduino Stalker.
  • PCA9306 - Dual bidirectional I2C-bus and SMBus voltage-level translator.
  • DS1307 - I2C Real Time Clock chip.
  • LM1117 - Low Drop Out linear voltage regulator used in the power supply section.
Source Code Examples
Programming Seeeduino Stalker is made easy through the use of Arduino and its libraries. A few code snippets provided below will help you kickstart the coding for your project. A RAR archive containing all of the following sketches is available here.
Please note that all of the Demo sketches presented below make use of the FileLogger library. Please refer to this thread at the Arduino Forum and download the library from its project page at Google Code.
Also, a few Seeeduino Stalker users have shared some of the code developed by them in a thread at the Arduino Forum.
Demo 1 - SD card usage
Using a FileLogger library to store all the data from GPSBee on to the SD Card.
#include <SD.h>constint chipSelect =10;
String buffer ="";unsignedchar ptr;
File myFile;
byte val;voidsetup(){Serial.begin(19200);pinMode(chipSelect,OUTPUT);if(!SD.begin(chipSelect)){return;}
File myFile = SD.open("data.log",FILE_WRITE);
myFile.close();}voidloop(){if(Serial.available()>0){
val =Serial.read();
buffer = String(val);
myFile.print(buffer);
myFile.close();}}
Demo 2 – Logging timestamped sensor data
The onboard Real Time Clock module can be used for adding timestamp to the periodically read sensor data.
The Arduino sketch presented below illustrates how to take sensor readings from Analog Pin 0 and save it to SD Card along with timestamps.
#include "FileLogger.h"#include "DS1307.h"#include <WProgram.h>#include <Wire.h>#define Timing 0#define Accept 1#define Record 2
byte start[7]={'B','e','g','i','n',0x0D,0x0A};
byte buffer[20];int temp;
byte ASCII[10]={'0','1','2','3','4','5','6','7','8','9'};unsignedchar result;unsignedchar state;inttime=0;int oldtime=0;voidsetup(void){
result = FileLogger::append("data.log", start, 7);//Initial the SD Cardwhile(result) result = FileLogger::append("data.log", start, 7);
RTC.stop();
RTC.set(DS1307_MIN,30);//set the minutes
RTC.set(DS1307_HR,10);//set the hours
RTC.set(DS1307_DATE,22);//set the date
RTC.set(DS1307_MTH,12);//set the month
RTC.set(DS1307_YR,9);//set the year
RTC.start();}voidloop(void){switch(state){case Timing:time=RTC.get(DS1307_SEC,true);delay(200);if(time!=oldtime){
oldtime=time;
temp=RTC.get(DS1307_MTH,false);
buffer[0]=ASCII[(temp/10)];
buffer[1]=ASCII[(temp%10)];
buffer[2]='-';
temp=RTC.get(DS1307_DATE,false);
buffer[3]=ASCII[(temp/10)];
buffer[4]=ASCII[(temp%10)];
buffer[5]='-';
temp=RTC.get(DS1307_HR,false);
buffer[6]=ASCII[(temp/10)];
buffer[7]=ASCII[(temp%10)];
buffer[8]='-';
temp=RTC.get(DS1307_MIN,false);
buffer[9]=ASCII[(temp/10)];
buffer[10]=ASCII[(temp%10)];
buffer[11]='-';//temp=RTC.get(DS1307_SEC,false);
buffer[12]=ASCII[(time/10)];
buffer[13]=ASCII[(time%10)];
buffer[14]=':';
state=Accept;}break;case Accept:
temp=analogRead(0);
buffer[15]=ASCII[(temp/100)];
buffer[16]=ASCII[((temp%100)/10)];
buffer[17]=ASCII[(temp%10)];
buffer[18]=0x0D;
buffer[19]=0x0A;
state=Record;break;case Record:
result = FileLogger::append("data.log", buffer, 20);if(result==0){
state=Timing;}break;default:
state=Timing;break;}}
Demo 3 Operating the Seeeduino Stalker as a Shield
The Seeeduino Stalker can be mounted as a shield on another Arduino Duemilanove/UNO compatible board.
The following sketch illustrates how to receive data from the microcontroller below via I2C and save it onto the SD Card.
#include "FileLogger.h"#include <Wire.h>
byte start[7]={'B','e','g','i','n',0x0D,0x0A};unsignedchar buffer[10];unsignedchar result;unsignedchar state;voidsetup(){
result = FileLogger::append("data.log", start, 7);//Initial the SD Cardwhile(result) result = FileLogger::append("data.log", start, 7);Wire.begin(4);// join i2c bus with address #4Wire.onReceive(receiveEvent);// register event}voidloop(){}void receiveEvent(int howMany){unsignedchar i=0;while(Wire.available()>0){
buffer[i]=Wire.receive();// receive byte as a character
i++;}
result = FileLogger::append("data.log", buffer, i);while(result) result = FileLogger::append("data.log", start, 7);}
Support
If you have questions or other better design ideas, you can go to our forum or wish to discuss.
Revision History
RevisionDescriptionsRelease Date
Seeeduino Stalker v1.0Initial public releaseDec 23, 2009
Seeeduino Stalker v2.0New and improved version with more featuresDec 17, 2010
Bug Tracker
Bug Tracker is the place you can publish any bugs you think you might have found during use. Please write down what you have to say, your answers will help us improve our products.
Additional Ideas
The Additional Ideas is the place to write your project ideas about this product, or other usages you've found. Or you can write them on Projects page.
Stalker Eagle Design Files
How to buy
Seeeduino Stalker v1.0 is already out of stock (Product page here, instead please checkout Seeeduino Stalker v2.0: Wiki page | Product Page
See Also
Licensing
This documentation is licensed under the Creative Commons Attribution-ShareAlike License 3.0 Source code and libraries are licensed under GPL/LGPL, see source code files for details.
