Watcher Function Module Development Guide
It's recommended that you firstly read the Watcher Software Framework to have an understanding about how the function module works.
In this documentation we're gonna show a step-by-step guide on how to develop a new function module. We're gonna take the UART Alarm module as an example.
1. Installation and first build
Please pass through the steps in Build the Watcher Development Environment if you've skipped it.
# you're in PROJ_ROOT_DIR/examples/factory_firmware/
cd main/task_flow_module
2. Choose a proper template
In the Watcher Software Framework we introduced the existing function module (short as FM in the following of the documentation) and what they're used for. When we're developing a new FM, we'd better start from a closest FM existing as a reference. In this tutorial we're going to develop an alarmer FM, so we choose one of the alarmer FMs, local alarmer is the simplest one, we'll take it.
cp tf_module_local_alarm.h tf_module_uart_alarm.h
cp tf_module_local_alarm.c tf_module_uart_alarm.c
It doesn't matter what name the files have, any .h and .c file will be scanned by the build system and taken into the compile code tree. But it's still recommended to have a meaningful file name.
3. Implement the registration
The TFE (task flow engine) provides an API function to register a new FM.
esp_err_t tf_module_register(const char *p_name,
const char *p_desc,
const char *p_version,
tf_module_mgmt_t *mgmt_handle);
The first three parameters are the name, the description and the version of your FM, they're used internally currently, e.g. matching FM from the registration table, log printing etc., but will be used in the future when the FMs are communicating with a local service.
// in tf_module_uart_alarm.h
#define TF_MODULE_UART_ALARM_NAME "uart alarm"
#define TF_MODULE_UART_ALARM_VERSION "1.0.0"
#define TF_MODULE_UART_ALARM_DESC "uart alarm function module"
// in tf_module_uart_alarm.c
esp_err_t tf_module_uart_alarm_register(void)
return tf_module_register(TF_MODULE_UART_ALARM_NAME,
TF_MODULE_UART_ALARM_DESC,
TF_MODULE_UART_ALARM_VERSION,
&__g_module_management);
The fourth parameter is a struct that contains necessary API functions to manage the life cycle of this FM.
// in tf_module.h
typedef struct tf_module_mgmt {
tf_module_t *(*tf_module_instance)(void);
void (*tf_module_destroy)(tf_module_t *p_module);
}tf_module_mgmt_t;
tf_module_instance is a function that will be called by the TFE when the engine is initializing all the FMs specified in a task flow, basically this means the engine has just received a task flow creation request and is starting the flow. tf_module_destroy is a function that will be called when the TFE is stopping the flow.
3.1 Instance
tf_module_t *tf_module_uart_alarm_instance(void)
tf_module_uart_alarm_t *p_module_ins = (tf_module_uart_alarm_t *) tf_malloc(sizeof(tf_module_uart_alarm_t));
if (p_module_ins == NULL)
return NULL;
p_module_ins->module_base.p_module = p_module_ins;
p_module_ins->module_base.ops = &__g_module_ops;
if (atomic_fetch_add(&g_ins_cnt, 1) == 0) {
// the 1st time instance, we should init the hardware
esp_err_t ret;
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
const int buffer_size = 2 * 1024;
ESP_GOTO_ON_ERROR(uart_param_config(UART_NUM_2, &uart_config), err, TAG, "uart_param_config failed");
ESP_GOTO_ON_ERROR(uart_set_pin(UART_NUM_2, GPIO_NUM_19, GPIO_NUM_20, -1, -1), err, TAG, "uart_set_pin failed");
ESP_GOTO_ON_ERROR(uart_driver_install(UART_NUM_2, buffer_size, buffer_size, 0, NULL, ESP_INTR_FLAG_SHARED), err, TAG, "uart_driver_install failed");
return &p_module_ins->module_base;
err:
free(p_module_ins);
return NULL;
The above is our implementation of the instance functions. It allocates memory for a struct tf_module_uart_alarm_t which we define for holding the parameters of this FM, like the members of a C++ class. In the struct tf_module_uart_alarm_t the 1st field is important - tf_module_t module_base, in the perspective of C++ programming, tf_module_t is the parent class for all the FMs. The instance function just give the TFE a pointer to a tf_module_t struct.
typedef struct {
tf_module_t module_base;
int input_evt_id; //this can also be the module instance id
int output_format; //default 0, see comment above
bool include_big_image; //default: false
bool include_small_image; //default: false
bool include_boxes; //default: false, coming soon
} tf_module_uart_alarm_t;
Two members of tf_module_t must be assigned.
p_module - a pointer that refers to the instance of the FM itself, this is used for the destroy function to get a handler of the instance and release the memory of it.
ops - a struct that contains API functions for operating the FM by the TFE, we will talk this later.
