Grove - Temperature Sensor V1.2
The Grove - Temperature Sensor uses a Thermistor to detect the ambient temperature. The resistance of a thermistor will increase when the ambient temperature decreases. It's this characteristic that we use to calculate the ambient temperature. The detectable range of this sensor is -40 - 125ºC, and the accuracy is ±1.5ºC
Note: This wiki works with Grove - Temperature sensor V1.1 as well, for V1.0 please refer to Grove - Temperature Sensor
SenseCAP S210x series industrial sensors provide an out-of-box experience for environmental sensing. Please refer to the S2101 Wireless Temperature and Humidity Sensor with higher performance and robustness for air quality monitoring. The series includes sensors for soil moisture, air temperature and humidity, light intensity, CO2, EC, and an 8-in-1 weather station. Try the latest SenseCAP S210x for your next successful industrial project.
SenseCAP Industrial Sensor
S2101 Air Temp & Humidity
Specifications
  • Voltage: 3.3 ~ 5V
  • Zero power resistance: 100 KΩ
  • Resistance Tolerance: ±1%
  • Operating temperature range: -40 ~ +125 ℃
  • Nominal B-Constant: 4250 ~ 4299K
Platforms Supported
ArduinoRaspberryArduPy
caution
Getting Started
After this section, you can make Grove - Temperature Sensor V1.1/1.2 run with only few steps.
note
If this is the first time you work with Arduino, we firmly recommend you to see Getting Started with Arduino before the start.
Play With Arduino
Hardware
  • Step 1. Prepare the below stuffs:
Seeeduino V4.2Base ShieldGrove - Temperature Sensor
Get One NowGet One NowGet One Now
  • Step 2. Connect Grove - Temperature Sensor to port A0 of Grove-Base Shield.
  • Step 3. Plug Grove - Base Shield into Seeeduino.
  • Step 4. Connect Seeeduino to PC via a USB cable.
note
If we don't have Grove Base Shield, We also can directly connect Grove_Ultrasonic_Ranger to Seeeduino as below.
SeeeduinoGrove - Temperature Sensor
5VRed
GNDBlack
Not ConenctedWhite
A0Yellow
Software
  • Step 1. Launch Arduino IDE and click File>New to open a new page. Copy the following code into the new page and upload. If you do not know how to upload the code, please check How to upload code.
// Demo code for Grove - Temperature Sensor V1.1/1.2
// Loovee @ 2015-8-26
#include <math.h>
const int B = 4275; // B value of the thermistor
const int R0 = 100000; // R0 = 100k
const int pinTempSensor = A0; // Grove - Temperature Sensor connect to A0
#if defined(ARDUINO_ARCH_AVR)
#define debug Serial
#elif defined(ARDUINO_ARCH_SAMD) || defined(ARDUINO_ARCH_SAM)
#define debug SerialUSB
#else
#endif
Serial.begin(9600);
int a = analogRead(pinTempSensor);
float R = 1023.0/a-1.0;
R = R0*R;
float temperature = 1.0/(log(R/R0)/B+1/298.15)-273.15; // convert to temperature via datasheet
Serial.print("temperature = ");
Serial.println(temperature);
delay(100);
Step 2. Open the Serial Monitor of Arduino IDE by click Tool-> Serial Monitor. Or tap the ++ctrl+shift+m++ key at the same time. if every thing goes well, you will get the temperature.
The result should be like:
Play With Raspberry Pi (With Grove Base Hat for Raspberry Pi)
Hardware
  • Step 1. Things used in this project:
Raspberry piGrove Base Hat for RasPiGrove - Temperature Sensor
Get ONE NowGet ONE NowGet ONE Now
  • Step 2. Plug the Grove Base Hat into Raspberry.
  • Step 3. Connect the temperature sensor to port A0 of the Base Hat.
  • Step 4. Connect the Raspberry Pi to PC through USB cable.
note
For step 3 you are able to connect the temperature sensor to any analog Port but make sure you change the command with the corresponding port number.
Software
caution
If you are using Raspberry Pi with Raspberrypi OS >= Bullseye, you have to use this command line only with Python3.
  • Step 1. Follow Setting Software to configure the development environment.
  • Step 2. Download the source file by cloning the grove.py library.
cd ~
  • Step 3. Excute below commands to run the code.
cd grove.py/grove
python3 grove_temperature_sensor.py 0
Following is the grove_temperature_sensor.py code.
import sys
import time
from grove.factory import Factory
def main():
from grove.helper import SlotHelper
sh = SlotHelper(SlotHelper.ADC)
pin = sh.argv2pin()
sensor = Factory.getTemper("NTC-ADC", pin)
print('Detecting temperature...')
while True:
print('{} Celsius'.format(sensor.temperature))
time.sleep(1)
if __name__ == '__main__':
main()
success
If everything goes well, you will be able to see the following result
pi@raspberrypi:~/grove.py/grove $ python3 grove_temperature_sensor.py 0
Hat Name = 'Grove Base Hat RPi'
24.7473402633 Celsius
24.7112751977 Celsius
File "grove_temperature_sensor.py", line 53, in <module>
main()
File "grove_temperature_sensor.py", line 49, in main
time.sleep(1)
KeyboardInterrupt
You can quit this program by simply press ++ctrl+c++.
note
You may have noticed that for the analog port, the silkscreen pin number is something like A1, A0, however in the command we use parameter 0 and 1, just the same as digital port. So please make sure you plug the module into the correct port, otherwise there may be pin conflicts.
