Energy Monitor Shield V0.9b
Energy Monitor Shield is an Arduino-compatible expansion card designed for building energy monitoring system with LCD screen and an interface for connecting the wireless transceiver nRF24L01 +.
Model: 830070001
  • Connect up to three sensors AC (30-100A).
  • Support for LCD Screen Nokia LCD5110
  • Turn off the LCD backlight with a jumper
  • Two buttons to control (operate one analog pin)
  • Interface to connect the transceiver to 2.4G nRF24L01 +
  • GROVE-compatible connector: I2C
  • Fully compatible with Ethernet Shield (Wiznet 5100 + SD)
Layout and schematics
  • The left side of EM Shield are three connectors for current sensors, right - connector for LCD-screen.
  • Jumper JP1 is used to enable / disable real-backlight LCD-screen.
  • In the upper right corner - I2C-connector.
  • On the right are two buttons (labeled S1 and S2).
  • In the center of the board (just to the right LCD-screen) - connector for nRF24L01 +.
Schematic of the device
Basic functionality
In the basic version (without using Ethernet Shield) may organize monitoring of energy consumption in three different circuits using current sensors. Information about the current level of consumption can be displayed on the LCD screen. Device Management can be organized using two buttons on the Shield. The obtained data can be transmitted by the transceiver nRF24L01 +.
Expansion Capabilities
Additionally EM Shield can connect any device using i2c Grove-compatible connector (sensors, displays, etc.). EM Shield was designed to be fully compatible with the Ethernet Shield (Wiznet 5100 + SD) - so you can use these two Shields together to create even more advanced device monitoring electricity (logging on SD-card and presenting data on a web page).
Interfaces
  • A0, A1, A2 - involved for connecting sensors AC
  • A4 (SDA), A5 (SCL) - displayed on the connector "I2C" (the other two pin connector - VCC and GND for sensor supply)
  • Interface for connecting RF-module nRF24L01+:
    • D11 - MOSI
      • D12 - MISO
    • D13 - SCK
      • D8 - RF_CE
      • D7 - RF_CSN
      • D2 - RF_IRQ
  • Interface for connecting LCD5110:
    • D11 - MOSI
    • D13 - SCK
      • D5 - LCD_D/C
      • D6 - LCD_RST
      • D3 - LCD_CS
  • A3 - Buttons
Libraries
Necessary libraries
To use Energy Monitor Shield requires the following libraries:
Requires the libraries that are used when working RF24 and LCD-display: SPI
Features using libraries
Library has used examples of them just to understand how they work.
Initialization RF-module as follows:
... //RF24 radio(CE,CSN); RF24 radio(7,8); ...
Initialize LCD-display is as follows:
... //LCD5110 myGLCD(DC,RST,CS); LCD5110 myGLCD(5,6,3); ...
Simple demonstration
#include <SPI.h>
#include <LCD5110_Graph_SPI.h>
#include "EmonLib.h"
#define WINDOW 15
#define DELTA 1500
EnergyMonitor emon1;
double sIrms;
float Pcur;
float Pmax;
float Pmin=100;
extern unsigned char SmallFont[];
unsigned long measureTime;
boolean flag=false;
double delta=0;
#define DELTAMEASURE 30000
void setup(void)
myGLCD.InitLCD(70);
myGLCD.setFont(SmallFont);
myGLCD.update();
emon1.current(0, 111.1); // Current: input pin, calibration.
double Irms[WINDOW];
// Calibrate (find offset)
double cIrms = 0;
flag = false;
while (!flag) {
myGLCD.print("calibrating", 0, 0);
myGLCD.update();
Irms[0] = emon1.calcIrms(1480); // the first value in the measurement obviously "crooked"
//Serial.println("calculate delta");
for (int i=0; i<WINDOW; i++) {
Irms[i] = emon1.calcIrms(1480);
cIrms = cIrms + Irms[i];
delay(100);
delta = cIrms/WINDOW;
flag = true;
//myGLCD.print(" ready", 0, 0);
//myGLCD.update();
void loop(void)
// write the current value
sIrms = emon1.calcIrms(1480) - delta; // Calculate Irms only
sIrms = abs(sIrms);
Pcur = sIrms*0.220;
// the received data is printed
char tbuf[6];
dtostrf(Pcur,5,5,tbuf);
myGLCD.print(tbuf, 0, 0);
dtostrf(analogRead(A3),4,0,tbuf);
myGLCD.print(tbuf, 30, 15);
myGLCD.update();
delay(250);
Simple demonstration with wireless technology
This example code is in the public domain.
#include <SPI.h>
#include <MySensor.h> // Include MySensors.org Library V1.5
#include "EmonLib.h" // Include Emon Library
#include <LCD5110_Graph_SPI.h> // Include NOKIA5110 Library
#define CHILD_ID_POWER 0
EnergyMonitor emon;
MyTransportNRF24 transport(7, 8); //for EMv1
MySensor gw(transport);
unsigned long lastSend;
unsigned long SEND_FREQUENCY = 20000; // Minimum time between send (in milliseconds). We don't wnat to spam the gateway.
float Irms;
float lastIrms = -99;
char tbuf[8];
char sbuf[12];
MyMessage IrmsMsg(CHILD_ID_POWER, V_KWH);
myGLCD.InitLCD();
myGLCD.update();
// The third argument enables repeater mode.
gw.begin(NULL, AUTO, true),
gw.sendSketchInfo("Energy Monitor v1", "1.0");
// emon.current(0, 111.1); // Current: input pin, calibration.
emon.current(0, 66.5);
// Register all sensors to gw (they will be created as child devices)
gw.present(CHILD_ID_POWER, S_POWER);
gw.process();
unsigned long now = millis();
double Irms = emon.calcIrms(1480); // Calculate Irms only
float realIrms = emon.Irms*220; //extract Real Power into variable
if (realIrms != lastIrms) {
gw.send(IrmsMsg.set(realIrms, 1)); //send to gateway
lastIrms=realIrms;
dtostrf(realIrms,5,2,tbuf);
sprintf(sbuf, " %s kWt", tbuf);
myGLCD.print(sbuf, 20, 0);
myGLCD.print("Powr:", 0, 0);
dtostrf(Irms,5,2,tbuf);
sprintf(sbuf, " %s Amp", tbuf);
myGLCD.print(sbuf, 20, 10);
myGLCD.print("Irms:", 0, 10);
myGLCD.update();
Serial.print("Power: ");
Serial.println(realIrms);
gw.sleep(SEND_FREQUENCY);
Version Tracker
Revision Description Release
1.0 Public version 01.04.2014
0.9b Public version (Not produced) 20.10.2013
0.9 Prototype 10.09.2013
Questions and Answers
How to buy
This product can be purchased:
Licensing
This documentation is licensed under the Creative Commons Attribution-ShareAlike License 3.0 Source code and libraries are
licensed under GPL/LGPL, see source code files for details.