The rest of the instance function is to initialize the hardware and the stuff related to your logic of your FM.
One thing needs a mention is that, the FM may be instanced multiple times. You need to handle the re-enter of the instance function, and if your FM doesn't support multiple instances, you need to return a NULL pointer for the 2nd call of the instance function.
In this uart alarmer example, we will use reference counter to handle the re-enter logic.
esp_err_t ret;
3.2 Destroy
void tf_module_uart_alarm_destroy(tf_module_t *p_module_base)
if (p_module_base) {
if (atomic_fetch_sub(&g_ins_cnt, 1) <= 1) {
// this is the last destroy call, de-init the uart
uart_driver_delete(UART_NUM_2);
ESP_LOGI(TAG, "uart driver is deleted.");
if (p_module_base->p_module) {
free(p_module_base->p_module);
destroy is always simple 😂 We just need to free the memory, and de-init the hardware if necessary.
4. Implement the operations
The ops member of our parent class is defined as the following,
struct tf_module_ops
int (*start)(void *p_module);
int (*stop)(void *p_module);
int (*cfg)(void *p_module, cJSON *p_json);
int (*msgs_sub_set)(void *p_module, int evt_id);
int (*msgs_pub_set)(void *p_module, int output_index, int *p_evt_id, int num);
When the TFE initialize the FM, it will call these functions in the following order, cfg -> msgs_sub_set -> msgs_pub_set -> start -> stop.
cfg - take the paramers from the task flow json, use these parameters to configure your FM
msgs_sub_set - create the connection to the up-stream FM, by registering an event handler to the event id of the up-stream FM. The input parameter evt_id is prepared by the TFE by extracting from the task flow json. The 1st parameter p_module is the pointer to the FM instance itself.
msgs_pub_set - store the connections to the down-stream FMs, if this FM has no output, we can leave this function empty. The 1st parameter p_module is the pointer to the FM instance itself. The 2nd parameter output_index is the port number, e.g. this FM has 2 outputs, msgs_pub_set will be called twice, with output_index = 0 and 1 successively. The 3rd parameter p_evt_id is a pointer to an array which holds all the event ids of the down-stream FMs on this port, the size of the array is num which is the last parameter.
start and stop - are just their literal meanings. They all take in the p_module as parameter which is the pointer to the FM instance itself.
4.1 cfg
static int __cfg(void *p_module, cJSON *p_json)
tf_module_uart_alarm_t *p_module_ins = (tf_module_uart_alarm_t *)p_module;
cJSON *output_format = cJSON_GetObjectItem(p_json, "output_format");
if (output_format == NULL || !cJSON_IsNumber(output_format))
ESP_LOGE(TAG, "params output_format missing, default 0 (binary output)");
p_module_ins->output_format = 0;
} else {
ESP_LOGI(TAG, "params output_format=%d", output_format->valueint);
p_module_ins->output_format = output_format->valueint;
cJSON *include_big_image = cJSON_GetObjectItem(p_json, "include_big_image");
if (include_big_image == NULL || !cJSON_IsBool(include_big_image))
ESP_LOGE(TAG, "params include_big_image missing, default false");
p_module_ins->include_big_image = false;
} else {
ESP_LOGI(TAG, "params include_big_image=%s", cJSON_IsTrue(include_big_image)?"true":"false");
p_module_ins->include_big_image = cJSON_IsTrue(include_big_image);
cJSON *include_small_image = cJSON_GetObjectItem(p_json, "include_small_image");
if (include_small_image == NULL || !cJSON_IsBool(include_small_image))
ESP_LOGE(TAG, "params include_small_image missing, default false");
p_module_ins->include_small_image = false;
} else {
ESP_LOGI(TAG, "params include_small_image=%s", cJSON_IsTrue(include_small_image)?"true":"false");
p_module_ins->include_small_image = cJSON_IsTrue(include_small_image);
cJSON *include_boxes = cJSON_GetObjectItem(p_json, "include_boxes");
if (include_boxes == NULL || !cJSON_IsBool(include_boxes))
ESP_LOGE(TAG, "params include_boxes missing, default false");
p_module_ins->include_boxes = false;
} else {
ESP_LOGI(TAG, "params include_boxes=%s", cJSON_IsTrue(include_boxes)?"true":"false");
p_module_ins->include_boxes = cJSON_IsTrue(include_boxes);
return 0;
As you see, the cfg function is just extracting field values from the cJSON object which comes from the params field of the FM object of a task flow. e.g. The following is a simple task flow which includes the uart alarmer FM.