Play With Raspberry Pi (with GrovePi_Plus)
Hardware
Raspberry piGrovePi_PlusGrove - Temperature Sensor
  • Step 2. Plug the GrovePi_Plus into Raspberry.
  • Step 3. Connect Grove - Temperature Sensor ranger to A0 port of GrovePi_Plus.
  • Step 4. Connect the Raspberry to PC via USB cable.
Software
In this wiki we use the path ~/GrovePi/ instead of /home/pi/Desktop/GrovePi, you need to make sure Step 2 and Step 3 use the same path.
We firmly suggest you to update the firmware, or for some sensors you may get errors. :::
caution
  • Step 3. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
  • Step 4. Excute below commands to use the Grove - Temperature Sensor to meansure the temperature.
cd ~/GrovePi/Software/Python
sudo python3 grove_temperature_sensor.py
Here is the grove_temperature_sensor.py code.
# NOTE:
# The sensor uses a thermistor to detect ambient temperature.
# The resistance of a thermistor will increase when the ambient temperature decreases.
# There are 3 revisions 1.0, 1.1 and 1.2, each using a different model thermistor.
# Each thermistor datasheet specifies a unique Nominal B-Constant which is used in the calculation forumla.
# The second argument in the grovepi.temp() method defines which board version you have connected.
# Defaults to '1.0'. eg.
# temp = grovepi.temp(sensor) # B value = 3975
# temp = grovepi.temp(sensor,'1.1') # B value = 4250
# temp = grovepi.temp(sensor,'1.2') # B value = 4250
import time
import grovepi
# Connect the Grove Temperature Sensor to analog port A0
# SIG,NC,VCC,GND
sensor = 0
while True:
try:
print("temp =", temp)
time.sleep(.5)
except KeyboardInterrupt:
break
except IOError:
print ("Error")
pi@raspberrypi:~/GrovePi/Software/Python $ sudo python3 grove_temperature_sensor.py
('temp =', 25.28652137917777)
('temp =', 25.368489566400115)
('temp =', 25.61468397498203)
('temp =', 27.43501590142614)
('temp =', 27.85285590636829)
('temp =', 27.18509952680688)
('temp =', 26.852756540240193)
Play With Wio Terminal (ArduPy)
Hardware
Wio TerminalGrove - Temperature Sensor
  • Step 2. Connect Grove - Temperature Sensor to A0 port of Wio Terminal.
  • Step 3. Connect the Wio Terminal to PC through USB Type-C cable.
Software
  • Step 1. Follow ArduPy Getting Started to configure the ArduPy development environment on Wio Terminal.
  • Step 2. Make sure that the ArduPy firmware is flashed into Wio Terminal. For more information, please follow here.
aip build
aip flash
  • Step 3. Copy the following code and save it as ArduPy-temp.py:
from machine import Pin, ADC
from machine import LCD
from machine import Sprite
import time, math
raw = ADC(Pin(13))
lcd = LCD()
spr = Sprite(lcd) # Create a buff
B = 4275 # B value of the thermistor
R0 = 100000 # R0 = 100k
def temp(reading):
R = 1023.0 / reading - 1.0
R = R0*R
temperature = 1.0/(math.log(R/R0)/B+1/298.15)-273.15 # Convert to temperature via datasheet
return temperature
def main():
spr.createSprite(320, 240)
while True:
spr.setTextSize(2)
spr.fillSprite(spr.color.BLACK)
spr.setTextColor(lcd.color.ORANGE)
spr.drawString("Temperature Reading", 45, 10)
spr.drawFastHLine(40, 35, 240, lcd.color.DARKGREY)
spr.setTextColor(lcd.color.WHITE)
spr.drawString("- ", 20, 50)
spr.drawFloat(temp(raw.read()), 3, 40,50)
spr.drawString("C", 120, 50)
spr.pushSprite(0,0)
time.sleep_ms(500)
print("Temperature: ", temp(raw.read()), "C")
if __name__ == "__main__":
main()
  • Step 4. Save the ArduPy-temp.py in a location that you know. Run the following command and replace <YourPythonFilePath> with your ArduPy-temp.py location.
aip shell -n -c "runfile <YourPythonFilePath>"
# Example:
# aip shell -n -c "runfile /Users/ansonhe/Desktop/ArduPy-temp.py"
  • Step 5. We will see the temperature value display on terminal as below, and displaying on the Wio Terminal LCD screen.
ansonhe@Ansons-Macbook-Pro ~:aip shell -n -c "runfile /Users/ansonhe/Desktop/ArduPy-temp.py"
Positional argument (/dev/cu.usbmodem141101) takes precedence over --open.
Connected to ardupy
Temperature: 28.08603 C
Temperature: 28.50415 C
Temperature: 28.16953 C
Temperature: 28.25308 C
Temperature: 28.33671 C
Reference
If you want to know how the algorithm of temperature coming, please refer to the below image:
Schematic Online Viewer
Projects
Temperature sensor Grove module:
