RGBW Stripe WireLess Shield V1.0
RGBW Stripe WireLess Shield has 4 PWM output to connect RGBW LED Strip. Anyone can handle a load of 1.5 A with a voltage of 5 to 24 V. Integrated control in 5 Arduino easily provide power from the input power supply. Self-renewing fuse protects LED Strip overcurrent. For remote control RGB tape used popular transceiver nRF24L01+. The most interesting is that the board has a memory, and you can now update the firmware of your Arduino through the air!
Feature
  • Built on Arduino-compatible architecture (DualOptiboot)
  • Compatibility with 12 - 24V RGB LED Strip
  • 4 PWM output (RGBW)
  • On board 64kb SPI flash / E2prom (for OTA firmware updates)
  • Built-in Auto LED RF activity (for nRF24L01 +)
  • Mini transceiver 2.4G nRF24L01 +
  • Self-renewing fuse
  • Built-in button
  • GROVE-compatible connector: I2C
Layout and schematics
Libraries
Necessary libraries
Demo code (example)
int L_RED = 6;
int L_GREEN = 9;
int L_BLUE = 3;
int L_WHITE = 5;
int brightness = 0;
int fadeAmount = 5;
pinMode(L_RED, OUTPUT);
pinMode(L_GREEN, OUTPUT);
pinMode(L_BLUE, OUTPUT);
pinMode(L_WHITE, OUTPUT);
// RED
analogWrite(L_RED, brightness);
brightness = brightness + fadeAmount;
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// GREEN
analogWrite(L_GREEN, brightness);
// BLUE
analogWrite(L_BLUE, brightness);
// WHITE
analogWrite(L_WHITE, brightness);
Version Tracker
Revision Description Release
1.0 rev 1 Public version 19.11.2015