"tlid": 3,
"ctd": 3,
"tn": "Local Human Detection",
"type": 0,
"task_flow": [
"id": 1,
"type": "ai camera",
"index": 0,
"version": "1.0.0",
"params": {
"model_type": 1,
"modes": 0,
"model": {
"arguments": {
"iou": 45,
"conf": 50
"conditions": [
"class": "person",
"mode": 1,
"type": 2,
"num": 0
"conditions_combo": 0,
"silent_period": {
"silence_duration": 5
"output_type": 0,
"shutter": 0
"wires": [
[2]
"id": 2,
"type": "alarm trigger",
"index": 1,
"version": "1.0.0",
"params": {
"text": "human detected",
"audio": ""
"wires": [
[3]
"id": 3,
"type": "uart alarm",
"index": 2,
"version": "1.0.0",
"params": {
"output_format": 1,
"include_big_image": false,
"include_small_image": false
"wires": []
In the above task flow, the params for uart alarmer is
"output_format": 1,
We analyze the cJSON, extract values we need and store them into the module instance typically.
4.2 msgs_sub_set
static int __msgs_sub_set(void *p_module, int evt_id)
p_module_ins->input_evt_id = evt_id;
return tf_event_handler_register(evt_id, __event_handler, p_module_ins);
Mark down the event id of the up-stream FM for future use, and register an event handler for the event.
4.3 event handler
In the Watcher Software Framework we learned that the data flow is driven by an event loop. Basically a FM will receive data from its event handler, then it consumes the data, does calculations, gets some result. It needs to post the result into the event loop in the end - the target is the down-stream FMs who's interested in the data of this FM.
In this uart alarmer example, we consume data from an alarm trigger FM which has the output data type TF_DATA_TYPE_DUALIMAGE_WITH_INFERENCE_AUDIO_TEXT. Since the uart data preparation is simple, we do all the data generation in the event loop handler. This is not recommended though, if your data processing is time consuming or IO eager. In that case, you need to create a worker task (thread) to do the background processing.
We prepare a binary output buffer or a JSON string according to the input parameter output_format. Finally we write these data into the UART. Our FM has only one output which is the hardware, not another FM, in this reason our msgs_pub_set is dummy one. In the end, we need to release the data coming from the event loop, the reason will be explained in the next section.
4.4 msgs_pub_set
In this example the msgs_pub_set is dummy because our FM has no down-stream consumer. Let's take the ai camera FM as an example.
// in tf_module_ai_camera.c
static int __msgs_pub_set(void *p_module, int output_index, int *p_evt_id, int num)
tf_module_ai_camera_t *p_module_ins = (tf_module_ai_camera_t *)p_module;
__data_lock(p_module_ins);
if (output_index == 0 && num > 0)
p_module_ins->p_output_evt_id = (int *)tf_malloc(sizeof(int) * num);
if (p_module_ins->p_output_evt_id )
memcpy(p_module_ins->p_output_evt_id, p_evt_id, sizeof(int) * num);
p_module_ins->output_evt_num = num;
} else {
ESP_LOGE(TAG, "Failed to malloc p_output_evt_id");
p_module_ins->output_evt_num = 0;
else
ESP_LOGW(TAG, "Only support output port 0, ignore %d", output_index);
__data_unlock(p_module_ins);
return 0;
It's not complicated but just store the event ids into the FM instance's structure. This is where you need to add a member field into your FM's type struct, in this case tf_module_ai_camera_t.
When we gonna use these event ids? The moment that data is generated, and passes through the time gating. In the example of ai camera, the data originated from the SPI output of the Himax SoC which runs the local AI inference, and passes a few condition gate, if all the conditions are met, the data then reaches the time that needs to be posted into the event loop.
for (int i = 0; i < p_module_ins->output_evt_num; i++)
tf_data_image_copy(&p_module_ins->output_data.img_small, &info.img);
tf_data_inference_copy(&p_module_ins->output_data.inference, &info.inference);
ret = tf_event_post(p_module_ins->p_output_evt_id[i], &p_module_ins->output_data, sizeof(p_module_ins->output_data), pdMS_TO_TICKS(100));
if( ret != ESP_OK) {
ESP_LOGE(TAG, "Failed to post event %d", p_module_ins->p_output_evt_id[i]);
tf_data_free(&p_module_ins->output_data);
} else {
ESP_LOGI(TAG, "Output -> %d", p_module_ins->p_output_evt_id[i]);
We need to post to every subscriber of our output. As you can see, we make a copy of the data for every subscriber.
THE RULE OF MEMORY ALLOCATION AND RELEASE
- The data maker FM does the memory allocation for each subscriber
- The data consumer FM does the memory release after the data is used up.
4.5 start and stop
These are runtime controls for the FM, to support flow pause/resume in the future. Currently you can make the FM run after it's instanced, but we still suggest split logics into FM's life cycle management and FM's runtime control.
5. Test
Now we have our uart alarmer FM, before we pull a request, how could we test it locally.
We implement a console command to issue a task flow locally.
SenseCAP> help taskflow
taskflow [-iej] [-f <string>]
import taskflow by json string or SD file, eg:taskflow -i -f "test.json".
export taskflow to stdout or SD file, eg: taskflow -e -f "test.json"
-i, --import import taskflow
-e, --export export taskflow
-f, --file=<string> File path, import or export taskflow json string by SD, eg: test.json
-j, --json import taskflow json string by stdin
Please refer to Build the Watcher Development Environment - 5. Monitor the log output to get the console. Prepare a task flow with space and white characters removed, and issue the task flow with,
taskflow -i -j<enter>
Please input taskflow json:
#<paste your task flow json here, for an example>
{"tlid":3,"ctd":3,"tn":"Local Human Detection","type":0,"task_flow":[{"id":1,"type":"ai camera","index":0,"version":"1.0.0","params":{"model_type":1,"modes":0,"model":{"arguments":{"iou":45,"conf":50}},"conditions":[{"class":"person","mode":1,"type":2,"num":0}],"conditions_combo":0,"silent_period":{"silence_duration":5},"output_type":0,"shutter":0},"wires":[[2]]},{"id":2,"type":"alarm trigger","index":1,"version":"1.0.0","params":{"text":"human detected","audio":""},"wires":[[3]]},{"id":3,"type":"uart alarm","index":2,"version":"1.0.0","params":{"output_format":1},"wires":[]}]}
How to compose a task flow? In the Watcher Software Framework we introduced every FM and their parameters. Composing a task flow is pretty much drawing wires between FM blocks, like the Node-RED.
Before we have a GUI for composing the task flow, we can use the export command to collect examples. Just use the Mobile App to issue a flow with a local alarm function enabled (RGB light), when the flow is running, export the task flow with,
taskflow -e
This command will export the running task flow to the console. If the task flow is super long its output might be interrupted by other log, in this case we need a TF card. Format the TF card into FAT/exFAT file system, plug it into the Watcher. Now we can export the running task flow into the TF card,
taskflow -e -f tf1.json
# only support file name in the root dir
# please don't specify leading dir in the path, the command can't create dir
Now you have examples, modify one of the alarmer FM (generally it's the last FM), replace it with your uart alarmer FM, add a few parameters to the JSON object of your FM, use a JSON editor to remove the white space, and import it with the taskflow -i -j command above.
That's it, enjoy the exploration.
Appendix - More task flow examples
Here we provide a few more task flow examples that you can start with.
{"tlid":3,"ctd":3,"tn":"Local Human Detection","type":0,"task_flow":[{"id":1,"type":"ai camera","index":0,"version":"1.0.0","params":{"model_type":1,"modes":0,"model":{"arguments":{"iou":45,"conf":50}},"conditions":[{"class":"person","mode":1,"type":2,"num":0}],"conditions_combo":0,"silent_period":{"silence_duration":5},"output_type":0,"shutter":0},"wires":[[2]]},{"id":2,"type":"alarm trigger","index":1,"version":"1.0.0","params":{"text":"human detected","audio":""},"wires":[[3,4]]},{"id":3,"type":"local alarm","index":2,"version":"1.0.0","params":{"sound":1,"rgb":1,"img":0,"text":0,"duration":1},"wires":[]},{"id":4,"type":"sensecraft alarm","index":3,"version":"1.0.0","params":{"silence_duration":30},"wires":[]}]}
{"tlid":1,"ctd":1,"tn":"Local Gesture Detection","type":0,"task_flow":[{"id":1,"type":"ai camera","index":0,"version":"1.0.0","params":{"model_type":3,"modes":0,"model":{"arguments":{"iou":45,"conf":65}},"conditions":[{"class":"paper","mode":1,"type":2,"num":0}],"conditions_combo":0,"silent_period":{"silence_duration":5},"output_type":0,"shutter":0},"wires":[[2]]},{"id":2,"type":"alarm trigger","index":1,"version":"1.0.0","params":{"text":"scissors detected","audio":""},"wires":[[3,4]]},{"id":3,"type":"local alarm","index":2,"version":"1.0.0","params":{"sound":1,"rgb":1,"img":0,"text":0,"duration":1},"wires":[]},{"id":4,"type":"sensecraft alarm","index":3,"version":"1.0.0","params":{"silence_duration":30},"wires":[]}]}
{"tlid":1719396404172,"ctd":1719396419707,"tn":"Man with glasses spotted, notify immediately","task_flow":[{"id":753589649,"type":"ai camera","type_id":0,"index":0,"vision":"0.0.1","params":{"model_type":0,"model":{"model_id":"60086","version":"1.0.0","arguments":{"size":1644.08,"url":"https://sensecraft-statics.oss-accelerate.aliyuncs.com/refer/model/1705306215159_jVQf4u_swift_yolo_nano_person_192_int8_vela(2).tflite","icon":"https://sensecraft-statics.oss-accelerate.aliyuncs.com/refer/pic/1705306138275_iykYXV_detection_person.png","task":"detect","createdAt":1705306231,"updatedAt":null},"model_name":"Person Detection--Swift YOLO","model_format":"tfLite","ai_framework":"6","author":"SenseCraft AI","description":"The model is a Swift-YOLO model trained on the person detection dataset. It can detect human body existence.","task":1,"algorithm":"Object Dectect(TensorRT,SMALL,COCO)","classes":["person"]},"modes":0,"conditions":[{"class":"person","mode":1,"type":2,"num":0}],"conditions_combo":0,"silent_period":{"time_period":{"repeat":[1,1,1,1,1,1,1],"time_start":"00:00:00","time_end":"23:59:59"},"silence_duration":60},"output_type":1,"shutter":0},"wires":[[193818631]]},{"id":193818631,"type":"image analyzer","type_id":3,"index":1,"version":"0.0.1","params":{"url":"","header":"","body":{"prompt":"Is there a man with glasses?","type":1,"audio_txt":"Man with glasses"}},"wires":[[420037647,452707375]]},{"id":452707375,"type_id":99,"type":"sensecraft alarm","index":2,"version":"0.0.1","params":{"silence_duration":10,"text":"Man with glasses"},"wires":[]},{"id":420037647,"type_id":5,"type":"local alarm","index":3,"version":"0.0.1","params":{"sound":1,"rgb":1,"img":1,"text":1,"duration":10},"wires":[]}],"type":0}
